Results 1 to 3 of 3
Thread: 2014 Audi Q7 Adaptive Cruise Control
    Nov 2019
    Hi. This is my first post. I am a Master Auto Technician with 30 years experience, I'm good at diagnostics but I am new to the VCDS. This is my personal vehicle, the cruise has not worked since we purchased it. It says "ACC not available" when attempting to use the cruise. It has code 01044 Module incorrectly coded that can't be cleared. I can communicate with the module. Ive checked fuses, wiring, etc. It seems to check out OK. I don't know if the module may have been replaced from a salvage yard or something-it looks good.
    I guess my question is, how do I know if the module has the correct coding? I don't where to get this information. I have tried some various coding from other Autoscans from similar vehicles but it doesn't seem to help. Any help would be greatly appreciated. Thanks.
    Thursday,09,January,2020,19:35:08:34269
    VIN: WA1DGAFE2DD006297   License Plate:
    Chassis Type: FE-AU56 (4F0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 36 3C 42 46 47 4C 4F
              52 55 56 5F 62 69 6C 6D 6F 72
    VIN: WA1DGAFE2DD006297   Mileage: 198840km-123553miles
    Address 01: Engine (CTW)       Labels:. 06E-907-551-CAJ.clb
       Part No SW: 4L0 910 551 Q    HW: 4L0 907 551 A
       Component: 3.0l V6 TFSI        0020
       Revision: --H08---    Serial number:
       Coding: 0121000A290F0228
       Shop #: WSC 31414 790 00001
       VCID: 36203B7641C2A0FF4D-8062
    Readiness: 1110 1101
       Part No SW: 0C8 927 750 Q    HW: 0C8 927 750 Q
       Component: AL1000 AISIN  001 2090
       Coding: 001378
       Shop #: WSC 41070 002 1048576
       ROD: EV_TCMAL991031_002.rod
       VCID: 3A382F46BDDA449FA9-806E
       Revision: 00H02001
       Coding: 0623697
       VCID: 3424017E57BEB2EF73-8060
       Part No SW: 4F0 910 852 B    HW: 4F0 905 852 H
       Component: FBSAUDIC6 ELV   H08 0200
       Revision: 00H08000    Serial number: 10603702024205
       Coding: 0000135
       VCID: 2502EC3AEC64DB67F4-8070
       Component: FBSAUDIC6 EZS   H04 0020
       Subsystem 3 - Part No: 4F0 910 220 G
       Component: FBSAUDIC6 IDG   H01 0053
    00190 - Driver's Door Handle Touch Sensor (G415)
                007 - Short to Ground
                        Fault Status: 01100111
                        Reset counter: 92
                        Mileage: 198845 km
                        Date: 2020.01.09
                        Time: 19:31:05
    00191 - Passenger's Door Handle Touch Sensor (G416)
                        Reset counter: 92
                        Mileage: 198845 km
                        Date: 2020.01.09
                        Time: 19:31:05
                        Reset counter: 92
                        Mileage: 198845 km
                        Date: 2020.01.09
                        Time: 19:31:05
       Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AJ
       Revision: 00---026    Serial number: 00000030257538
       Coding: 000CC026
       VCID: 2502EC3A2C64DB67F4-8070
       Subsystem 1 - Part No SW: 8K0 959 772 F    HW: 8K0 959 772
       Component: SLR-B8  H06 0007
       Serial number:           0037242536
       Coding: 070000
       Part No SW: 4F0 910 279 AG    HW: 4F0 907 279 C
       Component: ILM Fahrer      H31 0400
       Coding: 0133123
       VCID: 6E90D3167912D83F45-803A
       Component: Wischer AU716   H18 0110
       Coding: 00064792
       Shop #: WSC 31414
       Coding: 00150059
       Shop #: WSC 31414
    Address 10: Park/Steer Assist (J446)       Labels:| 4L0-919-475-7X2.clb
       Part No SW: 4L0 919 475 A    HW: 4H0 919 475 C
       Component: PARKHILFE 8K  H07 0011
       Revision: 11001001    Serial number: 55901225500404
       Coding: 28011F
       ASAM Dataset: EV_EPHVA18AU7160000 001001
       ROD: EV_EPHVA18AU7160000.rod
       VCID: 3424017E9FBEB2EF73-8060
    Address 13: Auto Dist. Reg        Labels: None
       Part No SW: 4L0 910 561 A    HW: 4L0 907 561
       Component: ABSTANDSREGELUNGH07 0160
       Coding: 0011118
       Shop #: WSC 31414 551 00000
       VCID: 271EE6329668C977C6-8072
                        Reset counter: 92
                        Mileage: 198845 km
                        Date: 2020.01.09
                        Time: 19:08:20
                        Temperature: 17.0°C
                        Voltage: 11.26 V
                        Bin. Bits:    01000
                        Hex Value: 0x0411
                        Hex Value: 0x0006
                        Speed: -3.6 km/h
                        Lateral Accel.: 0.00 m/s^2
       Component: 73 AIRBAG AUDI8RH43 0230
       Revision: 07H43000    Serial number: 0038QD0A7V2E
       Coding: 0014131
       VCID: 2B161A028A80ED1722-807E
       Subsystem 1 - Part No: 4L0 959 339 C
       Component: BF-Gewichtsens. H05 0040
       Subsystem 2 - Serial number: 6332QSME042246700
       Subsystem 3 - Serial number: 6342QSME1D231478F
       Subsystem 4 - Serial number: 6352QSME09233B7AM
       Subsystem 5 - Serial number: 6362QSME0422214A3
       Subsystem 6 - Serial number: 63734SME1922056E/
       Subsystem 7 - Serial number: 63834SME18222E5A3
       Part No SW: 4F0 910 549 B    HW: 4F0 953 549 F
       Component: J0527               0830
       Revision: 00H08000    Serial number: 90026122530230
       Coding: 0012252
       VCID: 281CE50E9B76C60FCF-807C
       Component: E0221           H03 0040
       Part No SW: 4L0 920 985 F    HW: 4L0 920 985 F
       Component: KOMBIINSTR.   H35 0316
       Revision: 00000000    Serial number: NG021AJ9D
       Coding: 8BD663040D00CF05020205
       VCID: 373E367286C859F756-8062
       Part No SW: 4F0 907 468 S    HW: 4F0 907 468 G
       Component: GW-BEM 5CAN-M H06 0058
       Revision: MB700037    Serial number: 3700M12908009B
       Coding: 00C303
       VCID: 3FCE5E52AEF861B79E-806A
       Component: J367-BDM  H07 0125
       Serial number: 00000000002790261837
       Part No SW: 4L0 910 158     HW: 4L0 919 158 AB
       Revision: 00---010    Serial number: 00000000347273
       Coding: 0000006
       VCID: 689CA50E5BF6060F0F-803C
       Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
       Component: MEM-FS        H08 0064
       Revision: AA000000    Serial number: 00000038725575
       Coding: 00581B00000011110000
       VCID: 322807666DAABCDF61-8066
       Component: J0769_SWA_MasterH02 0050
       Revision: 00H02000    Serial number: 6PZ 009 014-10
       VCID: 2E101316B992983F05-807A
       Component: J0770_SWA_Slave_H02 0050
       Subsystem 3 - Serial number: 5F03.09.1200H02000AMS14953˙
       Subsystem 4 - Serial number: S14953˙
       Component: TSG FA        H12 0362
       Revision:             Serial number: 0000038986968
       Coding: 011F57205E40440004
       VCID: 48DC458EFB36260F2F-801C
       Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
       Component: Komfortgeraet   H12 0130
       Revision: 0130 ---    Serial number: 01843873860000
       Coding: 3569949
       VCID: 383C354E4BD6568F5F-806C
       Part No SW: 4L0 035 223 J    HW: 4L0 035 223 G
       Component: BOSE G3 Q7    H04 0160
       Revision: CH004000    Serial number: 00000000003919
       Coding: 030000
       VCID: 291AE00A407CFF07D0-807C
       Part No SW: 4F0 910 274 B    HW: 4F0 907 274
       Component: J793  RKA+      H04 0110
       Revision: 00000519    Serial number: 00005190055422
       Coding: 0693965
       VCID: 2306F222E25025579A-8076
       Component: ILM Beifahrer   H16 0100
       Revision:             Serial number: 00000000117791
       Coding: 0012001
       VCID: 5EF083D689B248BFF5-800A
       Component: TSG BF        H12 0362
       Revision:             Serial number: 0000040838810
       VCID: 47DE46B2F628297726-8012
                        Reset counter: 92
                        Mileage: 198845 km
                        Date: 2020.01.09
                        Time: 19:08:20
       Part No SW: 4L0 910 357 B    HW: 4L0 907 357 B
       Component: AFS 1           H01 0010
       Coding: 0000031
       Component: AFS-Modul links H07 0004
       Component: AFS-Modul rechtsH07 0004
       Part No SW: 4G0 035 082 E    HW: 4G0 035 082
       Component: Radio U SIRIU H60 0121
       Revision: AB001007    Serial number: 156IB0C7639578
       Coding: 020007010000000000
       VCID: 2208F7263D4A2C5F91-8076
       Part No SW: 4L2 035 746 C    HW: 4L2 035 746 A
       Component: H-BNT-NA      H43 0624
       Revision: --------    Serial number: 224I+0C7506747
       Coding: 180200060004E9EF710003456F632003140000000100000000
       VCID: 2E1013167992983F05-807A
       Subsystem 1 - Part No: 8R0 060 884 AM
       Component: NAR 2012  0605
       Component: DU7 High  H41 0104
       Serial number: A130IT0C2544418
       Subsystem 3 - Part No SW: 4L0 919 614 C    HW: 4L0 919 614 C
       Component: E0380 Bedient  H01 0060
       Serial number: 00000002035518
       Subsystem 4 - Part No: 8R0 060 961 D
       Component: CD-Database  4353
       Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
       Component: TSG HL        H11 0362
       Revision:             Serial number: 0000039978034
       Coding: 010E57204040230004
       VCID: 46C04BB6F122307FDD-8012
    Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
       Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
       Component: Anhaenger     H12 0100
       Revision: 2A001001    Serial number: 00000375154707
       Coding: 0200000000000000
       VCID: 312A086A68AC87C718-8064
       Part No SW: 4L0 907 428     HW: 7P6 907 441 D
       Component: TopView       H05 0293
       Revision: 11001001    Serial number: 82330JF0057351
       Coding: 020C010001000100000102000000
       ASAM Dataset: EV_CamSysteCorneViewAUDI 004005
       ROD: EV_CamSysteCorneViewAUDI.rod
       VCID: 6E90D316B112D83F45-803A
       Part No SW: 4L0 910 945     HW: 4L0 827 851 E
       Component: ValeoHeckdeckel H57 0500
       Revision: --H57001    Serial number: E5030000B
       Shop #: WSC 98765 666 38354
       VCID: 6C94D91E4F0E2A2F6B-8038
       Subsystem 2 - Serial number: ($ó
       Subsystem 3 - Serial number: RD22.09.12--H57001002K0066˙
       Subsystem 4 - Serial number: 2K0066˙
       Component: ILM HINTEN 2    H08 0080
       Revision: AAH08080    Serial number: 129298153-----
       Coding: 0003595
       VCID: 2600EB369162D07FFD-8072
       Component: J_245_EE16_SKB10H12 0220
       Component: J_394_EE16_SKB10H12 0220
       Component: J_392_EE16_SKB10H12 0220
       Component: TSG HR        H11 0362
       Revision:             Serial number: 0000039977865
    End----------(Elapsed Time: 02:17, VBatt start/end: 12.4V/12.4V)-----------
    Unfortunately, I'm not finding any coding info for that module either.
    Looks like we have another thread. Closing this one.
    Carry on here:
    https://forums.ross-tech.com/showthread.php?21450
