Results 1 to 5 of 5
Thread: 2013 AUDI A8L LEVEL CONTROL 34 ISSUE WITH INCORRECT CODING
    Jan 2020
    Thursday,09,January,2020,08:30:21:22985
    VIN: WAUR2AFD8DN032122   License Plate:
    Chassis Type: FD-AU64 (4H0)
    Scan: 01 02 03 05 06 08 09 10 13 15 16 17 19 28 34 36 3B 3C 42 46
              47 48 52 53 56 5B 5F 62 6C 6D 6F 72 81 85 88 89 8A 8B 8D 8E
              8F 90 BA
    VIN: WAUR2AFD8DN032122   Mileage: 104234km-64768miles
    48-Seat, Rear, DS -- Status: OK 0000
    5B-Seat,Rear,PS -- Status: OK 0000
    8A-Multicont. Seat Rear,DS -- Status: OK 0000
    8D-Multicont. Seat Rear,PS -- Status: OK 0000
    BA-Motor Mounts -- Status: Malfunction 0010
    Address 01: Engine (------CEUA)       Labels: Redir Fail!
       Part No SW: 4H0 906 014 L    HW: 4H0 906 014
       Component: 4.0l V8TFSI / H62 0005
       Revision: NCH62---
       Coding: 022A00326546010E1000
       Shop #: WSC 51059 002 1048576
       ASAM Dataset: EV_ECM40TFS0114H0906014L 001005
       ROD: EV_ECM40TFS0114H0906014L.rod
       VCID: 2C010350C68EABF745F-8078
       Part No SW: 4H1 927 158 BK    HW: 0BK 927 156 AG
       Component: 0BK 40TFSIUSA H16 1005
       Revision: --H16---
       Coding: 000002
       ASAM Dataset: EV_TCMALX51011 002020
       ROD: EV_TCMALX51011_002_AU64.rod
       VCID: 7AADF5087C5AC547873-802E
       Part No SW: 4H0 907 379 E    HW: 4H0 907 379 E
       Component: ESP PREMIUM   H10 0352
       Coding: C4E5F30023A7CF00E200
       ASAM Dataset: EV_ESPPremi 005013
       ROD: EV_ESPPremi_005_AU64.rod
       VCID: 34311B301EBEF3371DF-8060
    0675 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
              [Net_Fahrwerk_03_FA_Niveau_Druck_HL_Error]
                        Reset counter: 234
                        Mileage: 104234 km
                        Date: 2020.01.06
                        Time: 11:16:16
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 82
                        Bit Info 4: 00
                        F-Path: 39
                        F-Type: 24
                        Uz: B6
    0720 - Tire Pressure Warning
              C102D 00 [009] - -
                        Reset counter: 234
                        Mileage: 104234 km
                        Date: 2020.01.06
                        Time: 11:16:00
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 82
                        Bit Info 4: 00
                        F-Path: 47
                        F-Type: 01
                        Uz: B5
    0776 - Function Restriction due to Implausible Message(s)
              U1112 00 [009] - -
              [Net_Fahrwerk_03_FA_Niveau_Druck_HL_Invalid]
                        Reset counter: 234
                        Mileage: 104234 km
                        Date: 2020.01.07
                        Time: 09:33:06
                        VzRef: 00
                        Bit Info 1: C0
                        Bit Info 2: 40
                        Bit Info 3: 82
                        Bit Info 4: 00
                        F-Path: 39
                        F-Type: 23
                        Uz: AF
       Part No SW: 4H0 907 064 CD    HW: 4H0 907 064 CD
       Component: BCM2 2.0      H33 0433
       Coding: 0DA72046000000000000
       VCID: 6D87CE543D9462FF121-8038
       Serial number: 2313000055956003
       Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
       Revision: AA000000    Serial number: 00000058178659
       Coding: C018B60085047201010001010101112131313333283333
       VCID: 353726341544EA3F2A1-8060
    Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
       Part No SW: 4H0 820 043 L    HW: 4H0 820 043 L
       Component: Klima 4 Zonen H20 0130
       Coding: 688122BE7C
       VCID: 290FFA44C97CBEDFBE9-807C
       Revision: 11012002    Serial number: 00000001711344
       Coding: 09072091073C9FE38B000804A0003800009CD308860001218001085C7B00
       VCID: 6FBBD45C379890EF20D-803A
       Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS641 130317  H35 0080
       Serial number:         130319171758
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 10321569
       Coding: 025523
       Component: E1 - LDS  H07 0044
       Serial number: 08 04 2013  00001062
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555R5JX802
       Serial number: 00000015041300010632
       Coding: 100000
       Serial number: 00000012041300010811
       Coding: 100000
       Subsystem 7 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA105264000003332772
       Coding: 020300
       Serial number: 1398C2A6000000000001
    00532 - Supply Voltage B+
                        Reset counter: 14
                        Mileage: 104220 km
                        Date: 2019.12.06
                        Time: 13:59:00
       Revision: 11001001    Serial number: 61031310601236
       Coding: A80B0E
       VCID: 71BFD224212C861F369-8024
       Part No SW: 4H0 907 561 B    HW: 4H0 907 561
       Component: ACC3          H19 0410
       Coding: 7E01020101
       ASAM Dataset: EV_AdaptCruisContrAU64X 002021
       ROD: EV_AdaptCruisContrAU64X_002.rod
       VCID: 2A0D0548CC7AB5C7B73-807E
    93440 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
              [FAULT_CIS_VIDEO_FAIL]
                        Fault Frequency: 23
                        Reset counter: 234
                        Mileage: 104234 km
                        Date: 2020.01.06
                        Time: 11:16:35
                        Control Module temperature: 29 °C
                        Voltage terminal 15: 14.486 V
                        Velocity_vehicle_reference: -0.00 m/s
       Part No SW: 4H0 959 655 D    HW: 4H0 959 655 D
       Component: Airbag10.43   H45 0042
       Revision: --------    Serial number: 003JS001GKVW
       Coding: 303143303230303030314A55304C34483053
       VCID: 372B2C3C0FC8182F38D-8062
       Subsystem 1 - Part No SW: 4H0 959 339 A    HW: 4H0 959 339 A
       Component: BF-Gewichtss.  H03 0040
       Serial number: 5850000R1332607JWD
       Serial number: 3575HRB405P0INGSE1A4
       Serial number: 3585HRB40064UO4CD1SU
       Serial number: 3515JRB401A50H9KOQ1G
       Serial number: 3525JRB401A50H9KLI16
       Serial number: 3554VRB401A50G4AC1CW
       Serial number: 3564VRB401C50G4ABPSV
       Revision: --------    Serial number: 90815MDA00003
       Coding: 0004BC
       VCID: 38292F0002561757317-806C
       Subsystem 1 - Part No SW: 4H0 951 528 L    HW: 4H0 951 528 L
       Component: E221 - MFL  H09 0010
       Serial number: 09 01 2013  33330672
       Part No SW: 4H0 920 980 K    HW: 4H0 920 980 K
       Component: TBenUSAACC--- H50 0515
       Revision: 34081076    Serial number: 658120413592005
       Coding: 0B4608015740D705020000
       ASAM Dataset: EV_RBD4K 004046
       ROD: EV_RBD4K_AU64.rod
       VCID: 3333182C1BB0F40F045-8066
       Analog_clock:
       Subsystem 1 - Part No SW: 4H0 919 204 G    HW: 4H0 919 204 G
       Component: Analoguhr D4  H05 0225
       Serial number: 2130318001244
       Part No SW: 4H0 907 468 AC    HW: 4H0 907 468 AC
       Component: J533--Gateway H12 0037
       Revision: --------    Serial number: 00000000898856
       Coding: 00ED074800
       ASAM Dataset: EV_GatewPkoUDS 001018
       VCID: 72BDDD28242ABD07CF3-8026
       Subsystem 1 - Part No SW: 4H0 915 181 F    HW: 4H0 915 181 F
       Component: J367-BDM  H08 0181
       Serial number: 50101H15331911228536
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 8K0 959 663 C    HW: 8K0 959 663 C
       Serial number: 13107001657021200410
    Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
       Part No SW: 4H0 919 158 K    HW: 4H0 919 158 K
       Component: Klima Fond    H16 0121
       Coding: 2000000000
       ROD: EV_AirCondiHeck_AU64.rod
       VCID: 38292F0002D61757317-806C
       Part No SW: 4H0 907 553 E    HW: 4H0 907 553
       Component: LUFE-DAEMPFER H17 0099
       Coding: 008003
       Shop #: WSC 00001 123 12345
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2E050958F092D9E76BB-807A
    6 Faults Found:
    677386 - Ride-Height System; Plausibility Error
              C1046 00 [009] - -
                        Fault Frequency: 7
                        Reset counter: 234
                        Mileage: 104234 km
                        Date: 2020.01.07
                        Time: 09:33:53
    677387 - Ride-Height System; Plausibility Error
              C1046 00 [009] - -
                        Reset counter: 234
                        Mileage: 104234 km
                        Date: 2020.01.06
                        Time: 12:22:01
    0001 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 234
                        Mileage: 104234 km
                        Date: 2020.01.06
                        Time: 12:20:26
    367877 - Ride Height Not Learned
              C1044 00 [009] - -
                        Reset counter: 234
                        Mileage: 104234 km
                        Date: 2020.01.06
                        Time: 12:20:26
    266752 - Control module not coded
              U1013 00 [009] - -
                        Reset counter: 234
                        Mileage: 104234 km
                        Date: 2020.01.06
                        Time: 12:20:26
    38144 - No End-of-Line Programming
              B2013 00 [009] - -
              [keine Bandendeprogrammierung erfolgt (Auslieferungszustand)]
                        Reset counter: 234
                        Mileage: 104234 km
                        Date: 2020.01.06
                        Time: 12:20:26
       Revision: AA000000    Serial number: 00000058178315
       Coding: C018BF8085857201030001010101112131313333203333
       Part No SW: 4H0 907 637 K    HW: 4H0 907 637 F
       Component: SARA 6D       H02 0056
       Revision: --------    Serial number: EJ1BPA7700RDUZ
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       Part No SW: 4H0 907 566 A    HW: 4G0 907 566
       Component: J769  SWA MasterH02 0050
       Revision: 00H02000    Serial number: 6PZ 010 287-07
       VCID: 2E050958FC12D9E76BB-807A
       Subsystem 1 - Part No: 4H0 907 568 A
       Component: J770  SWA Slave H02 0050
       Subsystem 2 - Serial number: 6PZ 010 287-27
       Subsystem 3 - Serial number: 5F11.04.1300H02000AMS15865˙
       Subsystem 4 - Serial number: S15865˙
       Part No SW: 4H0 959 793 R    HW: 4H0 959 793 G
       Component: TSG FA        H06 0273
       Revision: --------    Serial number: 0000057058573
       Coding: 011F1F005E0062C202003017
       VCID: 48C95FC072B667D7417-801C
       Revision: 00002001    Serial number: 0304733532
       Coding: 0106023A00FA759FB0B0C784020301070000000000000000000000000000
       Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
       Component: GTO BF  H01 0080
       Serial number: 00000000000000139008
       Subsystem 3 - Part No SW: 4H4 959 591     HW: 4H4 959 591
       Component: J245  007C  H06 0005
       Serial number: 313600046919
       Coding: 020200
       Subsystem 4 - Part No SW: 4H0 947 135 BR    HW: 4H0 947 135 BR
       Component: Dachelektroni  H13 0080
       Serial number: A2013000000000696749
       Coding: 070000
       Subsystem 5 - Part No SW: 4H4 959 591     HW: 4H4 959 591
       Component: J394  0014  H06 0005
       Serial number: 313700047580
       Coding: 020200
       Subsystem 6 - Part No SW: 4H4 959 591     HW: 4H4 959 591
       Component: J392  006A  H06 0005
       Serial number: 313600046910
       Coding: 020200
       Subsystem 7 - Part No SW: 4H4 959 591     HW: 4H4 959 591
       Component: J867  00E0  H06 0005
       Serial number: 313700047532
       Coding: 020200
       Subsystem 8 - Part No SW: 3AA 962 243     HW: 3AA 962 243
       Component: GEB.F.Heckoef  H12 0719
       Serial number: 84367207
    02907 - Control Module for Roof Shade (J394)
                        Fault Status: 01100101
                        Reset counter: 234
                        Mileage: 104234 km
                        Date: 2020.01.06
                        Time: 11:18:00
       Part No SW: 4G1 035 223 A    HW: 4G1 035 223 A
       Component: BOSE-G3C7-ANC H02 0540
       Revision: CJ002700    Serial number: 00000000006950
       Coding: 030000
       VCID: 1C61D39096AE5B7735F-8048
    Address 48: Seat, Rear, DS (J876)       Labels: None
       Part No SW: 4H0 959 860     HW: 4H0 959 860
       Component: MEM-FS-Fond   H06 0155
       Revision: AA000000    Serial number: 00000056563762
       Coding: 001892800000700D0A00392038193A2039203B3B202020
       VCID: 71BFD22421AC861F369-8024
       Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
       Component: TSG BF        H06 0273
       Revision: --------    Serial number: 0000058068305
       Coding: 011F1F005E0062C202003006
       VCID: 3C213310366E3B77D5F-8068
       Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
       Component: EPB-4         H03 0013
       Revision: --------    Serial number: 00000000649263
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2B03004CC380ACCF4C5-807E
       Part No SW: 4H0 035 082 E    HW: 4H0 035 082
       Component: Radio U SIRIU H60 0121
       Revision: AB001007    Serial number: 155D00D7528539
       Coding: 020007010000000001
       VCID: 2313E86CABD0648FF45-8076
    Address 5B: Seat,Rear,PS (J877)       Labels: None
       Component: MEM-BFS-Fond  H06 0155
       Revision: AA000000    Serial number: 00000054693840
       Coding: 001896800000700D0A00392038193A2039203B3B382020
       Part No SW: 4H0 035 746 E    HW: 4H0 035 746 C
       Component: H-BNT-NA      H50 0622
       Revision: --------    Serial number: 183DW0D7508061
       Coding: 020200000001F9EF7D128B1E00000003140001000000000000
       VCID: 2A0D0548CCFAB5C7B73-807E
       Subsystem 1 - Part No: 8R0 060 884 BA
       Component: NAR 2013  0703
       Subsystem 2 - Part No SW: 4H0 919 604 G    HW: 4H0 919 604 G
       Component: DU8 D4 SV NB  H48 0021
       Serial number: AUZ8ZDDC9009F3K
       Subsystem 3 - Part No SW: 4H1 919 600 H    HW: 4H1 919 600
       Component: E380 BDT D4  H09 0065
       Serial number: 00000000112305
       Component: CD-Database  4949
       Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
       Component: TSG HL        H06 0273
       Revision: --------    Serial number: 0000057161180
       Coding: 010F1F00420062C202003006
       Part No SW: 4H0 907 441 A    HW: 4H0 907 441
       Revision: --H06---    Serial number: 525 PA8J33D1CD
       Coding: 1080003
       VCID: 2615F178D4E291A793B-8072
    Address 6D: Trunk Elect. (----)       Labels:* None
       Part No SW: 4H0 959 107 AB    HW: 4H0 959 107 M
       Component: HDSG-Modul    H11 0043
       Revision: 10011001    Serial number: 092300696
       Coding: 0210044100
       ASAM Dataset: EV_DeckLidContrUnit 001032
       ROD: EV_DeckLidContrUnit.rod
       VCID: 6E85C958301299E72BB-803A
    Address 6F: Centr. Conv. II (J773)       Labels:* None
       Revision: --------    Serial number: 000000105055
       Coding: 200000
       ASAM Dataset: EV_Ambie 001008
       ROD: EV_Ambie.rod
       VCID: 6393A86CEBD0248FB45-8036
       Component: TSG HR        H06 0273
       Revision: --------    Serial number: 0000057161177
    Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
       Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
       Component: GSM-LL        H08 0083
       Revision: 0L0D5015    Serial number: SN130302  0334
       ROD: EV_GSM2x3Mono.rod
       Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
       Component: DPC-SG        H26 0038
       Coding: E9060000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 2615F178D86291A793B-8072
    0708 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
              [EGD_Fahrwerk_01_Signal_Error]
                        Fault Frequency: 7
                        Reset counter: 234
                        Mileage: 104234 km
                        Date: 2020.01.06
                        Time: 11:56:40
                        Outside air temperature: -36.0 °C
                        Voltage terminal 15: 13.3 V
                        Control Module temperature: 58.0 °C
    0793 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
              [EGD_Fahrwerk_01_Permanent_Error]
                        Fault Frequency: 14
                        Reset counter: 234
                        Mileage: 104234 km
                        Date: 2020.01.06
                        Time: 11:19:17
                        Outside air temperature: -41.0 °C
                        Voltage terminal 15: 14.4 V
                        Control Module temperature: 47.0 °C
       Serial number: 00010800145902
       Coding: 766FF2
       ROD: EV_IVBDriveSideFrnt.rod
       VCID: 2F3B145CF798D0EF60D-807A
       Serial number: 00010800144401
       Coding: 366FF2
    Address 8A: Multicont. Seat Rear,DS (J875)       Labels:* None
       Part No SW: 4H0 907 182 G    HW: 4H0 907 182 G
       Component: IVB           H08 0042
       Serial number: 00010801183101
       Coding: 202F00
       ASAM Dataset: EV_IVBDriveSideRear 001003
       Part No SW: 4H0 907 541 B    HW: 4H0 907 541
       Component: ACC3          H19 0400
       Coding: 7E01020101
       ASAM Dataset: EV_AdaptCruisContr2AU64X 002018
       ROD: EV_AdaptCruisContr2AU64X_002.rod
       VCID: 2809FF40D27687D7A17-807C
    Address 8D: Multicont. Seat Rear,PS (J874)       Labels:* None
       Serial number: 00010646012301
       Coding: 202F00
       ASAM Dataset: EV_IVBPasseSideRear 001003
       Part No SW: 4G0 907 107 E    HW: 4H0 907 107
       Component: BV-SG         H31 0041
       Serial number: 005000121404137
       Coding: 02A19A000111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
    0091 - Function Limitation due to Missing Video Data
              C1108 00 [009] - -
              [DPC_SystemError]
                        Fault Frequency: 20
                        Reset counter: 234
                        Mileage: 104234 km
                        Date: 2020.01.06
                        Time: 11:20:05
                        Outside air temperature: 19.0 °C
                        Voltage terminal 15: 14.8 V
                        Control Module temperature: 24.0 °C
       Coding: 0066F609031F0376070308014240C2010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 313F1224E1ACC61F769-8064
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: 323D1D28E4AAFD070F3-8066
    Address BA: Motor Mounts (J931)       Labels: 4H0-907-145.clb
       Part No SW: 4H0 907 145     HW: 4H0 907 145
       Component: AEM - LEAR    H05 0006
       Revision: 00001001    Serial number: 97804001765804
       ASAM Dataset: EV_AEMLearAU64X 002014
       ROD: EV_AEMLearAU64X_AU57.rod
       VCID: 6695B17818E251A753B-8032
    1294 - Actuator 1 for Drivetrain Mounts
              C1131 07 [009] - Mechanical Failure
                        Reset counter: 234
                        Mileage: 104234 km
                        Date: 2020.01.06
                        Time: 11:20:31
    End----------(Elapsed Time: 03:21, VBatt start/end: 14.7V/14.7V)-----------
    16.4905° S, 151.7375° W
    I hate to say this, but this vehicle will need to have the ODIS factory scan tool connected and a test plan completed to clear the B2013: No End-of-Line Programming fault code in the [34-Level Control] controller.
    Please see this Ross-Tech forum post for more information.
    UDS - Re-adapt Adaptive Suspension to default position
    (See: Special Notes, warnings, etc)
    Hope this helps.
    drpeter
  3. Likes PetrolDave, Dana, Uwe liked this post
    If the car suspension can't auto adapt with comporting Safe Act requirements & like a TV must do so for the CAA, sure makes me wonder if this is a new legal argument, how about you?
    Jan 2020
    thanks drpeter
    Dec 2019
    Just a thought and of course it depends on your vehicle, but most almost all scans I have read on module 34 for A8's are coded 008000 unlike yours with 008003. Could be sport suspension related etc. but it stuck out to me and worth checking if you haven't given up by now.
    Most the other codes are due to ride height not being adapted. I had a similar scenario when doing my suspension and I had to clear my codes several times while attempting the coding and adaption. Also make sure you meet the pre-requisites. I didn't have over a half a tank as recommended and hitting my lift which resulted in abortions due to safety reasons in the process.
    The adaption process DrPeter referenced is spot on and what I used, follow it to the T and make sure you select the correct drop downs.
  7. Likes Jack@European_Parts liked this post
