Results 1 to 10 of 11
Thread: Skoda Octavia Virtual Cockpit Retrofit - Nav error
    Jan 2019
    This is coming up when trying to put the nav on the virtual cockpit display.
    I'm worried that maybe the unit (MIB2) is not compatible.
    Sunday,05,January,2020,10:40:53:18214
    VIN: TMBKK7NE2J0139287   License Plate: VRS
    Mileage: 35204km-21874mi   Repair Order:
    Chassis Type: NE-SK37 (3Q0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 4B 52 5F A5 A9 D6
              D7
    VIN: TMBKK7NE2J0139287   Mileage: 35204km-21874miles
    Address 01: Engine (J623-CUNA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 BS    HW: 04L 907 309 R
       Component: R4 2,0L EDC   H24 1541
       Revision: B5H24---
       Coding: 011D0012032501081000
       Shop #: WSC 73430 031 00000
       ASAM Dataset: EV_ECM20TDI01104L906026BS 002003
       ROD: EV_ECM20TDI01104L906026BS_002.rod
       VCID: 7CA1F71AB66F158795F-8028
    17158 - Databus
       Part No SW: 0D9 300 043 C    HW: 02E 927 770 AS
       Component: DQ250-6F MQB  H54 5202
       Revision: 06454104    Serial number: TFK01707130789
       ROD: EV_TCMDQ250021.rod
       VCID: 1A6DD1825C1BCBB7273-804E
    Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
       Part No SW: 5Q0 614 517 AQ    HW: 5Q0 614 517 AF
       Component: ESC           H62 0400
       Revision: 00000000    Serial number: 62057000004246
       Coding: 250793913423097540790608C0CA29A4C92C9002600394742061F070C029430000000012121212B8586C384E4484EE
       ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
       ROD: EV_Brake1UDSContiMK100ESP_036.rod
       VCID: 005983EADA877167C97-8054
       Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
       Component: VWKESSYMQB    021 0803
       Revision: 00021000    Serial number: 0450339169
       Coding: 032C0C
       Shop #: WSC 73430 790 00063
       ASAM Dataset: EV_KessyHellaMQBAB 002020
       VCID: 3C21371AF6EFD587D5F-8068
       Part No SW: 5E0 907 044 AQ    HW: 5E0 907 044 AQ
       Component: Climatronic   H04 2001
       Revision: 00001K00
       Coding: 0211010400211001100500080010102A
       Shop #: WSC 73430 031 00063
       ASAM Dataset: EV_ACClimaBHBVW37X 006146
       VCID: 74B1DF3A9E3F5DC7DDF-8020
    1048834 - Functional Limitation due to Energy Management
              B10CD 00 [008] - -
              [PTC-Reduzierung durch BCM]
                        Reset counter: 6
                        Mileage: 34730 km
                        Date: 2019.12.30
                        Time: 18:49:29
                        Voltage terminal 30: 13.9 V
                        Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 1
                        Auxiliary heater: in stages-Act.val.: 0
              P1719 00 [008] - -
              [PTC-Reduzierung durch MSG]
                        Fault Frequency: 63
                        Reset counter: 21
                        Mileage: 32430 km
                        Date: 2019.12.03
                        Time: 12:36:11
       Part No SW: 5Q0 937 086 BM    HW: 5Q0 937 086 BH
       Component: BCM PQ37BOSCH 034 0242
       Revision: --------    Serial number: 865822071700A4
       Shop #: WSC 73430 790 00000
       ROD: EV_BCMBOSCH_018.rod
       VCID: 065595F2F8A35F57F3B-8052
       Subsystem 1 - Part No SW: 5E2 955 119 A    HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS371 170601  051 0915
       Serial number: 887253F0401715200329
       Coding: 164DDD
       Component: RLHS  042 0105
       Serial number: S5Y17M08D14H12M19S47
       Coding: 00885D
       Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
       Serial number: 000000000ZY17117077M
       Subsystem 4 - Part No SW: 5QD 951 605     HW: 5QD 951 605
       Serial number: 00002856223971374909
    262936 - Sensor for anti-theft alarm system
              B1330 29 [008] - Signal Implausible
    395521 - Function Limitation due to Active Protection Function
              B2023 00 [008] - -
              [Störschutzzählerüberlauf]
       Part No SW: 5QA 919 283 B    HW: 5QA 919 283
       Component: PDC 4 KanalH07 0044
       Serial number: 000308419617216
       Coding: 0601050011
       ASAM Dataset: EV_EPHVA14AU3700000 009033
       ROD: EV_EPHVA14AU3700000_009.rod
       VCID: 49CF5ECEA93D702F5E9-801C
       Part No SW: 3Q0 959 655 BH    HW: 3Q0 959 655 BH
       Component: Airbag VW21   006 0703
       Revision: --------    Serial number: 003W4PF0MYMS
       Coding: 98CCC000000000005C5400CC008800000065
       ROD: EV_AirbaVW21TS6VW48X.rod
       VCID: 055792FEC5A5544FFA1-8050
       Subsystem 1 - Part No SW: -----------    HW: 454 002 407 17
       Serial number: 357000000001D659972O
       Subsystem 2 - Part No SW: -----------    HW: 454 002 507 17
       Serial number: 3580000000080079972F
       Subsystem 3 - Part No SW: -----------    HW: 454 802 507 17
       Serial number: 3510001EEDC10000000L
       Subsystem 4 - Part No SW: -----------    HW: 454 802 307 17
       Serial number: 35200FA6BDB10000000Y
       Subsystem 5 - Part No SW: -----------    HW: 454 802 506 17
       Serial number: 35500066A5D10000000B
       Part No SW: 5Q0 953 507 HQ    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 09081704220317
       Coding: 1410
       VCID: 0C41A7DAE6CF2507A5F-8058
       Part No SW: 5E0 920 957 E    HW: 5E0 920 957 E
       Component: KOMBI         303 0310
       Coding: 27A5091869808600010A6B021001000000000000
       VCID: 2F3B105637993E1F60D-807A
       Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
       Component: GW MQB High   433 4303
       Revision: --------    Serial number: 0006648492
       Coding: 030100045F087300EB00026A1C0F00010001070000000000000000000000
       ROD: EV_GatewNF.rod
       VCID: 33331C26DBB11AFF045-8066
       Subsystem 2 - Part No SW: 3V0 919 719 B    HW: 3V0 919 719 B
       Component: E221__MFL-PR6  H02 0160
       Serial number: 000000000B2618130717
       Serial number: 75886000001707270781
       Revision: 00000000    Serial number: 17000199060007
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 34311F3ADEBF1DC71DF-8060
       Part No SW: 5Q4 959 393 E    HW: 5Q4 959 393 B
       Serial number: 0000270994982
       Coding: 001C00208001040000001100
       VCID: 45D752FE8525944FBA1-8010
       Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E
       Component: FOND_FHSG_DRV  005 0007
       Serial number: 00000000000015676666
       Coding: 1D0200
       Coding: 9107
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 3A2D3102FCDBEBB7C73-806E
    Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
       Serial number: 08081710801764
       Coding: 000000070100046E00003D01010000000000000000000000000000000000
       VCID: 72BDD922E42B53F7CF3-8026
       Part No SW: 5Q4 959 392 E    HW: 5Q4 959 392 B
       Serial number: 0000270930000
       VCID: 44D14FFA8E1FAD47ADF-8010
       Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E
       Component: FOND_FHSG_PSG  005 0007
       Serial number: 00000000000015630789
       Coding: 050200
    Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-STD2.clb
       Part No SW: 5Q0 035 874 C    HW: 5Q0 035 874 C
       Component: MU-S-ND-ER    H41 0456
       Serial number: SKZAZ2T5308553
       Coding: 03735201FF00000051111201008800002F0209C601200500CF
       ROD: EV_MUStd4CTSAT_VW41.rod
       Subsystem 1 - Part No SW: 5E0 919 605 M    HW: 5E0 919 605 M
       Component: ABT_Std-2_Nav  H50 8130
       Serial number: SKZ6ZHT2182839
       Subsystem 2 - Part No SW: 5L0 051 236 T    HW: -----------
       Component: ECE1 2017/18  --- 0820
              U11B8 00 [008] - No Communications
              [USB - communication error]
                        Reset counter: 249
                        Mileage: 33603 km
                        Date: 2019.12.18
                        Time: 07:12:58
                        Voltage terminal 30: 10.1 V
                        Interface for external media: status-Status: Open circuit
       Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
       Component: MQB_B_MFK     H08 0272
       Serial number: 07081712P13433
       Coding: 0203070200000401000213408150A80084000E200000
       Part No SW: 5E0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0001
       Serial number: 170627201238
       VCID: 698FBE4EC9FD902F7E9-803C
       Part No SW: 7P5 941 591 AD    HW: 7P5 941 591 A
       Component: LED1L         H06 0005
       ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
       VCID: 7EA5FD12A0730797BBB-802A
       Component: LED1R         H06 0005
       ROD: EV_LED_PLUS_R_KEBODAVW416_VW41.rod
    End----------(Elapsed Time: 01:42, VBatt start/end: 12.2V/12.0V)-----------
    The auto-scan was from before I fitted cockpit.
    below is current long coding (for module 17);
     25AD091869808600010AF7020001000000000000
    Also some adaptions and long coding that I try just gives me "out of range" error.
    I even tried plugging in my MIB2 unit from MK7.5 Golf with virtual cockpit and the map display was still pink.
    adaptions / long coding ive changed;
    Go to Byte 12 and check the box for Bit 2 - Alternative Dimming Function active: - ERROR
    Open module 5F and open Long Coding Helper; go to Byte 22 and uncheck Bit 0 - Instrument Cluster Graphics [STANDARD]: - WORKED
    Go to Adaptations in Module 5F and change the following channels to the settings below:
    Dashboard_Display_Configuration-ability_switch_nav_maps ---> On - WORKED
    Dashboard_Display_Configuration-call_picture ---> On - WORKED
    Dashboard_Display_Configuration-fastlist_most ---> On - ERROR
    Dashboard_Display_Configuration-navigation_map_compression_mode ---> H264 - WORKED
    Dashboard_Display_Configuration-navigation_map_transmission_mode ---> MOST_streaming - WORKED
    Also tried this - Now go to Adaptations and choose the channel Display depiction and change it from Version 1 to Version 2 (this will enable NAV in the AID screen; Version 1 doesn't support it. I couldn't figure out why my navigation map would not show up on the AID after everything was enabled and it was all because of this setting)
    doesnt make difference ^^
    My thoughts on possibities;
    MIB 2 Unit not compatible - unsure
    Fibre optic cable not working - X - Tried unplugging and then contact / radio logos no longer transmit so that works.
    Missing coding / adaptions - unsure
    Would be perfect if someone here has facelift Skoda Octavia here who I could copy their long coding and adaption maps of 5F and 17 so i can compare
    IIRC you need a MIB2.5 as well as an optical cable.
    Mar 2014
    Europe
    Based on the part number the 5F unit is MIB 2.5 Amundsen with sw 0465.
    I can confirm this works with AID without any problem, I had it in my car before I switched to Columbus.
    I'll find my older scans and coding/adaptations.
    Try to find something like "ability to switch maps" adaptation in 5F and set this to On. Then reboot the 5F and try to switch the map between AID and MIB several times.
    Tartu, Estonia
    Check:
    ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode
    ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution
    The world is my oyster...
    May 2016
    Change the resolution. I tjought Skoda use resolution 3 in adaptions in 5F. Most must be on and instrument cluster graphics needs to be also most
    Mar 2015
    Australia
    Quote Originally Posted by vastechnics View Post
    Yes you are correct, this should be the display config adaptations:
    ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps,OFF
    ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,On
    ENG122230-ENG122341-Dashboard_Display_Configuration-coverart,On
    ENG122230-ENG122340-Dashboard_Display_Configuration-crossroad_detail_map_compression_mode,H264
    ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution,resolution_3
    ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode,MOST_stream ing
    ENG122230-ENG142153-Dashboard_Display_Configuration-dynamic_icon,0
    ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most,On
    ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode,H264
    ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution,resolution_3
    ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode,MOST_streaming
    ENG122230-ENG122342-Dashboard_Display_Configuration-stationart,On
    NOTE:
    The display will likely NOT update until it gets some wheel speed sensor input. So it will look like it's still broken. (caused me a bit of wasted time going back over and over coding and adaptations until I found this out)
    So after you set the correct adaptations and coding in 5F and 17, reboot 5F, then make sure the car can see GPS satelites and just move the car forward/back or go for a short drive and then the nav screen will update in the cluster and you should see the map.
    2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|THA475 Amp+active sub|Whiteline ALK|RVC|Discover Media
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|Full colour MFD|Quad LED tail rings| Climatronics upgrade| Dynaudio retrofit | B7 RLine Flat Steering Wheel|3AA CCM|B7 Adaptive Cruise with Front Assist|TPMS Direct|Discover Media retrofit|PLA 2.0|Lane Assist|BCM Retrofit|HBA/FLA
  7. Likes Uwe, PetrolDave liked this post
    Verified VCDS User kreativ's Avatar
    Aug 2014
    Hidden
    You need to update your Amundsen firmware to minimum sw0465 - below sw0465 virtual cockpit wont work properly.
    A TPI exist for firmware 0475
  9. #8
    Jan 2019
    Quote Originally Posted by kamold View Post
    NOTE:
    ah okay, I can give that a go. I was changing adaptions however I wasn't driving around so wasn't updating.
  10. #9
    Jan 2019
    Quote Originally Posted by kreativ View Post
    are you able to get me a link to where I can download the firmware?
  11. #10
    Aug 2014
    Hidden
    Quote Originally Posted by Gashhey View Post
    Your skoda dealer can help you with firmware update.
    MIB firmware are not meant for sharing with the public
  12. Likes Uwe liked this post
