Hi folks,
Thanks for having me.
On my APY Engine 2000 Audi S3 8L am trying to run the Diagnostics for the F83 Brake Detection Switch in the ABS/ESP module.
Sadly Group 031 in the Basic Settings is not available. Anyone came across the same issue?
Here is a little background. My car has an ESP error with number 00812, Solenoid error F84. ABS still works fine.
Address 03: ABS Brakes Labels: None
Controller: 8N0 907 379 E
Component: ESP 20 CAN V004
Coding: 18448
Shop #: WSC 06435
VCID: 3E0F4581296F
00812 - Brake Pressure Release Solenoid (F84)
35-00 - -
I already replaced the Brake Pedal switch and also the entire Brake Servo/Booster but the error still exists so I suspect a wiring fault somewhere.
I have no other errors anywhere! Both Brake Pressure Sensors work fine and values are spot on, the Brake Pedal Switch reports operated or not operated in the Measuring Blocks, the F83 just says 'Activated'.
Reading through ELSA I came across the "Checking functions of the brake detection switch, ESP F83" method you can execute on the VAS 5051 A, which should be executed on Brake Servo swap.
I can go into "04 - Basic Settings" of the ABS/ESP module in VCDS/VAG-COM but all the groups written in ELSA (031-032-033) of this systems check error out with "Group Error".
Does anyone know the correct group I need to execute or is there something wrong elsewhere?
Like mentioned, no other errors anywhere in the car, autoscan is perfectly clean.
Thanks!
P.s. If anyone asks about the coding, the 18448 is correct. The ITT Mark 20 on the S3 has 2 dedicated codes for the APY and BAM egine, which is 18448.
I have been dealing with this error since 2 years already but i am determined to figure out what's going on ...
Coding: 18448
Shop #: WSC 06435
VCID: 3E0F4581296F
35-00 - -
Thanks!
