MFSW and cruise control for transporter t5.1
brecht_van
Belgium
C?ID=306708
I just bought a used transporter t5.1, great to drive with it, the only problem I have is that there is no cruisecontrol. Should it be possible to retrofit a cruise control and maybe some multifunction knobs on the wheel?
This is the scan from the car:
Saturday,04,January,2020,20:51:01:02681
VIN: WV2ZZZ7HZCH029917   License Plate: T5
Mileage: 141100km-87675mi   Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 02 03 04 08 09 10 15 17 18 19 25 2E 37 56 69 0B
VIN: WV2ZZZ7HZCH029917   Mileage: 141100km-87675miles
Address 01: Engine (J623-CCHB)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 DN    HW: 03L 907 309 K
   Component: R4 2,0L EDC   H43 9122
   Revision: 26H43---    Serial number: 00000000000000
   Coding: 0125401A231400080000
   Shop #: WSC 02756 790 50316
   ASAM Dataset: EV_ECM20TDI01103L906019DN 002009
   ROD: EV_ECM20TDI01103L906019DG.rod
   VCID: FAB896377DD5A09F69-80AE
   Part No SW: 0BT 300 045 M    HW: 0BH 927 711 C
   Component: DSG DQ500-7F  H05 1712
   Revision: 00H05V01
   ROD: EV_TCMDQ500021_VW36.rod
   VCID: BFCE2723267745B71E-80EA
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 H    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0107
   Revision: 00H43001
   Coding: 208764AD09A6049E26AB90726A6510
   Shop #: WSC 02756 790 49152
   VCID: B73E4F0306477DF7D6-80E2
Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
   Part No SW: 7E5 907 040 N    HW: 7E5 907 040 N
   Component: ClimatronicT5 H11 0304
   Revision: 00001002
   Coding: 0004000102
   ASAM Dataset: EV_ClimatronicT5 A01003
   ROD: EV_ClimaAutoT5Basis.rod
   VCID: B3267B131A3F91D7EA-80E6
   Slave 1:
   Subsystem 1 - Part No SW: 7E5 907 049 B    HW: 7E5 907 049 B
   Component: Heckbedienung  H10 0202
   Serial number: BHB-0011708110010166
9479189 - Signal Line for Air Quality Sensor
          B10A4 15 [009] - Open or Short to Plus
                    Reset counter: 143
                    Mileage: 141105 km
                    Date: 2020.01.04
                    Time: 00:24:58
   Part No SW: 7H0 937 087 H    HW: 7H0 937 087
   Component: BCM T5GP H+4  H47 0251
   Revision: BO047001    Serial number: 0429 221110355
   Coding: A0A039BA0E232013002008102E2B8DDC0000410F60040000300000000000
   Shop #: WSC 02756 790 00000
   VCID: B93A493B30536B8720-80EC
   Subsystem 1 - Part No SW: 7E0 959 801 A    HW: 7E0 959 801 A  Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  003 3311
   Coding: 040000
   Subsystem 2 - Part No SW: 7E0 959 802 A    HW: 7E0 959 802 A  Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  003 3311
   Coding: 040000
                    Reset counter: 183
                    Mileage: 141105 km
                    Date: 2014.05.27
                    Time: 04:59:08
Address 10: Park/Steer Assist (J446)       Labels:| 7E0-919-475.clb
   Part No SW: 7E0 919 475 E    HW: 7E0 919 475 A
   Component: PARKHILFE 8K  H11 0013
   Revision: --------    Serial number: 47401119501051
   Coding: 118101
   ASAM Dataset: EV_VW75XParkAssis8K A01005
   ROD: EV_VW75XParkAssis8K_A01.rod
   VCID: B424780F1F3196EFF3-80E0
   Part No SW: 7E0 959 655 C    HW: 7E0 959 655 C
   Component: VW10Airbag007 H06 0013
   Revision: --------    Serial number: 003HM001CW9A
   Coding: 000000000000000000000000000000003037
   Shop #: WSC 02754 790 50316
   VCID: B6204207094D84FFCD-80E2
   Serial number: 3495ZRB40630D6ISCHG2
   Serial number: 3505ZRB40690D6ISF0FS
   Part No SW: 7E0 920 870 E    HW: 7E0 920 870 E
   Component: KOMBI         H04 0305
   Coding: 160F00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   VCID: AB166373C20FC917A2-80FE
Address 18: Aux. Heat        Labels: None
   Part No: 7E0 815 071 B
   Component: J737__Standheizung  0605
   Revision: 00085000    Serial number: 09019275F00000
   Coding: 0000031
   Shop #: WSC 02757 790 00000
   VCID: A404884F67D1066F63-80F0
   Part No SW: 6N0 909 901     HW: 7H0 937 087
   Component: GW-K-CAN TP20 H47 0251
   Revision: BO047001
   Coding: 042200
   VCID: F0ACB41F23A9EACFD7-80A4
   Component: IMMO          H04 0305
   VCID: EA98A6770D75101F99-80BE
   Revision: A1001003    Serial number: 7660583697
   VCID: A91A997BC0F3DB0750-80FC
   Part No SW: 7E0 035 680 A    HW: 7E0 035 680 A
   Component: RNS-MID       H55 3978
   Revision: AB001001    Serial number: VWZ6Z7L6222059
   Coding: 04000402040000A00014
   Shop #: WSC 02754 790 00000
   VCID: A3068B53A2DF01571A-80F6
   Revision: 3A001001    Serial number: 00000154679125
   Coding: 410D000102000000
   VCID: B02C741FE329AACF97-80E4
End----------(Elapsed Time: 01:34, VBatt start/end: 12.9V/12.9V)-----------
brecht_van
Belgium
C?ID=306708
Thanks for the welcome.
I did a search in the wiki and found this, http://wiki.ross-tech.com/wiki/index.php/Cruise_Control_Retrofitting_(6R)
Looks like the link of Uwe is the older model of the transporter but thanks for the help.
So if I understand this correctly I have a bcm of the type high+ so it should be possible to retrofit the cruise control. The mfsw should also be possible if I look on the electric scheme, there is no difference between the control modules with or without msfw. I wil just try it. Should there be another module than the bcm and the radio where is schould change the coding?
dnoermann
C?ID=358118
Correct, the POLO Guide will work with T5 Model Year 2010-2015 it is the same Model PQ25.
MFSW will work, too.
For CCS you will need the Stalk, CCS as Button in MFSW will not work.
For CCS wou probably will have to install the CCS Wire From the Stalk to BCM and to Engine ECU, probably you are lucky and this wire is already there.
Coding for CCS will be needed in Engine ECU and BCM.
Coding for MFSW will ne needed in BCM.
All regarding bits are named in VCDS
brecht_van
Belgium
C?ID=306708
Thanks for the reply Dnoermann, this is verry helpful for me. Does anybody know if its possible to activate the abs tyre pressure guard in this transporter? I think I will also need a reset button for the tyre pressure guard if its possible to code this in the abs module?
dnoermann
C?ID=358118
The Set Taster is an option :)
To Enable TPMS just change coding of ABS Byte 12 set Bit 4.
In Speedo you need to enable TPMS, too, this bis is labeled in VCDS.
To Set the OK State, you can use the Button, or with VCDS in ABS set it with AP Channel 042.
Or if you have a newer Speedo from 2014+ than there will ne a menu in Speedo for this.
brecht_van
Belgium
C?ID=306708
Thank you for the information. Tried it and it does work. I will just order a set taster, works easyier than have to set it with the laptop.
dnoermann
C?ID=358118
You are Welcome.
The fun Part will be installing the Wire into the ABS ....
You will have to take a lot stuff apart in the front to get that done.
Been there, done that :)
brecht_van
Belgium
C?ID=306708
Does anyone know the original number of the connector that fits the set taster. I ordered a original taster and connector to the dealer but the connector doesnt fit. The connector number is 7E0 927 121
brecht_van
Belgium
C?ID=306708
The cruise control and MFSW are already installed but now i'm wondering if it should be possible to instal a rain sensor and automatic lights. Does anyone know if this is possible with this bcm or do I have to upgrade it to a higer version (maybe a 7H0937090 version?)
iichel
Netherlands, eastern part
C?ID=284912
Rain sensor will work
Automatic lights need a new bcm and some wiring for both the light switch and the bcm
MartinsX
Riga, Latvia
C?ID=268515
TPMS Reset button: 7E5 927 121 WHS, connector housing 6Q0 972 773 B, contacts 000 979 019 E or 000 979 019 EA (gold plated) for wire cross-section 0,5mm2.
brecht_van
Belgium
C?ID=306708
Thank you for the info.
Thats what is tought. Is it possible to change the bcm with vcds?
brecht_van
Belgium
C?ID=306708
Thanks, already ordered 2 times at the stealer but 2 times the wrong connector with the right number. Now odered somewhere on the internet.
MartinsX
Riga, Latvia
C?ID=268515
What is wrong connector with right number? :D
brecht_van
Belgium
C?ID=306708
A mistake at the central parts distribution centre. They swapped the connectors so if I ordered the 6q 972 773 B connector is receive a connector with another number. But on the packaging there is the right number. First time this happened they said. Lucky me.
