Results 1 to 6 of 6
Thread: Audi a6 c7 avant rear door’s not responding
    New User
    Dec 2019
    St Helens, UK
    Hi all
    I have audi a6 c7 avant 2012
    I was fitting a towbar last month with a dedicated wiring loom when i installed everything the car failed to start ( no ignition) only worked radio, headlights, door lock’s operating from inside the car.
    I checked all fuses they were fine
    Then it was towed to a garage they said body control module failed
    They changed for second hand one it was still no ignition after all
    Then towed to other specialist they said need’s new module
    It was changed and the car up and running again
    Only issue the both side of the rear door not operating it’s locked i doesn’t do anything for a window or for door child lock etc
    The guy online reprogrammed and coded the bcm he said coding is fine
    Is any suggestion what causing the fault i am still thinking something with coding issue but they say door control module
    Old module 4h0 907 064 CN
    New module 4h0 907 064 GB (ordered from Audi)
    https://ibb.co/xJQ7kG9
    https://ibb.co/MDRpFJq
    Last edited by Uwe; 01-09-2020 at 09:34 AM. Reason: IMG -> URL on second and third images
    Please post a VCDS scan.
    New User
    Dec 2019
    St Helens, UK
    Address: 0062 System name: 62 - Door electronics, rear left Protocol variant: KWP2000/TP20 (Ereignisse: 1)
    +Identification:
    Data source:
    Vehicle
    Hardware part number:
    4G8959795G
    Part number:
    4G8959795J
    Hardware version number:
    H03
    Software version number:
    0506
    Production date:
    10.06.2012
    01  08  14  00  40  01  62  00  02  08  00  02
    Index
    Byte
    Value (hex)
    Value (bin)
    $1
    $01
    00000001
    $2
    $08
    00001000
    3
    $3
    $14
    00010100
    4
    $4
    $00
    00000000
    5
    $5
    $40
    01000000
    6
    $6
    $01
    00000001
    7
    $7
    $62
    01100010
    8
    $8
    $00
    00000000
    9
    $9
    $02
    00000010
    10
    $A
    $08
    00001000
    11
    $B
    $00
    00000000
    12
    $C
    $02
    00000010
    010814004001620002080002
    Flash capability:
    flashable
    System designation:
    TSG HL
    Version of the target data container:
    0034
    Equipment code:
    00000000000038E3
    +Event memory entries (Data source: Vehicle):
    Entry in fault memory
    Number:
    VAG03681:  Incorrect sign.
    Fault type 1:
    Implausible signal
    Fault type 2:
    Intermittent
    +Standard ambient conditions:
    Date:
    29/12/19
    Time:
    20:17:24
    Mileage (DTC):
    211450
    Priority:
    3
    Frequency counter:
    4
    Unlearning counter / driving cycle:
    233
    Address: 0072 System name: 72 - Door electronics, rear right Protocol variant: KWP2000/TP20 (Ereignisse: 1)
    +Identification:
    Data source:
    Vehicle
    4G8959795G
    Part number:
    4G8959795J
    H03
    0506
    Production date:
    10.06.2012
    Index
    Byte
    Value (hex)
    Value (bin)
    $1
    $01
    00000001
    $2
    $08
    00001000
    3
    $3
    $14
    00010100
    4
    $4
    $00
    00000000
    5
    $5
    $40
    01000000
    6
    $6
    $01
    00000001
    7
    $7
    $62
    01100010
    8
    $8
    $00
    00000000
    9
    $9
    $02
    00000010
    10
    $A
    $08
    00001000
    11
    $B
    $00
    00000000
    12
    $C
    $02
    00000010
    Flash capability:
    flashable
    System designation:
    TSG HR
    0034
    Equipment code:
    00000000000038E3
    Number:
    Fault type 1:
    Implausible signal
    Fault type 2:
    Intermittent
    Date:
    29/12/19
    Time:
    20:17:24
    Mileage (DTC):
    211450
    Priority:
    3
    Frequency counter:
    4
    233
    I'm not sure what that ^^^^ data came from, but it wasn't VCDS.
  5. Likes PetrolDave liked this post
    New User
    Dec 2019
    St Helens, UK
    Saturday,18,January,2020,13:38:05:46521
    VCDS Version: 19.6.2.0
    Dealer/Shop Name: VCDS-VAG-COM Diagnostics Chorley/Preston/Blackburn area
    Workshop Code: 123 12345 000000
    VIN: WAUZZZ4G3DN020936   License Plate: YS12WCL
    Mileage: 211638km-131505mi   Repair Order:
    xpetyax21@gmail.com
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 55 56 5F
              62 72
    VIN: WAUZZZ4G3DN020936   Mileage: 211638km-131505miles
    Address 01: Engine (J623-CLAB)       Labels:. 059-907-401-V2.clb
       Part No SW: 4G0 907 311 E    HW: 4G0 907 401
       Component: 3.0TDI EDC17  H37 0001
       Revision: 53H37---
       Coding: 12034012052401020000
       Shop #: WSC 45009 003 1048576
       ASAM Dataset: EV_ECM30TDI0114G0907311E 001001
       ROD: EV_ECM30TDI0114G0907311E.rod
       VCID: 2541E1F62454BF67F4-8070
    4481 - Cruise Control Switch (E45)
              P0568 00 [032] - Implausible Signal
                        Mileage: 211615 km
                        Date: 2020.01.18
                        Time: 13:01:51
                        Engine speed: 1847.50 /min
                        Normed load value: 14.9 %
                        Vehicle speed: 111 km/h
                        Coolant temperature: 78 °C
                        Intake air temperature: 12 °C
                        Voltage terminal 30: 14.620 V
                        Cruise Control System (CCS): switch position-Bits 0-7: 128
                        Cruise Control System (CCS): status-Bits 0-7: 8
                        Cruise control switch-off: irreversible-Bits 0-7: 255
                        Cruise control switch-off: reversible-Bits 0-7: 14
                        Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
    4483 - Function Restriction due to Faults in Other Modules
              U1113 00 [032] - -
                        Mileage: 211615 km
                        Date: 2020.01.18
                        Time: 13:01:52
                        Engine speed: 1851.00 /min
                        Normed load value: 18.0 %
                        Voltage terminal 30: 14.640 V
                        Cruise Control System (CCS): switch position-Bits 0-7: 192
                        Cruise Control System (CCS): status-Bits 0-7: 200
                        Cruise control switch-off: irreversible-Bits 0-7: 0
                        Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 1
       Part No SW: 4G1 927 155 F    HW: 0AW 927 156 K
       Component: 0AW 30TDI RdW H04 0002
       Revision: --H04---    Serial number: 0000000310
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_TCMVL381 A02428
       ROD: EV_TCMVL381.rod
       VCID: 2F6D03DE76A8F5370E-807A
       Part No SW: 4G0 907 379 H    HW: 4G0 907 379 H
       Component: ESP PREMIUM   H09 0361
       Coding: 07A18701E085E180DB00
       Shop #: WSC 61035 002 1048576
       VCID: 366336BA89F2C4FF4D-8062
    0632 - Tire Pressure Warning
              C102D 00 [008] - -
                        Reset counter: 234
                        Mileage: 211482 km
                        Date: 2020.01.04
                        Time: 02:11:41
                        VzRef: 47
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        F-Path: 01
                        F-Type: 2F
                        Uz: BA
       Part No SW: 4H0 907 064 GB    HW: 4H0 907 064 GB
       Coding: 01B93046000000000000
       VCID: 6FEDC3DEBE28B5374E-803A
       Serial number: 2312000106842015
    Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
       Part No SW: 4G0 820 043 AC    HW: 4G0 820 043 AC
       Component: KLIMA 2 ZONEN H11 0070
       Serial number: 21061200110997
       Coding: 3622000821
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_AirCondiBasisUDS 002040
       VCID: 60CFB0E27BF61A4FC7-8034
    0276 - Engine Off Timer Performance
              P150A 00 [008] - -
                        Reset counter: 233
                        Mileage: 211450 km
                        Date: 2019.12.31
                        Time: 01:18:44
                        Voltage terminal 30: 14.34 V
       Part No SW: 4H0 907 063 CF    HW: 4H0 907 063 F
       Revision: 20012002    Serial number: 00000001529519
       Coding: 2600201040349FE00181008300001D0C0F9DC70827090201000004606100
       VCID: 6ED3DEDAB922BC3F45-803A
       Component: WWS57X 120504  H35 0080
       Serial number:         120523162330
       Coding: 0045F7
       Serial number: 20341094
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
       Component: E1 - LDS  H07 0044
       Serial number: 18 06 2012  00000889
       Component: Humidity_Sens  H02 0002
       Serial number: 04090336000000000001
       Part No SW: 4H0 919 475 AG    HW: 4H0 919 475 AG
       Component: PARKHILFE ACC H01 0072
       Revision: 11001001    Serial number: 61061216400550
       Coding: 88C308
       ASAM Dataset: EV_EPHVA18AU57X0000 003008
       ROD: EV_EPHVA18AU57X0000_003.rod
       VCID: 77FDFBBECE78FDF796-8022
       Revision: --------    Serial number: 003JG0091GN1
       Coding: 30323436313330303537554A305234473053
       Serial number: 3575HRB40571E4S0E8NB
       Serial number: 3585HRB405F1E4S098OG
       Serial number: 3515JRB400C4UEIMAGK6
       Serial number: 3525JRB40184UI5CJ9FP
       Serial number: 3554VRB40064UH26OHF$
       Serial number: 3564VRB40064UH2660TJ
       Revision: 00000000    Serial number: 20120620000359
       Coding: 000035
       VCID: 306F00A26396EACF17-8064
       Component: E221 - MFL  H08 0009
    00895 - Cruise Control Switch (E45)
                        Fault Status: 00101110
                        Reset counter: 235
                        Mileage: 211615 km
                        Date: 2020.01.18
                        Time: 13:01:51
       Part No SW: 4G8 920 983 C    HW: 4G8 920 983 C
       Component: TDieGb        H79 0515
       Revision: 28460207    Serial number: 658140612596028
       Coding: 33A610000B412600010000
       ASAM Dataset: EV_RBD4K 004046
       ROD: EV_RBD4K_AU57.rod
       VCID: 356131B694F4CFE744-8060
       Part No SW: 4G0 907 468 AB    HW: 4G0 907 468 AA
       Component: J533--Gateway H10 0028
       Revision: --------    Serial number: 00000000573774
       Coding: 00CD077D00
       ASAM Dataset: EV_GatewPkoUDS 001013
       VCID: 70EFC0A2AB16AACF57-8024
       Component: J367-BDM  H07 0141
       Serial number: 00000000003790568151
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
       Component: J532_DCDCStab  H23 0021
       Serial number: 010412000000000000CE
       Component: SARA 3D       H02 0053
       Revision: --------    Serial number: EJ1BPA720017AL
       ASAM Dataset: EV_SARA2 005011
       ROD: EV_SARA2.rod
       VCID: 33650FAE9A80D1D76A-8066
       Component: TSG FA        H03 0506
       Coding: 011C16004001620002080002
       VCID: 479D4B7EF6184D7726-8012
       Component: RCEPS         H35 0010
       Revision: 00001000    Serial number: 0023602620
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: 326B0AAA659AD8DF61-8066
       Revision: 00002001    Serial number: 0515491072
       Coding: 013B062220B90000832009040001040F0000000000000000000000000000
       Component: TSG BF        H03 0506
       VCID: 4683467AF112547FDD-8012
       Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
       Component: EPB-4         H03 0013
       Revision: --------    Serial number: 00000000379015
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2B5517CE42B0891722-807E
       Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
       Serial number: 120614-0002-049
       Coding: 112296101000A300
       ROD: EV_HeadlRegulBasic.rod
       VCID: 2C5714D247BE8E2F2B-8078
       Part No SW: 4G0 035 061 E    HW: 4G0 035 061
       Component: Radio U DAB   H60 0099
       Revision: AB001007    Serial number: 109F$0C7567901
       Coding: 010103020100000001
       VCID: 1F4DF31E0E0865B7BE-804A
       Part No SW: 4G0 035 670 H    HW: 4G0 035 670 H
       Component: H-BNT-EU      H49 0526
       Revision: --------    Serial number: 190F%0C7509854
       Coding: 050101010003A1ED05808B3E00000003000001000000000000
       VCID: 285FE8C25B46A20FCF-807C
       Subsystem 1 - Part No: 8R0 060 884 AH
       Component: EUR 2012  1308
       Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
       Component: DU8 C7 SV  H42 0021
       Serial number: AUZ8ZDC9401TY9E
       Subsystem 3 - Part No SW: 4G2 919 610 C    HW: 4G2 919 610 C
       Serial number: 90349LF4000GE
       Subsystem 4 - Part No: 8R0 060 961 C
       Component: CD-Database  3638
       Component: TSG HL        H03 0506
       Coding: 010814004001620002080002
       VCID: 49994D46E00CBB0730-801C
    03681 - Incorrect Signature
                008 - Implausible Signal
                        Fault Status: 01101000
                        Fault Frequency: 62
                        Reset counter: 195
                        Mileage: 211450 km
                        Date: 2019.12.31
                        Time: 01:37:08
       Component: TSG HR        H03 0506
                        Fault Frequency: 62
                        Reset counter: 195
                        Mileage: 211450 km
                        Date: 2019.12.31
                        Time: 01:37:09
    End-------------------------(Elapsed Time: 06:28)--------------------------
    Address 01: DTCs cleared
    Address 03: DTCs cleared
    Address 08: DTCs cleared
    Address 16: DTCs cleared
    Address 62: DTCs cleared
    Address 72: DTCs cleared
    Address 72,4G8 959 795 J,recoded (Long Coding),from,010814004001620002080002,to,010816004001620002080002,(12345/123/00000),
    Address 72,4G8 959 795 J,recoded (Long Coding),from,010816004001620002080002,to,010814004001620002080002,(12345/123/00000),
    Address 46,4H0 907 064 GB,recoded (Long Coding),from,013B062220B90000832009040001040F0000000000000000000000000000,to,013B06A220B90000832009040001040F0000000000000000000000000000,(12345/123/00000),
    Address 46,4H0 907 064 GB,recoded (Long Coding),from,013B06A220B90000832009040001040F0000000000000000000000000000,to,013B06A020B90000832009040001040F0000000000000000000000000000,(12345/123/00000),
    Address 46,4H0 907 064 GB,recoded (Long Coding),from,013B06A020B90000832009040001040F0000000000000000000000000000,to,013B06A220B90000832009040001040F0000000000000000000000000000,
    I don't recall ever having seen the fault code "03681 - Incorrect Signature" before. Not sure what to tell you.
