Results 1 to 10 of 13
Thread: 2012 S5 Back up camera module commun. error
    Dec 2019
    I am in the process of installing the b/u camera. I bought and installed a harness from Kufatec. I have the video wires connected to pins 11 (transparent wire) and pin 5 (black) to the blue connector on back of MMI. The twisted pair is connected to pins 15 high and low on the Can Bus connector. I had a tech set the camera coding as I wasn't comfortable doing so, even tho I have the RT software. The error we get is "no communication with controller" The camera and controller are salvage items. Controller is part 8TO 907 441C, I discovered it should be "D" version. I do have a friend with an 09 car (S5 as well) and plan to try the controller in his car. Open to suggestions if I have missed anything.
    thanks Ed
    Hi and welcome.
    Dec 2019
    Will do, going into uncharted territory as far as posting the Auto Scan. I will need to drive a few miles as I cleared it last night. There were a bunch of error codes that were probably caused by a low battery or ignition on, with Can bus plug removed.
    Dec 2019
    Let's give this try: Still have all sorts of weird codes, and no car issues
    Chassis Type: FR-AU48 (8T0)
    Scan: 01 02 03 05 06 08 09 15 16 17 19 22 36 42 46 47 52 53 55 56
              5F 6C
    VIN: WAUCVAFRXCA005485   Mileage: 56380km-35032miles
    05-Acc/Start Auth. -- Status: Malfunction 1010
    06-Seat Mem. Pass -- Status: Malfunction 1010
    08-Auto HVAC -- Status: Sporadic communication error 1000
    09-Cent. Elect. -- Status: Sporadic communication error 1000
    17-Instruments -- Status: Sporadic communication error 1000
    36-Seat Mem. Drvr -- Status: Malfunction 1010
    42-Door Elect, Driver -- Status: Sporadic communication error 1000
    46-Central Conv. -- Status: Sporadic communication error 1000
    52-Door Elect, Pass. -- Status: Sporadic communication error 1000
    53-Parking Brake -- Status: Malfunction 1010
    6C-Back-up Cam. -- Status: Cannot be reached 1100
    Address 01: Engine (J623-CAUB)       Labels:. 079-907-560-CAU.clb
       Part No SW: 8T0 907 560 AF    HW: 8T0 907 560
       Component: 4.2l V8/4V    H24 0001
       Revision: 76H24---
       Coding: 01140009190F0120
       Shop #: WSC 06324 000 00000
       VCID: 7EA502B030FF0337BBB-802A
    Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
       Part No SW: 8K0 927 158 M    HW: 0B6 927 156
       Component: 0B6 42 FSIUSA H05 0003
       Revision: --H05---
       Coding: 001012
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_TCMAL651211 001012
       ROD: EV_TCMAL651.rod
       VCID: 40D9BC480A0BB5C7897-8014
    6 Faults Found:
    2465 - No Communication with Instrument Cluster
              U0155 00 [032] - -
                        Time: 00:00:00
                        Transmission input speed: 0 /min
                        Transmission output speed: 0 /min
                        Engine torque: 0 Nm
                        Transmission fluid temperature: 10 °C
                        Accelerator position: 0.0 %
                        Clutch status: 0
    4776 - Steering Column Control Module
              U0212 00 [032] - No Communications
                        Time: 00:00:00
                        Engine torque: 0 Nm
                        Clutch status: 0
    2474 - No Communication with ESP (Vehicle Dynamics) Control Module
              U0122 00 [032] - -
                        Time: 00:00:00
                        Engine torque: 0 Nm
                        Clutch status: 0
    2478 - No Communications with Parking Brake Control Module
              U0128 00 [032] - -
                        Time: 00:00:00
                        Engine torque: 0 Nm
                        Clutch status: 0
    4774 - Body Control Module (Central Electric 2)
              U0141 00 [032] - No Communications
                        Time: 00:00:00
                        Engine torque: 0 Nm
                        Clutch status: 0
    2463 - No Communications with Steering Angle Sender (G85)
              U0126 00 [032] - -
                        Time: 00:00:00
                        Engine torque: 0 Nm
                        Clutch status: 0
       Part No SW: 8K0 907 379 BJ    HW: 8K0 907 379 BJ
       Component: ESP8 quattro  H04 0060
       Coding: 120D1A
       VCID: 025D7640440767D7DF3-8056
                        Fault Frequency: 7
                        Reset counter: 163
                        Mileage: 56317 km
                        Date: 2019.12.20
                        Time: 17:35:31
                        Hex Value: 0x0000
                        Hex Value: 0x0280
                        Hex Value: 0x0032
                        Hex Value: 0x8493
                        Hex Value: 0x00FF
                        Fault Status: 00101101
                        Reset counter: 159
                        Hex Value: 0x0000
                        Hex Value: 0x0780
                        Hex Value: 0x0028
                        Hex Value: 0x5090
                        Hex Value: 0x00FF
                        Reset counter: 159
                        Hex Value: 0x0000
                        Hex Value: 0x0780
                        Hex Value: 0x001C
                        Hex Value: 0x7A90
                        Hex Value: 0x00FF
                        Fault Status: 00101110
                        Reset counter: 159
                        Hex Value: 0x0000
                        Hex Value: 0x0780
                        Hex Value: 0x0013
                        Hex Value: 0xBC90
                        Hex Value: 0x00FF
                        Fault Frequency: 7
                        Reset counter: 163
                        Mileage: 56317 km
                        Date: 2019.12.20
                        Time: 17:35:31
                        Hex Value: 0x0000
                        Hex Value: 0x0280
                        Hex Value: 0x0032
                        Hex Value: 0x8493
                        Hex Value: 0x00FF
       Part No SW: 8K0 907 064 CF    HW: 8K0 907 064 CF
       Component: BCM2 2.0      H05 0435
       Coding: 090000
       VCID: 76B51A9018CF4B77E3B-8022
       Subsystem 1 - Part No SW: 8T0 959 754 M    HW: 8T0 959 754 M
       Component: FBSAUDIB8 IDG  H60 0072
       Serial number: 0811000122510009
       Serial number: 2311000180185001
                        Reset counter: 159
                        Mileage: 56317 km
                        Date: 2019.12.21
                        Time: 13:57:33
       Part No SW: 8T0 959 760 C    HW: 8T0 959 760 C
       Component: MEM-BFS       H10 0074
       Revision: AA000000    Serial number: 00000013511521
       Coding: 00017025002C00000000
       VCID: 43D3B3441B9DAEDF945-8016
                        Reset counter: 159
    01964 - Control Module for Seat & Steering Column Memory (J136)
                        Reset counter: 159
                        Reset counter: 159
       Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
       Component: KLIMA 3 ZONEN H08 0180
       Revision: C1000000    Serial number: 01120920110880
       Coding: 48122000
       VCID: 00597C484A0B75C7C97-8054
       Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Component: BCM1 1.0      H30 0392
       Revision: 10030001    Serial number: 00000001204571
       Coding: 26001091063CAF212700080300003D3D0F9CD3C802010161000000
       VCID: 3C21C8B86663D127D5F-8068
       Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 070911  H15 0070
       Serial number: SWF11090070519
       Coding: 00FD11
       Component: RLS  H04 0003
       Serial number: 11652492
       Coding: 02532C
       Subsystem 3 - Part No SW: 8K0 941 531 BA    HW: 8K0 941 531 BA
       Component: E1 - LDS  H03 0031
       Serial number: 00000000001808110454
       Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
       Component: HOMELINK  H01 0010
       Part No SW: 8K0 959 655 K    HW: 8K0 959 655 K
       Component: AirbagVW-AU10 H44 0610
       Serial number: 003GLD0NZC0.
       Coding: 303338334330303030304A55304C38543053
       VCID: 45D7AD5C152990EFBA1-8010
       Subsystem 1 - Part No SW: 8K0 959 339 A    HW: 8K0 959 339 A
       Component: BF-Gewichtss.  H02 0060
       Serial number: 5810000R11000062VS
       Serial number: 6334MSME63326477B
       Serial number: 6344MSME636402476
       Serial number: 6352QSME2B60477AO
       Serial number: 6362QSME3D5D275C
       Serial number: 63732SME5A61227E3
       Serial number: 63832SME5E6728447
    12583424 - Powertrain Databus
              U0002 00 [008] - No Communications
              [High Speed CAN Communication Bus no signal/communication]
                        Reset counter: 159
                        Time: 00:00:00
    9482752 - Seat Occupied Recognition
              B10B2 00 [008] - Function Restriction due to Missing Message(s)
              [Bladder Mat: functional restriction because of missing message]
                        Reset counter: 159
                        Time: 00:00:00
       Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
       Component: Lenks.Modul   H17 0014
       Revision: --------    Serial number: 90372KHO0004B
       Coding: 000036
       VCID: 3E25C2B0707FC337FBB-806A
       Component: E221 - MFL  H02 0010
                        Reset counter: 163
                        Mileage: 56317 km
                        Date: 2019.12.20
                        Time: 17:35:31
                        Reset counter: 159
                        Fault Status: 00100101
                        Reset counter: 159
                        (no units): 44.0
                        Text: 2C92FFFFFFFF00C0FF
                        Lambda Factor: 4.24
                        Raw, Index/Key Err.: 255 255 000
       Part No SW: 8T0 920 983 D    HW: 8T0 920 983 D
       Component: KOMBIINSTR.   H43 0258
       Revision: 00000000    Serial number: EI144VP8C
       Coding: 8B1701008300D705020000
       VCID: 3FDBBFB47775CA3FF0D-806A
       Part No SW: 8T0 907 468 AD    HW: 8T0 907 468 K
       Component: GW-BEM 4CAN-M H09 0117
       Revision: EC000056    Serial number: 5600E1190103BD
       Coding: 00C303
       VCID: 035373445B1D6EDFD45-8056
       Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
       Component: J367-BDM  H07 0170
       Serial number: 11034071300811
    14 Faults Found:
                        Reset counter: 121
                        Mileage: 56341 km
                        Date: 2020.01.02
                        Time: 11:31:59
                        Bin. Bits:    10111
                        Voltage: 11.50 V
                        Count: 6
                        Bin. Bits:    10011
                        Time: 25.40 s
                        Reset counter: 163
                        Mileage: 56381 km
                        Date: 2020.01.04
                        Time: 10:37:16
                        Bin. Bits:    10000
                        Voltage: 12.00 V
                        Count: 10
                        Bin. Bits:    10010
                        Time: 22.90 s
                        Reset counter: 163
                        Mileage: 56381 km
                        Date: 2020.01.04
                        Time: 10:37:16
                        Bin. Bits:    10000
                        Voltage: 12.00 V
                        Count: 10
                        Bin. Bits:    10010
                        Time: 22.90 s
                        Reset counter: 163
                        Mileage: 56381 km
                        Date: 2020.01.04
                        Time: 10:37:16
                        Bin. Bits:    10000
                        Voltage: 12.00 V
                        Count: 10
                        Bin. Bits:    10010
                        Time: 22.90 s
                        Reset counter: 163
                        Mileage: 56381 km
                        Date: 2020.01.04
                        Time: 10:37:16
                        Bin. Bits:    10000
                        Voltage: 12.00 V
                        Count: 10
                        Bin. Bits:    10010
                        Time: 23.30 s
                        Reset counter: 163
                        Mileage: 56381 km
                        Date: 2020.01.04
                        Time: 10:37:16
                        Bin. Bits:    10000
                        Voltage: 12.00 V
                        Count: 10
                        Bin. Bits:    10010
                        Time: 23.40 s
                        Reset counter: 163
                        Mileage: 56381 km
                        Date: 2020.01.04
                        Time: 10:37:16
                        Bin. Bits:    10000
                        Voltage: 12.00 V
                        Count: 10
                        Bin. Bits:    10010
                        Time: 23.40 s
                        Reset counter: 163
                        Mileage: 56381 km
                        Date: 2020.01.04
                        Time: 10:37:16
                        Bin. Bits:    10000
                        Voltage: 12.00 V
                        Count: 10
                        Bin. Bits:    10010
                        Time: 23.40 s
                        Reset counter: 163
                        Mileage: 56381 km
                        Date: 2020.01.04
                        Time: 10:37:16
                        Bin. Bits:    10000
                        Voltage: 12.00 V
                        Count: 10
                        Bin. Bits:    10010
                        Time: 23.40 s
    00456 - Control Module for Access and Start Control (J518)
                        Reset counter: 163
                        Mileage: 56381 km
                        Date: 2020.01.04
                        Time: 10:37:16
                        Bin. Bits:    10000
                        Voltage: 12.00 V
                        Count: 10
                        Bin. Bits:    10010
                        Time: 24.30 s
                        Reset counter: 163
                        Mileage: 56381 km
                        Date: 2020.01.04
                        Time: 10:37:16
                        Bin. Bits:    10000
                        Voltage: 12.00 V
                        Count: 10
                        Bin. Bits:    10010
                        Time: 24.40 s
                        Reset counter: 163
                        Mileage: 56381 km
                        Date: 2020.01.04
                        Time: 10:37:16
                        Bin. Bits:    10000
                        Voltage: 12.00 V
                        Count: 10
                        Bin. Bits:    10010
                        Reset counter: 163
                        Mileage: 56381 km
                        Date: 2020.01.04
                        Time: 10:37:16
                        Bin. Bits:    10000
                        Voltage: 12.00 V
                        Count: 10
                        Bin. Bits:    10010
                        Time: 25.40 s
    00461 - Control Module for Seat Memory; Passenger (J521)
                        Reset counter: 163
                        Mileage: 56381 km
                        Date: 2020.01.04
                        Time: 10:37:16
                        Bin. Bits:    10000
                        Voltage: 12.00 V
                        Count: 10
                        Bin. Bits:    10010
                        Time: 25.40 s
    Address 22: AWD (J492)       Labels: 8K0-907-163.clb
       Part No SW: 8K0 907 163 A    HW: 8K0 907 163 A
       Component: 4 Wheel Drive H12 0025
       Serial number: 000408110001016
       ASAM Dataset: EV_AllWheelDiffeQSPCAN 003016
       VCID: 2E05F2F0A09F33B76BB-807A
    0074 - Combination / Chassis CAN Bus (SAE Bus D)
              U0056 00 [008] - Performance
              [Kombi/Fahrwerk CAN keine Kommunikation DTC_CAN_COMB_NO_COM]
                        Reset counter: 159
       Component: MEM-FS        H10 0074
       Revision: AA000000    Serial number: 00000013496962
       Coding: 00197325002C00000000
                        Reset counter: 160
                        Reset counter: 160
                        Reset counter: 159
                        Reset counter: 159
       Part No SW: 8T0 959 793 M    HW: 8T0 959 793 D
       Component: TSG FA        H08 1501
       Coding: 011C03224E00120102
       VCID: 53F38304EBFD3E5F245-8006
       Revision: 00002001    Serial number: 0157786142
       Coding: 0106029A00FA440480B0003200000000
       Component: GTO BF  H01 0070
       Serial number: 00000000000000432942
       Part No SW: 8T0 035 223 AN    HW: 8T0 035 223 AK
       Component: DSP Prem      H10 0190
       Revision: 00010001    Serial number: 34804009629302
       VCID: 7AAD0EA02CD72F17873-802E
       Part No SW: 8T0 959 792 M    HW: 8T0 959 792 D
       Component: TSG BF        H08 1501
       VCID: 52FD8600D4E737572F3-8006
       Revision: 00000003    Serial number: 10000000846964
       VCID: 3431E0984E3319671DF-8060
                        Reset counter: 159
                        Mileage: 56317 km
                        Date: 2019.12.21
                        Time: 15:00:23
                        Voltage: 11.50 V
                        Count: 80
                        Hex Value: 0x0263
                        Hex Value: 0x0001
                        Hex Value: 0x1010
                        Reset counter: 159
                        Voltage: 11.60 V
                        Count: 74
                        Hex Value: 0x0263
                        Hex Value: 0x0081
                        Hex Value: 0x1010
       Part No: 8K5 907 357 B
       VCID: 392FD1AC6551E40FCE9-806C
    00532 - Supply Voltage B+
                        Reset counter: 146
                        Mileage: 48864 km
                        Date: 2019.03.31
                        Time: 14:06:29
                        Reset counter: 159
                        Mileage: 1048574 km
                        Reset counter: 159
                        Mileage: 1048574 km
       Part No SW: 4G0 035 082 B    HW: 4G0 035 082
       Component: Radio U SIRIU H53 0076
       Revision: AB001007    Serial number: 156I$0B7549204
       Coding: 020007010000000001
       VCID: 1F1B1F34D7B5AA3FD0D-804A
    03278 - Functionality Limited due to Missing Messages
                        Reset counter: 159
                        Bin. Bits: 00000000 00000001
       Part No SW: 8T1 035 664 D    HW: 8T1 035 664 B
       Component: H-BN-NA       H52 0165
       Revision: --------    Serial number: 490I40B7638807
       Coding: 010200020206A1EE45000B0C000000030000
       Shop #: WSC 06325 123 12345
       VCID: 392FD1AC6951E40FCE9-806C
       Component: NAR 2011  0505
       Component: DU7 High  H41 0104
       Serial number: A130IF0BS016788
       Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
       Component: E0380 Bedient  H08 0100
       Serial number: 00000000923420
       Component: CD-Database  2712
                        Reset counter: 121
                        Mileage: 56341 km
                        Date: 2020.01.02
                        Time: 11:40:41
                        Bin. Bits: 00001000 00000000
                        Bin. Bits: 00000000 00000000
    00862 - Antenna for GPS Navigation (R50/R52)
                        Reset counter: 121
                        Mileage: 56341 km
                        Date: 2020.01.02
                        Time: 11:40:03
                        Voltage: 11.80 V
    Address 6C: Back-up Cam.
    End----------(Elapsed Time: 01:45, VBatt start/end: 12.3V/12.1V)]
    When was that scan done? It's so full of fault codes (many of which have older time/date stamps) that the signal-to-noise ratio is quite low.
    Please clear all faults. Do it one module at a time if necessary, then re-scan and re-post.
    Dec 2019
    Scan from just now, cleared codes and drove for about 40 miles: 5F seems to be CD related, although it works fine.
              5F 6C
    VIN: WAUCVAFRXCA005485   Mileage: 56480km-35095miles
       Revision: 76H24---
       Revision: --H05---
       Coding: 001012
       Coding: 120D1A
       Coding: 090000
       Coding: 48122000
       Coding: 00FD11
       Coding: 02532C
       Coding: 000036
       Coding: 00C303
                        Reset counter: 124
                        Mileage: 56386 km
                        Date: 2020.01.05
                        Time: 13:00:07
                        Bin. Bits:    10111
                        Voltage: 11.60 V
                        Count: 6
                        Bin. Bits:    10011
                        Time: 25.40 s
                        Reset counter: 124
                        Mileage: 56386 km
                        Date: 2020.01.05
                        Time: 13:00:06
                        Reset counter: 124
                        Mileage: 56386 km
                        Date: 2020.01.05
                        Time: 13:00:14
                        Voltage: 12.00 V
    End----------(Elapsed Time: 01:37, VBatt start/end: 12.4V/12.4V)----------
  7. Likes Uwe liked this post
    Your Back-Up Cam is off-line in both scans. Neither VCDS nor the car's Gateway can talk to it.
    That makes it puzzling how a tech could have done coding on it. One can't code something that's off-line.
  9. #8
    Dec 2019
    So your thought is even tho I an see the icon 6 C labeled back up Cam, it is not turned on in coding? And I should be able to accomplish this with VCDS? I did pull the MMi, just to check the fiberoptic cable. I discovered I had left off the blue connector. But not sure what that is for. There is a green jack there as well, with no wire to it. Same as on the trunk module.
    thanks Ed
  10. #9
    Quote Originally Posted by Ed O S5 View Post
    Nope. The Gateway knows about it, so it's coded there, but nothing can talk to it. My guess is there's problem with the physical installation.
  11. #10
    Dec 2019
    Well, that's a start. Obvious connections to check are the twisted pair comm cable that connects to Canbus connector on right side of glove box. The other end is a large plug going to the trunk controller. thanks for the advise.
    Ed
