2010 Audi Q7 - multimedia system partially dead
dcarter
C?ID=341296
2010 Audi Q7 - display doesn't show anything, Media Player 1 has no lights on it, sound system doesn't work. Scan shows errors in communication to 0E Media Player 1, 47 Sound System, 56 Radio, and 5F Information Electronics.
Thursday,02,January,2020,18:14:35:62740
VCDS Version: 19.6.2.0  HEX-NET CB: 0.4508.4
VIN: WA1DVBFE6AD006424   License Plate:
Mileage: 227190km-141169mi   Repair Order:
Chassis Type: FE (4F0)
Scan: 01 02 03 05 08 09 0E 15 16 17 19 28 36 3C 42 46 47 4C 4F 52
          55 56 5F 62 69 6C 6D 6F 72 76
VIN: WA1DVBFE6AD006424   Mileage: 227190km-141169miles
4C-Tire Pressure II -- Status: Malfunction 0010
Address 01: Engine (BAR)       Labels:. 079-907-560-BAR.clb
   Part No SW: 4L0 910 560 Q    HW: 4L0 907 560 B
   Component: 4.2l V8/4V          0030
   Revision: 78H05---    Serial number:
   Coding: 0121000A190F0960
   Shop #: WSC 31414 790 00001
   VCID: 3620D18441B269FF4D-8062
005241 - Brake Boost Vacuum System
               P1479 - 008 - Mechanical Failure
                    Mileage: 209402 km
                    Date: 2019.01.03
                    Time: 13:10:18
                    RPM: 1587 /min
                    Load: 48.6 %
                    Speed: 16.0 km/h
                    Temperature: 36.0°C
                    Temperature: 15.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 14.351 V
               P0300 - 001 -  - Intermittent - MIL ON
                    Fault Status: 10100001
                    Fault Frequency: 27
                    Mileage: 209634 km
                    Date: 2019.01.05
                    Time: 09:29:04
                    RPM: 759 /min
                    Load: 38.0 %
                    Temperature: 19.0°C
                    Temperature: 0.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.970 V
000776 - Cylinder 8
               P0308 - 008 - Misfire Detected - Intermittent
                    Mileage: 225447 km
                    Date: 2019.12.18
                    Time: 18:23:14
                    RPM: 1810 /min
                    Load: 40.4 %
                    Speed: 21.0 km/h
                    Temperature: 56.0°C
                    Temperature: 29.0°C
                    Voltage: 13.970 V
000774 - Cylinder 6
               P0306 - 001 - Misfire Detected - Intermittent - MIL ON
                    Mileage: 226695 km
                    Date: 2019.12.30
                    Time: 16:22:37
                    RPM: 3866 /min
                    Load: 74.1 %
                    Speed: 77.0 km/h
                    Temperature: 51.0°C
                    Temperature: 18.0°C
                    Absolute Pres.: 960.0 mbar
                    Voltage: 14.097 V
   Part No SW: 09D 927 750 LK    HW: 09D 927 750 LK
   Component: AL 750 6A           1578
   Revision: 00H92000    Serial number:
   Coding: 0001016
   VCID: 02487D545DFA055FB1-8056
   Part No SW: 4L0 910 517 K    HW: 4L0 614 517 K
   Revision: 00H30001
   Coding: 0082993
   VCID: 3228ED94ADDA75DF61-8066
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 D
   Component: FBSAUDIC6 ELV   H05 0100
   Revision: 00H05000    Serial number: 10602601510678
   Coding: 0000135
   VCID: 250206C8EC141267F4-8070
   Subsystem 3 - Part No: 4F0 910 220 G
   Component: FBSAUDIC6 IDG   H01 0053
                    Fault Status: 00100111
                    Reset counter: 178
                    Mileage: 224444 km
                    Date: 2019.11.14
                    Time: 07:49:37
                    Fault Status: 01111011
                    Reset counter: 148
                    Mileage: 223717 km
                    Date: 2019.10.26
                    Time: 15:57:27
00230 - Transmission Park Selector Switch (F305)
                    Fault Status: 00101010
                    Reset counter: 210
                    Mileage: 226138 km
                    Date: 2019.12.29
                    Time: 13:49:08
   Part No SW: 4L0 910 043 C    HW: 4L0 820 043 AB
   Component: KLIMA 4 ZONEN H12 0030
   Revision: 00---017    Serial number: 00000030143468
   Coding: 0C0028
   VCID: 24041BCC272EEB6FE3-8070
                    Reset counter: 207
                    Mileage: 222264 km
                    Date: 2019.10.15
                    Time: 05:05:40
                    Temperature: 39.0°C
                    Temperature: 3.0°C
                    Temperature: -55.0°C
                    RPM: 1640 /min
                    Absolute Pres.: 3.0 bar
                    Current: 0.000 A
                    Temperature: 7.0°C
00003 - Control Module
                    Fault Status: 00100011
                    Mileage: 226138 km
                    Date: 2019.12.29
                    Time: 13:48:40
                    Temperature: 28.0°C
   Part No SW: 4F0 910 279 Q    HW: 4F0 907 279 A
   Component: ILM Fahrer      H26 0340
   Coding: 0133123
   VCID: 373EDC8046B890F756-8062
   Component: Wischer AU716   H17 0100
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
                    Fault Frequency: 146
                    Reset counter: 219
                    Mileage: 209632 km
                    Date: 2019.01.04
                    Time: 15:30:00
Address 0E: Media Player 1
   Component: 72 AIRBAG AUDI8RH43 0230
   Revision: 07H43000    Serial number: 0038QD09DMT.
   Coding: 0014130
   VCID: 2B16F0F08AF0241722-807E
   Subsystem 1 - Part No: 4L0 910 339 A
   Component: BF-Gewichtsens. H03 0030
   Subsystem 2 - Serial number: 6332QSME0E521C22D
   Subsystem 3 - Serial number: 6342QSME08521E22A
   Subsystem 4 - Serial number: 6352QSME0E5205205
   Subsystem 5 - Serial number: 6362QSME34515110+
   Subsystem 6 - Serial number: 63734SME214C5230U
   Subsystem 7 - Serial number: 63834SME404C351E2
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 C
   Component: J0527               0530
   Revision: 00H06000    Serial number: 90026100180099
   Coding: 0012242
   VCID: 271E0CC096180077C6-8072
   Component: E0221           H02 0100
   Part No SW: 4L0 920 982 M    HW: 4L0 920 982 M
   Component: KOMBIINSTR.   H08 0214
   Revision: 00200000    Serial number: DKW01TN2A
   Coding: 8BD663040100CF05020201
   Shop #: WSC 02116 444 103882
   VCID: 3B36C0B0BA90B497B2-806E
   Part No SW: 4F0 907 468 N    HW: 4F0 907 468 G
   Component: GW-BEM 5CAN-M H06 0035
   Revision: MB200030    Serial number: 3000M102120259
   Coding: 000303
   VCID: 3A38C5B4B5AA8D9FA9-806E
   Component: J367-BDM  H07 0125
   Serial number: 00000000002791031873
                    Fault Frequency: 18
                    Reset counter: 199
                    Mileage: 224443 km
                    Date: 2019.11.13
                    Time: 01:07:00
                    Bin. Bits:    00000
                    Voltage: 11.40 V
                    Count: 18
   Part No SW: 4L0 910 158     HW: 4L0 919 158 AB
   Revision: 00---010    Serial number: 00000000225272
   Coding: 0000006
   VCID: 689C4FFC5B86CF0F0F-803C
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 110
                    Mileage: 222264 km
                    Date: 2019.10.15
                    Time: 05:05:45
                    Mileage: 215862 km
                    Date: 2019.05.16
                    Time: 16:56:54
   Part No SW: 4F0 959 760 C    HW: 4F0 959 760 C
   Component: MEM-FS        H08 0062
   Revision: AA000000    Serial number: 00001010066079
   Coding: 00581B00000011110000
   VCID: 312AE29868DC4EC718-8064
   Component: J0769_SWA_MasterH01 0050
   Revision: 00H01000    Serial number: 6PZ 009 014-10
   Coding: 0010001
   VCID: 2E10F9E4B9E2513F05-807A
   Component: J0770_SWA_Slave_H01 0050
   Subsystem 3 - Serial number: 5F12.02.1000H010003C911114ÿ
   Subsystem 4 - Serial number: 911114ÿ
   Part No SW: 4F0 959 793 R    HW: 8K0 959 793 D
   Revision:             Serial number: 0000103037705
   Coding: 011F57205E40440004
   VCID: 46C0A144F152F97FDD-8012
01705 - Selection Switch for Mirror-Adjust (E48)
                    Fault Frequency: 62
                    Reset counter: 219
                    Mileage: 219685 km
                    Date: 2019.08.17
                    Time: 12:49:21
   Part No SW: 4L0 910 289 H    HW: 4L0 907 289 H
   Component: Komfortgeraet   H10 0110
   Revision: 0110 ---    Serial number: 01271342080000
   Coding: 3569693
   VCID: 3522D6885CB462E744-8060
Address 47: Sound System
   Part No SW: 4F0 910 274 A    HW: 4F0 907 274
   Component: J793  RKA+      H02 0100
   Revision: 00000506    Serial number: 00005061103873
   Coding: 0700109
   VCID: 22081DD4FD3AE55F91-8076
02214 - Tire Pressure Warning
            000 - - - MIL ON
                    Fault Status: 11100000
                    Fault Frequency: 12
                    Reset counter: 50
                    Mileage: 210896 km
                    Date: 2019.03.03
                    Time: 12:29:16
                    Hex Value: 0x0001
                    Hex Value: 0x0000
                    Hex Value: 0x0007
                    Voltage: 14.60 V
                    Temperature: -7.0°C
                    (no units): 92.0
   Component: ILM Beifahrer   H13 0100
   Revision:             Serial number: 00000000063443
   Coding: 0012001
   VCID: 5EF0692489C281BFF5-800A
   Part No SW: 4F0 959 792 R    HW: 8K0 959 792 D
   Revision:             Serial number: 0000103036854
   VCID: 45C2A648CC54F267D4-8010
   Part No: 8P0 907 357 H
   Coding: 0000007
   VCID: 3FCEB4A06E88A8B79E-806A
Address 56: Radio
   Revision:             Serial number: 0000103026372
   Coding: 010E57204040230004
   VCID: 43C6B850C260CC57FA-8016
Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
   Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
   Component: Anhaenger     H08 0070
   Revision: 2A001001    Serial number: 00000127174387
   Coding: 0200000000000000
   Revision: --H03---    Serial number: 525PA8-J0241H7
   Coding: 1021201
   Part No SW: 4L0 910 945     HW: 4L0 827 851 D
   Component: ValeoHeckdeckel H29 0410
   Revision: --H29001    Serial number: 8K9827852  B
   Shop #: WSC 98765 666 38354
   VCID: 6C9433EC4F7EE32F6B-8038
   Subsystem 3 - Serial number: RD04.03.10--H29001001B0248ÿ
   Subsystem 4 - Serial number: 1B0248ÿ
   Revision: AAH05061    Serial number: 003896873-----
   Coding: 0003595
   VCID: 260001C49112197FFD-8072
   Component: J_245_EE16_SKB09H10 0200
   Component: J_394_EE16_SKB09H10 0200
   Component: J_392_EE16_SKB09H10 0200
   Revision:             Serial number: 0000103026368
   Part No SW: 4L0 910 283 E    HW: 4L0 919 283 E
   Component: Parkhilfe 8-Kan H02 0100
   Revision: 00H02000    Serial number: 85131000702502
   Coding: 0231366
   VCID: 2C14F3EC8FFE232F2B-8078
End----(Elapsed Time: 02:03, VBatt start/end: 11.8V/11.9V. VIgn 11.9V)-----
Thursday,02,January,2020,18:27:59:62740
VIN: WA1DVBFE6AD006424   License Plate: DBS6931
Control Module Part Number: 4F0 907 468 N
  Component and/or Version: GW-BEM 5CAN-M H06 0035
Optical Bus Diagnostic : 3dB Attenuation
Controller          	Electrical          	Optical
19-CAN Gateway      	OK                  	OK
5F-Information Electr.(High/D3)	OK                  	OK
0E-Media Player 1   	OK                  	OK
47-Sound System     	OK                  	OK
56-Radio            	OK                  	OK
Log-DBS6931-WA1DVBFE6AD006424-227190km-141169mi.txt
Displaying Log-227190km-141169mi.txt.
Optical Bus Diagnostic shows all ok on 5 function units. Vehicle is supposed to have Navigation and Telephone, and maybe other components, but they aren't showing on this.
Thursday,02,January,2020,20:24:08:62740
VCDS Version: Release 19.6.2
Optical Bus Diagnostic : Standard
56-Radio            	OK                  	OK
Checked all fuses in plenum, driver's side, passenger's side, trunk right, and all are good. Seems odd to me that the optical bus diagnostic scan showed all ok but autoscan shows no communication with the four controllers listed.
Looking for information on identifying which controllers should be active and their order of communication so we can try to troubleshoot the system. I might even be asking the wrong questions, but looking for suggestions.
Agreed, that is odd. Normally when all the MMI stuff is off-line, it's due to a break in the optical ring that the optical diagnostics will reveal.
In fact, I'm not sure what to make of this.
Many of the things that were separate modules previously (in MMI 2G) were integrated into the 5F module in the newer MMI 3G, so I wouldn't worry about that.
dcarter
C?ID=341296
“Many of the things that were separate modules previously (in MMI 2G) were integrated into the 5F module in the newer MMI 3G“
Good to know. Thanks
