Results 1 to 6 of 6
Thread: Caddy rear light facelift
    Mar 2015
    Hi I replaced the rear lights on my
    2017 Vw caddy with the facelift ones
    I swapped a few wires on the multi plug
    And got them functioning ok
    Problem is I have a bulb failure light on dash as new lamps only have
    One reverse light and the old ones have two can any one help code this out also there is a section at the bottom of the lamp thatís
    Not illuminated was wondering if this can be coded on
    Thanks in advance
    I have the new VCDS hex lead
    Please post an Auto-Scan for context.
    Mar 2015
    Friday,10,January,2020,12:24:40:52587
    VIN: WV1ZZZ2KZFX145997   License Plate: N25 SJH
    Mileage: 54680km-33976mi   Repair Order:
    Chassis Type: 2K-VN35 (7N0)
    Scan: 01 03 09 0F 15 16 17 19 25 37 42 44 46 52 56
    VIN: WV1ZZZ2KZFX145997   Mileage: 54680km-33976miles
    0F-Digital Radio -- Status: Cannot be reached 1100
    37-Navigation -- Status: Not registered 0001
    Address 01: Engine (J623-CAYD)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 TF    HW: 03L 907 425 C
       Component: R4 1.6l TDI   H43 9978
       Revision: --H43---    Serial number: 00000000000000
       Coding: 00114010032500080000
       Shop #: WSC 35110 790 50316
       ASAM Dataset: EV_ECM16TDI02103L906023TF 003002
       ROD: EV_ECM16TDI02103L997557M.rod
       VCID: 7DA6021F2D7DB85FA21-8028
       Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
       Component: ESP MK60EC1   H46 0166
       Revision: 00H46001
       Coding: 433C400D092603FFC21402ED9020C081A0000020
       Shop #: WSC 35110 377 08192
       VCID: 045077FB4E17C997EDF-8050
       Part No SW: 5K0 937 085 AA    HW: 5K0 937 085 AA
       Component: BCM PQ35 B+   122 0174
       Revision: BB122001
       Coding: 071A583A8833186A08C800829000006403017288524F0120648000000040
       VCID: 72BC212364A3F727CF3-8026
       Subsystem 1 - Part No: 1T2 955 119 A  Labels: 1KX-955-119.CLB
       Component: Wischer 16041  27  0512
       Coding: 009795
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 76
                        Mileage: 54673 km
                        Date: 2020.01.09
                        Time: 17:46:51
                            Term 15 On
                        Voltage: 13.90 V
    Address 0F: Digital Radio
       Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
       Component: VW10Airbag02Q H07 0013
       Revision: --------    Serial number: 003HL00WU27Q
       Coding: 000000000000000000000000000000003251
       VCID: 3536DA3F55CDA01F2A1-8060
       Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
       Revision: --X01---    Serial number: 20180415300805
       Coding: 1892160000
       Shop #: WSC 00078 790 12345
       ASAM Dataset: EV_SMLSNGVOLWS A01004
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 025C71E35483C7A7DF3-8056
       Serial number: 10000000000000076833
       Coding: E30000
    0516 - Databus
                        Reset counter: 75
                        Mileage: 54666 km
                        Date: 2020.01.09
                        Time: 17:08:15
       Part No SW: 2K0 920 966 C    HW: 2K0 920 966 C
       Component: KOMBI         H03 0905
       Coding: 180800
       VCID: 3038EB2BAAAF8537797-8064
       Part No SW: 7N0 907 530 AP    HW: 7N0 907 530 AK
       Component: J533  Gateway H57 1653
       Revision:   H57       Serial number: 300415F1000013
       Coding: 357401
       VCID: 7EA4051320FBA347BBB-802A
    02649 - Digital Radio Tuner
                        Reset counter: 75
                        Mileage: 54666 km
                        Date: 2020.01.09
                        Time: 17:07:38
                        Fault Frequency: 33
                        Mileage: 54666 km
                        Date: 2020.01.09
                        Time: 17:07:34
       Component: IMMO          H03 0905
       VCID: 6A8C39434CF33FE7773-803E
       Part No SW: 5P0 035 191 D    HW: 5P0 035 191 D
       Component: RNS315        H05 0010
       Serial number: SEZAZ2K9112252
       Coding: 040002000200000000000000
       Shop #: WSC 12345 123 12345
       ASAM Dataset: EV_RNS315SeatEUV1UDS A01005
       ROD: EV_RNS315SeatEUV1UDS.rod
       VCID: 2C00FF5B8687E1D745F-8078
       Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
       Component: Tuer-SG         009 2110
       Coding: 0000560
       VCID: 48C8A3CB3EBF2DF7417-801C
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 140    3501
       Revision: 00H22000
       VCID: 392ED60F7555447FCE9-806C
       Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
       Coding: 0000560
       VCID: 47CAA0F733A1228F48D-8012
    End----(Elapsed Time: 00:45, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
    So the bad news is that's a PQ35 BCM, which means Byte 18 is the likely the secret.
    The good news is that your Byte 18 is not 00, but an actual value, 0x72..
    Beyond that, hopefully someone with more familiarity than I have with these lighting setups will chime in here.
    Nov 2016
    Need VCP to edit the eeprom, not a vcds job. I wouldn’t entertain changing byte 18 manually as this can have adverse repercussions
  6. #6
    Mar 2015
    Hi I have access to odis if so you think that would do the trick
    Thanks
    H
