Hi folks,
Happy New Year to you all!!
Ok, so my drivers side headlight got damaged recently rather than replace the damaged headlight with a new unit (and potentially have a visible difference with the other headlight), I'm wondering if it's relatively easy to upgrade the headlights? Hoping it's plug'n'play with only coding changes required but thought I'd ask you guys for your thoughts.
The car currently has Xenons, so it's really an upgrade to the Daylight Running Lights from Halogen to LED I'd like to attempt. Do I need a controller for the LED DRL? Are there any wiring modifications to the loom required?
When I started looking, I also thought that it might be a good addition to also install the adaptive cornering units? Is there anything extra I might require for this?
See below a scan I had handy...nothing has changed on the car since this was done. I hope I've included enough info to get hopefully a positive answer!
Cheers,
Colly
Cheers,
Colly
Wednesday,24,May,2017,15:58:03:25238
VCDS Version: 17.1.3.0 (x64)
VIN: WVWZZZ3CZCE****** License Plate:
Chassis Type: 3C (7N0)
Scan: 01 03 08 09 10 14 15 16 17 19 20 25 2E 37 42 44 46 4C 4F 52
53 55 56 61 62 69 72
VIN: WVWZZZ3CZCE****** Mileage: 97510km-60589miles
Address 01: Engine (J623-CFFB) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 PR HW: 03L 907 309 AE
Component: R4 2,0L EDC H25 2480
Revision: 41H25--- Serial number: 00000000000000
Coding: 00190032042501080000
Shop #: WSC 00015 115 00000
ASAM Dataset: EV_ECM20TDI01103L906018PR 003003
ROD: EV_ECM20TDI01103L906018PR.rod
VCID: 09121E9CA85BD409BE-805C
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 AG HW: 3AA 614 109 AG
Component: J104 C2 450M VDE9 0023
Revision: --H07--- Serial number: 00000005309333
Coding: 0004016
Shop #: WSC 05311 000 00000
VCID: 72E059706DCDB7D1EF-8026
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3AA 907 044 F HW: 3AA 907 044 F
Component: Climatronic H03 0101
Revision: 00001K01
Coding: 0010004809
VCID: 336E9C749A57FED924-8066
Address 09: Cent. Elect. (J519) Labels: 3AA-937-087.clb
Part No SW: 3AA 937 087 J HW: 3AA 937 087 J
Component: BCM PQ47 H++ 421 0465
Revision: BD421001
Coding: 000800000000000000880088940029642355008860220720E484C72000C1
Shop #: WSC 05311 000 08193
VCID: 4182C6BCD8EB5C49A6-8014
Subsystem 1 - Part No SW: 3C8 955 119 G HW: 3C8 955 119 G Labels: 1KX-955-119.CLB
Component: WWS464 141211 010 0604
Serial number: 141211
Coding: 00B795
Component: RLHS 037 0059
Serial number: S4Y16M04D05H08M27S09
Coding: 028877
Address 10: Park/Steer Assist (J791) Labels: 3AA-919-475.clb
Part No SW: 3AA 919 475 H HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0026
Revision: -------- Serial number: 56261202002795
Coding: 159207
Shop #: WSC 00905 210 105356
ASAM Dataset: EV_EPHVA2C000000000 002009
ROD: EV_EPHVA2C000000000_VW41.rod
VCID: 4084C3B8DBE15541A9-8014
Address 14: Susp. Elect. (J250) Labels: 3C0-907-376.clb
Part No SW: 3C0 907 376 A HW: 3C0 907 376
Component: DAEMPFUNGS-SG H07 0071
Revision: 00000000 Serial number: 27011203520001
Coding: 010180
Shop #: WSC 05314 000 00000
VCID: 27567824568F827988-8072
Part No SW: 5N0 959 655 AA HW: 5N0 959 655 AA
Component: J234__703 VW10 HI 2118
Revision: 24017000 Serial number: 003L7P28UPA2
Coding: 0012339
VCID: 7CFC77483F89F1A1B5-8028
Subsystem 1 - Serial number: 6332MTS636140212
Subsystem 2 - Serial number: 6342MTS675030172
Subsystem 3 - Serial number: 6351HTS6E9N10AKR
Subsystem 4 - Serial number: 6361HTS62G600AKR
Address 16: Steering wheel (J527) Labels: 3C0-953-569.clb
Part No SW: 3C5 953 501 BN HW: 5K0 953 569 AB
Revision: FF010040 Serial number: 20120202100628
Coding: 0182270000
VCID: 72E05970A5CDB7D1EF-8026
Component: E221__MFL-TK6 H06 0022
Coding: E20000
Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
Part No SW: 3C8 920 970 S HW: 3C8 920 970 S
Component: KOMBI H04 0609
Coding: 440F01
Shop #: WSC 05314 115 00000
VCID: 3C7CB748B70931A1F5-8068
Part No SW: 7N0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H41 1623
Revision: H41 Serial number: 210112F1000423
Coding: 469007
Shop #: WSC 00000 288 14483
VCID: 3E78BD40A91523B1DB-806A
Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
Part No SW: 7N0 857 511 F HW: 8P0 857 511 C
Component: FLA H04 0012
Revision: AA001002
Coding: 02029B6B74745D545420363E01
VCID: 3668A5608125EBF103-8062
Part No SW: 3AA 959 433 HW: 3AA 959 433
Component: IMMO 043 0400
Revision: 00043000 Serial number: VWZCZ000000000
VCID: 76E8656001A5ABF1C3-8022
Component: ELV 029 0380
3C0905861J ELV 029 0380
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7661815801
Coding: 020000
VCID: 29527E1C409BB4099E-807C
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 3C0 035 279 G HW: 3C0 035 279 G
Component: RNS315-EU H35 0263
Serial number: VWZAZ2L3898915
Coding: 0400040104000F0000019002
ASAM Dataset: EV_RNS315EUV2UDS A01004
ROD: EV_RNS315EUV2UDS.rod
VCID: 275678245E8F827988-8072
Component: EUR_W_0038 0038
Part No SW: 3C8 959 701 HW: 3C0 959 793 C
Component: TUER-SG FT 002 0538
Revision: 12110009 Serial number: 0004319213
Coding: 0202B7
Shop #: WSC 05311 115 00000
ROD: EV_TSGFPQ35BRFVW46X.rod
VCID: 6DDA4A0CBCF3682932-8038
Slave Driver:
Subsystem 1 - Part No SW: 3C8 959 704 D HW: 3C8 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0501
Serial number: 00000002695448
Coding: 010090
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 207 3305
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 3776A864462F12F918-8062
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ47 ELV 043 0634
Coding: 01910A0001860E763604941570085FCE105C01
Component: Neigungssensor 004 0611
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H41 1623
Coding: 00000008
VCID: 6FE65004BEFF9A3900-803A
Subsystem 1 - Part No SW: 3C8 919 204 A HW: 3C8 919 204 A
Component: Analoguhr 005 0003
Part No SW: 3C8 959 702 HW: 3C0 959 792 C
Component: TUER-SG BT 002 0538
Revision: 14110009 Serial number: 0004364920
Coding: 0202B6
ROD: EV_TSGBPQ35BRFVW46X.rod
VCID: 6ED84D00B1F593310B-803A
Slave Passenger:
Subsystem 1 - Part No SW: 3C8 959 703 D HW: 3C8 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0501
Serial number: 00000002702120
Coding: 010090
Part No SW: 3AA 907 801 G HW: 3AA 907 801 G
Component: J540 EPB4 VW-64783 0009
Revision: H19 Serial number: 00000000664900
Coding: 0022167
VCID: 356AA26C5C23E0E90A-8060
Address 55: Headlight Range (J431) Labels: 6R0-907-357.clb
Part No SW: 6R0 907 357 B HW: 6R0 907 357 A
Component: LWR-ECU 005 0030
Coding: 07A6020001000000
ASAM Dataset: EV_HeadlRegulVWLWRCC 002004
ROD: EV_HeadlRegulVWLWRCC.rod
VCID: 3972AE5CB83B0489EE-806C
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Component: Batt.regelung H41 1623
Coding: 030F185A
VCID: 71E2567CA8CB8CC916-8024
Component: J367-BDM H07 0180
Serial number: 00000000008900268417
Address 69: Trailer (J345) Labels: 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00008030261245
Coding: 410D000100000000
VCID: 306493786341C5C159-8064
End-------------------------(Elapsed Time: 03:36)--------------------------
