Skoda octavia lighting fault
Radiosolutions
C?ID=178437
61 reg. problem with lighting system, all working but bulb warning and bend lighting fault on dash. faults in headlight range module for level sensors and power faults. checked fuses all ok. rosstech recommend changing cornering light module located rear of radio sytem. i ffitted a secondhand module and coded it but faults still exist. can anyone help please.
Saturday,04,January,2020,11:56:00:28694
VIN: TMBAE61Z1C2091326   License Plate: FL61FLJ
Mileage: 81750km-50797mi   Repair Order: OCTAVIA.SHAUN
Chassis Type: 1Z-SK35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 36 37 42 44 46 52 55 56 62 72
VIN: TMBAE61Z1C2091326   Mileage: 81750km-50797miles
Address 01: Engine (J623-CFHC)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 C    HW: 03L 906 018 BR
   Component: R4 2.0l TDI   H25 9978
   Revision: 42H25---    Serial number:
   Coding: 00190012042500080000
   Shop #: WSC 28767 002 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018C 003008
   ROD: EV_ECM20TDI01103L906018C.rod
   VCID: 2A0D05C77C782837B73-807E
4635 - Engine Oil Temp. Sensor (G8)
          P0196 00 [032] - Implausible Signal
4629 - ECM Power Relay Load Circuit
          P068A 00 [032] - Opens Too Early
8169 - Terminal 30
          U140A 00 [032] - Open Circuit
          [Terminal 30Open circuit]
   Revision: 00H31001
   Coding: 133B401C092B00FBC80E02E6901F0082350000
   Shop #: WSC 73430 790 00066
   VCID: 7BA3F083C3E261BF9C5-802E
01169 - Door Contact Switch Driver Side (F2)
                    Reset counter: 155
                    Mileage: 81458 km
                    Date: 2014.05.08
                    Time: 10:05:55
                    Count: 32768
                    Count: 29184
                    Count: 147
                    Count: 51200
                    Count: 65021
   Part No SW: 3T0 907 044 BL    HW: 3T0 907 044 BL
   Component: Climatronic   H18 0506
   Revision: 00001007
   Coding: 0000000002
   VCID: 7DA7FE9BDD766F8FA21-8028
   Part No SW: 1K0 937 087 Q    HW: 1K0 937 087 Q
   Component: BCM PQ35  H   110 0651
   Revision: 00110 AC
   Coding: 48000AB8E85BB1C04008008011001124437000AE726D85605C8440000040
   VCID: 3FDB4493977ABD9FF0D-806A
   Subsystem 1 - Part No: 1Z2 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 14101  26  0601
   Coding: 00D7B7
   Component: RLS 011111 05  54  0403
   Coding: 0730ED
   Subsystem 3 - Part No: 1Z0 951 171
   Component: Innenraumuebe  008 5101
   Component: LIN BACKUP HO  H11 9005
Address 10: Park/Steer Assist (J446)       Labels:| 1Z0-919-475-V2.clb
   Part No SW: 1Z0 919 475 E    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0005
   Revision: --H06---    Serial number: 28261130002517
   Coding: 108001
   Shop #: WSC 13765 790 00066
   ASAM Dataset: EV_EPHVA18SKxxx0000 001001
   ROD: EV_EPHVA18SKxxx0000_001.rod
   VCID: 43D34863FB12D97F945-8016
   Component: Q8 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD2TS7C+
   Coding: 0020792
   VCID: 3D273E9B9176AF8FE21-8068
   Subsystem 1 - Serial number: 6332MSME64330C537
   Subsystem 2 - Serial number: 6342MSME63512E45C
   Subsystem 3 - Serial number: 6351HSME295254521
   Subsystem 4 - Serial number: 6361HSME29526D76I
   Part No SW: 5K0 953 521 BN    HW: 5K0 953 569 E
   Revision: FF010040    Serial number: 20111026800488
   Coding: 108A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 79AFEA8BC95E53AF8E9-802C
   Subsystem 1 - Part No SW: 3T0 959 537     HW: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0012
   Coding: 800000
   Part No SW: 1Z0 920 943 S    HW: 1Z0 920 943 S
   Component: KOMBI         H05 0607
   Coding: 410E01
   Shop #: WSC 73430 031 00066
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK34.rod
   VCID: 49CF5A4BD93E032F5E9-801C
   Revision:   H42       Serial number: 251011F2000023
   Coding: 351303
   VCID: 3A2D35878C5898B7C73-806E
   Component: IMMO          H05 0607
   VCID: 6A8DC5C7BCF8E837773-803E
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 E    HW: 3C0 959 760 E
   Component: Sitzverstellung     1102
   Revision: 00005000    Serial number: 00000000000000
   VCID: 2F3B14D34B1A4D1F60D-807A
   Part No SW: 3T0 035 680 E    HW: 3T0 035 680 E
   Component: RNS-MID       H61 3984
   Revision: AB001001    Serial number: SKZ6Z7L7305074
   Coding: 04000402000100810000
   VCID: 323D1DA7542860F70F3-8066
   Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
   Component: Tuer-SG         009 2120
   Coding: 0005118
   VCID: 76B5E1B7F4C03CD7E3B-8022
   Part No: 1K0 909 144 N
   Component: EPS_ZFLS Kl. 69     3301
   Revision: 00H22000
   VCID: 353726BBA94677CF2A1-8060
   Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
   Coding: 0005118
   VCID: 48C95F4FCEB4FA27417-801C
   Coding: 1507610
   VCID: 34311BBFA23C6EC71DF-8060
   Coding: 00000023
   Coding: 00000023
01537 - Vehicle Level Sensor; Supply Voltage
                    Fault Status: 11101000
                    Fault Frequency: 39
                    Reset counter: 123
                    Mileage: 81558 km
                    Date: 2014.05.13
                    Time: 10:29:44
                    Voltage: 12.07 V
                        ABS 1
00496 - Sensor for Vehicle Leveling; Front
                    Fault Status: 11101010
                    Fault Frequency: 38
                    Reset counter: 123
                    Mileage: 81558 km
                    Date: 2014.05.13
                    Time: 10:30:46
                    Voltage: 9.80 V
                        ABS 1
00497 - Sensor for Vehicle Leveling; Rear
                    Fault Frequency: 38
                    Reset counter: 123
                    Mileage: 81558 km
                    Date: 2014.05.13
                    Time: 10:30:46
                    Voltage: 9.80 V
                        ABS 1
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Coding: 0000144
   Shop #: WSC 73430 790 1012546
   VCID: 323D1DA7582860F70F3-8066
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 333318A3A73269FF045-8066
End----(Elapsed Time: 01:35, VBatt start/end: 11.8V/12.0V. VIgn 12.0V)-----
PetrolDave
Westbury, UK
C?ID=1423
Have you tried clearing the faults after fitting the replacement module?
Radiosolutions
C?ID=178437
Yes tried to clear faults but just come back
langers2k
C?ID=224085
Have you verified the wiring to both sensors is undamaged?
I'd also suggest unplugging both sensors too - a short or damaged sensor might cause the faults your seeing.
Do the faults in the ECU return when cleared?
Water ingress in lights or sensors causing back feed of B+?
