Page 4 of 4 FirstFirst ... 234
Results 31 to 37 of 37
Thread: Passat B6 2007 retrofit ACC?
  1. #31
    Open module(s) showing DTC in VCDS, select Clear Codes?
  2. #32
    Oct 2016
    Norway
    That will not erase dtc in supported codes!
  3. #33
    Quote Originally Posted by sers77 View Post
    Please explain what you mean by "supported codes"???
    Give an example if possible
  4. #34
    Oct 2016
    Norway
  6. #35
    Supported Codes shows (on control modules that support this feature) produces a list of the DTCs that the module in question is ABLE to detect/report as faults. It is not intended as a list of currently active/detected fault codes. You cannot clear DTCs there. If you have cleared DTCs on the Fault Codes screen for that module and there is still something showing as active on the Supported Codes screen, then the module is buggy about the way it reports stuff using that function.
  8. #36
    Oct 2016
    Norway
    But if DTC is present on another module (for another module) and you find a RED dtc under supported codes, then disconnecting the battery for 15min might solve the problem
    Got the ECU DTC for 13 erased, but got another one for ABS now
    The ABS flashed to 3C0698109E and i can choose and change to 8T3 and 8T5 but gives DTC 01319.
    With ABS flashed to HW25 3C0698109E I cannot change to BMP-engine, its stuck on "16 MY 2010: 2.0l CR-TDI CBAB & 6-speed automatic". So I guess the coding helper is wrong?!?!?
    With ABS flashed to HW20 3C0614109L (shows up as HW25 in VCDS) I can choose BMP-engine but not change to either 8T3 or 8T5...
    Saturday,21,March,2020,17:07:41:07409
    VCDS Version: 19.6.2.2 (x64)
    VIN: WVWZZZ3CZ7E096323   License Plate: RK14554
    Mileage: 189330km-117644mi   Repair Order:
    Chassis Type: 3C-VW46 (3C0)
    Scan: 01 02 03 08 09 10 13 15 16 17 19 25 2E 36 37 42 44 46 47 52
              53 56 62 69 6D 72 77 7D
    VIN: WVWZZZ3CZ7E096323   Mileage: 189330km-117644miles
    Address 01: Engine        Labels: 03G-906-021-BMM.clb
       Part No SW: 03G 906 021 NK    HW: 03G 906 021 AB
       Component: R4 2,0L EDC A000AG  9972
       Revision: --H06---    Serial number: VWZCZ000000000
       Coding: 0000078
       Shop #: WSC 61962 003 1048576
       VCID: 75E519001CDDC7E786-8020
       Part No SW: 02E 300 050 D    HW: 02E 927 770 AD
       Component: GSG DSG         082 1404
       Revision: 05308020    Serial number: 00001105240204
       Shop #: WSC 04940 001 00001
       VCID: 13214798326979D708-8046
    Address 03: ABS Brakes        Labels:. 3C0-614-109-C4.clb
       Part No SW: 3C0 698 109 E    HW: 3C0 614 109 AF
       Component: J104    C4 440 V3   0017
       Revision: --025---    Serial number: 00000705092387
       Coding: 0026902
       VCID: 2C53FC648F17C62F29-8078
                        Reset counter: 138
                        Mileage: 189335 km
                        Date: 2020.03.21
                        Time: 01:25:55
                        Hex Value: 0x0000
                        Voltage: 14.00 V
                        Bin. Bits: 00011111
                        Count: 161
                        Hex Value: 0x0000
    Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
       Part No SW: 3C0 907 044 AJ    HW: 3C0 907 044 AJ
       Component: ClimatronicPQ46 050 0505
       Revision: 00050005    Serial number: 00000000000000
       VCID: 69DD45704065130712-803C
       Part No SW: 3C8 937 049 F    HW: 3C8 937 049 F
       Revision: 00H54000    Serial number: 00000009463926
       Coding: ED888E2701061A00500A00000F000000841D1D435C80312C002000000000
       Shop #: WSC 05124 123 12345
       VCID: 3463E40457279EEF71-8060
       Subsystem 1 - Part No: 3C1 955 119 A  Labels: 1KX-955-119.CLB
       Component: Wischer VW461   012 0503
       Coding: 00064501
       Shop #: WSC 05124
       Component: RLS     250414 054  0403
       Coding: 01977121
       Shop #: WSC 05124
       Part No SW: 3C8 919 475 A    HW: 3C8 919 475
       Component: PARKHILFE 8K  H07 0009
       Revision: --------    Serial number: 08740933702375
       Coding: 100102
       Shop #: WSC 05314 123 12345
       VCID: 326FE21C6D3390DF63-8066
    Address 13: Auto Dist. Reg        Labels: 3C0-907-567.clb
       Part No SW: 3C0 907 567 L    HW: 3C0 907 567 L
       Component: AC201  RDW 1    031 0120
       Revision: 00031000    Serial number: 00000000051681
       Coding: 0010000
       Part No SW: 3C0 909 605 N    HW: 3C0 909 605 N
       Component: 0D AIRBAG VW8R  030 2522
       Revision: 11030000    Serial number: 003B2PJU4TMG
       Coding: 0012356
       Shop #: WSC 05311 000 00000
       VCID: 316DED10A835ABC71A-8064
       Subsystem 1 - Serial number: 6332MSME12431421W
       Subsystem 2 - Serial number: 6342MSME124569414
       Subsystem 3 - Serial number: 6351HTS6K5QADO63U
       Subsystem 4 - Serial number: 6361HTS6K5QE5KN2$
       Part No SW: 3C9 953 501 BM    HW: 5K0 953 569 T
       Revision: FF010040    Serial number: 20120209100177
       Coding: 1992A50002
       VCID: 75E51900D4DDC7E786-8020
       Component: E221__MFL-TAS  H06 0010
       Coding: 830000
       Part No SW: 3AA 920 880 C    HW: 3AA 920 880 C
       Component: KOMBI         H03 0407
       Coding: 161D00
       Shop #: WSC 05314 115 00000
       VCID: 3361E7189A2999D768-8066
       Part No SW: 3C0 907 530 Q    HW: 3C0 907 951
       Component: J533  Gateway   H13 0171
       Revision:   H13       Serial number: 3520P09C0203F9
       Coding: FDA4FF56520612002002
       VCID: 2F69EB68BE01BD370C-807A
       Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
       Component:    IMMO         042 0383
       Revision: 00042000    Serial number: VWZCZ000000000
       Shop #: WSC 06402 785 00200
       VCID: 397DD53070456387A2-806C
    Address 2E: Media Player 3
    Address 36: Seat Mem. Drvr (J810)       Labels: 3C0-959-760.lbl
       Part No SW: 3C8 959 760 A    HW: 3C8 959 760 A
       Component: Sitzmemory    H05 2601
       Revision: 00H05000
       Coding: 000039
       VCID: 3361E718922999D768-8066
       Part No SW: 1T0 035 680 D    HW: 1T0 035 680 C
       Component: RNS-MID       H06 4020
       Revision: AB001001    Serial number: VWZ6Z7K9061156
       Coding: 00050400010000A20011
       Shop #: WSC 01324 020 00200
       VCID: 2F69EB687E01BD370C-807A
       Part No SW: 1K0 959 701 AE    HW: 1K0 959 793 P
       Component: J386  TUER-SG FT    1517
       Revision: 71009005    Serial number: 00000643489028
       Coding: 0004599
       VCID: 71ED2D1068B5EBC75A-8024
       Part No: 1K1 909 144 L
       Component: EPS_ZFLS Kl.136 H07 1806
       Shop #: WSC 02598 001 1048576
       Component:    KSG PQ46 ELV 042 0572
       Coding: 189109005103C83F3F02151FF0C88F06705900
       Shop #: WSC 00046 123 12345
       Part No SW: 3C0 035 456 F    HW: 3C0 035 456 F
       Component: DSP 10 Kanal        0013
       Revision: 00010000    Serial number: 00000000004663
       VCID: 23411758E2C9095798-8076
       Part No SW: 1K0 959 702 AE    HW: 1K0 959 792 P
       Component: J387  TUER-SG BT    1517
       Revision: 71009005    Serial number: 00000501889105
       Coding: 0004598
       VCID: 72EF221C6DB3D0DFA3-8026
       Part No SW: 3C8 907 801 E    HW: 3C8 907 801 E
       Component: J540 EPB3  VW-15417 0007
       Revision:   010       Serial number: 00000000161442
       Coding: 0000057
       Shop #: WSC 05311 123 12345
       Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
       Component: J388   TUER-SG HL   0307
       Revision: 41004101    Serial number: 00000000763596
       Coding: 0000208
       VCID: 70EB281463BFE2CF55-8024
       Component: Anhaenger     H07 0100
       Revision: 3A001001    Serial number: 00000131398946
       Coding: 410D000101000000
       VCID: 306BE814633FA2CF15-8064
    Address 6D: Trunk Elect.        Labels: 3C9-827-383.clb
       Part No SW: 3C9 827 383 G    HW: 3C9 827 383 G
       Component: J605  HECKDECKEL    0730
       Revision: 00H27001
       Shop #: WSC 05314 000 00000
       VCID: 3565D9005C5D87E746-8060
       Subsystem 1 - Part No: 3C9 827 384 G
       Component: J756  HECKDECKEL    0730
       Subsystem 2 - Serial number: 0900H27001001A0206
       Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
       Component: J389   TUER-SG HR   0307
       Revision: 41004101    Serial number: 00000000773163
       Coding: 0000208
       Part No SW: 7P6 035 730 M    HW: 7P6 035 730 M
       Component: TELEFON       H15 4217
       Revision: 1B001001    Serial number: 00007666071836
       Coding: 0910000000010101
       Shop #: WSC 00015 115 00001
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA_002.rod
       VCID: 3C73CC24B77756AFB9-8068
       Revision: 00900000    Serial number:
       VCID: 2D55F160B40DCF273E-8078
    End-------------------------(Elapsed Time: 03:28)--------------------------
  9. #37
    Oct 2016
    Norway
    My guess is that ABS needs to be HW20..
