Results 1 to 9 of 9
Thread: MK4 cluster swap
    Jun 2014
    Canada
    MK4 cluster swap
    Hi, I have a 2003 jetta tdi standard, the customer wants to install a cluster from his parts car a 2005 jetta tdi bew standard as well. The reason he wants this done is because how the cluster looks. There is a current security code but ignore it, is caused by an aftermarket spare key sometimes doesn't read. I have security pin codes from both cars I understand the vin has to be written, coded and program the keys. The wiring diagram looks the same does anyone know if the cluster is compatible with this car.Mario
    Auto-scan and part numbers would be a great start + go to retrofits........
    Why not just swap the face plate?
    Nov 2016
    Give part numbers please for both clusters
    If you know how to use an eeprom reader, i can move the data from old cluster to new cluster for you very simply too, as well as radio code etc so everything will function correctly
    Jun 2014
    Canada
    Sorry i forgot to post auto scan, new cluster # vw1j5920806Q VDO A2C53031735
    Tuesday,07,January,2020,22:08:39:15785
    VCDS Version: 19.6.1.0 (x64)
    VIN: 3VWSP29M93M124983   License Plate: ETHAN   VW
    Mileage: 328910km-204375mi   Repair Order:
    Chassis Type: 9M (9M - VW Jetta IV (1998 > 2014))
              75 76
    VIN: 3VWSP29M93M124983   Mileage: 328910km-204375miles
    Address 01: Engine        Labels: 038-906-012-AGR.clb
       Part No: 038 906 012 GN
       Component: 1,9l R4 EDC G600SG  4308
       Coding: 00002
       Shop #: WSC 93377
       VCID: 62C01712EE72185FEF-4B00
       3VWSP29M93M124983     VWZ7Z0B6209707
                P1570 - 35-10 -  - Intermittent
    Address 03: ABS Brakes        Labels: 1C0-907-37x-ABS.lbl
       Part No: 1C0 907 379 L
       Component: ABS FRONT MK60      0101
       Coding: 0004097
       VCID: 336EA2565108C1D754-513C
       Part No: 1C0 909 605 A
       Component: 1N AIRBAG VW51 02   0006
       Coding: 12622
       Shop #: WSC 00066
       VCID: 22405712AEF2585FAF-5120
       Part No: 1J0 920 806 L
       Component: KOMBI+WEGFAHRSP VDO V64
       Coding: 07332
       Shop #: WSC 88888
       VCID: 3064AD5AF01EFACF29-5120
    01176 - Key
    01304 - Radio
                49-00 - No Communications
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 00066
       VCID: 70E46D5A309EBACF69-5120
    01304 - Radio
       Part No: 1C0 959 799 C
       Component: 1H Komfortgerát HLO 0003
       Coding: 00258
       Shop #: WSC 00066
       VCID: 3776964615702DF768-4B00
       Component: 1H Tőrsteuer.FS KLO 0009
       Component: 1H Tőrsteuer.BF KLO 0009
       Component: 1H Tőrsteuer.HL KLO 0009
       Component: 1H Tőrsteuer.HR KLO 0009
    6 Faults Found:
    01179 - Incorrect Key Programming
                35-00 - -
                27-00 - Implausible Signal
    End-------------------------(Elapsed Time: 05:29)--------------------------
  6. Likes Dana liked this post
    Dallas (McKinney) ,TX ,USA
    Cluster will work ,I have done many of them.
    Use Immobilizer 3 cluster matching procedure and you should be Ok if you have both SKC , from original and form 2005 cluster.
    Immobilizer/ECU
    email : marinmm2001@gmail.com
  8. Likes Jack@European_Parts, Uwe, Dana liked this post
  9. #6
    Black and silver cluster face , Speed , Tach , Temp and fuel gauge scale is not same , it will be off set.
    Immobilizer/ECU
  10. Likes NitrousOxide liked this post
  11. #7
    Maybe Marin but many are swappable in past anything 02.5> should indeed be Immo 3.
    Happy New Year by the way haven't seen you in while.
    I think OP should be more concerned with D2 coil being weak possibly/key issue or consider defeat since an old POS anyway, definitely better than being stuck!
  12. Likes Jetta ,97 liked this post
  13. #8
    Moving to Retrofits.
  14. Likes Jack@European_Parts liked this post
  15. #9
    Jun 2014
    Canada
    All good now, new cluster is working. I took to long and battery died i also put the wrong pin and locked me out had to leave key on for a few minutes. Just google mk4 swap and tons of videos the hard part is getting the pin codes from both clusters. Thank you for your help, new cluster looks much better.Mario
  16. Likes Uwe, Jetta ,97, Dana liked this post
