Results 1 to 5 of 5
Thread: Audi B7 S4 Cruise Control retro fit issues
    Jan 2020
    Hi Guys I know this has been gone over a million times but I have read every post on every page and I still cant get this to work, I have a b7 S4 that we have fitted a cruise control stalk into and have coded it in the (correct) way following every possible option I can find and I still have no luck, I can go in through vcds and view that all the buttons for the cruise are working which they are and same for the brake switch (which is new) oh and its and auto, I have one fault code showing that was already in the car before the retro fit and clears but comes back as soon as engine is started even without touching the throttle but so far have not found the source of this. has any one got any other ideas, I tried to do a throttle adaption but it does not allow me to do it the way that the ross-tech web site suggests. here is the auto scan from the car. Thanks
    Monday,30,December,2019,11:07:41:22271
    VIN:    License Plate:
              67 69 75 76 77
    VIN:   Mileage: 249090km-154777miles
    Address 01: Engine        Labels: 079-910-560-BBK.lbl
       Part No SW: 8E3 910 560     HW: 4E0 907 560
       Component: 4.2L V8/5V      A   0020
       Revision: --H01---    Serial number:
       Coding: 0011771
       Shop #: WSC 06335 000 00000
       VCID: 6582AF58AC37396734-8030
    Readiness: 0110 1101
       Part No SW: 8E1 910 156 M    HW: 09L 927 156 B
       Component: AG6 09L 4,2 MPI RdW 0030
       Revision: --H01---    Serial number:        4283918
       VCID: 312A0B08A87FA5C718-8064
    006273 - Powertrain Data Bus: Missing Message
                   P1881 - 000 - Acceleration Request
                        (no units): 30.0
                        (no units): 108.0
                        Temperature: 18.0°C
                        T.B. Angle: 0.0°
    Address 03: ABS Brakes        Labels: 8E0-910-517.clb
       Part No SW: 8E0 910 517 J    HW: 8E0 614 517 BH
       Component: ESP8 quattro    H06 0140
       Coding: 0004902
       VCID: 2E101074B941BA3F05-807A
       Part No: 8E0 820 043 BL
       Component:   A4 Klimaautomat   3233
       Coding: 00000
       VCID: 6C94DA7C1EDD082F6B-513C
    Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
       Part No: 8E0 907 279 N
       Component: int. Lastmodul  ECE 0907
       Coding: 10021
       Shop #: WSC 06335
       VCID: 3D322738352751A78C-4B00
    Address 15: Airbags        Labels: 8E0-959-655-94.lbl
       Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
       Component:    Airbag 9.41  H13 4230
       Revision: 91H13423    Serial number: 0036M0G65PA7
       Coding: 0030612
       VCID: 3B3629207A335F97B2-806E
       Subsystem 1 - Serial number: 6332DRB404B08F1BX
       Subsystem 2 - Serial number: 6342DRB404A8CD36/
       Subsystem 3 - Serial number: 6352ARB402100C300
       Subsystem 4 - Serial number: 6362ARB401F3543ES
       Subsystem 5 - Serial number: 63729RB402076F9E-
       Subsystem 6 - Serial number: 63829RB402076FC8Y
       Part No: 8E0 953 549 Q
       Component: Lenksáulenmodul     0701
       Coding: 04142
       Shop #: WSC 06335
       VCID: 41CA5BC849DF3547E8-4B00
    Address 17: Instruments        Labels: 8E0-920-9xx-8EC.lbl
       Part No SW: 8E0 920 983     HW: 8E0 920 983
       Component: KOMBI+WFS 4     H14 0200
       Revision: 0200        Serial number: 00000000000000
       Coding: 0007418
       Shop #: WSC 00999 444 64523
       VCID: 6C94DA7C4EDD082F6B-5160
    Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.lbl
       Coding: 0007418
    Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
       Part No: 8E0 951 177
       Component: Innenraumueberw.   0804
       Coding: 00001
       VCID: 6B96D9601BD30F1762-50F4
       Part No: 8E0 959 433 CH
       Component: Komfortgerát T3B    4135
       Coding: 07151
       Shop #: WSC 06335
       VCID: 79BAF328618FAD87E0-4B00
       Subsystem 1 - Part No: 8E2959802F
       Component: Tőrsteuer.FS BRM 0606
       Subsystem 2 - Part No: 8E2959801F
       Component: Tőrsteuer.BF BRM 0606
       Component: Tőrsteuer.HL BRM 0606
       Component: Tőrsteuer.HR BRM 0606
       Part No: 8P0 907 357 F
       Coding: 0000005
       VCID: 3D322738642751A78C-8068
    End----(Elapsed Time: 05:15, VBatt start/end: 11.7V/11.6V. VIgn 11.6V)-----
    Hi and welcome.
    Got you Verified and moving this to Retrofits.
    Quote Originally Posted by Mike-newing View Post
    Please explain step-by-step what you're doing and what happens when it "does not allow" it.
    Are you sure you've done the Coding-II with 11463?
    I would expect to see a 'G' in the component field once that's done, like this:
    Component: 4.2L V8/5V G 0020
  3. Likes PetrolDave liked this post
    Jan 2020
    HI Uwe thanks for getting me verified and sorry for taking so long to reply I had to wait to get the car back from the guy Im trying to sort it for, I managed to work out the throttle adaption thing I just hadn't read every thing about on some models you have to go into basic settings and do it that way and what was my issue so that's all done and sorted but as for the cruise control Im still having no luck I have checked codes and checked for that (G) you mention and it does not appear I have included some images so you can see what Im doing hope you can help.
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    Thanks Mike
    Please try 16167 and see if that makes the 'A' in the Component field go away. You'll need to exit the control module and possibly cycle the ignition to see if it took effect.
  6. Likes PetrolDave liked this post
    Jan 2020
    Thanks Again Uwe you have solved all my issues, I cant explain how many times I have tried code 16167 to deactivate any thing that was in the system and then re activate and nothing has worked and then you say to do it but say cycle the ignition a few times and I do that turn it on and off a few times and I see it the (A) disappeared and I knew then it was going to happen popped 11463 in ignition off and on a few times and the (G) was there, the test drive was the best feeling ever, Thanks very much just shows I have a lot to learn but was well worth buying my hex-net mobile for the amount of cars I work on just need to get more practice on it.
    Thanks again Mike
  8. Likes Uwe liked this post
