Results 1 to 6 of 6
Thread: 2005 New Beetle 1.8 turbo conv air bag light on
    Jan 2020
    can the airbag control module be reset from code" 00003 /014 defective" VCDS release 19.6.2
    Thursday,09,January,2020,15:46:16:05114
    VIN: 3VWCD31Y55M350443   License Plate:
    Chassis Type: 1Y (1Y - VW New Beetle Cab (2003 > 2010))
    VIN: 3VWCD31Y55M350443   Mileage: 118890km-73874miles
    Address 01: Engine        Labels: 06A-906-032-BKF.lbl
       Part No: 06A 906 032 QT
       Component: 1.8l 5VT NB MT      6477
       Coding: 00001
       Shop #: WSC 13813
       VCID: 0059872DB3123CA7C97-513C
       3VWCD31Y55M350443     VWZ5Z0D9188110
    Readiness: 0100 1100
       Part No: 1C0 907 379 M
       Coding: 0019970
       Shop #: WSC 00066 000 00000
       VCID: 34311BFDB22A50071DF-5160
       Part No: 6Q0 909 605 AF
       Component: 01 AIRBAG VW71      0609
       Coding: 0012337
       VCID: 7BA3F0C1DFF45F7F9C5-5160
       Subsystem 1 - Part No: 1C0 959 339 B
       Component: BF-Gewichtsens. 006 0006
    00003 - Control Module
                014 - Defective
    Address 17: Instruments        Labels: 1C0-920-x4x.lbl
       Part No: 1C0 920 951 F
       Component: KOMBI+WEGFAHRS. M73 V02
       Coding: 11232
       VCID: 2411EBBD07CAC0878DF-4B1E
       Part No: 6N0 909 901
       Component: Gateway K<->CAN    V022
       Coding: 00006
       Shop #: WSC 00066
       VCID: 70B9D7ED83B22C27397-4B00
    Address 26: Auto Roof        Labels: 1Y0-959-255-HYD.lbl
       Part No: 1Y0 959 255 C
       Component:  VSG  NBC       ¤
       VCID: 40D9472DF692FCA7897-513C
                014 - Defective
       Part No: 1C0 959 799 G
       Component: 6J Komfortgerát HLO 0004
       Coding: 00256
       Shop #: WSC 00066
       VCID: 3B2330C19A749F7FDC5-4B00
       Subsystem 1 - Part No: 1Y1959801C
       Component: 6J Tőrsteuer.FS KLO 0005
       Subsystem 2 - Part No: 1Y1959802D
       Component: 6J Tőrsteuer.BF KLO 0005
       Subsystem 3 - Part No: 1Y0959811
       Component: Tőrsteuer.HL KLO 0005
       Subsystem 4 - Part No: 1Y0959812
       Component: Tőrsteuer.HR KLO 0005
    01358 - Internal Central Locking Switch; Driver Side (E150)
    End----------(Elapsed Time: 04:03, VBatt start/end: 12.1V/12.1V)-----------
    In this airbag module, I don't think so.
    Jan 2020
    Thank You. if i get a used one can VCDS make it useable on this car?
    You would need the exact, correct airbag module for this car. The main part number alone, "6Q0 909 605 AF" is not sufficient to spec a module for these cars. You need index or color code 001, so the full spec would be, "6Q0 909 605 AF /001".
    Trouble is most everyone who sells used parts is unaware of this.
    If you get the correct part for the car, it should be plug & play (aside from possibly clearing fault codes). If you get the wrong index, there's nothing VCDS can do for you.
    Jan 2020
    Thank You
    the old one is in my lap. the part # is 6Q0 909 605AF The index is" H/S Index : 06 09" other numbers # AE4,220 4381-21,*0037FS1B*,37040101
    do you know if i can get one to use for this car with these numbers?
    Walt
  6. #6
    Jan 2020
    the index should have been HW/SW sorry
