Results 1 to 4 of 4
Thread: Errors keep coming 9175296 Fatigue Recognition - 1275 - Unknown Error Code New Car??
    Jun 2016
    Hello all,
    I always read two errors that come back after a short period.
    When I look at other cars with the same modules I also see this error coming back.
    Even a car from 2017 just like me, with 300 km has the same error, keep coming.
    I understand that this is not a problem!!
    But would still like to know because of these malfunctions already known in 2017
    3 years later, a cause must be known especially here for experienced users.
    Can anyone tell me what i could do to correct the malfunctions.
    Gateway have a never version from 4286 to 4287, maybe this problem have resolved with this flash.
    if so i would like to hear this.
    The A5: Frt Sens. Drv. Assist (R242) H06 0231 no new firmware!
    Last guestion!
    There is no program to compare changes in the adaptation channels, by entering both scans and automatically seeing the adjusted adaptation channel.
    Now i always copy one adaptation values to the other files and try to check 2500 values if changed.
    This could be possible for a few experts to put this together!!
    Component: GW MQB High 418 4286
    Revision: -------- Serial number: 0005997816
    Coding: 030100045F086800FB00025E1C0F0001000105000000000000 0000000000
    ROD: EV_GatewNF.rod
    VCID: 2F4249D476BBB2370E-807A
    9175296 - Function Restriction due to Driver Fatigue Recognition
    B130E 00 [008] - -
    Reset counter: 114
    Mileage: 61270 km
    Date: 2020.01.04
    Time: 14:38:01
    Supply voltage: Terminal 30: 14.7 V
    Terminal 15: On
    Part No SW: 3Q0 980 654 G HW: 3Q0 980 654
    Component: MQB_B_MFK H06 0231
    Serial number: 26021711P21435
    Coding: 0003070000000401002223548050A90098000E300040
    VCID: 3B5A6D84B2C35E97B2-806E
    B182E F0 [024] - Unknown Error Elaboration
    Reset counter: 72
    Mileage: 61258 km
    Date: 2020.01.04
    Time: 14:16:07
    Control Module temperature: 38 °C
    Outside air temperature: 9.0 °C
    Vehicle speed: 33.10 km/h
    System run time: 7120.4 s
    Voltage terminal 15: 14.6 V
    mid: 01 62
    Status of camera: operational
    Engine_Running_Info: 1
    Software_Info_4: 1
    Software_Info_3: 3
    Software_Info_2: 2
    Software_Info_1: 0
     Tuesday,07,January,2020,13:46:46:42750
    VCDS Version: 19.6.2.0 (x64)
    VIN: WVWZZZAUZHW330832   License Plate:
    Chassis Type  AU-VW37 (3Q0)
    Scan: 01 02 03 08 09 10 13 15 16 17 18 19 3C 42 44 4B 52 5F A5
    VIN: WVWZZZAUZHW330832   Mileage: 61439km-38176miles
    4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
    Address 01: Engine (J623-DCYA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 EK    HW: 04L 907 309 R
       Component: R4 2.0l TDI   H24 4029
       Revision: B5H24---
       Coding: 0125001A036405082000
       ASAM Dataset: EV_ECM20TDI01104L906026EK 004003
       ROD: EV_ECM20TDI01104L906026EK_004_VW37.rod
       VCID: 77D2B1B4CE6BBAF796-8022
       Part No SW: 0GC 300 040 T    HW: 0GC 927 711 G
       Component: GSG DQ381     H06 0705
       Revision: 00H06V07
       ROD: EV_TCMDQ381061_VW37.rod
       VCID: 354E7BBC94E788E744-8060
       Revision: 00000000    Serial number: 60567000000388
       Coding: 01FA62A12423096C477F060340C52980462490E26002947338625078C2A2430000000012121212B835351919323200
       Part No SW: 5G1 907 044 AC    HW: 5G1 907 044 AC
       Revision: 00001K08
       Coding: 00020114204111011105000C0010102A
       Shop #: WSC 00028 028 00068
       ASAM Dataset: EV_ACClimaBHBVW37X 006143
       VCID: 69F6E7CC88DF1C0710-803C
       Air quality sensor:
       Part No SW: 5Q0 937 084 CF    HW: 5Q0 937 084 CF
       Component: BCM MQBAB M+  H34 0236
       Serial number: 02001705300925
       ROD: EV_BCMBOSCH_017.rod
       VCID: 7EDCA490E1518BBFD5-802A
       Component: WWS    170124  043 0551
       Serial number:         170204055822
       Component: RLHS  052 0107
       Serial number: S6Y19M10D08H01M29S57
       Coding: 00A8DD
       Serial number: 000000000ZY170321QM8
       Serial number: 00000000000068369376
       Sun Roof:
       Component: J245 PS73.404  H03 0004
       Serial number: 0000FST001FU3CP00000
       Coding: 181901
       Part No SW: 5QA 919 294 A    HW: 5QA 919 294
       Component: PDC 8 KanalH07 0038
       Serial number: 000308418617058
       Coding: 0471155011
       ASAM Dataset: EV_EPHVA18AU3700000 009031
       VCID: 4AB43840ED19F71F39-801E
       Part No SW: 5Q0 907 572 H    HW: 3QF 907 572
       Coding: 330067C15DFFC728949C810580400600000000000000000000
       VCID: 3C586E98B7CD59AFBB-8068
       Part No SW: 5Q0 959 655 AS    HW: 5Q0 959 655 AS
       Component: AirbagVW21    003 0317
       Serial number: 003TMR2MRH3N
       Coding: 98FCC0C0000000005C5400CF000800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 1106EF2CC0CF84C738-8044
       Belt Pretensioner left:
       Component: BeltPretRevFL  H37 0350
       Serial number: 34169667E23021740626
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H37 0350
       Serial number: 34169668E23021741286
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 002 502 17
       Serial number: 357000000003318CE12G
       Subsystem 4 - Part No SW: -----------    HW: 480 002 402 17
       Serial number: 35800000000DBAECB124
       Subsystem 5 - Part No SW: -----------    HW: 480 401 502 17
       Serial number: 3510001AF2537333839
       Subsystem 6 - Part No SW: -----------    HW: 480 401 702 17
       Serial number: 3520001BD2537332C2B%
       Subsystem 7 - Part No SW: -----------    HW: 480 402 102 17
       Serial number: 35500019F24542C5454%
       Part No SW: 5Q0 953 507 JD    HW: 5Q0 953 549 D
       Component: Lenks. Modul  004 0140
       Revision: --------    Serial number: 22021704400926
       Coding: 0C30
       VCID: 0126DF6C90AFF447A8-8054
       Part No SW: 5G1 920 791     HW: 5G1 920 791
       Component: KOMBI         408 2180
       Coding: 07AC01086F8C000801887B0B5400000080000000
       Shop #: WSC 12345 123 61029
       Part No SW: 5Q0 963 272 G    HW: 5Q0 963 272 G
       Component: STH-MQB       008 0075
       Coding: 9309
       VCID: 3A546880BDF9679FA9-806E
       Component: R64 D208L  004 0401
       Serial number: 00000000000000193952
       Coding: 030100045F086800FB00025E1C0F00010001050000000000000000000000
       ROD: EV_GatewNF.rod
       Serial number: 29170000424190027072
       Coding: 2FFFFF
       Serial number: 4113133204
              B130E 00 [008] - -
                        Reset counter: 114
                        Mileage: 61270 km
                        Date: 2020.01.04
                        Time: 14:38:01
                        Terminal 15: On
       Serial number: 0430447012
       Coding: 02011103
       ROD: EV_HREntryHella_VW37.rod
       Component: HRE_Slave  H12 0071
       Serial number: 0429724314
       Coding: 020111
       Serial number: 300117EAU14611
       Coding: 003B0220D000048000001000
       VCID: 43AA1564CA332657FA-8016
       Subsystem 1 - Part No SW: 5Q0 959 811     HW: 5Q0 959 811   Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000013604576
       Coding: 110000
       Coding: 9107
       ROD: EV_SteerAssisMQB_013.rod
    Address 4B: Multifunc. Module
    Interface not compatible.
       Serial number: 040217EB327884
       Coding: 003B0020DE00048000801000
       VCID: 42A41060D5292F5FF1-8016
       Subsystem 1 - Part No SW: 5Q0 959 812     HW: 5Q0 959 812   Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000013522770
       Coding: 090000
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
       Part No SW: 5NA 035 042     HW: 5NA 035 042
       Component: MU-H-LN-EU    H51 0913
       Serial number: A847B0HB003164
       Coding: 02731001FF00000051110001000808101F0100F4012004009F
       VCID: 72C480A0A509DFDFA1-8026
       Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
       Component: ABT_High-2  H40 9077
       Serial number: VWZ6ZFT0551156
       Subsystem 2 - Part No SW: V03 959 806 FN    HW: -----------
       Component: ECE 2020  --- 0184
       Component: Gracenote2  --- 1015
                        Reset counter: 72
                        Mileage: 61258 km
                        Date: 2020.01.04
                        Time: 14:16:07
                        mid: 01 62
                        Software_Info_4: 1
                        Software_Info_3: 3
                        Software_Info_2: 2
                        Software_Info_1: 0
    End-------------------------(Elapsed Time: 04:00)--------------------------
    Quote Originally Posted by barstanders View Post
    Adaptation maps are just text files. Use any "Compare" program.
    I use this one:
    https://www.grigsoft.com/wincmp3.htm
    But there are many others.
    Would be nice if it was an option in auto-scan to add OBD2 data & a map out of all adaptions and measuring blocks by blitz or by selection?
    Jun 2016
    Dear All,
    As I get this malfunction for a while, every time after resetting it comes back after a day.
    I have looked at the module and see that at byte 18, bit 0-7 are nothing!
    When I select this bit I have two options:
    00 Fatigue Detection ( MKE ) Variant 1
    07 Fatigue Detection ( MKE ) Variant 7
    So i think considering mine 05, I assume variant 5.
    maybe the text will be adjusted in the future.
    if I adjust this to variant 1 or 7 this may cause problems, causing me to go to the dealer!!
    http://prnt.sc/qyco2r
    http://prnt.sc/qycorx
    Can anyone tell me how i can resolve this error message.
    B130E 00 [008] - -
    Reset counter: 114
    Mileage: 61270 km
    Date: 2020.01.04
    Time: 14:38:01
    Terminal 15: On
