Results 1 to 7 of 7
Thread: Retrofit LED DRL and possibly AFS to 2012 VW CC that already has Xenon headlights
    Mar 2015
    N Ireland
    Question Retrofit LED DRL and possibly AFS to 2012 VW CC that already has Xenon headlights
    Hi folks,
    Happy New Year to you all!!
    Ok, so my drivers side headlight got damaged recently rather than replace the damaged headlight with a new unit (and potentially have a visible difference with the other headlight), I'm wondering if it's relatively easy to upgrade the headlights? Hoping it's plug'n'play with only coding changes required but thought I'd ask you guys for your thoughts.
    The car currently has Xenons, so it's really an upgrade to the Daylight Running Lights from Halogen to LED I'd like to attempt. Do I need a controller for the LED DRL? Are there any wiring modifications to the loom required?
    When I started looking, I also thought that it might be a good addition to also install the adaptive cornering units? Is there anything extra I might require for this?
    See below a scan I had handy...nothing has changed on the car since this was done. I hope I've included enough info to get hopefully a positive answer!
    Cheers,
    Colly
    Wednesday,24,May,2017,15:58:03:25238
    VCDS Version: 17.1.3.0 (x64)
    VIN: WVWZZZ3CZCE******   License Plate:
    Chassis Type: 3C (7N0)
    Scan: 01 03 08 09 10 14 15 16 17 19 20 25 2E 37 42 44 46 4C 4F 52
              53 55 56 61 62 69 72
    VIN: WVWZZZ3CZCE******   Mileage: 97510km-60589miles
    Address 01: Engine (J623-CFFB)       Labels: 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 PR    HW: 03L 907 309 AE
       Component: R4 2,0L EDC   H25 2480
       Revision: 41H25---    Serial number: 00000000000000
       Coding: 00190032042501080000
       Shop #: WSC 00015 115 00000
       ASAM Dataset: EV_ECM20TDI01103L906018PR 003003
       ROD: EV_ECM20TDI01103L906018PR.rod
       VCID: 09121E9CA85BD409BE-805C
       Part No SW: 3AA 614 109 AG    HW: 3AA 614 109 AG
       Component: J104   C2 450M VDE9 0023
       Revision: --H07---    Serial number: 00000005309333
       Coding: 0004016
       Shop #: WSC 05311 000 00000
       VCID: 72E059706DCDB7D1EF-8026
       Part No SW: 3AA 907 044 F    HW: 3AA 907 044 F
       Component: Climatronic   H03 0101
       Revision: 00001K01
       Coding: 0010004809
       VCID: 336E9C749A57FED924-8066
    Address 09: Cent. Elect. (J519)       Labels: 3AA-937-087.clb
       Part No SW: 3AA 937 087 J    HW: 3AA 937 087 J
       Component: BCM PQ47 H++  421 0465
       Revision: BD421001
       Coding: 000800000000000000880088940029642355008860220720E484C72000C1
       Shop #: WSC 05311 000 08193
       VCID: 4182C6BCD8EB5C49A6-8014
       Subsystem 1 - Part No SW: 3C8 955 119 G    HW: 3C8 955 119 G  Labels: 1KX-955-119.CLB
       Component: WWS464 141211  010 0604
       Serial number: 141211
       Coding: 00B795
       Component: RLHS  037 0059
       Serial number: S4Y16M04D05H08M27S09
       Coding: 028877
    Address 10: Park/Steer Assist (J791)       Labels: 3AA-919-475.clb
       Part No SW: 3AA 919 475 H    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0026
       Revision: --------    Serial number: 56261202002795
       Coding: 159207
       Shop #: WSC 00905 210 105356
       ASAM Dataset: EV_EPHVA2C000000000 002009
       ROD: EV_EPHVA2C000000000_VW41.rod
       VCID: 4084C3B8DBE15541A9-8014
    Address 14: Susp. Elect. (J250)       Labels: 3C0-907-376.clb
       Part No SW: 3C0 907 376 A    HW: 3C0 907 376
       Component: DAEMPFUNGS-SG H07 0071
       Revision: 00000000    Serial number: 27011203520001
       Coding: 010180
       Shop #: WSC 05314 000 00000
       VCID: 27567824568F827988-8072
       Part No SW: 5N0 959 655 AA    HW: 5N0 959 655 AA
       Component: J234__703 VW10 HI   2118
       Revision: 24017000    Serial number: 003L7P28UPA2
       Coding: 0012339
       VCID: 7CFC77483F89F1A1B5-8028
       Subsystem 1 - Serial number: 6332MTS636140212
       Subsystem 2 - Serial number: 6342MTS675030172
       Subsystem 3 - Serial number: 6351HTS6E9N10AKR
       Subsystem 4 - Serial number: 6361HTS62G600AKR
    Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
       Part No SW: 3C5 953 501 BN    HW: 5K0 953 569 AB
       Revision: FF010040    Serial number: 20120202100628
       Coding: 0182270000
       VCID: 72E05970A5CDB7D1EF-8026
       Coding: E20000
    Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
       Part No SW: 3C8 920 970 S    HW: 3C8 920 970 S
       Component: KOMBI         H04 0609
       Coding: 440F01
       Shop #: WSC 05314 115 00000
       VCID: 3C7CB748B70931A1F5-8068
       Part No SW: 7N0 907 530 Q    HW: 1K0 907 951
       Component: J533  Gateway H41 1623
       Revision:   H41       Serial number: 210112F1000423
       Coding: 469007
       Shop #: WSC 00000 288 14483
       VCID: 3E78BD40A91523B1DB-806A
    Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
       Part No SW: 7N0 857 511 F    HW: 8P0 857 511 C
       Revision: AA001002
       Coding: 02029B6B74745D545420363E01
       VCID: 3668A5608125EBF103-8062
       Part No SW: 3AA 959 433     HW: 3AA 959 433
       Component:    IMMO         043 0400
       Revision: 00043000    Serial number: VWZCZ000000000
       VCID: 76E8656001A5ABF1C3-8022
    Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
       Revision: A1001003    Serial number: 7661815801
       Coding: 020000
       VCID: 29527E1C409BB4099E-807C
    Address 37: Navigation (J794)       Labels: 1K0-035-27x-37.clb
       Part No SW: 3C0 035 279 G    HW: 3C0 035 279 G
       Component: RNS315-EU   H35 0263
       Serial number: VWZAZ2L3898915
       Coding: 0400040104000F0000019002
       ASAM Dataset: EV_RNS315EUV2UDS A01004
       ROD: EV_RNS315EUV2UDS.rod
       VCID: 275678245E8F827988-8072
       Component: EUR_W_0038  0038
       Part No SW: 3C8 959 701     HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0538
       Revision: 12110009    Serial number: 0004319213
       Coding: 0202B7
       Shop #: WSC 05311 115 00000
       ROD: EV_TSGFPQ35BRFVW46X.rod
       VCID: 6DDA4A0CBCF3682932-8038
       Slave Driver:
       Subsystem 1 - Part No SW: 3C8 959 704 D    HW: 3C8 959 794   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  004 0501
       Serial number: 00000002695448
       Coding: 010090
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 207    3305
       Revision: 00H22000
       Shop #: WSC 02069 000 90108
       VCID: 3776A864462F12F918-8062
    Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
       Component:    KSG PQ47 ELV 043 0634
       Coding: 01910A0001860E763604941570085FCE105C01
    Address 4F: Centr. Electr. II (J520)       Labels: 1K0-907-532.clb
       Component: EZE_2         H41 1623
       Coding: 00000008
       VCID: 6FE65004BEFF9A3900-803A
       Subsystem 1 - Part No SW: 3C8 919 204 A    HW: 3C8 919 204 A
       Component: Analoguhr  005 0003
       Part No SW: 3C8 959 702     HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0538
       Revision: 14110009    Serial number: 0004364920
       Coding: 0202B6
       ROD: EV_TSGBPQ35BRFVW46X.rod
       VCID: 6ED84D00B1F593310B-803A
       Slave Passenger:
       Subsystem 1 - Part No SW: 3C8 959 703 D    HW: 3C8 959 795   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  004 0501
       Serial number: 00000002702120
       Coding: 010090
       Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
       Component: J540 EPB4  VW-64783 0009
       Revision:   H19       Serial number: 00000000664900
       Coding: 0022167
       VCID: 356AA26C5C23E0E90A-8060
    Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
       Part No SW: 6R0 907 357 B    HW: 6R0 907 357 A
       Component: LWR-ECU       005 0030
       Coding: 07A6020001000000
       ASAM Dataset: EV_HeadlRegulVWLWRCC 002004
       ROD: EV_HeadlRegulVWLWRCC.rod
       VCID: 3972AE5CB83B0489EE-806C
    Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
       Component: Batt.regelung H41 1623
       Coding: 030F185A
       VCID: 71E2567CA8CB8CC916-8024
       Component: J367-BDM  H07 0180
       Serial number: 00000000008900268417
    Address 69: Trailer (J345)       Labels: 1K0-907-383-V2.clb
       Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
       Revision: 3A001001    Serial number: 00008030261245
       Coding: 410D000100000000
       VCID: 306493786341C5C159-8064
    End-------------------------(Elapsed Time: 03:36)--------------------------
    Mar 2015
    N Ireland
    Ok,
    So after some research, I now know that I need the following modules:
    An AFS module (which if, I'm not mistaken, will replace my existing range controller)
    1T0941329 A/B
    LED DRL module
    4G0 907 697 F
    So now I just need to find out if there's any wiring loom differences. Grateful to anyone who could answer that question.
    Thanks,
    Colm
    Oct 2017
    Northwest UK
    Hi Colly
    You can in theory retrofit anything but there will be inevitable wiring/coding/module/hardware/software differences. It is not possible to randomly guess what would be required. All retrofits have their own unique challenges and gratification once complete. Headlight changes are quite common. There are some manufacturers who can supply plug and play Headlights without wiring/coding changes. Search the internet
    Mar 2015
    N Ireland
    Quote Originally Posted by myounus View Post
    Hi Colly
    Thanks for the advice myounus. Googling was my first port of call and why I'm here at all. I suppose I was thinking that there'd be an expert on here who might get me 90% of what would be required going from stock xenon's to LED DRL and AFS. But alas, I'll have to either just replace my damaged unit like for like or take the risk that I'll get all working after shelling out somewhere in the region of 600 hard earned beer tokens! lol
    Jul 2014
    Tallinn, Estonia
    Quote Originally Posted by colly View Post
    Ok,
    1T0941329 A/B
    LED DRL module
    4G0 907 697 F
    Thanks,
    Colm
    Besides the different AFS modules on the lights themselves and the addition of DRL power modules, the main AFS module itself is a different part also - 5M0907357F instead of 6R0907357 you currently have.
    Buy an hour of erWin access to get all the schematics required. There will probably be additional wires to run from the AFS module to the LED DRL equipped lights in order for the AFS to work.
  6. Likes myounus, colly liked this post
    Oct 2017
    Northwest UK
    The trouble is there are so many options and variations it's impossible to create a 'standard' guide. Personally I enjoy retrofitting but there are times (like last night) where you are scratching your head. Unfortunately manufacturers don't make it easy as they want to buy new cars and not update older ones.
  8. Likes Uwe liked this post
    Mar 2015
    N Ireland
    Thanks for that, siLc - exactly the sort of expertise I was after. I'll look into that erWin advice...first though I'll do a bit of investigation on the wiring in the car so I'll hopefully have a better idea what I'm looking for during my short-term access.
    Cheers,
    Colm
