Audi a6 c7 avant rear door’s not responding
xpetyax
New Member
St Helens, UK
Hi all
I have audi a6 c7 avant 2012
I was fitting a towbar last month with a dedicated wiring loom when i installed everything the car failed to start ( no ignition) only worked radio, headlights, door lock’s operating from inside the car.
I checked all fuses they were fine
Then it was towed to a garage they said body control module failed
They changed for second hand one it was still no ignition after all
Then towed to other specialist they said need’s new module
It was changed and the car up and running again
Only issue the both side of the rear door not operating it’s locked i doesn’t do anything for a window or for door child lock etc
The guy online reprogrammed and coded the bcm he said coding is fine
Is any suggestion what causing the fault i am still thinking something with coding issue but they say door control module
Old module 4h0 907 064 CN
New module 4h0 907 064 GB (ordered from Audi)
https://ibb.co/xJQ7kG9
https://ibb.co/MDRpFJq
Please post a VCDS scan.
xpetyax
New Member
St Helens, UK
Address: 0062 System name: 62 - Door electronics, rear left Protocol variant: KWP2000/TP20 (Ereignisse: 1)
+Identification:
Data source:
Vehicle
Hardware part number:
4G8959795G
Part number:
4G8959795J
Hardware version number:
H03
Software version number:
0506
Production date:
10.06.2012
01  08  14  00  40  01  62  00  02  08  00  02
Index
Byte
Value (hex)
Value (bin)
$1
$01
00000001
$2
$08
00001000
3
$3
$14
00010100
4
$4
$00
00000000
5
$5
$40
01000000
6
$6
$01
00000001
7
$7
$62
01100010
8
$8
$00
00000000
9
$9
$02
00000010
10
$A
$08
00001000
11
$B
$00
00000000
12
$C
$02
00000010
010814004001620002080002
Flash capability:
flashable
System designation:
TSG HL
Version of the target data container:
0034
Equipment code:
00000000000038E3
+Event memory entries (Data source: Vehicle):
Entry in fault memory
Number:
VAG03681:  Incorrect sign.
Fault type 1:
Implausible signal
Fault type 2:
Intermittent
+Standard ambient conditions:
Date:
29/12/19
Time:
20:17:24
Mileage (DTC):
211450
Priority:
3
Frequency counter:
4
Unlearning counter / driving cycle:
233
Address: 0072 System name: 72 - Door electronics, rear right Protocol variant: KWP2000/TP20 (Ereignisse: 1)
+Identification:
Data source:
Vehicle
4G8959795G
Part number:
4G8959795J
H03
0506
Production date:
10.06.2012
Index
Byte
Value (hex)
Value (bin)
$1
$01
00000001
$2
$08
00001000
3
$3
$14
00010100
4
$4
$00
00000000
5
$5
$40
01000000
6
$6
$01
00000001
7
$7
$62
01100010
8
$8
$00
00000000
9
$9
$02
00000010
10
$A
$08
00001000
11
$B
$00
00000000
12
$C
$02
00000010
Flash capability:
flashable
System designation:
TSG HR
0034
Equipment code:
00000000000038E3
Number:
Fault type 1:
Implausible signal
Fault type 2:
Intermittent
Date:
29/12/19
Time:
20:17:24
Mileage (DTC):
211450
Priority:
3
Frequency counter:
4
233
I'm not sure what that ^^^^ data came from, but it wasn't VCDS.
xpetyax
New Member
St Helens, UK
Saturday,18,January,2020,13:38:05:46521
VCDS Version: 19.6.2.0
Dealer/Shop Name: VCDS-VAG-COM Diagnostics Chorley/Preston/Blackburn area
Workshop Code: 123 12345 000000
VIN: WAUZZZ4G3DN020936   License Plate: YS12WCL
Mileage: 211638km-131505mi   Repair Order:
xpetyax21@gmail.com
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 55 56 5F
          62 72
VIN: WAUZZZ4G3DN020936   Mileage: 211638km-131505miles
Address 01: Engine (J623-CLAB)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 311 E    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H37 0001
   Revision: 53H37---
   Coding: 12034012052401020000
   Shop #: WSC 45009 003 1048576
   ASAM Dataset: EV_ECM30TDI0114G0907311E 001001
   ROD: EV_ECM30TDI0114G0907311E.rod
   VCID: 2541E1F62454BF67F4-8070
4481 - Cruise Control Switch (E45)
          P0568 00 [032] - Implausible Signal
                    Mileage: 211615 km
                    Date: 2020.01.18
                    Time: 13:01:51
                    Engine speed: 1847.50 /min
                    Normed load value: 14.9 %
                    Vehicle speed: 111 km/h
                    Coolant temperature: 78 °C
                    Intake air temperature: 12 °C
                    Voltage terminal 30: 14.620 V
                    Cruise Control System (CCS): switch position-Bits 0-7: 128
                    Cruise Control System (CCS): status-Bits 0-7: 8
                    Cruise control switch-off: irreversible-Bits 0-7: 255
                    Cruise control switch-off: reversible-Bits 0-7: 14
                    Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
4483 - Function Restriction due to Faults in Other Modules
          U1113 00 [032] - -
                    Mileage: 211615 km
                    Date: 2020.01.18
                    Time: 13:01:52
                    Engine speed: 1851.00 /min
                    Normed load value: 18.0 %
                    Voltage terminal 30: 14.640 V
                    Cruise Control System (CCS): switch position-Bits 0-7: 192
                    Cruise Control System (CCS): status-Bits 0-7: 200
                    Cruise control switch-off: irreversible-Bits 0-7: 0
                    Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 1
   Part No SW: 4G1 927 155 F    HW: 0AW 927 156 K
   Component: 0AW 30TDI RdW H04 0002
   Revision: --H04---    Serial number: 0000000310
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_TCMVL381 A02428
   ROD: EV_TCMVL381.rod
   VCID: 2F6D03DE76A8F5370E-807A
   Part No SW: 4G0 907 379 H    HW: 4G0 907 379 H
   Component: ESP PREMIUM   H09 0361
   Coding: 07A18701E085E180DB00
   Shop #: WSC 61035 002 1048576
   VCID: 366336BA89F2C4FF4D-8062
0632 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 234
                    Mileage: 211482 km
                    Date: 2020.01.04
                    Time: 02:11:41
                    VzRef: 47
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 26
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 2F
                    Uz: BA
   Part No SW: 4H0 907 064 GB    HW: 4H0 907 064 GB
   Coding: 01B93046000000000000
   VCID: 6FEDC3DEBE28B5374E-803A
   Serial number: 2312000106842015
Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 AC    HW: 4G0 820 043 AC
   Component: KLIMA 2 ZONEN H11 0070
   Serial number: 21061200110997
   Coding: 3622000821
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_AirCondiBasisUDS 002040
   VCID: 60CFB0E27BF61A4FC7-8034
0276 - Engine Off Timer Performance
          P150A 00 [008] - -
                    Reset counter: 233
                    Mileage: 211450 km
                    Date: 2019.12.31
                    Time: 01:18:44
                    Voltage terminal 30: 14.34 V
   Part No SW: 4H0 907 063 CF    HW: 4H0 907 063 F
   Revision: 20012002    Serial number: 00000001529519
   Coding: 2600201040349FE00181008300001D0C0F9DC70827090201000004606100
   VCID: 6ED3DEDAB922BC3F45-803A
   Component: WWS57X 120504  H35 0080
   Serial number:         120523162330
   Coding: 0045F7
   Serial number: 20341094
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Serial number: 18 06 2012  00000889
   Component: Humidity_Sens  H02 0002
   Serial number: 04090336000000000001
   Part No SW: 4H0 919 475 AG    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0072
   Revision: 11001001    Serial number: 61061216400550
   Coding: 88C308
   ASAM Dataset: EV_EPHVA18AU57X0000 003008
   ROD: EV_EPHVA18AU57X0000_003.rod
   VCID: 77FDFBBECE78FDF796-8022
   Revision: --------    Serial number: 003JG0091GN1
   Coding: 30323436313330303537554A305234473053
   Serial number: 3575HRB40571E4S0E8NB
   Serial number: 3585HRB405F1E4S098OG
   Serial number: 3515JRB400C4UEIMAGK6
   Serial number: 3525JRB40184UI5CJ9FP
   Serial number: 3554VRB40064UH26OHF$
   Serial number: 3564VRB40064UH2660TJ
   Revision: 00000000    Serial number: 20120620000359
   Coding: 000035
   VCID: 306F00A26396EACF17-8064
   Component: E221 - MFL  H08 0009
00895 - Cruise Control Switch (E45)
                    Fault Status: 00101110
                    Reset counter: 235
                    Mileage: 211615 km
                    Date: 2020.01.18
                    Time: 13:01:51
   Part No SW: 4G8 920 983 C    HW: 4G8 920 983 C
   Component: TDieGb        H79 0515
   Revision: 28460207    Serial number: 658140612596028
   Coding: 33A610000B412600010000
   ASAM Dataset: EV_RBD4K 004046
   ROD: EV_RBD4K_AU57.rod
   VCID: 356131B694F4CFE744-8060
   Part No SW: 4G0 907 468 AB    HW: 4G0 907 468 AA
   Component: J533--Gateway H10 0028
   Revision: --------    Serial number: 00000000573774
   Coding: 00CD077D00
   ASAM Dataset: EV_GatewPkoUDS 001013
   VCID: 70EFC0A2AB16AACF57-8024
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790568151
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 010412000000000000CE
   Component: SARA 3D       H02 0053
   Revision: --------    Serial number: EJ1BPA720017AL
   ASAM Dataset: EV_SARA2 005011
   ROD: EV_SARA2.rod
   VCID: 33650FAE9A80D1D76A-8066
   Component: TSG FA        H03 0506
   Coding: 011C16004001620002080002
   VCID: 479D4B7EF6184D7726-8012
   Component: RCEPS         H35 0010
   Revision: 00001000    Serial number: 0023602620
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 326B0AAA659AD8DF61-8066
   Revision: 00002001    Serial number: 0515491072
   Coding: 013B062220B90000832009040001040F0000000000000000000000000000
   Component: TSG BF        H03 0506
   VCID: 4683467AF112547FDD-8012
   Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
   Component: EPB-4         H03 0013
   Revision: --------    Serial number: 00000000379015
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2B5517CE42B0891722-807E
   Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
   Serial number: 120614-0002-049
   Coding: 112296101000A300
   ROD: EV_HeadlRegulBasic.rod
   VCID: 2C5714D247BE8E2F2B-8078
   Part No SW: 4G0 035 061 E    HW: 4G0 035 061
   Component: Radio U DAB   H60 0099
   Revision: AB001007    Serial number: 109F$0C7567901
   Coding: 010103020100000001
   VCID: 1F4DF31E0E0865B7BE-804A
   Part No SW: 4G0 035 670 H    HW: 4G0 035 670 H
   Component: H-BNT-EU      H49 0526
   Revision: --------    Serial number: 190F%0C7509854
   Coding: 050101010003A1ED05808B3E00000003000001000000000000
   VCID: 285FE8C25B46A20FCF-807C
   Subsystem 1 - Part No: 8R0 060 884 AH
   Component: EUR 2012  1308
   Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDC9401TY9E
   Subsystem 3 - Part No SW: 4G2 919 610 C    HW: 4G2 919 610 C
   Serial number: 90349LF4000GE
   Subsystem 4 - Part No: 8R0 060 961 C
   Component: CD-Database  3638
   Component: TSG HL        H03 0506
   Coding: 010814004001620002080002
   VCID: 49994D46E00CBB0730-801C
03681 - Incorrect Signature
            008 - Implausible Signal
                    Fault Status: 01101000
                    Fault Frequency: 62
                    Reset counter: 195
                    Mileage: 211450 km
                    Date: 2019.12.31
                    Time: 01:37:08
   Component: TSG HR        H03 0506
                    Fault Frequency: 62
                    Reset counter: 195
                    Mileage: 211450 km
                    Date: 2019.12.31
                    Time: 01:37:09
End-------------------------(Elapsed Time: 06:28)--------------------------
Address 01: DTCs cleared
Address 03: DTCs cleared
Address 08: DTCs cleared
Address 16: DTCs cleared
Address 62: DTCs cleared
Address 72: DTCs cleared
Address 72,4G8 959 795 J,recoded (Long Coding),from,010814004001620002080002,to,010816004001620002080002,(12345/123/00000),
Address 72,4G8 959 795 J,recoded (Long Coding),from,010816004001620002080002,to,010814004001620002080002,(12345/123/00000),
Address 46,4H0 907 064 GB,recoded (Long Coding),from,013B062220B90000832009040001040F0000000000000000000000000000,to,013B06A220B90000832009040001040F0000000000000000000000000000,(12345/123/00000),
Address 46,4H0 907 064 GB,recoded (Long Coding),from,013B06A220B90000832009040001040F0000000000000000000000000000,to,013B06A020B90000832009040001040F0000000000000000000000000000,(12345/123/00000),
Address 46,4H0 907 064 GB,recoded (Long Coding),from,013B06A020B90000832009040001040F0000000000000000000000000000,to,013B06A220B90000832009040001040F0000000000000000000000000000,
I don't recall ever having seen the fault code "03681 - Incorrect Signature" before. Not sure what to tell you.
heikeedwin
Maputo, Mozambique
C?ID=389069
Did you manage to sort this? Having the same issue.
