Results 11 to 20 of 23
Thread: Passat B6 2007 retrofit ACC?
    Oct 2016
    Norway
    Cannot find any information if my Q gateway is working with ACC? (So I guess not!)
    Pin 7 and 17 in gateway and that gives me no communication with 13 - dist. reg....
  2. #12
    Nov 2016
    B6 requires an additional can bus relay, your gateway doesnt have ext can bus. You are mixing up wiring with a B7
  3. #13
    Oct 2016
    Norway
    Yes, but thats all info I can find.
    What pins do I use from gateway to can bus relay (pin6 and pin16?)?
  4. #14
    Oct 2016
    Norway
    Don´t know what to code my ABS to...
    All codes I find are for B7 or with front assist!
    Now it says "ACC starting" in cluster.
    Friday,24,January,2020,16:59:50:07409
    VCDS Version: 19.6.2.0 (x64)
    VIN: WVWZZZ3CZ7E096323   License Plate: RKRADAR
    Mileage: 186900km-116134mi   Repair Order:
    Chassis Type: 3C-VW46 (3C0)
    Scan: 01 02 03 08 09 10 13 15 16 17 19 25 2E 36 37 42 44 46 47 52
              53 56 62 69 6D 72 77 7D
    VIN: WVWZZZ3CZ7E096323   Mileage: 186900km-116134miles
    Address 01: Engine        Labels: 03G-906-021-BMM.clb
       Part No SW: 03G 906 021 NK    HW: 03G 906 021 AB
       Component: R4 2,0L EDC A000AG  9972
       Revision: --H06---    Serial number: VWZCZ000000000
       Coding: 0000078
       Shop #: WSC 66565 257 00032
       VCID: 75E519001CDDC7E784-8020
    005717 - Please check DTC Memory of Auto. Distance Controller
                   P1655 - 000 -
                        Mileage: 186909 km
                        Date: 2020.01.24
                        Time: 00:04:01
                        (no units): 0.00
                        Bin. Bits: 00000100
                        Bin. Bits: 00000000
                        Bin. Bits: 00000011
       Part No SW: 02E 300 050 D    HW: 02E 927 770 AD
       Component: GSG DSG         082 1404
       Revision: 05308020    Serial number: 00001105240204
       Shop #: WSC 04940 001 00001
       VCID: 13214798326979D70A-8046
    Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
       Part No SW: 3C0 698 109 E    HW: 3C0 614 109 AF
       Component: J104    C4 440 V3   0017
       Revision: --025---    Serial number: 00000705092387
       Coding: 0002582
       Shop #: WSC 40511 222 91900
       VCID: 2C53FC648F17C62F2B-8078
    Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
       Part No SW: 3C0 907 044 AJ    HW: 3C0 907 044 AJ
       Component: ClimatronicPQ46 050 0505
       Revision: 00050005    Serial number: 00000000000000
       VCID: 69DD45704065130710-803C
       Part No SW: 3C8 937 049 F    HW: 3C8 937 049 F
       Revision: 00H54000    Serial number: 00000009463926
       Coding: ED888E2701061A00500A00000F000000841D1D435C80112C002000000000
       Shop #: WSC 05124 123 12345
       VCID: 3463E40457279EEF73-8060
       Subsystem 1 - Part No: 3C1 955 119 A  Labels: 1KX-955-119.CLB
       Component: Wischer VW461   012 0503
       Coding: 00064501
       Shop #: WSC 05124
       Component: RLS     250414 054  0403
       Coding: 01462477
       Shop #: WSC 05124
       Part No SW: 3C8 919 475 A    HW: 3C8 919 475
       Component: PARKHILFE 8K  H07 0009
       Revision: --------    Serial number: 08740933702375
       Coding: 100102
       Shop #: WSC 05314 123 12345
       VCID: 326FE21C6D3390DF61-8066
    Address 13: Auto Dist. Reg        Labels: 3C0-907-567.clb
       Part No SW: 3C0 907 567 L    HW: 3C0 907 567 L
       Component: AC201  RDW 1    031 0120
       Revision: 00031000    Serial number: 00000000051681
       Coding: 0010000
    9 Faults Found:
                        Fault Status: 00101101
                        Reset counter: 146
                        Mileage: 186909 km
                        Count: 4
                        Reset counter: 106
                        Mileage: 186909 km
                        Count: 4
                        Reset counter: 106
                        Mileage: 186909 km
                        Count: 69
                        Reset counter: 106
                        Mileage: 186909 km
                        Count: 37
                        Reset counter: 106
                        Mileage: 186909 km
                        Count: 144
                        Reset counter: 106
                        Mileage: 186909 km
                        Count: 50
                        Reset counter: 106
                        Mileage: 186909 km
                        Count: 75
                        Reset counter: 106
                        Count: 144
                        Reset counter: 106
                        Count: 41
       Part No SW: 3C0 909 605 N    HW: 3C0 909 605 N
       Component: 0D AIRBAG VW8R  030 2522
       Revision: 11030000    Serial number: 003B2PJU4TMG
       Coding: 0012356
       Shop #: WSC 05311 000 00000
       VCID: 316DED10A835ABC718-8064
       Subsystem 1 - Serial number: 6332MSME12431421W
       Subsystem 2 - Serial number: 6342MSME124569414
       Subsystem 3 - Serial number: 6351HTS6K5QADO63U
       Subsystem 4 - Serial number: 6361HTS6K5QE5KN2$
       Part No SW: 3C9 953 501 BM    HW: 5K0 953 569 T
       Revision: FF010040    Serial number: 20120209100177
       Coding: 1992A50002
       Shop #: WSC 00015 115 12345
       VCID: 75E51900D4DDC7E784-8020
       Component: E221__MFL-TAS  H06 0010
       Coding: 830000
       Part No SW: 3AA 920 880 C    HW: 3AA 920 880 C
       Component: KOMBI         H03 0407
       Coding: 161D00
       Shop #: WSC 05314 115 00000
       VCID: 3361E7189A2999D76A-8066
       Part No SW: 3C0 907 530 Q    HW: 3C0 907 951
       Component: J533  Gateway   H13 0171
       Revision:   H13       Serial number: 3520P09C0203F9
       Coding: FDA4FF56520612002002
       VCID: 2F69EB68BE01BD370E-807A
       Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
       Component:    IMMO         042 0383
       Revision: 00042000    Serial number: VWZCZ000000000
       Shop #: WSC 06402 785 00200
       VCID: 397DD53070456387A0-806C
    Address 2E: Media Player 3
    Address 36: Seat Mem. Drvr (J810)       Labels: 3C0-959-760.lbl
       Part No SW: 3C8 959 760 A    HW: 3C8 959 760 A
       Component: Sitzmemory    H05 2601
       Revision: 00H05000
       Coding: 000039
       VCID: 3361E718922999D76A-8066
       Part No SW: 1T0 035 680 D    HW: 1T0 035 680 C
       Component: RNS-MID       H06 4020
       Revision: AB001001    Serial number: VWZ6Z7K9061156
       Coding: 00050400010000A20011
       Shop #: WSC 01324 020 00200
       VCID: 2F69EB687E01BD370E-807A
       Part No SW: 1K0 959 701 AE    HW: 1K0 959 793 P
       Component: J386  TUER-SG FT    1517
       Revision: 71009005    Serial number: 00000643489028
       Coding: 0004599
       VCID: 71ED2D1068B5EBC758-8024
       Part No: 1K1 909 144 L
       Component: EPS_ZFLS Kl.136 H07 1806
       Shop #: WSC 02598 001 1048576
       Component:    KSG PQ46 ELV 042 0572
       Coding: 189109005103C83F3F02151FF0C88F06705900
       Shop #: WSC 00046 123 12345
       Part No SW: 3C0 035 456 F    HW: 3C0 035 456 F
       Component: DSP 10 Kanal        0013
       Revision: 00010000    Serial number: 00000000004663
       VCID: 23411758E2C909579A-8076
       Part No SW: 1K0 959 702 AE    HW: 1K0 959 792 P
       Component: J387  TUER-SG BT    1517
       Revision: 71009005    Serial number: 00000501889105
       Coding: 0004598
       VCID: 72EF221C6DB3D0DFA1-8026
       Part No SW: 3C8 907 801 E    HW: 3C8 907 801 E
       Component: J540 EPB3  VW-15417 0007
       Revision:   010       Serial number: 00000000161442
       Coding: 0000057
       Shop #: WSC 05311 123 12345
       Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
       Component: J388   TUER-SG HL   0307
       Revision: 41004101    Serial number: 00000000763596
       Coding: 0000208
       VCID: 70EB281463BFE2CF57-8024
       Component: Anhaenger     H07 0100
       Revision: 3A001001    Serial number: 00000131398946
       Coding: 410D000101000000
       VCID: 306BE814633FA2CF17-8064
    Address 6D: Trunk Elect.        Labels: 3C9-827-383.clb
       Part No SW: 3C9 827 383 G    HW: 3C9 827 383 G
       Component: J605  HECKDECKEL    0730
       Revision: 00H27001
       Shop #: WSC 05314 000 00000
       VCID: 3565D9005C5D87E744-8060
       Subsystem 1 - Part No: 3C9 827 384 G
       Component: J756  HECKDECKEL    0730
       Subsystem 2 - Serial number: 0900H27001001A0206˙
       Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
       Component: J389   TUER-SG HR   0307
       Revision: 41004101    Serial number: 00000000773163
       Coding: 0000208
       Part No SW: 7P6 035 730 M    HW: 7P6 035 730 M
       Component: TELEFON       H15 4217
       Revision: 1B001001    Serial number: 00007666071836
       Coding: 0910000000010101
       Shop #: WSC 00015 115 00001
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA_002.rod
       VCID: 3C73CC24B77756AFBB-8068
       Revision: 00900000    Serial number:
       VCID: 2D55F160B40DCF273C-8078
    End-------------------------(Elapsed Time: 03:18)--------------------------
  5. #15
    Jan 2015
    Bosnia and Herzegovina
    +8192 with Front Assist and +24576 with Front Assist and Follow to Stop (DSG)?
    There are 3 kind of services
    GOOD CHEAP FAST
    But you can only choose 2:
    GOOD and CHEAP won't be FAST
    FAST and GOOD won't be CHEAP
    CHEAP and FAST won't be GOOD
  6. #16
    Oct 2016
    Norway
    Stuck in "ACC STARTING" now.
    No speed in cruise mode, just --- and very strange to drive.
    Will adjust radar and figure out what channel 5 (in radar 13) is all about..
  7. #17
    Jan 2019
    Did you clear DTC in 13 ?
    Acc (13) is complaining about Communication errors to every other ECU.
    Is ACC switched on earlier than the rest ?
  8. #18
    Oct 2016
    Norway
    I will run a new scan after relay install, sorry!
    No I get dtc complaint from gearbox and ECU for dtc in ACC 13, but no dtc in ACC 13?
  9. #19
    Oct 2016
    Norway
    ABS coding 22, 28, 278, 284 = no DTC in ABS!
    But where do I go from here?
    Tried from 0000001 to 0000400
    ECU only accepts 13377 to activate ACC.
    Saturday,25,January,2020,19:37:24:07409
    VIN: WVWZZZ3CZ7E096323   License Plate: PASSAT ACC
    Mileage: 186910km-116140mi   Repair Order:
    VIN: WVWZZZ3CZ7E096323   Mileage: 186910km-116140miles
       Coding: 0000078
                   P1655 - 000 -
                        Mileage: 186915 km
                        Date: 2020.01.25
                        Time: 01:25:54
                        (no units): 0.00
                        Bin. Bits: 00000100
                        Bin. Bits: 00000000
                        Bin. Bits: 00000011
       Coding: 0002582
       Coding: 00064501
       Shop #: WSC 05124
       Coding: 01977121
       Shop #: WSC 05124
       Coding: 100102
       Coding: 0010000
       Coding: 0012356
       Coding: 1992A50002
       Coding: 830000
       Coding: 161D00
       Revision: 00H05000
       Coding: 000039
       Coding: 0004599
       Coding: 0004598
       Coding: 0000057
       Coding: 0000208
       Revision: 00H27001
       Coding: 0000208
    End-------------------------(Elapsed Time: 03:33)--------------------------
  10. #20
    Oct 2016
    Norway
    Does the car need xenon for ACC to work?
