Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Interface not found
    Unverified
    Dec 2019
    Australia
    Interface not found
    Hi all, I have a HEX+CAN cable which I have used and has been working fine in the past. Windows 10 has since installed updates and and now with a fresh VCDS install when being tested the LED flashes green and red for a while then it comes up with an error message "interface not found".
    I have tried on a brand new laptop with freshly installed Windows 10 Pro, updates disabled, Windows device guard disabled and a fresh VCDS install and it still comes up with the same error. I have searched the forum and the internet for another solution but can't find anything else that helps.
    In device manager it shows as Ross-Tech Direct USB interface and says it is working properly - screenshots below.
    Anyone have any ideas how to fix this? Is there an updated driver or a different driver I could try?
    VCDS Distributor AIB Wolfgang's Avatar
    Sep 2014
    Hello
    As the user manual discribes........
    Please connect your interface with the car and restart the "TEST"
    -Wolfgang
    Drive more talk less
    Please post a photo of the HEX+CAN interface you are using.
    Unverified
    Dec 2019
    Australia
    I have tried it with a motorbike connected and it gave the same error, but that bike potentially has some electrical issues.
    I will try tonight with it connected to a different vehicle and will post up some pics of the interface as well.
    Unverified
    Dec 2019
    Australia
    Ok, I have tried with a different car now and it still doesn't work.
    Pictures of interface:
    Heading for the HoS?
  7. Likes Mike@Gendan, _Val, Uwe liked this post
    Jun 2014
    Swansea, UK
    No serial number, and a VCDS version number listed on the interface?
    Absolutely, most 100% definitely a cloned interface, without a shadow of a doubt.
    The odd thing is the OP is a Verified user, so at some point they must have had a genuine interface.
  9. Likes PetrolDave, keith@gendan liked this post
  10. #8
    Unverified
    Dec 2019
    Australia
    I am pretty sure I bought the interface off here? It is the only interface I have and I verified my account using that interface.
  11. #9
    Did it come with a CD with the English 12.12 VCDS version on it?
  12. #10
    Jun 2014
    Swansea, UK
    Quote Originally Posted by edmands_3 View Post
    The interface in the pictures is 100% not one sourced from Ross-Tech.
    - Ross-Tech never put a software version number on the interface as their interfaces work with the latest version
    - All genuine interfaces from the HUC onwards have a printed serial number on the label
    - Ross-Tech don't use black screws
  13. Likes Uwe liked this post
