Results 1 to 10 of 18
Thread: Cant get ac sytem to charge (compressor wont kick on)
    Sep 2018
    I have a 2015 Audi S3 8v with 43k miles on it, about 3 weeks ago I replaced the engine on the car, I did the work, pulled the bad motor out through the front and replace the engine. When I removed the engine I set the ac compressor off to the side and disconnected lines at the condenser so I could pull the core out as a whole, I unhooked the the wiring harness and from the block itself instead of just unplugging it from the ecu, I did it like that only because I have aftermarket MPI installed and didnt want to unhook all those wires. A/c worked fine prior to engine removal, put the good motor in and hooked up all the wiring and now I cant get the a/c to charge, compressor wont kick on when trying to fill, I vac the system down. I get 2 codes, 1 for high pressure sensor no signal and ac first run in. Need your help. Sorry I forgot how to add scan Ill have to go back and fix
    Tuesday,07,January,2020,10:14:18:30521
    VCDS Version: 19.6.2.0 (x64)
    Chassis Type: FF-AU37 (5Q0)
    Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 3C 42 44 47 52 55
              5F 6C A9 BB BC
    VIN: WAUFFGFFXF1077035   Mileage: 71990km-44732miles
    A9-Struct. Borne Sound -- Status: Cannot be reached 0100
    Address 01: Engine (J623-CYFB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 8V0 906 259 K    HW: 06K 907 425 E
       Component: 2.0l R4 TFSI  H13 0602
       Revision: --H13---
       Coding: 0A1D00322426000E3000
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_ECM20TFS0208V0906259K 001003
       ROD: EV_ECM20TFS0208V0906259K.rod
       VCID: 489F1C7BF3C4C20F2F-801C
       Part No SW: 0D9 300 012     HW: 02E 927 770 AQ
       Component: DQ250-6A MQB  H53 4903
       Revision: 03253104    Serial number: TFK01409241359
       Shop #: WSC 04742 780 00200
       ROD: EV_TCMDQ250021.rod
       VCID: 53A53B173A8271D74A-8006
              P1734 00 [002] - -
       Part No SW: 3Q0 907 379 Q    HW: 3Q0 907 379 F
       Component: ESC           H42 0610
       Revision: 00000000    Serial number: 62734000003093
       Coding: 31FF6B9254270A730177030341C8698CD62A5080C08296B6024100D88207
       Revision: 00021000    Serial number: 0349814246
       Coding: 030C0C
       VCID: 3A7B76B3BD28A09FA9-806E
       Component: AC Automat    H13 0052
       Revision: 20026000    Serial number: 00000000470162
       VCID: 33655B979A4251D76A-8066
       Serial number: FA988357000000000001
    262658 - High Pressure Sensor
              B10AE 31 [009] - No Signal
                        Reset counter: 219
                        Mileage: 71990 km
                        Date: 2020.01.07
                        Time: 09:59:14
                        Outside air temperature: 20.5 °C
                        Engine speed: 766.00 /min
                        Temperature after evaporator: 24.9 °C
    524545 - AC Compressor First Run-In
              B109E F0 [009] - Not Performed
                        Reset counter: 219
                        Mileage: 71990 km
                        Date: 2020.01.07
                        Time: 09:59:13
       Part No SW: 5Q0 937 085 AC    HW: 5Q0 937 085 AC
       Component: BCM MQBAB HNA H18 0137
       Serial number: 01011428800483
       Coding: 04151C46C04106FD41C04004511807A00800000000000000000000000000
       ROD: EV_BCMBOSCH_013.rod
       VCID: 7AFBB6B3FDA8609FE9-802E
       Component: WWS371 141004  042 0585
       Serial number:         141021125002
       Coding: 0A47F7
       Serial number: 23336452
       Coding: 00006C
       Subsystem 3 - Part No SW: 8V0 941 531 AA    HW: 8V0 941 531 AA
       Serial number: 08 08 2014  00001063
       Serial number: 00000000000060812115
       Sun Roof:
       Component: J245 PS73.404  H02 0003
       Serial number: 0000FST0000754G00000
       Coding: 101F00
       Part No SW: 5Q0 919 294 J    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0051
       Revision: --------    Serial number: 39331428205581
       Coding: 0030150011
       VCID: 428B0E53D5F8E85FF1-8016
    Address 14: Susp. Elect. (J250)       Labels: 8V0-907-376.clb
       Part No SW: 8V0 907 376 C    HW: 8V0 907 376 C
       Component: DAEMPFUNGS-SG H08 0066
       Serial number:       220914038
       ROD: EV_AudiMagneRide.rod
       VCID: 4189015FD0FEF347E8-8014
       Serial number: 003GCR00VDBR
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 479D1F47FEDACD7726-8012
       Belt Pretensioner left:
       Serial number: 34178311B22101440278
       Coding: 333135
       Belt Pretensioner right:
       Serial number: 34178312B22101470632
       Coding: 333135
       Occupant Detection:
       Serial number: 6940000Y1400018PTT0L
       Coding: 303230
       Subsystem 4 - Part No SW: -----------    HW: 480 002 310 14
       Serial number: 357000000005C289611G
       Subsystem 5 - Part No SW: -----------    HW: 480 002 310 14
       Serial number: 35800000000613896118
       Subsystem 6 - Part No SW: -----------    HW: 480 401 610 14
       Serial number: 3510002C918166B572C5
       Subsystem 7 - Part No SW: -----------    HW: 480 401 610 14
       Serial number: 3520002C718166B2B12.
       Subsystem 8 - Part No SW: -----------    HW: 480 400 109 14
       Serial number: 3550002B5175A8E081ED
       Front Sensor Passenger:
       Subsystem 9 - Part No SW: -----------    HW: 480 400 109 14
       Serial number: 3560002B5175A8E2D1FM
       Part No SW: 8V0 953 521 CP    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 18101404400027
       Coding: A018
       VCID: 0A1BE673AD48701FF9-805E
       Part No SW: 8V0 920 970 S    HW: 8V0 920 970 S
       Coding: 0BED181B3B8857050201EA001800000000000000
       VCID: 4C97206BE7BC2E2F0B-8018
       Revision: --------    Serial number: 01101410802775
       Coding: 0101000830085A005B00022C980B00000001010000000000000000000000
       ROD: EV_GatewConti_011.rod
       VCID: 72EB9E93A5D818DFA1-8026
       Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
       Serial number: 17 10 2014  C0047695
    131612 - No Communications with Actuator for Structural Accoustics
              U10DF 00 [009] - -
                        Fault Frequency: 40
                        Reset counter: 218
                        Mileage: 71663 km
                        Date: 2019.12.26
                        Time: 17:22:54
                        Terminal 15: On
       Part No SW: 0CQ 907 554 D    HW: 0CQ 907 554 D
       Serial number: HA1-00004.09.14
       Coding: 0001
       VCID: 46831243F9D0D47FDD-8012
       Revision: 00000000    Serial number: 14000292251003
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 3467588B9F4C56EF73-8060
       Part No SW: 5Q0 907 566 A    HW: 8T0 907 566 B
       Serial number: 0348367775
       Coding: 030211
       VCID: 387F6CBB8324B28F5F-806C
       Subsystem 1 - Part No SW: 5Q0 907 568 A    HW: 8T0 907 568 B
       Component: SWA Slave  H05 0071
       Serial number: 0348774456
       Coding: 030211
       Serial number: 14101402090927
       Coding: 005D1F205C00048000000002
       VCID: 408F045BDBF4FA4FE7-8014
       Coding: 8102
       VCID: 377D6F878E3ABDF756-8062
       Part No SW: 8V0 035 465 C    HW: 8V0 035 465
       Component: MIBAMP1ALPINE H11 0410
       Serial number: AUZ8ZAEN900SSR%
       Coding: 01030300AAAA2AAA01
       Serial number: 14101403111564
       Coding: 005D17205E00048000000002
       VCID: 3F8D07A7A60A85B79E-806A
       Component: AFS-ECU       H01 0091
       Coding: 012200003F200400
       Coding: E00100
       Coding: E00100
       Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
       Coding: E00100
       Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
       Coding: E00100
       Part No SW: 8V0 035 038 B    HW: 8V0 035 038 B
       Component: MU-H-LNS-US   H43 0394
       Serial number: A302J0EB005348
       Coding: 017301020000000021220002041A00102F000225010001043E
       ROD: EV_MUHig6C3HBAS_AU37.rod
       Subsystem 1 - Part No SW: V03 959 800 SS    HW: -----------
       Component: NAR 2015  --- 0035
       Component: DU High  H49 0013
       Serial number: AUZ8Z9EY201YBT
       Multimedia Operating Unit:
       Serial number: C1000002091400030299
       Component: Gracenote  --- 3006
       Coding: 027300010201000300
       ROD: EV_2CamSysRearPASE.rod
       VCID: 306F549B6B546ACF17-8064
    Address A9: Struct. Borne Sound
       Part No SW: 5Q0 959 395 B    HW: 5Q0 959 395 B
       Component: TSG HFS       020 0025
       Serial number: 15101406071203
       Coding: 004D17204000048000000002
       Component: TSG HBFS      020 0025
       Serial number: 15101406071201
    End-------------------------(Elapsed Time: 05:30)--------------------------
    I would start by fixing whatever is causing the "High Pressure Sensor -- No Signal" fault.
    Sep 2018
    Ya I'm trying to figure that out, when you push the ac button on on the control, the light wont stay on, as soon as you release the button the light goes off, if I remember right the sensor plug is only hot when ac (botton) is on
    Do you have the RTFB OP?
    Isn't refrigerant required to be installed first in order to engage the PSI sensor ( AS FIRST RUN IN ) & as a GAS on high side and if it isn't, is it possible you contaminated system or the PSI sensor failed as a result & being reported on LIN?
    TSB #A871679 2041717 NHTSA ID #10130183
    Summary: This bulletin applies to any repair that requires replacement of the air conditioning compressor and details how to run a ODIS GFF test plan.
    http://wiki.ross-tech.com/wiki/index.php/Main_Page
    Sep 2018
    Anything is possible, when I opened the system up I plugged the ports immediately,.although yes the system was open and air was introduced, when I put the cat back together I pulled a good vacuum for a good amount of time and let it sit and the vacuum held, I hooked my gauges up and hooked up to my r134a tank, started the car and push the ac to on, but light goes right out, generally once you start introducing refrigerant the system starts cycling, it took 4oz and stopped since compression never kicked on the system equalized. I always fill on the low side. Guess there could be a chance some how the sensor fail in the few weeks the car sat while I was getting the other motor ready for install. I have voltage at the sensor so I'll order a new sensor and try that. I always only charge on the low side
  6. #6
    Did you try charging from high side yet as a GAS?
    What's RTFB say?
  7. #7
    HQ
    The "High Pressure Sensor", the G805.... locate it and unplug it. *editing out my dumb@$$ mistake*
    OK, now that I'm on my court ordered medication, lets try this again:
    /1 is ground
    /2 is data
    /3 is power
    You are going to need the factory repair manual for your vehicle. If you haven't done so already, purchase access to ERWIN, run your VIN and then print to PDF everything to do with your car.
    Jef
  8. Likes Jack@European_Parts, PetrolDave, Uwe liked this post
  9. #8
    Sep 2018
    on my plug it appears that 1 and 3 are (ground) and 2 is power, i have 11.8v between 1&2 and 11.8 between 3&2, my test light dont light up when touched to those, test light will light when tested on battery, I do have a manual and am in the process of going through it
  10. #9
    I believe if you RTFB the procedure it will become clear quickly.
  11. #10
    HQ
    Quote Originally Posted by Railroader View Post
    I've corrected my stupid mistake, see above.... /3 should be a power, comes off a fuse SC34. Now if in fact /3 is direct path to ground... well, that will be an issue.
    Jef
  12. Likes Jack@European_Parts, Uwe liked this post
