Skoda Octavia Virtual Cockpit Retrofit - Nav error
Gashhey
C?ID=350180
This is coming up when trying to put the nav on the virtual cockpit display.
I'm worried that maybe the unit (MIB2) is not compatible.
Sunday,05,January,2020,10:40:53:18214
VIN: TMBKK7NE2J0139287   License Plate: VRS
Mileage: 35204km-21874mi   Repair Order:
Chassis Type: NE-SK37 (3Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 4B 52 5F A5 A9 D6
          D7
VIN: TMBKK7NE2J0139287   Mileage: 35204km-21874miles
Address 01: Engine (J623-CUNA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 BS    HW: 04L 907 309 R
   Component: R4 2,0L EDC   H24 1541
   Revision: B5H24---
   Coding: 011D0012032501081000
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_ECM20TDI01104L906026BS 002003
   ROD: EV_ECM20TDI01104L906026BS_002.rod
   VCID: 7CA1F71AB66F158795F-8028
17158 - Databus
   Part No SW: 0D9 300 043 C    HW: 02E 927 770 AS
   Component: DQ250-6F MQB  H54 5202
   Revision: 06454104    Serial number: TFK01707130789
   ROD: EV_TCMDQ250021.rod
   VCID: 1A6DD1825C1BCBB7273-804E
Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 AQ    HW: 5Q0 614 517 AF
   Component: ESC           H62 0400
   Revision: 00000000    Serial number: 62057000004246
   Coding: 250793913423097540790608C0CA29A4C92C9002600394742061F070C029430000000012121212B8586C384E4484EE
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
   ROD: EV_Brake1UDSContiMK100ESP_036.rod
   VCID: 005983EADA877167C97-8054
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0450339169
   Coding: 032C0C
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_KessyHellaMQBAB 002020
   VCID: 3C21371AF6EFD587D5F-8068
   Part No SW: 5E0 907 044 AQ    HW: 5E0 907 044 AQ
   Component: Climatronic   H04 2001
   Revision: 00001K00
   Coding: 0211010400211001100500080010102A
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_ACClimaBHBVW37X 006146
   VCID: 74B1DF3A9E3F5DC7DDF-8020
   Air quality sensor:
1048834 - Functional Limitation due to Energy Management
          B10CD 00 [008] - -
          [PTC-Reduzierung durch BCM]
                    Reset counter: 6
                    Mileage: 34730 km
                    Date: 2019.12.30
                    Time: 18:49:29
                    Voltage terminal 30: 13.9 V
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 1
                    Auxiliary heater: in stages-Act.val.: 0
                    Auxiliary heater: in stages-Specified value for control: 3
1048835 - Functionality limited due to Engine Control Module
          P1719 00 [008] - -
          [PTC-Reduzierung durch MSG]
                    Fault Frequency: 63
                    Reset counter: 21
                    Mileage: 32430 km
                    Date: 2019.12.03
                    Time: 12:36:11
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
   Part No SW: 5Q0 937 086 BM    HW: 5Q0 937 086 BH
   Component: BCM PQ37BOSCH 034 0242
   Revision: --------    Serial number: 865822071700A4
   Shop #: WSC 73430 790 00000
   ROD: EV_BCMBOSCH_018.rod
   VCID: 065595F2F8A35F57F3B-8052
   Subsystem 1 - Part No SW: 5E2 955 119 A    HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 170601  051 0915
   Serial number: 887253F0401715200329
   Coding: 164DDD
   Component: RLHS  042 0105
   Serial number: S5Y17M08D14H12M19S47
   Coding: 00885D
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY17117077M
   Subsystem 4 - Part No SW: 5QD 951 605     HW: 5QD 951 605
   Serial number: 00002856223971374909
262936 - Sensor for anti-theft alarm system
          B1330 29 [008] - Signal Implausible
395521 - Function Limitation due to Active Protection Function
          B2023 00 [008] - -
          [Störschutzzählerüberlauf]
   Part No SW: 5QA 919 283 B    HW: 5QA 919 283
   Component: PDC 4 KanalH07 0044
   Serial number: 000308419617216
   Coding: 0601050011
   ASAM Dataset: EV_EPHVA14AU3700000 009033
   ROD: EV_EPHVA14AU3700000_009.rod
   VCID: 49CF5ECEA93D702F5E9-801C
   Part No SW: 3Q0 959 655 BH    HW: 3Q0 959 655 BH
   Component: Airbag VW21   006 0703
   Revision: --------    Serial number: 003W4PF0MYMS
   Coding: 98CCC000000000005C5400CC008800000065
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 055792FEC5A5544FFA1-8050
   Subsystem 1 - Part No SW: -----------    HW: 454 002 407 17
   Serial number: 357000000001D659972O
   Subsystem 2 - Part No SW: -----------    HW: 454 002 507 17
   Serial number: 3580000000080079972F
   Subsystem 3 - Part No SW: -----------    HW: 454 802 507 17
   Serial number: 3510001EEDC10000000L
   Subsystem 4 - Part No SW: -----------    HW: 454 802 307 17
   Serial number: 35200FA6BDB10000000Y
   Subsystem 5 - Part No SW: -----------    HW: 454 802 506 17
   Serial number: 35500066A5D10000000B
   Part No SW: 5Q0 953 507 HQ    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 09081704220317
   Coding: 1410
   VCID: 0C41A7DAE6CF2507A5F-8058
   Part No SW: 5E0 920 957 E    HW: 5E0 920 957 E
   Component: KOMBI         303 0310
   Coding: 27A5091869808600010A6B021001000000000000
   VCID: 2F3B105637993E1F60D-807A
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   433 4303
   Revision: --------    Serial number: 0006648492
   Coding: 030100045F087300EB00026A1C0F00010001070000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 33331C26DBB11AFF045-8066
   Subsystem 2 - Part No SW: 3V0 919 719 B    HW: 3V0 919 719 B
   Component: E221__MFL-PR6  H02 0160
   Serial number: 000000000B2618130717
   Serial number: 75886000001707270781
   Revision: 00000000    Serial number: 17000199060007
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 34311F3ADEBF1DC71DF-8060
   Part No SW: 5Q4 959 393 E    HW: 5Q4 959 393 B
   Component: TSG FS        011 0032
   Serial number: 0000270994982
   Coding: 001C00208001040000001100
   VCID: 45D752FE8525944FBA1-8010
   Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E
   Component: FOND_FHSG_DRV  005 0007
   Serial number: 00000000000015676666
   Coding: 1D0200
   Coding: 9107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2D3102FCDBEBB7C73-806E
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Part No SW: 3Q0 907 338     HW: 3Q0 907 338
   Component: FCM MQB Low   002 0286
   Serial number: 08081710801764
   Coding: 000000070100046E00003D01010000000000000000000000000000000000
   VCID: 72BDD922E42B53F7CF3-8026
   Part No SW: 5Q4 959 392 E    HW: 5Q4 959 392 B
   Component: TSG BFS       011 0032
   Serial number: 0000270930000
   VCID: 44D14FFA8E1FAD47ADF-8010
   Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E
   Component: FOND_FHSG_PSG  005 0007
   Serial number: 00000000000015630789
   Coding: 050200
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-STD2.clb
   Part No SW: 5Q0 035 874 C    HW: 5Q0 035 874 C
   Component: MU-S-ND-ER    H41 0456
   Serial number: SKZAZ2T5308553
   Coding: 03735201FF00000051111201008800002F0209C601200500CF
   ROD: EV_MUStd4CTSAT_VW41.rod
   Subsystem 1 - Part No SW: 5E0 919 605 M    HW: 5E0 919 605 M
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: SKZ6ZHT2182839
   Subsystem 2 - Part No SW: 5L0 051 236 T    HW: -----------
   Component: ECE1 2017/18  --- 0820
1637 - Interface for External Media
          U11B8 00 [008] - No Communications
          [USB - communication error]
                    Reset counter: 249
                    Mileage: 33603 km
                    Date: 2019.12.18
                    Time: 07:12:58
                    Voltage terminal 30: 10.1 V
                    Interface for external media: status-Status: Open circuit
   Component: MQB_B_MFK     H08 0272
   Serial number: 07081712P13433
   Coding: 0203070200000401000213408150A80084000E200000
   Part No SW: 5E0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0001
   Serial number: 170627201238
   VCID: 698FBE4EC9FD902F7E9-803C
Address D6: Light Ctrl Left 2 (A31)       Labels: 7P5-941-591.clb
   Part No SW: 7P5 941 591 AD    HW: 7P5 941 591 A
   Component: LED1L         H06 0005
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
   VCID: 7EA5FD12A0730797BBB-802A
Address D7: Light Ctrl Right 2 (A27)       Labels: 7P5-941-591.clb
   Component: LED1R         H06 0005
   ROD: EV_LED_PLUS_R_KEBODAVW416_VW41.rod
End----------(Elapsed Time: 01:42, VBatt start/end: 12.2V/12.0V)-----------
The auto-scan was from before I fitted cockpit.
below is current long coding (for module 17);
 25AD091869808600010AF7020001000000000000
Also some adaptions and long coding that I try just gives me "out of range" error.
I even tried plugging in my MIB2 unit from MK7.5 Golf with virtual cockpit and the map display was still pink.
adaptions / long coding ive changed;
Go to Byte 12 and check the box for Bit 2 - Alternative Dimming Function active: - ERROR
Open module 5F and open Long Coding Helper; go to Byte 22 and uncheck Bit 0 - Instrument Cluster Graphics [STANDARD]: - WORKED
Go to Adaptations in Module 5F and change the following channels to the settings below:
Dashboard_Display_Configuration-ability_switch_nav_maps ---> On - WORKED
Dashboard_Display_Configuration-call_picture ---> On - WORKED
Dashboard_Display_Configuration-fastlist_most ---> On - ERROR
Dashboard_Display_Configuration-navigation_map_compression_mode ---> H264 - WORKED
Dashboard_Display_Configuration-navigation_map_transmission_mode ---> MOST_streaming - WORKED
Also tried this - Now go to Adaptations and choose the channel Display depiction and change it from Version 1 to Version 2 (this will enable NAV in the AID screen; Version 1 doesn't support it. I couldn't figure out why my navigation map would not show up on the AID after everything was enabled and it was all because of this setting)
doesnt make difference ^^
My thoughts on possibities;
MIB 2 Unit not compatible - unsure
Fibre optic cable not working - X - Tried unplugging and then contact / radio logos no longer transmit so that works.
Missing coding / adaptions - unsure
Would be perfect if someone here has facelift Skoda Octavia here who I could copy their long coding and adaption maps of 5F and 17 so i can compare :)
IIRC you need a MIB2.5 as well as an optical cable.
icardiag
Europe
C?ID=113031
Based on the part number the 5F unit is MIB 2.5 Amundsen with sw 0465.
I can confirm this works with AID without any problem, I had it in my car before I switched to Columbus.
I'll find my older scans and coding/adaptations.
Try to find something like "ability to switch maps" adaptation in 5F and set this to On. Then reboot the 5F and try to switch the map between AID and MIB several times.
golfi_vend
Tartu, Estonia
C?ID=195131
Check:
ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode
ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution
vastechnics
C?ID=143747
Change the resolution. I tjought Skoda use resolution 3 in adaptions in 5F. Most must be on and instrument cluster graphics needs to be also most
kamold
Australia
C?ID=241363
Yes you are correct, this should be the display config adaptations:
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps,OFF
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,On
ENG122230-ENG122341-Dashboard_Display_Configuration-coverart,On
ENG122230-ENG122340-Dashboard_Display_Configuration-crossroad_detail_map_compression_mode,H264
ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution,resolution_3
ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode,MOST_streaming
ENG122230-ENG142153-Dashboard_Display_Configuration-dynamic_icon,0
ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most,On
ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode,H264
ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution,resolution_3
ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode,MOST_streaming
ENG122230-ENG122342-Dashboard_Display_Configuration-stationart,On
NOTE:
The display will likely NOT update until it gets some wheel speed sensor input. So it will look like it's still broken. (caused me a bit of wasted time going back over and over coding and adaptations until I found this out)
So after you set the correct adaptations and coding in 5F and 17, reboot 5F, then make sure the car can see GPS satelites and just move the car forward/back or go for a short drive and then the nav screen will update in the cluster and you should see the map.
kreativ
Hidden
C?ID=108852
You need to update your Amundsen firmware to minimum sw0465 - below sw0465 virtual cockpit wont work properly.
A TPI exist for firmware 0475
Gashhey
C?ID=350180
NOTE:
ah okay, I can give that a go. I was changing adaptions however I wasn't driving around so wasn't updating.
Gashhey
C?ID=350180
are you able to get me a link to where I can download the firmware?
kreativ
Hidden
C?ID=108852
Your skoda dealer can help you with firmware update.
MIB firmware are not meant for sharing with the public
ghost
C?ID=139898
So what was your finally channel map on 17 and 5F?
origin
Sydney, Australia
C?ID=67485
Hello Everyone
I tried above setup on my skoda octavia 2020 facelift and I have upgraded main unit to 5Q0 035 874c.
everything ok except i could not show map on my virtual cockpit.
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,error out of range
ENG122230-ENG122340-Dashboard_Display_Configuration-crossroad_detail_map_compression_mode, error out of range
ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution,resolution_1
ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode, error out of range
ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most, error out of range
but
i have able to do below
my latest VCDS scan
If someone have a trick to make it work
Monday,23,August,2021,16:32:36:56957
VCDS Version: 21.3.0.0 (x64)  HEX-V2 CB: 0.4544.4
VIN: TMBBC7NE4L0060512   License Plate: KECIIL0202
Mileage: 13523km-8402mi   Repair Order:
Scan: 01 02 03 08 09 10 13 15 17 19 42 44 52 5F 6C BB BC
VIN: TMBBC7NE4L0060512   Mileage: 13523km-8402miles
Address 01: Engine (J623-CZDA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HD    HW: 04E 907 309 BH
   Component: R4 1.4l TFS   H26 3742
   Revision: R7H26---
   Coding: 01250032246419080000
   Shop #: WSC 31000 790 00292
   ASAM Dataset: EV_ECM14TFS01104E906027HD 001007
   ROD: EV_ECM14TFS01104E906027HD.rod
   VCID: 6D87C1A91D1C19B3545-8038
   Center armrest control head 1:
14632 - Coolant Pump for Intercooler
          P190D 00 [032] - Mechanical Malfunction
   Part No SW: 0CW 300 043 B    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1601
   Revision: 00005008    Serial number: CU501909196771
   ROD: EV_TCMDQ200021_VW26.rod
   VCID: 36352EC528CA9A6B65F-8062
   Part No SW: 5Q0 614 517 ES    HW: 5Q0 614 517 BP
   Component: ESC           H35 0190
   Revision: 00000000    Serial number: 62669000003046
   Coding: 24078A912026216C407C060160C5242451048402600624723621F030D0024B0B0000000012121212B835351919323200
   Shop #: WSC 31000 790 00267
   VCID: 06559E0518AACAEBB5F-8052
   Part No SW: 5E0 907 044 BA    HW: 5E0 907 044 BA
   Component: Climatronic   H04 2201
   Revision: 00001K00
   Coding: 01110004000100011005000800101022
   ASAM Dataset: EV_ACClimaBHBVW37X 006150
   ROD: EV_ACClimaBHBVW37X_006_SK37.rod
   VCID: 6597B989C5EC21F31C5-8030
   Air quality sensor:
          B10CD 00 [008] - -
                    Fault Frequency: 24
                    Reset counter: 248
                    Mileage: 13413 km
                    Date: 2021.07.14
                    Time: 11:06:38
                    Voltage terminal 30: 11.6 V
                    CAN input signal(s) status-Back-up lamp: OFF
   Part No SW: 5Q0 937 084 DE    HW: 5Q0 937 084 CD
   Component: BCM MQBAB B   H40 0312
   Serial number: 01001926601972
   ASAM Dataset: EV_BCMMQB 020001
   ROD: EV_BCMBOSCH_020_VW26.rod
   VCID: 7EA5F6E5407A922BFDF-802A
   Wiper motor control module:
   Component: WWS371 190709  051  0916
   Serial number: 887253F0401919000818
   Coding: 065DDD
   Component: RLHS  051  0206
   Serial number: S6Y19M09D12H06M02S28
   Coding: 00885D
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 507 AD    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004  0070
   Serial number: 00000018091920241080
6922 - Bulb for Low Beam Headlamp Right
          B1218 15 [008] - Open or Short to Plus
                    Reset counter: 224
                    Mileage: 13377 km
                    Date: 2021.07.02
                    Time: 14:02:14
7178 - Bulb for High Beam Headlamp Left
          B1219 15 [008] - Open or Short to Plus
                    Reset counter: 226
                    Mileage: 13385 km
                    Date: 2021.07.04
                    Time: 12:57:58
   Part No SW: 5QA 919 283 E    HW: 5QA 919 283
   Component: PDC 4 Kanal   H08 0061
   Serial number: 000150059319262
   Coding: 0601150011
   ASAM Dataset: EV_EPHVA14AU3700000 009044
   ROD: EV_EPHVA14AU3700000_009_AU37.rod
   VCID: 4CC16C2D4646F0BB23B-8018
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Coding: 3300600109FFC728949C810520400600000000000000000004
   VCID: 44D1440D6E1638FBEBB-8010
1389 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [FAULT_VBAT_BUSMON_LOW]
                    Reset counter: 230
                    Mileage: 13413 km
                    Date: 2021.07.18
                    Time: 12:04:05
                    Control Module temperature: 15 °C
                    Voltage terminal 15: 8.9 V
                    Status_ACC_System: ACC_Init
   Part No SW: 3Q0 959 655 CM    HW: 3Q0 959 655 CM
   Revision: --------    Serial number: 003Z2PJXKCH.
   Coding: 98CCC000000000005C540000008800000065
   ROD: EV_AirbaVW21TS6VW48X_VW37.rod
   VCID: 0B43AF3103C8B783EA1-805E
   Subsystem 1 - Part No SW: -----------    HW: 454 002 608 19
   Serial number: 3570000000079C38FF31
   Subsystem 2 - Part No SW: -----------    HW: 454 002 508 19
   Serial number: 358000000002BCF4CF34
   Subsystem 3 - Part No SW: -----------    HW: 454 802 608 19
   Serial number: 3510069708A19000000G
   Subsystem 4 - Part No SW: -----------    HW: 454 802 408 19
   Serial number: 35200034A60190000000
   Subsystem 5 - Part No SW: -----------    HW: 454 802 808 19
   Serial number: 35500C1279B19000000M
   Part No SW: 5E0 920 790 A    HW: 5E0 920 790 A
   Component: KOMBI         509 1711
   Coding: 25A4020825800008018822011001000080000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001031
   ROD: EV_DashBoardVDDMQBA0_VW37.rod
   VCID: 2615FE85F86AEAEBD5F-8072
16777018 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_Audio_0x31 keine Kommunikation]
                    Reset counter: 236
                    Mileage: 13437 km
                    Date: 2021.07.30
                    Time: 15:32:56
          U1110 00 [008] - -
          [BAP_TEL_0x28 keine Kommunikation]
                    Reset counter: 236
                    Mileage: 13437 km
                    Date: 2021.07.30
                    Time: 15:32:56
16777056 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_SDS_0x46 keine Kommunikation]
                    Reset counter: 236
                    Mileage: 13437 km
                    Date: 2021.07.30
                    Time: 15:32:56
   Component: GW MQB High   442 4388
   Revision: --------    Serial number: 0000120455
   Coding: 030100047F08570800000250140F00010001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 70B9D8DD0A2EF45B7F3-8024
   Generator:
   Component: 4-01-13-01-04
   Subsystem 2 - Part No SW: 3V0 919 719 E    HW: 3V0 919 719 E
   Component: E221__MFL-PR6  H03 0180
   Serial number: 000000000B0596200919
   Serial number: 75886003001908290B67
131699 - Control unit for information electronics 1
          U1054 00 [008] - No Communication
          [Timeout Knoten 0x73 / 5F - Steuergerät für Informationselektronik 1]
                    Reset counter: 240
                    Mileage: 13437 km
                    Date: 2021.07.30
                    Time: 15:32:49
                    Terminal 30 power supply: 11.2 V
                    Terminal 15: On
          U1101 00 [009] - Active
                    Fault Frequency: 27
                    Reset counter: 217
                    Mileage: 13480 km
                    Date: 2021.08.10
                    Time: 15:52:21
                    Terminal 30 power supply: 11.3 V
                    Terminal 15: On
8531970 - Quiescent Current
          U1406 00 [008] - Too High
          [Ruhestrom oberer Grenzwert überschritten]
                    Reset counter: 230
                    Time: 00:00:00
                    Terminal 30 power supply: 12.0 V
                    Terminal 15: OFF
8526361 - LV Energy Management
          B1802 F1 [008] - Warning Triggered
                    Fault Frequency: 12
                    Reset counter: 248
                    Mileage: 13413 km
                    Date: 2021.07.18
                    Time: 12:03:57
                    Terminal 30 power supply: 10.4 V
                    Terminal 15: On
   Part No SW: 5Q4 959 593 K    HW: 5Q4 959 593 K
   Component: TSG FS        007 0485
   Serial number: 0000390330452
   Coding: 00110120D001020000001100
   VCID: 4DC76129BD5CF9B3345-8018
   Subsystem 1 - Part No SW: 5Q0 959 408 A    HW: 5Q0 959 164
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000033920324
   Coding: 1D0200
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1082
   Coding: 01170000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 74B1D4CD7E36C87B9BB-8020
   Part No SW: 5Q4 959 592 K    HW: 5Q4 959 592 K
   Component: TSG BFS       007 0485
   Serial number: 0000390244344
   Subsystem 1 - Part No SW: 5Q0 959 407 A    HW: 5Q0 959 163
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000034150758
   Coding: 050200
   Component: MU-S-ND-ER    H41 0478
   Serial number: SKZAZ2U0985090
   Coding: 03730201FF000000F5411101C0AD0C1FAF030BB701B11600FF
   Shop #: WSC 12345 123 61029
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 343114CD3EB6887B5BB-8060
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: SKZ6ZHV3392155
   Data carrier:
   Subsystem 2 - Part No SW: 5L0 051 236 CL    HW: -----------
   Component: MRM3 2022  --- 1710
16 Faults Found:
1543 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 208
                    Mileage: 13501 km
                    Date: 2021.08.19
                    Time: 15:00:52
                    Voltage terminal 30: 11.2 V
                    Byte_Coding_Condition-byte_0_condition: OK
                    Byte_Coding_Condition-byte_1_condition: OK
                    Byte_Coding_Condition-byte_10_condition: ERROR
                    Byte_Coding_Condition-byte_11_condition: ERROR
                    Byte_Coding_Condition-byte_12_condition: ERROR
                    Byte_Coding_Condition-byte_13_condition: ERROR
                    Byte_Coding_Condition-byte_14_condition: ERROR
                    Byte_Coding_Condition-byte_15_condition: ERROR
                    Byte_Coding_Condition-byte_16_condition: ERROR
                    Byte_Coding_Condition-byte_17_condition: ERROR
                    Byte_Coding_Condition-byte_18_condition: ERROR
                    Byte_Coding_Condition-byte_19_condition: ERROR
                    Byte_Coding_Condition-byte_2_condition: OK
                    Byte_Coding_Condition-byte_20_condition: ERROR
                    Byte_Coding_Condition-byte_21_condition: ERROR
                    Byte_Coding_Condition-byte_22_condition: ERROR
                    Byte_Coding_Condition-byte_23_condition: ERROR
                    Byte_Coding_Condition-byte_24_condition: ERROR
                    Byte_Coding_Condition-byte_25_condition: ERROR
                    Byte_Coding_Condition-byte_26_condition: ERROR
                    Byte_Coding_Condition-byte_27_condition: ERROR
                    Byte_Coding_Condition-byte_3_condition: OK
                    Byte_Coding_Condition-byte_4_condition: OK
                    Byte_Coding_Condition-byte_5_condition: OK
                    Byte_Coding_Condition-byte_6_condition: OK
                    Byte_Coding_Condition-byte_7_condition: OK
                    Byte_Coding_Condition-byte_8_condition: ERROR
                    Byte_Coding_Condition-byte_9_condition: OK
          B201A 00 [009] - -
          [Check software version management]
                    Reset counter: 208
                    Mileage: 13501 km
                    Date: 2021.08.19
                    Time: 15:00:52
                    Status_Software_Version_Management-module_name: K
1556 - Internal Control Module Memory Check Sum Error
          B2000 87 [009] - Missing message
                    Reset counter: 208
                    Mileage: 13501 km
                    Date: 2021.08.19
                    Time: 15:06:29
                    System_Software_Error-SW_Status_Consistency: 04 01 01
                    System_Software_Error-SW_Status_Device: o
          [Anti-theft protection - component protection active (0xEA6300)]
                    Reset counter: 208
                    Mileage: 13501 km
                    Date: 2021.08.19
                    Time: 15:00:52
0013 - Antenna Amplifier 1 for Digital Radio
          B1270 13 [009] - Open Circuit
                    Reset counter: 208
                    Mileage: 13501 km
                    Date: 2021.08.19
                    Time: 15:00:53
                    Status of digital radio antenna 1-Antenna current: 0 mA
                    Status of digital radio antenna 1-Connection between radio and antenna amplifier: Open circuit
                    Status of digital radio antenna 1-Connection between antenna amplifier and antenna: Not available
                    Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC: 0.000000
                    Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC: 0.000000
2565 - GPS Antenna
          B1054 13 [009] - Open Circuit
          [GPS aerial - open circuit]
                    Reset counter: 208
                    Mileage: 13501 km
                    Date: 2021.08.19
                    Time: 15:00:53
3077 - Telephone baseplate
          B1051 13 [009] - Open Circuit
          [Bracket for mobile phone holder - open circuit]
                    Reset counter: 208
                    Mileage: 13501 km
                    Date: 2021.08.19
                    Time: 15:00:52
6666 - Optical data bus
          U1049 00 [008] - Open circuit
                    Reset counter: 249
                    Mileage: 13506 km
                    Date: 2021.08.20
                    Time: 12:05:04
                    Voltage terminal 30: 11.8 V
                    System_Temperature_Sensor_6-max.value: -50 °C
                    System_Temperature_Sensor_6-min.value: -50 °C
                    System_Temperature_Sensor_6-Up-to-date: 22 °C
7193 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Lane departure warning: heading control (0x19) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 208
                    Mileage: 13501 km
                    Date: 2021.08.19
                    Time: 15:00:55
                    BAP-BAP_Function_ID: 02
7194 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Side assist (0x1A) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 208
                    Mileage: 13501 km
                    Date: 2021.08.19
                    Time: 15:00:55
7201 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Road sign display (0x21) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 208
                    Mileage: 13501 km
                    Date: 2021.08.19
                    Time: 15:00:55
7205 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Battery management (0x25) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 208
                    Mileage: 13501 km
                    Date: 2021.08.19
                    Time: 15:00:55
7226 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Pedestrian assist (0x3A) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 208
                    Mileage: 13501 km
                    Date: 2021.08.19
                    Time: 15:00:55
7228 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Efficiency assist (0x3C) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 208
                    Mileage: 13501 km
                    Date: 2021.08.19
                    Time: 15:00:56
7219 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Emergency call module (0x33) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 208
                    Mileage: 13501 km
                    Date: 2021.08.19
                    Time: 15:00:55
6672 - Optical Data Bus for Display in Instruments
          U10CF 00 [008] - Intermittent Disruption
          [Optical data bus: sporadic open circuit in instrument cluster display]
                    Reset counter: 249
                    Mileage: 13506 km
                    Date: 2021.08.20
                    Time: 12:05:04
                    System_Temperature_Sensor_6-Up-to-date: 23 °C
   Component: RVC Compact   H18 0231
   Coding: 0473010122002017000040
   ROD: EV_CamSysRVRVCPANAMQBAB.rod
   VCID: 392F25F919D4751388D-806C
Address BB: Door Rear Drv
Thank you
downtime
C?ID=280813
Your 5F is incorrectly coded and the adaptations are not matching your car. You need to check those first and make sure they match your old unit? I hope you got adamap from your old 5F unit before the change that you can manually change the channels to match.
You have component protection showing on both the CAN Gateway and the 5F, these need clearing by someone with e.g. FAZIT access as it cannot be cleared with VCDS.
origin
Sydney, Australia
C?ID=67485
Hello @downtime Thank you for your replied. Yes i have my old one below with VCDS
my old 5F = 03730100FF00000041510001001100002F0208E60120040003
my new 5F = 03730200FF000000F5411101C0AD0C1FAF030BB501B11700FF
Long coding from old Mib to new Mib = 03730100FF00000041510001001100002F0208E60120040003
i saw someone done it as below to combine
Long Coding from original Mib1: 03735101FF0000001111120100A800002F0001860100010046
Long Coding that came with the new Mib2: 03730201FF00000051111201008800002F0208C601200500CF
Long Coding from Mib1 pasted on Mib2 with USB Function changed: 03735101FF0000001111120100A800002F0001C60100010046
Could you let me know which one should i combine from old to new ?
Hello @PetrolDave Thank you for your replied . Could you recommended someone can do remote? the ebay person told me the device CP removed and unlock
Could you tell me how much to remove CP ?
Thank you
downtime
C?ID=280813
Need to check the coding.
The adamap is more important. That is having the biggest flaws in your installation. The missing messages are coming from incorrectly enabled features in adaptation.
origin
Sydney, Australia
C?ID=67485
Hello @downtime .. ok i will plug the old 5F tomorrow and take a screenshot of the adamap. I will compare with a new 5F adamap
Thank you
I'm the other side of the globe to you so all I can suggest is that you find a VW/Audi/Skoda specialist near you with Fazit access and ask them what they will charge.
downtime
C?ID=280813
Thank you
Easiest way is to use vcds, there applications and controller channel map. Export adaptation map as csv. Do that to both old and new units.
Then install notepad++ and compare plugin to that.
Open both files with notepad++ and compare.
Very easy to see differences and change the adaptations with vcds at the same time
