Results 1 to 10 of 17
Thread: MFSW retrofit MK7 sportwagen
    Dec 2019
    Quebec, Canada
    I'm doing a MFSW retrofit on my 17' sportwagen 4motion.
    I activated the MFSW in long coding.
    But in adaptation i can't acces any of the MFSW, that said channel not accessible
    From my research i think i do not have the good Can gateway since mine is a 'low'
    I use the steering 5G0419091DK ( model W/O CC since i have it on the flasher arm )
    Wiring harness 5G0 971 584 P
    Here the autoscan
    Monday,06,January,2020,23:44:36:19281
    VIN: 3VW017AU4HM510218   License Plate: PNZRWGN
    Mileage: 37182km-23103mi   Repair Order: 1
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 08 09 15 16 17 19 22 42 44 52 5F
    VIN: 3VW017AU4HM510218   Mileage: 37182km-23103miles
    Address 01: Engine (J623-CXBB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 8V0 906 264 L    HW: 06K 907 425 B
       Component: 1.8l R4 TFSI  H13 0002
       Revision: --H13---
       Coding: 091D00122426002F0000
       Shop #: WSC 00066 790 00202
       ASAM Dataset: EV_ECM18TFS0208V0906264L 001003
       ROD: EV_ECM18TFS0208V0906264L.rod
       VCID: 45D756FA2525533FBA1-8010
    Readiness: 0010 1101
       Part No SW: 0D9 300 012 F    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H54 4901
       Revision: 06354004    Serial number: TFK01607270797
       ROD: EV_TCMDQ250021.rod
       VCID: 196FCA8AF91D07DF2E9-804C
              P1734 00 [002] - -
    Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
       Part No SW: 5Q0 614 517 AF    HW: 5Q0 614 517 AF
       Component: ESC           H62 0398
       Revision: 00000000    Serial number: 52146000001057
       Coding: 04FA6AA12421096C8079030181CB292056249001C081943400430050C00503
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_Brake1UDSContiMK100ESP 035019
       ROD: EV_Brake1UDSContiMK100ESP_035_VW37.rod
       VCID: 75B7E63A354583BFEA1-8020
       Part No SW: 5GM 907 426 C    HW: 5GM 907 426 C
       Component: AC Manuell    H03 1601
       Revision: 00001K03
       Coding: 02020004200100000000000000000002
       ASAM Dataset: EV_ACManueBHBVW37X 004132
       ROD: EV_ACManueBHBVW37X_004.rod
       VCID: 48C95FCE12374E57417-801C
       Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
       Revision: --------    Serial number: 865810081600KM
       Coding: 000018464041804149E44000091407001000000000000000000000000000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 7AADF5061C5BECC7873-802E
       Component: WWS    160911  043 0581
       Serial number:         160920125549
    17674 - Bulb for Front Left Side Marker Lamp
              B12BA 15 [009] - Open or Short to Plus
                        Reset counter: 67
                        Mileage: 37139 km
                        Date: 2020.01.06
                        Time: 22:51:29
    17930 - Bulb for Front Right Side Marker Lamp
              B12BB 15 [009] - Open or Short to Plus
                        Reset counter: 67
                        Mileage: 37139 km
                        Date: 2020.01.06
                        Time: 22:51:29
       Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
       Serial number: 003MHM03DKHV
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 51FF72AAE16D8F9F169-8004
       Occupant Detection:
       Serial number: IBH0000J160005RJYS0D
       Coding: 303132
       Subsystem 2 - Part No SW: -----------    HW: 480 002 107 16
       Serial number: 35700000000B4840DC1P
       Subsystem 3 - Part No SW: -----------    HW: 480 002 107 16
       Serial number: 35800000000FE8E82D15
       Subsystem 4 - Part No SW: -----------    HW: 480 400 907 16
       Serial number: 3510002C920F1956215Z
       Subsystem 5 - Part No SW: -----------    HW: 480 400 907 16
       Serial number: 3520002C920F195362C2
       Subsystem 6 - Part No SW: -----------    HW: 480 400 708 16
       Serial number: 3550002C5215E1C363F8
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 400 708 16
       Serial number: 3560002C5215E1C5A1CA
       Part No SW: 5Q0 953 521 AA    HW: 5Q0 953 569 A
       Revision: FF034034    Serial number: 20160719501415
       Coding: 1610
       Shop #: WSC 66564 385 16448
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 71BFD22A412DAF9F369-8024
       Part No SW: 5G1 920 740 B    HW: 5G1 920 740 B
       Component: KOMBI         244 8311
       Coding: 03B5100AA080880902086A001000000000000000
       VCID: 2517F67AC565B33F9A1-8070
              U1014 00 [009] - -
                        Reset counter: 68
                        Mileage: 37139 km
                        Date: 2020.01.06
                        Time: 22:50:40
       Part No SW: 5Q0 907 530 AK    HW: 5Q0 907 530 K
       Component: GW MQB Low    210 2265
       Revision: --------    Serial number: 17071610802311
       Coding: 0901000830085900FB0000081C0F00000001050000000000000000000000
       Shop #: WSC 00066 790 07026
       ROD: EV_GatewConti_013.rod
       Power Converter DC AC:
       Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
       Component: WECHSELRICHTE  H53 0041
       Serial number: 0115589
       Serial number: HA1-00027.06.16
       Coding: 0001
       VCID: 4ACD65C60C3BBC47573-801E
       Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
       Serial number: 02091606050645
       Coding: 003003200000020000000000
       VCID: 41DF42EA310D7F1F869-8014
       Serial number: 00000000000013794038
       Coding: 011000
       Part No SW: 5Q0 909 144 T    HW: 5Q0 909 144 R
       Component: EPS_MQB_ZFLS  129 1072
       Coding: 0102
       ROD: EV_SteerAssisMQB_013.rod
       Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
       Serial number: 030916060500X2
       VCID: 40D947EE3A077617897-8014
       Serial number: 00000000000004288959
       Coding: 091000
       Part No SW: 3Q0 035 844 A    HW: 3Q0 035 844 A
       Component: MU-S-S-US     710 0751
       Coding: 02731200FF00000051220001001828001F0100D40120010002
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 2D070E5A9D958B7F521-8078
       Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
       Component: ABT_Std-2  H53 1031
       Serial number: VWZ8Z9SJW016UJ
    0020 - Tuner for Satellite Radio
              B11CF 53 [009] - Deactivated
                        Reset counter: 67
                        Mileage: 37139 km
                        Date: 2020.01.06
                        Time: 22:51:23
                        Voltage terminal 30: 12.3 V
                        SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
                        SDARS_tuner_status_2-Channel selection for satellite radio: 0
                        SDARS_tuner_status_2-Audio Signal: Available
                        SDARS_tuner_status_2-Antenna current: 135 mA
                        SDARS_tuner_status_2-Reception quality: optimum_signal
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 02
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 02
    End----------(Elapsed Time: 01:10, VBatt start/end: 12.7V/12.6V)-----------
    Apr 2018
    ITALY
    MFSW is a subsystem of 19 Gateway. as you can see in your scan, it shows nothing under the relevant section, so you probably have a wiring issue.
    Dec 2019
    Quebec, Canada
    Well, how can i check if it's a wiring issue ?
    I know that my steering wheel control modul is good..
    5Q0 953 569 A
    This should work with MFSW. So i guess if they build the car with it, that should be wired to the can
    Other than that i'm screwed
    May 2016
    First change the gateway to high
    Dec 2019
    Quebec, Canada
    Sure, i wanted to do so, but how ? Do i need to change the can gateway or it's possible to program it to high ?
    Quote Originally Posted by vastechnics View Post
  6. #6
    May 2016
    First check your vin what gateway is needed. Then go to someone who have GEKO acces. He can remove CP, SVM and restore FEC codes. After this you can do coding of the MFSW. No need to change slipring and all other things. I have done this several times . Just gateway high or mid.
  7. Likes Dana liked this post
    Apr 2018
    ITALY
    apologies I didn't notice you have a LOW Gateway. you need to swap to 5Q0 907 530 AM, it MUST BE the black one with gold lettering made by Continental with SW 2265 and HW 212.
  9. Likes Uwe, Dana liked this post
  10. #8
    Dec 2019
    Quebec, Canada
    Man sorry it’s chinesse for me all of these ahhaha
    Alright then, so i order that can gateway, install it. Code it right to my car. I guess i can copy paste the Coding from the one i actually have and voilà ? No need for ODIS or dealer ?
  11. #9
    Apr 2018
    ITALY
    when you install the new gateway, CP will kick in as soon as you switch ignition on. this will not prevent you to use the car or VCDS. so you can restore the old coding and all adaptations.
    after that you HAVE TO go to the dealer to clear CP and have FeC codes restored.
  12. Likes PetrolDave, Uwe, Pnzrwgn liked this post
  13. #10
    Dec 2019
    Quebec, Canada
    Ok i see ! So i will call my dealer first to see if they understand what i want to do. I don’t want to getting stuck with the car on cp ha
    Thank’s man !
