I have a 2015 Audi S3 8v with 43k miles on it, about 3 weeks ago I replaced the engine on the car, I did the work, pulled the bad motor out through the front and replace the engine. When I removed the engine I set the ac compressor off to the side and disconnected lines at the condenser so I could pull the core out as a whole, I unhooked the the wiring harness and from the block itself instead of just unplugging it from the ecu, I did it like that only because I have aftermarket MPI installed and didnt want to unhook all those wires. A/c worked fine prior to engine removal, put the good motor in and hooked up all the wiring and now I cant get the a/c to charge, compressor wont kick on when trying to fill, I vac the system down. I get 2 codes, 1 for high pressure sensor no signal and ac first run in. Need your help. Sorry I forgot how to add scan Ill have to go back and fix
Tuesday,07,January,2020,10:14:18:30521
VCDS Version: 19.6.2.0 (x64)
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 3C 42 44 47 52 55
5F 6C A9 BB BC
VIN: WAUFFGFFXF1077035 Mileage: 71990km-44732miles
A9-Struct. Borne Sound -- Status: Cannot be reached 0100
Address 01: Engine (J623-CYFB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 259 K HW: 06K 907 425 E
Component: 2.0l R4 TFSI H13 0602
Revision: --H13---
Coding: 0A1D00322426000E3000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0208V0906259K 001003
ROD: EV_ECM20TFS0208V0906259K.rod
VCID: 489F1C7BF3C4C20F2F-801C
Part No SW: 0D9 300 012 HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4903
Revision: 03253104 Serial number: TFK01409241359
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 53A53B173A8271D74A-8006
P1734 00 [002] - -
Part No SW: 3Q0 907 379 Q HW: 3Q0 907 379 F
Component: ESC H42 0610
Revision: 00000000 Serial number: 62734000003093
Coding: 31FF6B9254270A730177030341C8698CD62A5080C08296B6024100D88207
Revision: 00021000 Serial number: 0349814246
Coding: 030C0C
VCID: 3A7B76B3BD28A09FA9-806E
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0052
Revision: 20026000 Serial number: 00000000470162
VCID: 33655B979A4251D76A-8066
Serial number: FA988357000000000001
262658 - High Pressure Sensor
B10AE 31 [009] - No Signal
Reset counter: 219
Mileage: 71990 km
Date: 2020.01.07
Time: 09:59:14
Outside air temperature: 20.5 °C
Engine speed: 766.00 /min
Temperature after evaporator: 24.9 °C
524545 - AC Compressor First Run-In
B109E F0 [009] - Not Performed
Reset counter: 219
Mileage: 71990 km
Date: 2020.01.07
Time: 09:59:13
Part No SW: 5Q0 937 085 AC HW: 5Q0 937 085 AC
Component: BCM MQBAB HNA H18 0137
Serial number: 01011428800483
Coding: 04151C46C04106FD41C04004511807A00800000000000000000000000000
ROD: EV_BCMBOSCH_013.rod
VCID: 7AFBB6B3FDA8609FE9-802E
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 141004 042 0585
Serial number: 141021125002
Coding: 0A47F7
Component: G397_RLFS H06 0002
Serial number: 23336452
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
Serial number: 08 08 2014 00001063
Serial number: 00000000000060812115
Sun Roof:
Component: J245 PS73.404 H02 0003
Serial number: 0000FST0000754G00000
Coding: 101F00
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 J HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0051
Revision: -------- Serial number: 39331428205581
Coding: 0030150011
VCID: 428B0E53D5F8E85FF1-8016
Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
Part No SW: 8V0 907 376 C HW: 8V0 907 376 C
Component: DAEMPFUNGS-SG H08 0066
Serial number: 220914038
ROD: EV_AudiMagneRide.rod
VCID: 4189015FD0FEF347E8-8014
Component: AirbagVW20 009 0825
Serial number: 003GCR00VDBR
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 479D1F47FEDACD7726-8012
Belt Pretensioner left:
Component: BeltPretRevFL H36 0350
Serial number: 34178311B22101440278
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H36 0350
Serial number: 34178312B22101470632
Coding: 333135
Occupant Detection:
Serial number: 6940000Y1400018PTT0L
Coding: 303230
Subsystem 4 - Part No SW: ----------- HW: 480 002 310 14
Serial number: 357000000005C289611G
Subsystem 5 - Part No SW: ----------- HW: 480 002 310 14
Serial number: 35800000000613896118
Subsystem 6 - Part No SW: ----------- HW: 480 401 610 14
Serial number: 3510002C918166B572C5
Subsystem 7 - Part No SW: ----------- HW: 480 401 610 14
Serial number: 3520002C718166B2B12.
Subsystem 8 - Part No SW: ----------- HW: 480 400 109 14
Serial number: 3550002B5175A8E081ED
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 480 400 109 14
Serial number: 3560002B5175A8E2D1FM
Address 16: Steering wheel (J527) Labels:. 5Q0-953-549.clb
Part No SW: 8V0 953 521 CP HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 18101404400027
Coding: A018
VCID: 0A1BE673AD48701FF9-805E
Part No SW: 8V0 920 970 S HW: 8V0 920 970 S
Component: KOMBI H02 4291
Coding: 0BED181B3B8857050201EA001800000000000000
VCID: 4C97206BE7BC2E2F0B-8018
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 M
Component: GW MQB High 212 2203
Revision: -------- Serial number: 01101410802775
Coding: 0101000830085A005B00022C980B00000001010000000000000000000000
ROD: EV_GatewConti_011.rod
VCID: 72EB9E93A5D818DFA1-8026
Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Serial number: 17 10 2014 C0047695
131612 - No Communications with Actuator for Structural Accoustics
U10DF 00 [009] - -
Fault Frequency: 40
Reset counter: 218
Mileage: 71663 km
Date: 2019.12.26
Time: 17:22:54
Terminal 15: On
Part No SW: 0CQ 907 554 D HW: 0CQ 907 554 D
Serial number: HA1-00004.09.14
Coding: 0001
VCID: 46831243F9D0D47FDD-8012
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 14000292251003
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 3467588B9F4C56EF73-8060
Part No SW: 5Q0 907 566 A HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0348367775
Coding: 030211
VCID: 387F6CBB8324B28F5F-806C
Subsystem 1 - Part No SW: 5Q0 907 568 A HW: 8T0 907 568 B
Component: SWA Slave H05 0071
Serial number: 0348774456
Coding: 030211
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 14101402090927
Coding: 005D1F205C00048000000002
VCID: 408F045BDBF4FA4FE7-8014
Part No SW: 3Q0 909 144 H HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5061
Coding: 8102
VCID: 377D6F878E3ABDF756-8062
Part No SW: 8V0 035 465 C HW: 8V0 035 465
Component: MIBAMP1ALPINE H11 0410
Serial number: AUZ8ZAEN900SSR%
Coding: 01030300AAAA2AAA01
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 14101403111564
Coding: 005D17205E00048000000002
VCID: 3F8D07A7A60A85B79E-806A
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0091
Coding: 012200003F200400
Coding: E00100
Coding: E00100
Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo links H01 7050
Coding: E00100
Subsystem 4 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 7050
Coding: E00100
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-HGH1.clb
Part No SW: 8V0 035 038 B HW: 8V0 035 038 B
Component: MU-H-LNS-US H43 0394
Serial number: A302J0EB005348
Coding: 017301020000000021220002041A00102F000225010001043E
ROD: EV_MUHig6C3HBAS_AU37.rod
Subsystem 1 - Part No SW: V03 959 800 SS HW: -----------
Component: NAR 2015 --- 0035
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0013
Serial number: AUZ8Z9EY201YBT
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 L HW: 8V0 919 614 L
Component: ControlUnit_H H81 0816
Serial number: C1000002091400030299
Component: Gracenote --- 3006
Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A
Component: MQB RVC Mid H07 0140
Coding: 027300010201000300
ROD: EV_2CamSysRearPASE.rod
VCID: 306F549B6B546ACF17-8064
Address A9: Struct. Borne Sound
Part No SW: 5Q0 959 395 B HW: 5Q0 959 395 B
Component: TSG HFS 020 0025
Serial number: 15101406071203
Coding: 004D17204000048000000002
Component: TSG HBFS 020 0025
Serial number: 15101406071201
End-------------------------(Elapsed Time: 05:30)--------------------------
