Results 1 to 7 of 7
Thread: 14 CC new trunk harness cold weather problem
    Oct 2016
    Minnesota USA
    Hello everyone
    Broken trunk harness. I replaced the trunk harness with the factory part.
    Everything works now, but if the car is parked outside overnight in MN cold I have problems:
    select reverse: camera pops out of the VW logo.
    deselect reverse: camera display goes away, camera does not tuck itself away and often the trunk will pop open. This has only happened when the car is parked overnight in the cold. It usually sleeps in a garage.
    This car did not come from the factory with a backup camera. I installed the VW upgrade. I have checked the trunk ground post- all contacts seem to be tight.
    Any thoughts would be helpful.
    Saturday,04,January,2020,12:30:53:63181
    VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4513.4
    VIN: WVWAN7AN7EE517766   License Plate:
    Mileage: 132980km-82629mi   Repair Order:
                    Address 46: Central Conv.       Labels: 3C0-959-433-46.clb
    Control Module Part Number: 3AA 959 433 C    HW: 3AA 959 433 C
      Component and/or Version:    KSG PQ47 ELV 042 0645
               Software Coding: 1B910F8001862E521204141FF08A0F0E107C02
                Work Shop Code: WSC 13752 002 1048576
               Additional Info: 1K0951605C  LIN BACKUP HORN H05 1501                     NGS n.mounted
               Additional Info:                  IRUE n.mounted
                          VCID: B93AA563F0AFDF8720-80EC
    00893 - Switch for Trunk Handle (E234)
                        Fault Status: 00100111
                        Reset counter: 211
                        Mileage: 132850 km
                        Date: 2014.05.26
                        Time: 12:55:18
    16.4905 S, 151.7375 W
    I wonder if you could have some luck with a 'cold weather' spray lubricant, maybe a light silicon spray.
    Something that can displace any moisture and prevent freezing.
    Let us know how this works out for you...
    drpeter
    Was there a safety recall for harness + connectors and revised camera at NHTSA on this?
  5. Likes DrPeter liked this post
    Volkswagen - Recall / Service Campaign Lookup - Says no, however this vehicle did not come with the camera, so ???
    Maybe worth a call to VW Customer Care?
    drpeter
  7. Likes Jack@European_Parts liked this post
  8. #5
    YES!
  9. Likes DrPeter liked this post
  10. #6
    Oct 2016
    Minnesota USA
    Thanks for the info! I will reach out to VW regarding a potential recall.
    Camera/Rear latch switch part number: 5K0-827-469-AS
    Harness part number: 3C8-971-182-G
    This evening I took a bit of sandpaper to the contacts, removed the little white "ground cable organizer." Ground connection is definitely solid now.. We will see.
  11. #7
