Results 1 to 5 of 5
Thread: Open armor
    Apr 2018
    Norway
    Open armor
    Hey I don't get the hood of a caddy 2013 mod. looks the surface that the wire has gone off.
    This happened after the alternator switch. So, I wonder how I can get it up from the outside?
    Sunday,13,October,2019,17:48:50:36574
    Dealer/Shop Name: F526727B
    VIN: WV1ZZZ2KZBX305796   License Plate: CADDY
                    Address 01: Engine       Labels: 03L-906-023-CAY.clb
    Control Module Part Number: 03L 906 023 TH    HW: 03L 907 425 C
      Component and/or Version: R4 1.6l TDI   H43 9978
               Software Coding: 00114014032401080000
                Work Shop Code: WSC 35110 790 50316
                  ASAM Dataset: EV_ECM16TDI02103L906023TH 003002 (VN35)
                           ROD: EV_ECM16TDI02103L997557R.rod
                          VCID: 7F5BFE2A4775911FB0D-802A
    9840 - Injector: Cylinder 4 (N33)
              P0204 00 [237] - Circuit Malfunction
                        Mileage: 136861 km
                        Date: 2019.10.13
                        Time: 17:14:37
                        Engine speed: 1596.75 /min
                        Normed load value: 6.7 %
                        Vehicle speed: 81 km/h
                        Coolant temperature: 88 C
                        Intake air temperature: 15 C
                        Voltage terminal 30: 14.456 V
                        Incorrect information on selected Piezo power level-LF_STATE_PPS_SPI[0]: 0
                        Injector valve 3: capacity-CAPA_INJ_MAIN[2]: 24.3046 F
                        Voltage load of main injection cylinder 3-CHR_INJ_MAIN[2]: 1474.0 As
                        Measured energy of main injection cylinder 3-EGY_INJ_MAIN[2]: 44.695 mJ
                        Supply voltage of analog output 1-VCC_1: 5.00 V
                        Supply voltage of analog output 2-VCC_2: 5.02 V
                        Injection valve 3: voltage-V_INJ_MAIN[2]: 60.64 V
    9772 - Internal Control Module
              P0606 00 [040] - Processor Fault
                        Mileage: 136861 km
                        Date: 2019.10.13
                        Time: 17:14:22
                        Engine speed: 2053.50 /min
                        Normed load value: 49.8 %
                        Vehicle speed: 107 km/h
                        Coolant temperature: 87 C
                        Voltage terminal 30: 13.327 V
                        Environmental conditions-LF_TI_MON_1_ENVD: 4
                        Engine status-SF_ENG_STATE: PL
                        Engine torque-TQI_SP: 139.72 Nm
    Readiness: 1 1 0 0 0
    Monday,14,October,2019,11:04:17:36574
                    Address 19: CAN Gateway       Labels: 7N0-907-530-V2.clb
    Control Module Part Number: 7N0 907 530 D    HW: 1K0 907 951
      Component and/or Version: J533  Gateway H35 0614
               Software Coding: 357400
                Work Shop Code: WSC 35110 377 08192
                          VCID: 313FE812C121B76F769-8064
    01207 - Control Module for Auxiliary Heater (J364)
                        Fault Status: 00110100
                        Reset counter: 106
                        Mileage: 136201 km
                        Date: 2032.14.01
                        Time: 09:28:28
    Address 19: DTCs clearedFriday,03,January,2020,08:45:50:36574
    Fault Codes have been Erased
    10938 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
              P2185 00 [167] - Signal too High
                        Mileage: 140028 km
                        Date: 2020.01.03
                        Time: 10:13:29
                        Engine speed: 779.00 /min
                        Normed load value: 24.7 %
                        Coolant temperature: 60 C
                        Intake air temperature: 16 C
                        Ambient air pressure: 960 mbar
                        Voltage terminal 30: 14.682 V
    16.4905 S, 151.7375 W
    Is your hood (bonnet) stuck closed because of a broken release cable?
    If so, you may be able to get access to the cable connection behind the left headlight.
    - You might be able to do this from the underside of the vehicle.
    - The use of a metal hook / tool maybe needed to access and "grab" the cable.
    Or.....
    Are you concerned with the fault codes in the [01-Engine]?
    P0606 - Internal Control Module: Processor Fault
    In either case, we do recommend the use of the Official Factory Repair Information
    Thank you,
    drpeter
  3. Likes cleo, Uwe, Jack@European_Parts liked this post
    Apr 2018
    Norway
    Thanks for reply. Did as you said it worked very well, I got the bumper loosened. Got his hand in between the lantern and over got thanks in the wire it had jumped off the whole front there. Got loosened the clip and pulled it in so the bonnet loosened
  5. Likes DrPeter, Jack@European_Parts liked this post
  6. #4
    Awesome!!
  7. Likes cleo, Jack@European_Parts liked this post
  8. #5
    Tartu, Estonia
    Piezo crysytal of this injector is dead. Replace Injector and enjoy happy life.
    Named fault will also generate the ECU Processor fault.
    But first check wiring.
    I am a VW Freak - Le WV Freaks OR Come visit me at my work with ODIS concerns - FORSS ODIS GeKo/FaZit access for VW/AUDI/koda
    The world is my oyster...
