Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: 2019 Golf R - "Starting Map..."
Hybrid View
    Verified VCDS User psu's Avatar
    Jan 2020
    Pennsylvania, USA
    I was enabling windows w/ remote, driving school mode, disabled seat belt chime and attempted to disable all the screens about "this function not available while vehicle in motion..."
    I noticed today that the map in my MFD is gone.
    Also noticed that this toggle switch is now inactive:
    Any ideas?
    Wednesday,08,January,2020,17:22:26:62459
    VIN: WVWWA7AU6KW165357   License Plate: DA802Z
    Mileage: 819km-508mi   Repair Order:
    Chassis Type: AU-VW37 (3Q0)
    Scan: 01 03 05 08 09 10 13 14 15 17 19 22 29 2B 39 3C 42 44 47 4B
              52 5F 75 A5 A9 D6 D7
    VIN: WVWWA7AU6KW165357   Mileage: 819km-508miles
    29-Left Light -- Status: Malfunction 0010
    2B-Steer. Col. Lock -- Status: Malfunction 0010
    39-Right Light -- Status: Malfunction 0010
    4B-Multifunc. Module -- Status: Malfunction 0010
    A9-Struct. Borne Sound -- Status: Malfunction 0010
    Address 01: Engine (J623-DLRA)       Labels:. 06K-907-425-V1.clb
       Part No SW: 8V0 906 259 Q    HW: 06K 907 425 J
       Component: R4 2.0l TFSI  H13 0002
       Revision: --H13---
       Coding: 091900122446000E3004
       ASAM Dataset: EV_ECM20TFS0208V0906259Q 001003
       ROD: EV_ECM20TFS0208V0906259Q.rod
       VCID: 4EC569D060581AC70BB-801A
    15368 - ROD - Unknown Error Code
              - 00 [032]
                        Mileage: 34 km
                        Date: 2019.11.12
                        Time: 00:47:53
                        Vehicle speed: 255 km/h
                        Coolant temperature: 87 °C
                        Intake air temperature: 32 °C
                        Voltage terminal 30: 8.906 V
                        Unlearning counter according OBD: 10
                        Engine: operating status: ES
                        ECU_STATE: PWL
                        T_AST_SAE: 2849 s
                        T_IGK: 0.00 s
                        N_TOOTH: 0 /min
                        TAA: 8.000 °C
                        FUP_H_SAE: 14580.0 kPa
    17178 - Implausible Data Received from ESP Control Module
              U0416 00 [040] - -
                        Mileage: 34 km
                        Date: 2019.11.12
                        Time: 00:00:26
                        Engine speed: 1289.25 /min
                        Normed load value: 12.2 %
                        Coolant temperature: 7 °C
                        Intake air temperature: 8 °C
                        Voltage terminal 30: 12.089 V
                        Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                        Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                        Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                        Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                        Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                        Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                        Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                        Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                        Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                        Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
       Part No SW: 5Q0 614 517 DS    HW: 5Q0 614 517 BN
       Component: ESC           H35 0108
       Revision: 00000000    Serial number: 60269000000189
       Coding: 01FA6BA150260971457A030560CA6980D60A90A2C0069637344050D4D0A84B0B0000000012121212B835351919323200
       VCID: 055796FCF5AE199FFA1-8050
    0128 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
              [undervoltage]
                        Reset counter: 41
                        Mileage: 34 km
                        Date: 2019.11.11
                        Time: 00:00:05
    0297 - Steering Angle Sensor
              B1168 F2 [008] - Not Initialized
                        Reset counter: 41
                        Mileage: 34 km
                        Date: 2019.11.12
                        Time: 00:00:25
    16401 - Tire Pressure Warning
              C102D 00 [008] - -
                        Reset counter: 42
                        Mileage: 55 km
                        Date: 2019.12.26
                        Time: 13:55:04
    32830 - Parking Brake Motors
              C10E1 29 [008] - Signal Implausible
              [IPB-Actuator: Actuator state UNKNOWN]
                        Reset counter: 41
                        Mileage: 34 km
    32928 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
              [IPB: Supply Voltage below undervoltage threshold]
                        Reset counter: 41
                        Mileage: 34 km
                        Date: 2019.11.12
                        Time: 22:23:44
       Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
       Component: VWKESSYMQB    037 1204
       Revision: 00037000    Serial number: 6097481000
       Coding: 132C0C0623
       VCID: 43D348E4BB1AE7AF945-8016
    65794 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
              [Function restriction due to temp low voltage]
                        Fault Frequency: 43
                        Reset counter: 41
                        Mileage: 35 km
                        Date: 2019.11.07
                        Time: 11:20:00
                        Terminal_15_Kessy_specified_value: On
                        Terminal_15_Kessy_actual_value: On
                        Terminal_15_central electric_actual_value: On
                        Terminal_15red_Kessy_specified_value: On
                        Terminal_15red_Kessy_actual_value: On
                        Terminal_S_Kessy_specified_value: On
                        Terminal_S_Kessy_actual_value: On
                        Terminal_S_central electric_actual_value: On
                        Terminal_50_Kessy_specified_value: On
                        Terminal_50_Kessy_actual_value: On
                        ZAT_pressed: On
                        Park selector lever position: Not engaged and not locked
                        Enabling immobilizer: Condition met
                        Control Module Voltage: 7.190 V
                        Vehicle speed: 0.0 km/h
                        Engine speed: 0.0 /min
                        Status of vehicle locking: Vehicle unlocked
                        Coding information: coded
                        Coding information: Not coded
                        Driver door: closed
                        Front Passenger Door: closed
                        Left rear door: closed
                        Right rear door: closed
                        Active_LF_scans: Init
                        ID sensor 1 authentication: status: No response
                        ID sensor 2 authentication: status: No response
                        ID sensor 3 authentication: status: No response
                        ID sensor 4 authentication: status: No response
                        SPN_Byte 0: 00
                        SPN_Byte 1: 00
                        SPN_Byte 2: 00
    65813 - Supply voltage
              [Error Kessy Supply voltage too low]
                        Reset counter: 41
                        Mileage: 34 km
                        Date: 2019.11.11
                        Time: 00:01:29
                        ZAT_pressed: OFF
                        Enabling immobilizer: Condition not met
                        Control Module Voltage: 6.732 V
                        Driver door: closed
                        SPN_Byte 0: 00
                        SPN_Byte 1: 00
                        SPN_Byte 2: 00
       Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
       Revision: 00001K08
       Coding: 0002000420010000010500401211140A
       VCID: 6D87CE5CCD1EC1DF121-8038
       Air quality sensor:
              B10CD 00 [008] - -
                        Fault Frequency: 9
                        Reset counter: 41
                        Mileage: 35 km
                        Date: 2019.11.03
                        Time: 23:26:50
                        Voltage terminal 30: 10.9 V
                        CAN input signal(s) status-Back-up light: OFF
       Part No SW: 5Q0 937 085 BS    HW: 5Q0 937 085 BF
       Component: BCM MQBAB MNA H38 0273
       Serial number: 00001908300182
       ASAM Dataset: EV_BCMMQB 019001
       ROD: EV_BCMBOSCH_019_VW37.rod
       VCID: 0B43A0C4D3CA6FEFAC5-805E
       Component: WWS    190220  043 0551
       Serial number:         190307012831
       Component: RLHS  052 0107
       Serial number: SBY19M03D20H23M27S34
       Coding: 00A8DD
       Steering Column Switch:
       Subsystem 3 - Part No SW: 5Q1 953 507 M    HW: 5Q1 953 549
       Component: J527 SMLS MQB  004 0060
       Serial number: 00000013031904220145
    131330 - Supply voltage
              [Versorgungsspannung - unterer Grenzwert unterschritten >]
                        Reset counter: 41
                        Time: 00:00:00
    131586 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
              [Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten >]
                        Reset counter: 41
                        Mileage: 34 km
                        Date: 2019.11.12
                        Time: 00:02:30
    796961 - Steering Column Control Module
              B105D F1 [008] - Function Restricted to to Under-Voltage
              [Schaltermodul Lenksäule (SMLS)->FUNKTIONSEINSCHRÄNKUNG durch Unterspannung]
                        Reset counter: 41
                        Mileage: 34 km
                        Date: 2019.11.11
                        Time: 00:00:04
       Part No SW: 5QA 919 294 C    HW: 5QA 919 294
       Component: PDC 8 KanalH07 0050
       Serial number: 000308418019085
       Coding: 0471155801
       ASAM Dataset: EV_EPHVA18AU3700000 009039
       VCID: 4CC163D8964428D765F-8018
    13635840 - Supply voltage
              [Versorgungsspannung - zu niedrig]
                        Reset counter: 41
                        Mileage: 34 km
                        Date: 2019.11.11
                        Time: 00:01:16
              U1400 00 [008] - -
              [Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten]
                        Reset counter: 41
                        Time: 00:00:00
    13637426 - Databus
                        Reset counter: 41
                        Mileage: 34 km
                        Date: 2019.11.12
                        Time: 00:00:25
    13637120 - Databus
              [Parkbremse - EPB_01.EPB_Status - Fehlerspeicher auslesen]
                        Reset counter: 41
                        Mileage: 34 km
                        Date: 2019.11.12
                        Time: 00:04:41
       Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
       Coding: 2B0000C159FFC728949C810560401600000000000000000004
       VCID: 44D14BF8BE14E097ADF-8010
    9 Faults Found:
    2055 - Databus
              [FAULT_ALP_STEERINGWHEEL_INIT]
                        Reset counter: 41
                        Mileage: 34 km
                        Date: 2019.11.12
                        Time: 00:00:26
                        Control Module temperature: 7 °C
                        Voltage terminal 15: 11.9 V
    0803 - Databus
              [FAULT_BV1_FEHLER]
                        Reset counter: 41
                        Mileage: 34 km
                        Date: 2019.11.12
                        Time: 00:00:26
                        Voltage terminal 15: 12.0 V
    2086 - Databus
              [FAULT_EPB_ACTUATOR_FAIL]
                        Reset counter: 41
                        Mileage: 34 km
                        Date: 2019.11.12
                        Time: 00:04:42
                        Control Module temperature: 19 °C
                        Voltage terminal 15: 11.5 V
    2101 - Databus
              [FAULT_ESP_STATUS_SYSTEM]
                        Reset counter: 41
                        Mileage: 34 km
                        Date: 2019.11.12
                        Time: 00:00:25
    1091 - Databus
              [FAULT_TIMEOUT_ESP_20]
                        Reset counter: 41
                        Mileage: 34 km
                        Date: 2019.11.11
                        Time: 00:00:11
                        Control Module temperature: 22 °C
    1074 - Databus
              [FAULT_TIMEOUT_ESP_33]
                        Reset counter: 41
                        Mileage: 34 km
                        Date: 2019.11.11
                        Time: 00:00:11
                        Voltage terminal 15: 11.4 V
    2068 - Databus
              [FAULT_TSK_IRREV_FAIL]
                        Reset counter: 41
                        Mileage: 34 km
                        Date: 2019.11.12
                        Time: 00:00:26
                        Voltage terminal 15: 12.1 V
    1391 - Function Restricted due to Excessive Voltage
              U1401 00 [008] - -
              [FAULT_VBAT_BUSMON_HIGH]
                        Reset counter: 41
                        Mileage: 34 km
                        Date: 2019.11.12
                        Time: 00:03:55
                        Control Module temperature: 14 °C
                        Voltage terminal 15: 17.9 V
                        Velocity_vehicle_reference: -0.40 m/s
                        Longitudinal_acceleration_vehicle_reference: -2.43 m/s²
    1387 - Supply voltage
              [FAULT_VBAT_LOW]
                        Reset counter: 41
                        Mileage: 34 km
                        Date: 2019.11.11
                        Time: 00:01:29
                        Control Module temperature: 20 °C
                        Voltage terminal 15: 6.6 V
                        Status_ACC_System: ACC_Init
       Serial number: 13031941351533
       ROD: EV_DRCONTITEMIC_VW37.rod
       VCID: 38292F08F2DCB477317-806C
       Serial number: 003GCR0BFTC$
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 47CB5CF48F22CB8F48D-8012
       Occupant Detection:
       Serial number: IBH00000000000B51X2C
       Coding: 303344
       Subsystem 2 - Part No SW: -----------    HW: 480 002 103 19
       Serial number: 357000000009E9DC7A36
       Subsystem 3 - Part No SW: -----------    HW: 480 002 103 19
       Serial number: 358000000006DB754A3W
       Subsystem 4 - Part No SW: -----------    HW: 480 402 303 19
       Component: SideSensor_Dr  005 6149
       Serial number: 3510001A6EEFCE08499$
       Subsystem 5 - Part No SW: -----------    HW: 480 402 303 19
       Component: SideSensor_Pr  005 6149
       Serial number: 3520001C4EEE84E86B3.
       Subsystem 6 - Part No SW: -----------    HW: 480 402 603 19
       Component: FrontSensor_D  005 6149
       Serial number: 3550001A8EEE84E92AA2
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 402 603 19
       Component: FrontSensor_P  005 6149
       Serial number: 3560001A6EEE84E68A2$
    9483264 - Seat Occupied Recognition
              B10B4 00 [008] - Function Restriction due to Undervoltage
              [Bladder Mat: functional restriction because of low voltage]
                        Reset counter: 41
                        Mileage: 34 km
                        Date: 2019.11.11
                        Time: 00:01:33
       Part No SW: 5G1 920 891 B    HW: 5G1 920 891 B
       Component: KOMBI         403 4191
       Coding: 0BAD40127F88CF0502887F0B5401000080000000
       VCID: 2C010358368408D745F-8078
              [Versorgungsspannung - unterer Grenzwert unterschritten Versorgungsspannung Spannung dauerhaft zu niedrig]
                        Reset counter: 41
                        Time: 00:00:00
    16776988 - Databus
              [TSK_07 keine Kommunikation]
                        Reset counter: 41
                        Mileage: 34 km
                        Date: 2019.11.11
                        Time: 00:00:00
       Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
       Component: GW MQB High   442 4368
       Revision: --------    Serial number: 0009355191
       Coding: 0101000838085900FB00823A880F00000001070000000000000000000000
       ROD: EV_GatewNF.rod
       VCID: 6E85C950C0183AC72BB-803A
       Component: 0-00-00-00-00
       Subsystem 2 - Part No SW: 5G0 959 442 AE    HW: 5G0 959 442 AE  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H11 0052
       Serial number: 29190000416750069084
       Coding: 2CFFFF
    1282 - Supply voltage
              [Versorgungsspannung - unterer Grenzwert unterschritten]
    May 2014
    psu: Hi. wow - that's an interesting effect!!
    First, please post-up a current, unedited copy of an auto-scan for the car
    Second, I'm not sure if you are aware, but VCDS keeps a record of every change that you make with your dongle/cable device. Assuming that you use the release version of VCDS (i.e. not the Beta version), go to the c:\Ross-Tech\VCDS\Debug directory on the laptop that you use and there should be AdpLog.CSV and CodingLog.CSV files in this directory (ignore the Readme.TXT. file - it's proof that Uwe has a sense of humor! )
    May I invite that you open both of these files and study the records. Confirm in particular that the changes that you intended to make in your tweaks are actually the changes that were made. The records show the previous values - so revert any modifications that were made in error.
    EDIT: hmm...... thanks for posting the scan report. Looks like a "dubie" battery (local term - meaning "dubious" battery) in the auto-scan! Please charge battery, clear DTC s and re-post. Also incomplete scan - so can't see the hex5F module
  3. Likes psu, Dana liked this post
    Jan 2020
    Pennsylvania, USA
    Second, I'm not sure if you are aware, but VCDS keeps a record of every change that you make with your dongle/cable device. Assuming that you use the release version of VCDS (i.e. not the Beta version), go to the c:\Ross-Tech\VCDS\Debbug directory on the laptop that you use and there should be AdpLog.CSV and CodingLog.CSV files in this directory (ignore the Readme.TXT. file - it's proof that Uwe has a sense of humor! )
    Appreciate the very quick reply, sir.
    From another thread, I messed with a few settings:
    17 Adaptations
    Display Depiction - Change to Version 1
    5F Byte 22 - Bit 0 unchecked.
    When I went back out to do the auto scan, it was working! Crisis averted for now.
    In my auto scan, I'm seeing a lot of error messages. Is that normal?
    Thanks for the tip on the c:\Ross-Tech\VCDS\Debbug as well.
    I just read about that in another thread... so much to learn.
    May 2014
    Quote Originally Posted by psu View Post
    "sir"? I don't often get called "sir" and on the few times when I do, it's normally spelled "cur" - but thanks for the salutation!!
    17 Adaptations
    well done!!
    As I said in my EDIT - the "dubie" battery is causing lots of DTC s. Recharge, clear errors and re-post COMPLETE auto-scan
    so much to learn.
    Indeed - lot's of fun and joy for boys and girls !!
  6. Likes psu liked this post
    Jan 2020
    Pennsylvania, USA
    Too funny!
    Pardon my ignorance, what the heck is a dubie battery?! LOL.
    Feb 2018
    SLC
    psu: see below
    Dubious: not to be relied upon; suspect.
    6V is really bloody low for that poor battery
    If you are curious about the MK100 ABS controller's Bits and Bytes >>MK100 ABS Coding (Google Drive)<< NOT 100% ACCURATE, INFORMATION ONLY
  9. Likes DV52, psu, Dana liked this post
  10. #7
    Early to mid November of last year, when the car had around 34-35 km on the odometer, the battery was allowed to go hideously flat. Even if it's working OK now, I would guess that took years off its life. I suppose this happened before psu actually took delivery of the car? And that his selling dealer is yet another one who didn't do a proper pre-delivery inspection? There's a lot of that going around. Dealers seem to have no shame anymore.
    I think it would be useful if psu would post a complete scan, preferably one that was done after the mess of fault codes from November had been cleared and the ignition had been cycled.
  11. Likes psu, PetrolDave, Eric, Dana liked this post
  12. #8
    Jan 2020
    Pennsylvania, USA
    Quote Originally Posted by Somnus View Post
    psu: see below
    Doh! Been a long day for me I guess! LOL.
    Whew.. that's a bit unnerving to read.
    As I've said 100 times, I'm still learning all this but after reading your response, I went back and looked at the coding and put two and two together.
    I took delivery 12/26 and I see my TPMS light was logged as well. It popped on as I was getting home.
    So where do I go from here? Charge the battery and start clearing codes?
  13. #9
    Definitely.
  14. Likes Uwe, psu liked this post
  15. #10
    May 2014
    psu: Isn't it amazing what a complete story Uwe can create from a simple (and incomplete) auto-scan? I'm pea-green with envy- I hope one day to be able to see these patterns.
    Anyhow, hagiography notwithstanding - I'd like to invite that you consider an alternative way forward given the state of your dubie battery and it's checkered history as recounted in Uwe's tale of woe.
    If you look at your question as a simple risk management problem, it would not be unreasonable to deduce that your dubie battery is likely to have been seriously compromised at the hands of unscrupulous (or at the very least, woefully ignorant) battery torturers! How much battery health remains is an unknown - but this piece of kit is fairly important to the car's running.
    So - back to the underlying risk management decision: do you want to economize and extract the remaining life from the tortured battery - or do you want to get rid of the entire question of how unreliable the tortured battery might be?
    Personally, I favor the latter approach - life's too short to be stuck in the middle of nowhere with a dead battery. Buy a newie - I suggest and consider the subsequent cost to be a long term saving!!
