Results 1 to 10 of 16
Thread: MFSW and cruise control for transporter t5.1
    Jul 2019
    Belgium
    I just bought a used transporter t5.1, great to drive with it, the only problem I have is that there is no cruisecontrol. Should it be possible to retrofit a cruise control and maybe some multifunction knobs on the wheel?
    This is the scan from the car:
    Saturday,04,January,2020,20:51:01:02681
    VIN: WV2ZZZ7HZCH029917   License Plate: T5
    Mileage: 141100km-87675mi   Repair Order:
    Chassis Type: 7H-VN75 (6N0)
    Scan: 01 02 03 04 08 09 10 15 17 18 19 25 2E 37 56 69 0B
    VIN: WV2ZZZ7HZCH029917   Mileage: 141100km-87675miles
    Address 01: Engine (J623-CCHB)       Labels:. 03L-906-022-CAA.clb
       Part No SW: 03L 906 019 DN    HW: 03L 907 309 K
       Component: R4 2,0L EDC   H43 9122
       Revision: 26H43---    Serial number: 00000000000000
       Coding: 0125401A231400080000
       Shop #: WSC 02756 790 50316
       ASAM Dataset: EV_ECM20TDI01103L906019DN 002009
       ROD: EV_ECM20TDI01103L906019DG.rod
       VCID: FAB896377DD5A09F69-80AE
       Part No SW: 0BT 300 045 M    HW: 0BH 927 711 C
       Component: DSG DQ500-7F  H05 1712
       Revision: 00H05V01
       ROD: EV_TCMDQ500021_VW36.rod
       VCID: BFCE2723267745B71E-80EA
    Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
       Part No SW: 7E0 907 379 H    HW: 7E0 907 379 E
       Component: ESP MK25A XT  H43 0107
       Revision: 00H43001
       Coding: 208764AD09A6049E26AB90726A6510
       Shop #: WSC 02756 790 49152
       VCID: B73E4F0306477DF7D6-80E2
    Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
       Part No SW: 7E5 907 040 N    HW: 7E5 907 040 N
       Component: ClimatronicT5 H11 0304
       Revision: 00001002
       Coding: 0004000102
       ASAM Dataset: EV_ClimatronicT5 A01003
       ROD: EV_ClimaAutoT5Basis.rod
       VCID: B3267B131A3F91D7EA-80E6
       Slave 1:
       Subsystem 1 - Part No SW: 7E5 907 049 B    HW: 7E5 907 049 B
       Component: Heckbedienung  H10 0202
       Serial number: BHB-0011708110010166
              B10A4 15 [009] - Open or Short to Plus
                        Reset counter: 143
                        Mileage: 141105 km
                        Date: 2020.01.04
                        Time: 00:24:58
    Address 09: Cent. Elect. (J519)       Labels:. 7H0-937-08x-09.clb
       Part No SW: 7H0 937 087 H    HW: 7H0 937 087
       Component: BCM T5GP H+4  H47 0251
       Revision: BO047001    Serial number: 0429 221110355
       Coding: A0A039BA0E232013002008102E2B8DDC0000410F60040000300000000000
       Shop #: WSC 02756 790 00000
       VCID: B93A493B30536B8720-80EC
       Subsystem 1 - Part No SW: 7E0 959 801 A    HW: 7E0 959 801 A  Labels: 7E0-959-80X-V1.CLB
       Component: J386__TSG_FT  003 3311
       Coding: 040000
       Subsystem 2 - Part No SW: 7E0 959 802 A    HW: 7E0 959 802 A  Labels: 7E0-959-80X-V1.CLB
       Component: J387__TSG_BT  003 3311
       Coding: 040000
                        Reset counter: 183
                        Mileage: 141105 km
                        Date: 2014.05.27
                        Time: 04:59:08
       Part No SW: 7E0 919 475 E    HW: 7E0 919 475 A
       Component: PARKHILFE 8K  H11 0013
       Revision: --------    Serial number: 47401119501051
       Coding: 118101
       ASAM Dataset: EV_VW75XParkAssis8K A01005
       ROD: EV_VW75XParkAssis8K_A01.rod
       VCID: B424780F1F3196EFF3-80E0
       Part No SW: 7E0 959 655 C    HW: 7E0 959 655 C
       Component: VW10Airbag007 H06 0013
       Revision: --------    Serial number: 003HM001CW9A
       Coding: 000000000000000000000000000000003037
       Shop #: WSC 02754 790 50316
       VCID: B6204207094D84FFCD-80E2
       Serial number: 3495ZRB40630D6ISCHG2
       Serial number: 3505ZRB40690D6ISF0FS
       Part No SW: 7E0 920 870 E    HW: 7E0 920 870 E
       Component: KOMBI         H04 0305
       Coding: 160F00
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
       VCID: AB166373C20FC917A2-80FE
       Part No: 7E0 815 071 B
       Component: J737__Standheizung  0605
       Revision: 00085000    Serial number: 09019275F00000
       Coding: 0000031
       Shop #: WSC 02757 790 00000
       VCID: A404884F67D1066F63-80F0
       Part No SW: 6N0 909 901     HW: 7H0 937 087
       Component: GW-K-CAN TP20 H47 0251
       Revision: BO047001
       Coding: 042200
       VCID: F0ACB41F23A9EACFD7-80A4
       Component: IMMO          H04 0305
       VCID: EA98A6770D75101F99-80BE
       Revision: A1001003    Serial number: 7660583697
       VCID: A91A997BC0F3DB0750-80FC
       Part No SW: 7E0 035 680 A    HW: 7E0 035 680 A
       Component: RNS-MID       H55 3978
       Revision: AB001001    Serial number: VWZ6Z7L6222059
       Coding: 04000402040000A00014
       Shop #: WSC 02754 790 00000
       VCID: A3068B53A2DF01571A-80F6
       Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
       Revision: 3A001001    Serial number: 00000154679125
       Coding: 410D000102000000
       VCID: B02C741FE329AACF97-80E4
    End----------(Elapsed Time: 01:34, VBatt start/end: 12.9V/12.9V)-----------
    Hi and welcome.
    Moving to Retrofits.
    Please have a look at this page in our Wiki:
    http://wiki.ross-tech.com/wiki/index...tting_%287H%29
  3. Likes brecht_van liked this post
    Jul 2019
    Belgium
    Thanks for the welcome.
    I did a search in the wiki and found this, http://wiki.ross-tech.com/wiki/index...rofitting_(6R)
    Looks like the link of Uwe is the older model of the transporter but thanks for the help.
    So if I understand this correctly I have a bcm of the type high+ so it should be possible to retrofit the cruise control. The mfsw should also be possible if I look on the electric scheme, there is no difference between the control modules with or without msfw. I wil just try it. Should there be another module than the bcm and the radio where is schould change the coding?
    Jan 2019
    Quote Originally Posted by brecht_van View Post
    Correct, the POLO Guide will work with T5 Model Year 2010-2015 it is the same Model PQ25.
    MFSW will work, too.
    For CCS you will need the Stalk, CCS as Button in MFSW will not work.
    For CCS wou probably will have to install the CCS Wire From the Stalk to BCM and to Engine ECU, probably you are lucky and this wire is already there.
    Coding for CCS will be needed in Engine ECU and BCM.
    Coding for MFSW will ne needed in BCM.
    All regarding bits are named in VCDS
  6. Likes brecht_van liked this post
    Jul 2019
    Belgium
    Thanks for the reply Dnoermann, this is verry helpful for me. Does anybody know if its possible to activate the abs tyre pressure guard in this transporter? I think I will also need a reset button for the tyre pressure guard if its possible to code this in the abs module?
    Jan 2019
    The Set Taster is an option
    To Enable TPMS just change coding of ABS Byte 12 set Bit 4.
    In Speedo you need to enable TPMS, too, this bis is labeled in VCDS.
    To Set the OK State, you can use the Button, or with VCDS in ABS set it with AP Channel 042.
    Or if you have a newer Speedo from 2014+ than there will ne a menu in Speedo for this.
  9. Likes brecht_van liked this post
  10. #7
    Jul 2019
    Belgium
    Thank you for the information. Tried it and it does work. I will just order a set taster, works easyier than have to set it with the laptop.
  11. #8
    Jan 2019
    You are Welcome.
    The fun Part will be installing the Wire into the ABS ....
    You will have to take a lot stuff apart in the front to get that done.
    Been there, done that
  12. #9
    Jul 2019
    Belgium
    Does anyone know the original number of the connector that fits the set taster. I ordered a original taster and connector to the dealer but the connector doesnt fit. The connector number is 7E0 927 121
  13. #10
    Jul 2019
    Belgium
    The cruise control and MFSW are already installed but now i'm wondering if it should be possible to instal a rain sensor and automatic lights. Does anyone know if this is possible with this bcm or do I have to upgrade it to a higer version (maybe a 7H0937090 version?)
