Results 1 to 10 of 10
Thread: 2011 POLO 6R ABS LONG CODING ERROR 22
    Jan 2020
    England
    Im so sorry I know this has been covered lots of times, please could somebody help me I have a 2011 polo with no long coding, I have tried the codes that other people have been suggested but every time I just get error 22.
    If any of you can help me id more than appreciate it..
    Thank you in advance
    Saturday,04,January,2020,14:28:04:40489
    VCDS Version: 19.6.2.0 (x64)
    Dealer/Shop Name: AAK AUTO SERVICES
    Workshop Code: 444 00999 000000
    VIN: WVWZZZ6RZBU038680   License Plate: FX11KFU
    Mileage: 123200km-76552mi   Repair Order:
    Chassis Type: 6R-VW25 (6N0)
    Scan: 01 03 04 08 09 15 17 19 25 44 56
    VIN: WVWZZZ6RZBU038680   Mileage: 123200km-76552miles
    Address 01: Engine (CGP)       Labels: 03E-906-033-AZQ.lbl
       Part No SW: 03E 906 023 AL    HW: 03E 906 023 L
       Component: SIMOS91 1.2l 4V     4523
       Revision: --H05---    Serial number:
       Coding: 0000071
       Shop #: WSC 00999 444 64523
       VCID: 69DFD25043E7CB0710-5164
    Readiness: N/A
    Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
       Part No SW: 6R0 907 379 AJ    HW: 6R0 907 379 AF
       Revision: --------
       Shop #: WSC 00000 000 31414
       VCID: 0605F9ECB5B9047F9D-8052
                        Fault Frequency: 23
                        Reset counter: 235
                        Mileage: 123207 km
                        Date: 2014.05.25
                        Time: 01:27:22
                        Hex Value: 0x0007
                        Hex Value: 0x0000
                        Hex Value: 0x3213
                        Hex Value: 0x14B4
                        Hex Value: 0x00FF
                        Hex Value: 0x7F7F
                        Hex Value: 0x7F00
                        Fault Status: 01100101
                        Fault Frequency: 12
                        Reset counter: 235
                        Mileage: 123207 km
                        Date: 2014.05.25
                        Time: 07:12:18
                        Hex Value: 0x0007
                        Hex Value: 0x0000
                        Hex Value: 0x3251
                        Hex Value: 0x1BA2
                        Hex Value: 0x00FF
                        Hex Value: 0x7F7F
                        Hex Value: 0x7F00
                        Fault Frequency: 23
                        Reset counter: 235
                        Mileage: 123207 km
                        Date: 2014.05.25
                        Time: 01:27:22
                        Hex Value: 0x0007
                        Hex Value: 0x0000
                        Hex Value: 0x32E1
                        Hex Value: 0x20B4
                        Hex Value: 0x00FF
                        Hex Value: 0x7F7F
                        Hex Value: 0x7F00
    03306 - Coding Not Valid
                        Fault Frequency: 9
                        Reset counter: 19
                        Mileage: 123207 km
                        Date: 2014.05.25
                        Time: 06:32:02
                        Hex Value: 0x0002
                        Hex Value: 0x0000
                        Hex Value: 0x32E7
                        Hex Value: 0x25C6
                        Hex Value: 0x00FF
                        Hex Value: 0x7F80
                        Hex Value: 0x7C00
    Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AP.clb
       Part No SW: 6R0 820 045 H    HW: 6R0 820 045 H
       Component: Climatic       25 0660
       Revision: 00 11 25
       VCID: 3363703892AB41D76A-8066
       Part No SW: 6R0 937 085 E    HW: 6R0 937 085
       Component: BCM PQ25 M+   H46 0256
       Revision: BB046001    Serial number: 0341 299100793
       Coding: 64B02BBF08A10048002000003D2B0C900040410F60060000200000000000
       Shop #: WSC 06342 000 1048576
       VCID: 3D775600A4EF87A78C-8068
       Subsystem 1 - Part No SW: 6R0 959 802 R    HW: 6R0 959 802 R  Labels: 6R0-959-802.CLB
       Component: J386__TSG_FT  006 0903
       Serial number: KU0-KU007.09.1010956
       Coding: 18BC30
       Subsystem 2 - Part No SW: 6R0 959 801 T    HW: 6R0 959 801 T  Labels: 6R0-959-801.CLB
       Component: J387__TSG_BT  006 0902
       Serial number: KU0-KU025.08.1011357
       Coding: 08BC30
    00532 - Supply Voltage B+
                        Fault Status: 00100001
                        Reset counter: 19
                        Mileage: 123207 km
                        Date: 2014.05.25
                        Time: 06:32:09
                        Reset counter: 19
       Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
       Component: VW10Airbag00N H09 0020
       Revision: --------    Serial number: 003GX007HDDG
       Coding: 00304E
       Shop #: WSC 31414 790 31414
       ROD: EV_AirbaVW10BPAVW250.rod
       VCID: 4A9D0DDCED21201F39-801E
       Serial number: 3572SRB40000CB245282
       Serial number: 3582SRB40000CB28BB4I
       Serial number: 3515RRB40636T8MIG95X
       Serial number: 3525RRB40616VQ8AC0P.
       Part No SW: 6R0 920 960 E    HW: 6R0 920 960 E
       Component: KOMBI         H04 0304
       Coding: 440200
       Shop #: WSC 31414 790 50316
       ROD: EV_Kombi_UDS_VDD_RM09_004_VW23.rod
       VCID: 377B44288ED3ADF756-8062
       Part No SW: 6N0 909 901     HW: 6R0 937 085
       Component: GW-K-CAN TP20 H46 0256
       Revision: BB046001
       Coding: 002300
       VCID: 70E9BF34A33D3ACF57-8024
       Component: IMMO          H04 0304
       VCID: 6ADDAD5C8DE1C01F19-803E
       Part No: 6R0 423 156 B
       Component: LenkhilfeTRW        C277
       Coding: 11250
       Shop #: WSC 31414
       VCID: 2F6B7C48EA8365370E-807A
       Part No SW: 5M0 035 156 C    HW: 5M0 035 156 C
       Component: Radio         510 0521
       Revision: R0510001    Serial number: VWZ5Z1K0380520
       Coding: 0000020002
       VCID: 295F925040670B07D0-807C
                        Reset counter: 235
                        Mileage: 123207 km
                        Date: 2014.05.25
                        Time: 06:52:54
    End-------------------------(Elapsed Time: 02:35)--------------------------
    What happened to the car for the ABS long coding to be lost?
    Jan 2020
    England
    We dont know, it came to us having been at a previous garage, they had changed timing chain, cat, ho2s, map, crank breather amongst other bits and piece. Ie parts canon was fired.
    It has low manifold pressure which we have been looking into but all the abs, tpms lights etc on and boss wants them cleared before carrying on in case its more than just the coding.
    Quote Originally Posted by Daveflahaut View Post
    It would be a good idea to Get Verified so we can move this to Car Repair Support.
    Jan 2020
    England
    Will try now
  6. #6
    Aug 2016
    The Hague, NL
    Try this one: 230224E3217000BAC42B24EA84D100801700
  7. Likes Uwe liked this post
    Since the OP is verified now, moving to Car Repair Support.
  9. #8
    Jan 2020
    England
    Iichel thank you sooo much. How do you work that out so i can learn from this? �� niw just to try and do the steering angle sensor learning and all should be gone.
  10. Likes Uwe liked this post
  11. #9
    Aug 2016
    The Hague, NL
    There is a pattern in it. Model, make, engine, VIN are all hidden on the bytes. And more. Just need to know where to look
    Good luck with the steering angle. Don't forget to reset tpms
  12. Likes Uwe, Jack@European_Parts liked this post
  13. #10
