- Joined
- Dec 27, 2019
- Messages
- 21
- Reaction score
- 6
- Location
- Quebec, Canada
- VCDS Serial number
- C?ID=391367
I'm doing a MFSW retrofit on my 17' sportwagen 4motion.
I activated the MFSW in long coding.
But in adaptation i can't acces any of the MFSW, that said channel not accessible
From my research i think i do not have the good Can gateway since mine is a 'low'
I use the steering 5G0419091DK ( model W/O CC since i have it on the flasher arm )
Wiring harness 5G0 971 584 P
Here the autoscan
Here the autoscan
Monday,06,January,2020,23:44:36:19281
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
VIN: 3VW017AU4HM510218 License Plate: PNZRWGN
Mileage: 37182km-23103mi Repair Order: 1
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 22 42 44 52 5F
VIN: 3VW017AU4HM510218 Mileage: 37182km-23103miles
Address 01: Engine (J623-CXBB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 264 L HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0002
Revision: --H13---
Coding: 091D00122426002F0000
Shop #: WSC 00066 790 00202
ASAM Dataset: EV_ECM18TFS0208V0906264L 001003
ROD: EV_ECM18TFS0208V0906264L.rod
VCID: 45D756FA2525533FBA1-8010
Readiness: 0010 1101
Part No SW: 0D9 300 012 F HW: 02E 927 770 AQ
Component: DQ250-6F MQB H54 4901
Revision: 06354004 Serial number: TFK01607270797
ROD: EV_TCMDQ250021.rod
VCID: 196FCA8AF91D07DF2E9-804C
P1734 00 [002] - -
Address 03: ABS Brakes (J104) Labels:* 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 614 517 AF HW: 5Q0 614 517 AF
Component: ESC H62 0398
Revision: 00000000 Serial number: 52146000001057
Coding: 04FA6AA12421096C8079030181CB292056249001C081943400430050C00503
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_Brake1UDSContiMK100ESP 035019
ROD: EV_Brake1UDSContiMK100ESP_035_VW37.rod
VCID: 75B7E63A354583BFEA1-8020
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5GM 907 426 C HW: 5GM 907 426 C
Component: AC Manuell H03 1601
Revision: 00001K03
Coding: 02020004200100000000000000000002
ASAM Dataset: EV_ACManueBHBVW37X 004132
ROD: EV_ACManueBHBVW37X_004.rod
VCID: 48C95FCE12374E57417-801C
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 087 AA HW: 5Q0 937 087 AA
Revision: -------- Serial number: 865810081600KM
Coding: 000018464041804149E44000091407001000000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 7AADF5061C5BECC7873-802E
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 160911 043 0581
Serial number: 160920125549
17674 - Bulb for Front Left Side Marker Lamp
B12BA 15 [009] - Open or Short to Plus
Reset counter: 67
Mileage: 37139 km
Date: 2020.01.06
Time: 22:51:29
17930 - Bulb for Front Right Side Marker Lamp
B12BB 15 [009] - Open or Short to Plus
Reset counter: 67
Mileage: 37139 km
Date: 2020.01.06
Time: 22:51:29
Part No SW: 5Q0 959 655 T HW: 5Q0 959 655 T
Component: AirbagVW20 009 0825
Serial number: 003MHM03DKHV
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 51FF72AAE16D8F9F169-8004
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH0000J160005RJYS0D
Coding: 303132
Subsystem 2 - Part No SW: ----------- HW: 480 002 107 16
Serial number: 35700000000B4840DC1P
Subsystem 3 - Part No SW: ----------- HW: 480 002 107 16
Serial number: 35800000000FE8E82D15
Subsystem 4 - Part No SW: ----------- HW: 480 400 907 16
Serial number: 3510002C920F1956215Z
Subsystem 5 - Part No SW: ----------- HW: 480 400 907 16
Serial number: 3520002C920F195362C2
Subsystem 6 - Part No SW: ----------- HW: 480 400 708 16
Serial number: 3550002C5215E1C363F8
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 400 708 16
Serial number: 3560002C5215E1C5A1CA
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 521 AA HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF034034 Serial number: 20160719501415
Coding: 1610
Shop #: WSC 66564 385 16448
ROD: EV_SMLSVALEOMQB.rod
VCID: 71BFD22A412DAF9F369-8024
Part No SW: 5G1 920 740 B HW: 5G1 920 740 B
Component: KOMBI 244 8311
Coding: 03B5100AA080880902086A001000000000000000
VCID: 2517F67AC565B33F9A1-8070
U1014 00 [009] - -
Reset counter: 68
Mileage: 37139 km
Date: 2020.01.06
Time: 22:50:40
Part No SW: 5Q0 907 530 AK HW: 5Q0 907 530 K
Component: GW MQB Low 210 2265
Revision: -------- Serial number: 17071610802311
Coding: 0901000830085900FB0000081C0F00000001050000000000000000000000
Shop #: WSC 00066 790 07026
ROD: EV_GatewConti_013.rod
Power Converter DC AC:
Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A
Component: WECHSELRICHTE H53 0041
Serial number: 0115589
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 H HW: 0CQ 525 130
Serial number: HA1-00027.06.16
Coding: 0001
VCID: 4ACD65C60C3BBC47573-801E
Part No SW: 5Q0 959 393 E HW: 5Q0 959 393 B
Component: TSG FS 020 0041
Serial number: 02091606050645
Coding: 003003200000020000000000
VCID: 41DF42EA310D7F1F869-8014
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000013794038
Coding: 011000
Part No SW: 5Q0 909 144 T HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 129 1072
Coding: 0102
ROD: EV_SteerAssisMQB_013.rod
Part No SW: 5Q0 959 392 E HW: 5Q0 959 392 B
Component: TSG BFS 020 0041
Serial number: 030916060500X2
VCID: 40D947EE3A077617897-8014
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000004288959
Coding: 091000
Part No SW: 3Q0 035 844 A HW: 3Q0 035 844 A
Component: MU-S-S-US 710 0751
Coding: 02731200FF00000051220001001828001F0100D40120010002
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 2D070E5A9D958B7F521-8078
Subsystem 1 - Part No SW: 3G0 919 605 H HW: 3G0 919 605 H
Component: ABT_Std-2 H53 1031
Serial number: VWZ8Z9SJW016UJ
B11CF 53 [009] - Deactivated
Reset counter: 67
Mileage: 37139 km
Date: 2020.01.06
Time: 22:51:23
Voltage terminal 30: 12.3 V
SDARS_tuner_status_2-Audio Signal: Available
SDARS_tuner_status_2-Antenna current: 135 mA
SDARS_tuner_status_2-Reception quality: optimum_signal
SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 02
SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 02
End----------(Elapsed Time: 01:10, VBatt start/end: 12.7V/12.6V)-----------
