09 Electronics message normal on Atlas?
C?ID=313143
When I try to open the 09 Central Electronics of my 2018 Atlas, I get the following message:
Coding is NOT Supported by this Control Module Variant. Replacement Control Modules must be parameterized by using the Factory Tool and Software-Version-Management (SVM)
Is this normal on the Atlas? I'm used to my Jetta so sorry if this is stupid.
Autoscan:
Sunday,05,January,2020,01:42:42:41190
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VMWare)
VCDS Version 19.6.2.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: 1V2KR2CA8JC567568   License Plate:
Mileage: 88572km-55036mi   Repair Order:
Chassis Type: CA-VW41 (3Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 2B 3C 42 44 4B 52 5F 6C 75
          D6 D7
VIN: 1V2KR2CA8JC567568   Mileage: 88572km-55036miles
Address 01: Engine (0-32-CDVC)       Labels:. 03H-907-309-V1.clb
   Part No SW: 03H 906 026 E    HW: 03H 907 309 K
   Component: VR6 3.6l FSI  H21 6024
   Revision: 52H21000
   Coding: 012A00124424010870000000000000000000000000000000
   Shop #: WSC 03302 444 00000
   ASAM Dataset: EV_ECM36FSI01103H906026E 001005
   ROD: EV_ECM36FSI01103H906026AG.rod
   VCID: 2708F3CDDF671A5FA8D-8073
   CAN Converter 01:
Readiness: 0000 0100
   Part No SW: 09G 927 158 A    HW: 09G 927 158
   Component: AISIN AQ8     206 3387
   Coding: 0000000100000000000000000000000000000000
   Shop #: WSC 09003 957 00200
   ROD: EV_TCMAQ450031_VW37.rod
   VCID: 313C1D95E1A354EF769-8065
   Part No SW: 5Q0 614 517 CE    HW: 5Q0 614 517 AC
   Component: ESC           H25 0413
   Revision: 00000000    Serial number: 50958000000417
   Coding: 44FC6B8D84261A73C57C0306A2CB6922D62158A3C045967E00415058C28A4200002F641C12141A118DDB45506CC8CF
   ROD: EV_Brake1UDSContiMK100IPB_036_VW41.rod
   VCID: 76B6EE89484D33D7E3B-8023
16401 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 208
                    Mileage: 88230 km
                    Date: 2019.12.11
                    Time: 14:01:41
   Component: VWKESSYMQB    037 0907
   Revision: 00037000    Serial number: 0467740447
   Coding: 1F20000723
   VCID: 3E2636A920FDBB97FBB-806B
          U1400 00 [008] - -
                    Reset counter: 211
                    Mileage: 88230 km
                    Date: 2019.12.14
                    Time: 14:12:49
                    ZAT_pressed: OFF
                    Control Module Voltage: 7.486 V
                    Vehicle speed: 0.0 km/h
                    Engine speed: 0.0 /min
                    Coding information: coded
                    Driver door: Open
                    Front Passenger Door: closed
                    Left rear door: closed
                    Right rear door: closed
                    Active_LF_scans: Init
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
Address 08: Auto HVAC (J301)       Labels:* None
   Part No SW: 3CN 907 426 E    HW: 3CN 907 426 E
   Component: AC Manuell    H04 2002
   Revision: 00001K00
   Coding: 1602000620001800100020404200000C
   ASAM Dataset: EV_ACManueBHBVW416 001002
   ROD: EV_ACManueBHBVW416.rod
   VCID: 45D45945452BE84FBA1-8011
   Fresh Air Blower Back:
   Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
   Part No SW: 5Q0 937 085 BN    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H36 0253
   Serial number: 8015015902ˇˇˇˇ
   ROD: EV_BCMBOSCH_018.rod
   VCID: 06569E4938AD2357F3B-8053
   Subsystem 1 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  047 0105
   Serial number: S7Y18M02D13H15M04S13
   Coding: 00382D
204290 - Remote key 1
          B1479 18 [009] - Current Too Low
                    Reset counter: 168
                    Mileage: 88230 km
                    Date: 2019.12.11
                    Time: 14:06:11
204546 - Remote key 2
                    Reset counter: 168
                    Mileage: 88230 km
                    Date: 2019.12.11
                    Time: 14:05:25
   Part No SW: 3Q0 959 655 BN    HW: 3Q0 959 655 BN
   Component: Airbag VW21   006 0713
   Revision: --------    Serial number: 003SUM5CHKEM
   Coding: 8CCCDC00000000005000001A420800000065
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 0B40AF7D23CF5E3FAC5-805F
   Occupant Detection:
   Component: Occ.Detection  H13 0022
   Serial number: IBH0000J180008X3TO0%
   Coding: 303030
   Subsystem 2 - Part No SW: -----------    HW: 454 001 212 17
   Serial number: 35700000000EDC286B2/
   Subsystem 3 - Part No SW: -----------    HW: 454 001 401 18
   Serial number: 358000000002D6ECCB22
   Subsystem 4 - Part No SW: -----------    HW: 454 801 001 18
   Serial number: 351002768FD12000000K
   Subsystem 5 - Part No SW: -----------    HW: 454 801 401 18
   Serial number: 3520068E401130000004
   Subsystem 6 - Part No SW: -----------    HW: 454 800 201 18
   Serial number: 35500DAC97612000000U
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 454 800 201 18
   Component: FrontSensor_P  304 0149
   Serial number: 35600A7E17112000000E
   Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 18021820241001
   Coding: 0410
   VCID: 0748934D3FA73A5F88D-8053
Address 17: Instruments (J285)       Labels:* None-SRI3
   Part No SW: 3CN 920 850 A    HW: 3CN 920 850 A
   Component: KOMBI         380 0310
   Coding: 0BA4171DAB88CF0502086B0850000000A0000000
   VCID: 3D2431A52DFBA08FE21-8069
   Component: GW MQB High   518 5323
   Serial number: 26011800840079
   Coding: 030500347F087300FB0320481E0F00010001070000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 382A20B102D985A7317-806D
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0103
   Serial number: 28180000051590091439
   Coding: 30FFFF
   Serial number: 3047705600
   Component: Haldex4Motion H52 7084
   Serial number: HA1-00007.12.17
   Coding: 0301
   VCID: 4CC26C616641190765F-8019
   Part No SW: 3Q0 905 861 B    HW: 3Q0 905 861 B
   Component: ELV-MQBB      H05 0020
   Serial number: 18000012734010
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW41.rod
   VCID: 3330179D1BBF66FF045-8067
   Component: HRE_Master    H12 0080
   Serial number: 0468858943
   Coding: 01011103
   ROD: EV_HREntryHella_VW27.rod
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0080
   Serial number: 0468952901
   Coding: 010111
   Serial number: 170218A0080489
   Coding: 003013200000020000000000
   VCID: 43D0475D4B1FD67F945-8017
   Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000000228640
   Coding: 011000
   Revision: 00000000    Serial number: 0002358811
   Coding: 01000310004001
   ROD: EV_SteerAssisVWBSMQBA_009_VW41.rod
   VCID: 40DA48515A09CD67897-8015
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Serial number: 03031800841812
   Coding: 000000070100135200010000000000000000000000000000000000000000
   VCID: 72BED29924252FF7CF3-8027
   Serial number: 060318A00801Q9
   VCID: 42DE42595405DF779F3-8017
   Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000000226286
   Coding: 091000
   Part No SW: 3Q0 035 844 B    HW: 3Q0 035 844 B
   Component: MU-S-S-US     722 0867
   Coding: 02140600FF00000051220001001808001F0500C40120050002
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 2E0606E9F09D4B176BB-807B
   Subsystem 1 - Part No SW: 5G6 919 605 C    HW: 5G6 919 605 C
   Component: ABT_Std-2  H50 8130
   Serial number: VWZ6ZJV0245693
          B11CF 53 [009] - Deactivated
                    Reset counter: 168
                    Mileage: 88230 km
                    Date: 2019.12.11
                    Time: 14:02:04
                    Voltage terminal 30: 14.8 V
                    SDARS_tuner_status_2-Audio Signal: Available
                    SDARS_tuner_status_2-Antenna current: 102 mA
                    SDARS_tuner_status_2-Reception quality: optimum_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
   Coding: 01150602A0002017300040
   VCID: 392C25B539D39CAFCE9-806D
   Component: OCULowMQBUS   009 0570
   Coding: 02140602C2821A017F1E06020000
   ROD: EV_OCULowMQB.rod
   Part No SW: 7P5 941 591 AA    HW: 7P5 941 591 A
   Component: LED1L         H06 0003
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
   VCID: 7BA0FFBD736F6EBF9C5-802F
   Component: LED1R         H06 0003
   ROD: EV_LED_PLUS_R_KEBODAVW416_VW41.rod
End----------(Elapsed Time: 01:36, VBatt start/end: 12.2V/12.2V)-----------
DV52
C?ID=194404
^^^801:Hi.
If you look at the hex09 module in your auto-scan, you will see that the "coding" has a zero-string. That means that your MQB build- platform, Atlas has one of the later model BCM s where ALL the software switches that were in "Coding" are now in Adaptation channels.
What are you attempting to do?
C?ID=313143
Windows up/down with remote, disable auto start/stop, rain window up
DV52
C?ID=194404
801: hi again- I'm mighty confused (well......... to be fair - I'm more confused than normal) !;)
hmm......... aren't these 3 x tweaks adaptation channel based on MQB platform vehicles? Except perhaps for the auto-rain close tweak, which requires access to the rain-light sensor coding - which, although the RLS is a LIN slave to the BCM- this still does NOT require access to the BCM coding.
I've clearly missed something - please help!!!
C?ID=313143
I guess I don't know. I'm fairly new to this. I coded my mk5 Jetta pretty heavily and I guess I'm just not used to the adaption processes (aside from the mk6 steering wheel, new transmission). So to answer your question, maybe? I'm more seeking direction.
DV52
C?ID=194404
^^^801: so, I have this sense of ownership of your problem - I guess because you have been kind and honest in your response to my questions!!! Which of the tweaks do you want to start with? Perhaps windows up/down with remote?
PS: I'm less familiar with the Atlas- but I'm aware that in other late-model MQB platform vehicles, the tweak to disable auto start/stop (which is called the "voltage method") won't work.
PPS: Also, I'm aware that the auto rain-close tweak has been problematic on some MQB platform vehicles (depending on the type of rain sensor that's fitted) - again, not sure if this applies to the Atlas.
C?ID=313143
Right now the only thing that's driving me nuts are the single fog on when turning.
Somnus
SLC, USA
C?ID=215931
If you want to turn off the "fog lights as cornering lights" feature, try changing the following adaptation channels in the BCM with SA login 31347
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B: From Abbiegelicht links  To not active
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B: From Abbiegelicht rechts  To not active
Or if I read your post incorrectly, and you want to turn them ON, just reverse it. :D
C?ID=313143
Great! Thanks! Now for the remote window roll down/up.... ha.
UPDATE: figured it out. Thank you guys.
