Results 1 to 4 of 4
Thread: 2019 Passat 150PS Diesel DSRA
    Mar 2018
    First VCDS Scan Engine not running:
    Thursday,02,January,2020,14:36:55:39636
    VIN: WVWZZZ3CZLE048230   License Plate:
    Chassis Type: 3C-VW48 (3Q0)
    Scan: 01 03 05 08 09 10 13 15 17 19 23 2B 42 44 52 5F 65 75 A5 CA
    VIN: WVWZZZ3CZLE048230   Mileage: 1949km-1211miles
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-DSRA)       Labels: None
       Part No SW: 05L 906 022 BJ    HW: 05L 907 309 B
       Component: R4 2.0l TDI   H30 9737
       Revision: E3H30---
       Coding: 011904120344050830000000000000000000000000000000
       Shop #: WSC 05311 115 00312
       ASAM Dataset: EV_ECM20TDI01105L906022BJ 006004
       ROD: EV_ECM20TDI01105L906022BJ_VW48.rod
       VCID: 70B9D7D03A2ABEC7397-8024
    4997 - Glow Plug Control Module
              P064C 00 [032] - -
                        Mileage: 1941 km
                        Date: 2019.12.24
                        Time: 09:20:56
                        Coolant temperature: 17 °C
                        Intake air temperature: 15 °C
                        Voltage terminal 30: 11.960 V
                        Preheat time: 1000 ms
                        Glow status-Bits 0-7: 0
                        Glow status-Bits 0-7: 48
                        Glow cycles above temperature threshold-Bits 0-7: 0
                        Glow cycles below temperature threshold-Bits 0-7: 0
                        Extern.temp.sens.1 bank 1: raw value: 12.5 °C
       Part No SW: 5Q0 614 517 FA    HW: 5Q0 614 517 BR
       Component: ESC           H82 0190
       Revision: 00000000    Serial number: 62799000003903
       Coding: 0EECBA8F31243B744779060360C349705D8CDCE2600692713460F00850224A0B0003000012121212B835351919323200
       Shop #: WSC 00015 115 08193
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
       ROD: EV_Brake1UDSContiMK100IPB_038.rod
       VCID: 75B7E6C445489BEFEA1-8020
       Part No SW: 3Q0 959 435 M    HW: 3Q0 959 435 M
       Component: VWKESSYMQB    027 1307
       Revision: 00027000    Serial number: 0529356985
       Coding: 002F0F0623
       ASAM Dataset: EV_KessyHellaMQBAB 004052
       VCID: 44D14B005E127267ADF-8010
       Part No SW: 5G0 907 044 ER    HW: 5G0 907 044 ER
       Component: Climatronic   H04 2202
       Revision: 00001K10
       Coding: 1112011420011001111500008010D836
       ASAM Dataset: EV_ACClimaBHBVW37X 006150
       VCID: 7BA3F0FC636CCD9F9C5-802E
       Part No SW: 5Q0 937 086 CE    HW: 5Q0 937 086 BQ
       Component: BCM PQ37BOSCH 038 0303
       Revision: --------    Serial number: J53F22091900EP
       ASAM Dataset: EV_BodyContrModul1UDSBosc 020001
       ROD: EV_BCMBOSCH_020_VW27.rod
       VCID: 7F5B04EC7774D1BFB0D-802A
       Subsystem 1 - Part No SW: 3G2 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS    190823  043  0607
       Serial number:         190913094057
       Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
       Component: RLHS  051  0206
       Serial number: SBY19M10D10H01M04S38
       Coding: 0008DD
       Light switch:
       Component: E1 - LDS MQB  H01  0032
       Serial number: 11 10 2019  10001133
       Component: Sensor, DWA  005  0316
       Serial number: 000000000ZY192550TNA
       Subsystem 5 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
       Component: Sirene, DWA  004  0007
       Serial number: 00000000000000637664
       Steering Column Switch:
       Subsystem 7 - Part No SW: 5Q1 953 521 BC    HW: 5Q1 953 569
       Component: Lenks.Modul  H03  0170
       Serial number: 0100160920190C100917
       Part No SW: 5QA 919 294 G    HW: 5QA 919 294
       Component: PDC 8 Kanal   H08 0061
       Serial number: 000150058319278
       Coding: 0471051801
       Shop #: WSC 05311 115 00091
       ASAM Dataset: EV_EPHVA18AU3700000 009046
       VCID: 50F977509A6A9EC7197-8004
       Part No SW: 5Q0 907 572 R    HW: 3Q0 907 567 A
       Component: ACC BOSCH MQB H01 0771
       Coding: 2A0178C251FFC728949C812461400600000000000000000066
       ASAM Dataset: EV_ACCBOSCHVW416 003014
       ROD: EV_ACCBOSCHVW416_003.rod
       VCID: 46D55108682E4077B3B-8012
    0836 - Databus
              [FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
                        Reset counter: 49
                        Mileage: 632 km
                        Date: 2019.12.07
                        Time: 10:34:53
                        Control Module temperature: 23 °C
                        Voltage terminal 15-Voltage: 12.5 V
                        Vehicle speed: 3.80 m/s
                        Longitudinal acceleration: 0.42 m/s²
                        Adaptive distance regulation: status: ACC_Off_MainSwitch_Off
       Part No SW: 3Q0 959 655 CP    HW: 3Q0 959 655 CP
       Component: Airbag VW21   006 0720
       Revision: --------    Serial number: 003Z4PHKNN0L
       Coding: 98FCC0C0000000005C5400CF008840000065
       Shop #: WSC 05311 000 08193
       ROD: EV_AirbaVW21TS6VW48X.rod
       VCID: 0E45A92840DEC8374BB-805A
       Belt Pretensioner left:
       Component: BeltPretRevFL  106 1040
       Serial number: 3G0857705B0277T01240
       Coding: 80000D
       Belt Pretensioner right:
       Component: BeltPretRevFR  106 1040
       Serial number: 3G0857706B0287T01049
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 454 002 208 19
       Serial number: 3570000000056A58FE3
       Subsystem 4 - Part No SW: -----------    HW: 454 002 108 19
       Serial number: 358000000002F328FE3Z
       Subsystem 5 - Part No SW: -----------    HW: 454 802 708 19
       Serial number: 35100FB788A19000000Z
       Subsystem 6 - Part No SW: -----------    HW: 454 802 708 19
       Serial number: 35200966B8A19000000R
       Subsystem 7 - Part No SW: -----------    HW: 454 802 108 19
       Serial number: 35500DD696319000000U
       Part No SW: 3G0 920 951 F    HW: 3G0 920 951 F
       Component: KOMBI         304 6700
       Coding: 27A401906684060001886A071001000880600000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009069
       VCID: 2A0D05B8DC768417B73-807E
    16777018 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
              [BAP_Audio_0x31 keine Kommunikation]
                        Reset counter: 69
                        Mileage: 16 km
                        Date: 2019.11.30
                        Time: 14:04:05
    16777020 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
              [BAP_TEL_0x28 keine Kommunikation]
                        Reset counter: 69
                        Mileage: 16 km
                        Date: 2019.11.30
                        Time: 14:04:10
       Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
       Component: GW MQB High   442 4388
       Revision: --------    Serial number: 0000100722
       Coding: 030900045F087300F900425C080F00000001070000000000000000000000
       ASAM Dataset: EV_GatewNF 013026
       ROD: EV_GatewNF.rod
       Component: 5-01-14-01-04
       Subsystem 2 - Part No SW: 3G0 959 442 J    HW: 3G0 959 442 J
       Component: E221__MFL-PR6  H06 0110
       Serial number: PR6-0440036272190387
       Coding: 2C0B00
       Component: J367-BDMConti  H03 1051
       Serial number: 758860030019100418D1
    Address 23: Brake Booster (J539)       Labels: None
       Part No SW: 3Q0 909 059 G    HW: 3Q0 909 059 A
       Component: EBKV          H06 0069
       Serial number: BPA085270919013
       Coding: 0102C500340000C618638C31000049922449920400
       ASAM Dataset: EV_BrakeBoostG2BoschVW48X 011019
       ROD: EV_BrakeBoostG2BoschVW48X_011_VW41.rod
       VCID: 3B2330FC23EC0D9FDC5-806E
       Part No SW: 3Q0 905 861 B    HW: 3Q0 905 861 B
       Component: ELV-MQBB      H05 0020
       Serial number: 19000256970006
       ROD: EV_ELVMarqMQBA0_VW37.rod
       VCID: 333318DC0BBCC5DF045-8066
       Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
       Component: TSG FS002 0325
       Serial number: YE007SI309168
       Coding: 00350A20D001028000001000
       ASAM Dataset: EV_DCU2DriveSideMAXHKLO 001018
       VCID: 49CF5A347930AF0F5E9-801C
       Subsystem 1 - Part No SW: 5Q4 959 811 H    HW: 5Q4 959 811 H
       Component: Fond FHSG DRV  010 0004
       Serial number: 00000000000013263331
       Coding: 0D0000
       Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
       Component: EPS_MQB_ZFLS  130 1082
       Coding: 911F0000
       Shop #: WSC 00015 115 00312
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 74B1DBC04E3282E7DDF-8020
       Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
       Component: TSG BFS002 0325
       Serial number: YE007SI40229D
       Coding: 00350020DC01028000001000
       ASAM Dataset: EV_DCU2PasseSideMAXHKLO 001018
       VCID: 48C95F30623A5607417-801C
       Subsystem 1 - Part No SW: 5Q4 959 812 H    HW: 5Q4 959 812 H
       Component: Fond FHSG PSG  010 0004
       Serial number: 00000000000013349501
       Coding: 050000
       Part No SW: 3G5 035 820     HW: 3G5 035 820
       Component: MU-O-ND-EU    H12 0152
       Serial number: VWZAZ2W1159028
       Coding: 24810008000020000000000000000000000000000000000000
       ASAM Dataset: EV_MUOIMQB 001001
       ROD: EV_MUOIMQB_VW48.rod
       VCID: 619FA294E1C0074FA69-8034
    1561 - predictive route data
              B1630 02 [008] - Signal Failure
                        Reset counter: 21
                        Mileage: 632 km
                        Date: 2019.12.07
                        Time: 10:34:53
                        Voltage terminal 30: 12.6 V
       Part No SW: 5Q0 907 273 B    HW: 5Q0 907 273
       Component: RDKBERU30     H04 0009
       Serial number: 30000000339166
       ROD: EV_RDKBERU30_006_VW48.rod
       VCID: 34311BC00EB2C2E71DF-8060
    Address 75: Telematics (J949)       Labels:* None
       Part No SW: 5WA 035 284     HW: 5WA 035 284
       Component: OCUGen3High   H20 0083
       Serial number: 0000000907VIQS3
       Coding: 024810001968AC209005460160002607
       ASAM Dataset: EV_OCUGen3High 002115
       ROD: EV_OCUGen3High_VW37.rod
       VCID: 0353881C1B9CB55FD45-8056
    7170 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Multi Function Display (0x0F) - Funktionseinschränkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
                        Reset counter: 40
                        Mileage: 1940 km
                        Date: 2019.12.23
                        Time: 14:50:37
                        Voltage terminal 30: 13.1 V
    0081 - Databus
                        Reset counter: 30
                        Mileage: 633 km
                        Date: 2019.12.07
                        Time: 10:35:35
                        Voltage terminal 30: 12.7 V
    1190912 - Ethernet Databus Branch 1
              U122C 00 [008] - No Communication
                        Reset counter: 20
                        Mileage: 634 km
                        Date: 2019.12.07
                        Time: 10:36:23
                        Ethernet counter checksum error: branch 1: 0
                        Ethernet counter connection interruptions: branch 1: 1
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
       Part No SW: 2Q0 980 653     HW: 2Q0 980 653
       Component: MQB MFK 3.0   H11 1027
       Serial number: E33417011192890
       Coding: 00000808114C4020109E00001020000000410000000000000000000000000000
       ASAM Dataset: EV_MFK3ValeoMQB 005035
       ROD: EV_MFK3ValeoMQB_005_VW38.rod
       VCID: 72BDDDD834268CD7CF3-8026
       Part No SW: 4K0 907 594 AD    HW: 4K0 907 594
       Component: SAD_STG_1     006 0002
       Coding: 708000748101
       ASAM Dataset: EV_SunRoofCONTIAU736 009011
       ROD: EV_SunRoofCONTIAU736_009_VW37.rod
       VCID: 76B5E1C8584E90F7E3B-8022
    End----(Elapsed Time: 01:53, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
    After Clear All DTCs Engine not running:
    Thursday,02,January,2020,14:41:48:39636
       Revision: E3H30---
    Readiness: 0 0 0 1 1
       Coding: 002F0F0623
       Revision: 00001K10
       Coding: 0008DD
       Light switch:
       Coding: 0471051801
       Coding: 80000D
       Coding: 80000D
       ROD: EV_GatewNF.rod
       Coding: 2C0B00
       Coding: 0D0000
       Coding: 911F0000
       Coding: 050000
    End----(Elapsed Time: 01:47, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
  2. Likes Uwe, Jef, Dana liked this post
  3. #2
    Mar 2018
    Title should refer to 150PS not 140. Can this be changed?
    Administrator Andy's Avatar
    Sector 7G
    Quote Originally Posted by 32110 View Post
    It has been done.
  5. Likes 32110, Uwe liked this post
  6. #4
    Mar 2018
    Engine Channel Maps with engine running but not up to full temperature.
    Adpmap:
    ;SW:05L-906-022-BJ   HW:05L-907-309-B ---  Engine
    ;Component:R4 2.0l TDI   H30 9737, Coding:011904120344050830000000000000000000000000000000
    ;EV_ECM20TDI01105L906022BJ,006004,EV_ECM20TDI01105L906022BJ_VW48.rod
    ;Thursday,30,January,2020,15:25:38:39636
    ;VCDS Version: Release 19.6.2 (x64)  Data version: 20190930 DS308.0
    ;VCID: 70B9D7D03A2ABEC7397-8024
    IDE00263-Injector 1 correction value,8GZYFFF ,7
    IDE00264-Injector 2 correction value,ARID6BK ,7
    IDE00265-Injector 3 correction value,8PR1FTH ,7
    IDE00266-Injector 4 correction value,8P8SA6G ,7
    IDE01096-Particulate Filter Statistics,0 ,1
    IDE01711-Blocking of particle filter regeneration,not active ,1
    IDE01945-Engine run-in oil pressure,not active ,1
    IDE02248-Individually adjustable maximum speed limit,300.0 km/h,2
    IDE02332-Deactivate production mode,00 00 00 ,3
    IDE02637-Adaptation for metering quantity measurement,4 ,1
    IDE04158-Activation of start-stop function,active ,1
    IDE04617-Protective function,OFF ,1
    IDE07903-Adaptation of ash mass,0.81 g,2
    IDE10309-Adaptation of oxidation catalytic converter ageing,124160 s,2
    IDE12048-MAS13895-Adaptation of correction angle position detection bank 1 outlet-Error angle sensor,-29.69 °,4
    IDE12048-MAS13896-Adaptation of correction angle position detection bank 1 outlet-Error angle sensor wheel,0.00 °,4
    IDE12080-MAS13895-Adaptation of correction angle of crankshaft position detection-Error angle sensor,7.03 °,4
    IDE12080-MAS13896-Adaptation of correction angle of crankshaft position detection-Error angle sensor wheel,0.00 °,4
    Elapsed Time: 00:04
    Blockmap:
    ;Thursday,30,January,2020,15:24:38:39636
    Group,Description,Actual
    IDE00011,Vehicle Identification Number (VIN),WVWZZZ3CZLE048230,
    IDE00019,Voltage terminal 30,13.180, V
    IDE00020-ENG57549,Terminal 15 status-Bits 0-7,1,
    IDE00021,Engine speed,824, /min
    IDE00022,Transmission input speed,10000.0, /min
    IDE00025,Coolant temperature,52, °C
    IDE00030,Status of actuator test,not active,
    IDE00075,Vehicle speed,0, km/h
    IDE00076,Status of initial fuel filling,was not yet started,
    IDE00078,Time since engine start,195, s
    IDE00083,Throttle valve position (absolute),21.2, %
    IDE00085,Normed load value,23.5, %
    IDE00086,Accelerator position,14, %
    IDE00090-ENG57549,selected gear-Bits 0-7,0,
    IDE00097,OBD - requirements for which this vehicle is designed,Euro-OBD,
    IDE00100,Engine torque,26.3, Nm
    IDE00102,Control Module temperature,31.0, °C
    IDE00151,Oil fill level,66.444, mm
    IDE00172,A/C compressor torque,20.0, Nm
    IDE00182,Camshaft adaptation intake bank 1: phase position,-3.12, °
    IDE00190,Charge air pressure specified value,964, hPa
    IDE00196,Engine oil temperature,48.4, °C
    IDE00202,Low fuel pressure: specified value,5.000, bar
    IDE00304,Fuel level,36.00, l
    IDE00322,Status of basic setting,was not yet started,
    IDE00323,Security Access: Number of invalid keys,0,
    IDE00347,Air mass: actual value:,6.74, g/s
    IDE00348,Intake air temperature,19, °C
    IDE00349,Throttle valve position: normed,11, %
    IDE00351,Main injection: start of activation,0.00, °
    IDE00352,Main injection: duration of activation,325.2, µs
    IDE00353,Engine start: start quantity,16.71, mg/stroke
    IDE00354,Engine start: start synchronization,EPM_MODE_OK,
    IDE00354-ENG127291,Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE,48,
    IDE00355-ENG57549,Cruise Control System (CCS): status-Bits 0-7,0,
    IDE00358,Limitation: torque,109.3, Nm
    IDE00359,Limitation: smoke,109.4, Nm
    IDE00360,Limitation: accelerator pedal,0.0, Nm
    IDE00363-ENG57549,Glow status-Bits 0-7,0,
    IDE00363-ENG57549,Glow status-Bits 0-7,255,
    IDE00364,Preheat time,0, ms
    IDE00365,Injection amount deviation cylinder 1,0.20, mg/stroke
    IDE00366,Injection amount deviation cylinder 2,-0.11, mg/stroke
    IDE00367,Injection amount deviation cylinder 3,-0.18, mg/stroke
    IDE00368,Injection amount deviation cylinder 4,0.09, mg/stroke
    IDE00371,Fuel consumption,0.47, l/h
    IDE00375,Generator: load signal,38.65, %
    IDE00383,Pre-injection 1: activation start,3.71, °
    IDE00384,Pre-injection 1: activation duration,240.0, µs
    IDE00385,Pre-injection 2: activation start,10.61, °
    IDE00386,Pre-injection 2: activation duration,211.6, µs
    IDE00387,Post-injection 1: activation start,0.00, °
    IDE00388,Post-injection 1: activation duration,0.0, µs
    IDE00389,Post-injection 2: activation start,0.00, °
    IDE00390,Post-injection 2: activation duration,0.0, µs
    IDE00394,Camshaft position: start of phase window,122.52, °
    IDE00395,Camshaft position: end of phase window,303.84, °
    IDE00399,Regulation factor: total,1.000,
    IDE00405,Crankshaft speed (RPM),825.5, /min
    IDE00406,Camshaft speed (RPM),412.5, /min
    IDE00413,Starter control: Interlock- or P/N-signal,False result,
    IDE00413-ENG127289,Starter control: Interlock- or P/N-signal-Test_Program_B TRUE UBYTE,0,
    IDE00416-ENG57549,Starter control: terminal 50 acknowledgment-Bits 0-7,4,
    IDE00417-ENG57549,Starter control: shut-off conditions 1-Bits 0-7,1,
    IDE00420,Service regeneration: current duration,0.0, s
    IDE00430-ENG57549,Particle filter: field regeneration request status-Bits 0-7,0,
    IDE00432,Particle filter: time since last regeneration,3.074, H
    IDE00434,Particle filter: soot mass calculated,13.96, g
    IDE00435,Particle filter: soot mass measured,-9.99, g
    IDE00436,Particle filter: kilometers since last regeneration,197.2, km
    IDE00443-ENG57549,Accelerator pedal: switch positions-Bits 0-7,9,
    IDE00445,Unlearning counter according OBD,255,
    IDE00450,Operating Instructions,--no display--,
    IDE00451,Currently running routine,Unknown (0),
    IDE00472,Mean injection quantity,4.34, mg/stroke
    IDE00474,Ambient air pressure,99, kPa abs
    IDE00477,Torque request: sum of auxiliary aggregate,12.9, Nm
    IDE00541,Acceleration,0.000, m/s²
    IDE00556,Outside air temperature,12, °C
    IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),0.255 Lambda / 0.973 mA,
    IDE00583,Throttle valve specified value,10, %
    IDE00584,Distance driven since erasing DTC memory,329, km
    IDE00585,Dist. driven with exh. Malfunction Indicator Lamp activated,0, km
    IDE00588,Fuel tank fill level,54.9, %
    IDE00595,Allocation of oxygen sensors,B1S1 ,
    IDE00600,Conversion factors,,
    IDE00601,Monitoring status since erasing DTC memory,,
    IDE00603,Number of driving cycles since erasing DTC memory,2,
    IDE00608,Type of fuel,Diesel,
    IDE00727,Test steps still to be performed,0,
    IDE00773,Terminal 15 status via CAN,1,
    IDE00784,Current test step,0,
    IDE00787,Cause for cancellation,0,
    IDE01076,Time since ignition off,129184, s
    IDE01260,Generator power,848.23, W
    IDE01378,High fuel pressure: control deviation,-1400, hPa
    IDE01381,Pre-injection 3: activation duration,0.0, µs
    IDE01382,Post-injection 3: activation start,0.00, °
    IDE01383,Post-injection 3: activation duration,0.0, µs
    IDE01387,Injector 1: rail pressure calibration point 1,0.00, µs
    IDE01388,Injector 1: rail pressure calibration point 2,0.00, µs
    IDE01389,Injector 1: rail pressure calibration point 3,0.00, µs
    IDE01390,Injector 2: rail pressure calibration point 1,0.00, µs
    IDE01391,Injector 2: rail pressure calibration point 2,0.00, µs
    IDE01392,Injector 2: rail pressure calibration point 3,0.00, µs
    IDE01393,Injector 3: rail pressure calibration point 1,0.00, µs
    IDE01394,Injector 3: rail pressure calibration point 2,0.00, µs
    IDE01395,Injector 3: rail pressure calibration point 3,0.00, µs
    IDE01396,Injector 4: rail pressure calibration point 1,0.00, µs
    IDE01397,Injector 4: rail pressure calibration point 2,0.00, µs
    IDE01398,Injector 4: rail pressure calibration point 3,0.00, µs
    IDE01405-ENG57549,Status of starter activation-Bits 0-7,2,
    IDE01407,Particle filter: fuel consumption since last regeneration,8.59, l
    IDE01410,Charge limit over-charge,50.00, g
    IDE01880,Accelerator position 2,14, %
    IDE01922,Vehicle distance driven,3836, km
    IDE02211,Brake pressure,0.00, MPa
    IDE02228,Fuel pressure regulator valve: specified value rail pressure,1.3378e+006, hPa
    IDE02540-ENG57549,Longitudinal acceleration sensor: status-Bits 0-7,0,
    IDE02558-ENG100471,High pressure test: cancel condition-Param 1 Tst Abort Fid,-,
    IDE02558-ENG100389,High pressure test: cancel condition-Param 10 Tst Abort Inj Quant,-,
    IDE02558-ENG103668,High pressure test: cancel condition-Param 11 Tst Abort Eng Speed,-,
    IDE02558-ENG102582,High pressure test: cancel condition-Param 12 Tst Abort Rail Pres High,-,
    IDE02558-ENG104255,High pressure test: cancel condition-Param 13 Tst Abort Rail Pres Low,-,
    IDE02558-ENG32262,High pressure test: cancel condition-Param 14 Tst Abort Acctlst Nez,-,
    IDE02558-ENG32263,High pressure test: cancel condition-Param 15 Tst Abort Covehtrqacs High,-,
    IDE02558-ENG100876,High pressure test: cancel condition-Param 16 Undefined Abort Reason,Undefined Abort Reason,
    IDE02558-ENG101560,High pressure test: cancel condition-Param 2 Tst Abort Clutch,-,
    IDE02558-ENG102266,High pressure test: cancel condition-Param 3 Tst Abort Speed Nez,-,
    IDE02558-ENG100337,High pressure test: cancel condition-Param 4 Tst Abort Brake Press,-,
    IDE02558-ENG101825,High pressure test: cancel condition-Param 5 Tst Abort Thrpedal Press,-,
    IDE02558-ENG103033,High pressure test: cancel condition-Param 6 Tst Abort Loop Ctl,-,
    IDE02558-ENG103871,High pressure test: cancel condition-Param 7 Tst Abort Eng Idle Speed,-,
    IDE02558-ENG102719,High pressure test: cancel condition-Param 8 Tst Abort Eng Cold,-,
    IDE02558-ENG99486,High pressure test: cancel condition-Param 9 Tst Abort Pf Regen,-,
    IDE02742,Oil pressure actual value,257.4, kPa
    IDE02756,Number of manual engine starts,258,
    IDE02757,Number of automatic engine starts,338,
    IDE03008-MAS04415,Stop process prevented-Ambient air pressure,not active,
    IDE03008-MAS04416,Stop process prevented-Sporadic function restriction,not active,
    IDE03008-MAS04417,Stop process prevented-Poor start detection,not active,
    IDE03008-MAS04590,Stop process prevented-Mixture adaptation,not active,
    IDE03008-MAS06602,Stop process prevented-Engine temperature,not active,
    IDE03008-MAS06604,Stop process prevented-Start-stop sensor system,not active,
    IDE03008-MAS06605,Stop process prevented-Regeneration operation,not active,
    IDE03008-MAS06606,Stop process prevented-Brake under pressure too low,not active,
    IDE03010-IDE00924,Number of prevented stop processes-Steering angle,14,
    IDE03010-MAS01627,Number of prevented stop processes-Steering,34,
    IDE03010-MAS02040,Number of prevented stop processes-Play protection,0,
    IDE03010-MAS04415,Number of prevented stop processes-Ambient air pressure,0,
    IDE03010-MAS04416,Number of prevented stop processes-Sporadic function restriction,0,
    IDE03010-MAS04417,Number of prevented stop processes-Poor start detection,0,
    IDE03010-MAS04589,Number of prevented stop processes-Diagnosis of exhaust system,0,
    IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,0,
    IDE03010-MAS04591,Number of prevented stop processes-Diagnosis of air system,0,
    IDE03010-MAS04592,Number of prevented stop processes-Hybrid battery power insufficient,0,
    IDE03010-MAS04593,Number of prevented stop processes-Auxiliary consumers power too high,0,
    IDE03010-MAS04595,Number of prevented stop processes-Deceleration takeover active,0,
    IDE03010-MAS04805,Number of prevented stop processes-Clutch protection K0,0,
    IDE03010-MAS04870,Number of prevented stop processes-Test of thermostat not complete,0,
    IDE03010-MAS05758,Number of prevented stop processes-Driving situation,0,
    IDE03010-MAS06602,Number of prevented stop processes-Engine temperature,1,
    IDE03010-MAS06605,Number of prevented stop processes-Regeneration operation,15,
    IDE03010-MAS06606,Number of prevented stop processes-Brake under pressure too low,0,
    IDE03010-MAS08032,Number of prevented stop processes-Event memory entry in engine control module,0,
    IDE03010-MAS09416,Number of prevented stop processes-Adaptation active,0,
    IDE03010-MAS11563,Number of prevented stop processes-Engine hood open,0,
    IDE03010-MAS11835,Number of prevented stop processes-Function locked due to excessive stalling,0,
    IDE03010-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
    IDE03010-MAS12864,Number of prevented stop processes-Tighter traffic flow detected,0,
    IDE03010-MAS13643,Number of prevented stop processes-E machine output too low,0,
    IDE03010-MAS13644,Number of prevented stop processes-Motor protection active,0,
    IDE03010-MAS13645,Number of prevented stop processes-Fuel salinization protection active,0,
    IDE03010-MAS13661,Number of prevented stop processes-Exhaust emission control diagnosis,0,
    IDE03010-MAS16918,Number of prevented stop processes-Restriction in the start system,0,
    IDE03011-MAS01627,Number of requested start processes-Steering,6,
    IDE03011-MAS04369,Number of requested start processes-Engine temperature too high,0,
    IDE03011-MAS04370,Number of requested start processes-Engine temperature too low,0,
    IDE03011-MAS04416,Number of requested start processes-Sporadic function restriction,0,
    IDE03011-MAS04592,Number of requested start processes-Hybrid battery power insufficient,0,
    IDE03011-MAS04593,Number of requested start processes-Auxiliary consumers power too high,0,
    IDE03011-MAS04595,Number of requested start processes-Deceleration takeover active,0,
    IDE03011-MAS06606,Number of requested start processes-Brake under pressure too low,1,
    IDE03011-MAS06607,Number of requested start processes-SCR System requires restart,0,
    IDE03011-MAS09730,Number of requested start processes-Cat. heater,0,
    IDE03011-MAS11563,Number of requested start processes-Engine hood open,0,
    IDE03011-MAS11834,Number of requested start processes-Rolling vehicle,7,
    IDE03011-MAS13644,Number of requested start processes-Motor protection active,0,
    IDE03011-MAS13645,Number of requested start processes-Fuel salinization protection active,0,
    IDE03011-MAS16918,Number of requested start processes-Restriction in the start system,0,
    IDE03015,Compression test cylinder 1,0.0, /min
    IDE03016,Compression test cylinder 2,0.0, /min
    IDE03017,Compression test cylinder 3,0.0, /min
    IDE03018,Compression test cylinder 4,0.0, /min
    IDE03133,Heat circuit 1 for reduc. agent meter. system: act. curr.,0, mA
    IDE03134,Heat circuit 2 for reduc. agent meter. system: act. curr.,408, mA
    IDE03135,Sensor for reducing agent tank temperature: temperature,11.7, °C
    IDE03137,Heat circuit 1 for reduc. agent meter. system: act. voltage,0.0, mV
    IDE03138,Heat circuit 2 for reduc. agent meter. system: act. voltage,128.0, mV
    IDE03139,Reducing agent injector: resistance,13712, mOhm
    IDE03140,NOx sensor 1: NOx concentration,0, ppm
    IDE03141,NOx sensor 2: NOx concentration,0, ppm
    IDE03142,Remaining vehicle distance until reducing agent deficiency,14656.00, km
    IDE03144,Used reducing agent since last service,2546.010, g
    IDE03145,NOx sensor 2: offset for correction factor,0, ppm
    IDE03149,NOx sensor 1: offset for correction factor,0, ppm
    IDE03187,Checksum of flash,9360,
    IDE03235,Neutral position sensor: current transmission angle,0.20, °
    IDE03236,Neutral position sensor: adapted transmission angle,0.20, °
    IDE03242,Injector for reduction agent: current holding phase,454, mA
    IDE03243,Reducing agent injector: current saturation phase,833, mA
    IDE03246,Neutral position sensor: upper adaptation value,3220, mV
    IDE03247,Neutral position sensor: lower adaptation value,1320, mV
    IDE03248,Pressure control valve adaptation factor,0.9667,
    IDE03288-ENG57549,Heating circuit 1 for reducing agent metering: activation-Bits 0-7,0,
    IDE03289-ENG57549,Heating circuit 2 for reducing agent metering: activation-Bits 0-7,0,
    IDE03328,Transmission neutral position sensor voltage,2100, mV
    IDE03362,Requested transmission torque,1000.0, Nm
    IDE03383,Exhaust mass flow of EGR,11.3, kg/h
    IDE03387,Duration of overtemperature at the reduction agent injector,163, s
    IDE03393-ENG57549,Selector lever position-Bits 0-7,0,
    IDE03405-ENG57549,Particle filter field regeneration: cancel conditions-Bits 0-7,0,
    IDE03584-ENG57549,Engine starting requirements-Bits 0-7,0,
    IDE03585,System status for the start/stop function master,No release by coordinator,
    IDE03586-ENG57549,Starting requirements for active participants-Bits 0-7,0,
    IDE03587-IDE02697,Stop overrides for active participants-Multifunction unit control module,not active,
    IDE03587-MAS00124,Stop overrides for active participants-A/C,not active,
    IDE03587-MAS00127,Stop overrides for active participants-brakes,not active,
    IDE03587-MAS00506,Stop overrides for active participants-Adaptive Cruise Control,not active,
    IDE03587-MAS00832,Stop overrides for active participants-Convertible top control module,not active,
    IDE03587-MAS01090,Stop overrides for active participants-Transmission,not active,
    IDE03587-MAS01106,Stop overrides for active participants-Level control system,not active,
    IDE03587-MAS01490,Stop overrides for active participants-Energy management,not active,
    IDE03587-MAS01627,Stop overrides for active participants-Steering,not active,
    IDE03587-MAS02237,Stop overrides for active participants-Body computer 1/ veh. elec sys CM / cent elec.,not active,
    IDE03587-MAS02569,Stop overrides for active participants-All-wheel electronics,not active,
    IDE03587-MAS03757,Stop overrides for active participants-Quattro Sport,not active,
    IDE03587-MAS05129,Stop overrides for active participants-Engine,active,
    IDE03587-MAS06709,Stop overrides for active participants-Keyless operation,not active,
    IDE03587-MAS08785,Stop overrides for active participants-Parking aid,not active,
    IDE03587-MAS13018,Stop overrides for active participants-Front sensor system for driver assistance systems,not active,
    IDE03588-IDE02697,System malfunctions for active participants start/stop-Multifunction unit control module,not active,
    IDE03588-MAS00124,System malfunctions for active participants start/stop-A/C,not active,
    IDE03588-MAS00127,System malfunctions for active participants start/stop-brakes,not active,
    IDE03588-MAS00506,System malfunctions for active participants start/stop-Adaptive Cruise Control,not active,
    IDE03588-MAS00832,System malfunctions for active participants start/stop-Convertible top control module,not active,
    IDE03588-MAS01090,System malfunctions for active participants start/stop-Transmission,not active,
    IDE03588-MAS01106,System malfunctions for active participants start/stop-Level control system,not active,
    IDE03588-MAS01490,System malfunctions for active participants start/stop-Energy management,not active,
    IDE03588-MAS01627,System malfunctions for active participants start/stop-Steering,not active,
    IDE03588-MAS02237,System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.,not active,
    IDE03588-MAS02569,System malfunctions for active participants start/stop-All-wheel electronics,not active,
    IDE03588-MAS03757,System malfunctions for active participants start/stop-Quattro Sport,not active,
    IDE03588-MAS05129,System malfunctions for active participants start/stop-Engine,not active,
    IDE03588-MAS06709,System malfunctions for active participants start/stop-Keyless operation,not active,
    IDE03588-MAS08785,System malfunctions for active participants start/stop-Parking aid,not active,
    IDE03588-MAS13018,System malfunctions for active participants start/stop-Front sensor system for driver assistance systems,not active,
    IDE03589-MAS01161,Error status for start-stop related sensors-Communication error,not active,
    IDE03589-MAS11563,Error status for start-stop related sensors-Engine hood open,not active,
    IDE03589-MAS11868,Error status for start-stop related sensors-Driver door status,not active,
    IDE03589-MAS12097,Error status for start-stop related sensors-driver door open,active,
    IDE03589-MAS12098,Error status for start-stop related sensors-Start/Stop deactivated with button,not active,
    IDE03589-MAS12099,Error status for start-stop related sensors-Clutch signal error,not active,
    IDE03589-MAS12100,Error status for start-stop related sensors-Brake or speed signal error,not active,
    IDE03589-MAS12101,Error status for start-stop related sensors-Steering signal error,not active,
    IDE03660,Longitudinal acceleration,0.750, m/s²
    IDE03712-ENG57549,Engine diagnostic status in curr driving cycle (end-of-line)-Bits 0-7,128,
    IDE03712-ENG57549,Engine diagnostic status in curr driving cycle (end-of-line)-Bits 0-7,56,
    IDE03712-ENG57549,Engine diagnostic status in curr driving cycle (end-of-line)-Bits 0-7,224,
    IDE03767,Engine status,COENG_RUNNING,
    IDE03767-ENG127290,Engine status-Test_Program_Co Eng st COMPU VERB UBYTE,3,
    IDE03998,Clutch Position Sensor,9.6, %
    IDE04002,Charge press. ctrl.,BP_A cmd/act:96/91, kPa
    IDE04003,Charge air temperature sensor,B1S1/B1S2:36/43 °C /  °C,
    IDE04008,Fuel consumption per hour,0.45, L/h
    IDE04009,Driver's desired torque,-1, %
    IDE04010,Engine torque: normalized,7, %
    IDE04011,Nominal torque,340, Nm
    IDE04015,exh.gas recirc.,EGR A:37/37/0 % / EGR B:13/13/-2 %,
    IDE04016,Fuel Pressure Regulation,FRP CMD:25020/--- kPa / FRP ACT:24500/--- kPa,
    IDE04035,exh.gas recirc. temperature,EGRTemp 11/12:---/--- °C / EGRTemp 21/22:---/--- °C,
    IDE04083,Coolant temperatures,ECT 1:50, °C
    IDE04086,Turbocharger guide vane adjustment,VGT_A cmd/act:71/71 % / VGT_B cmd/act:---/--- %,
    IDE04090,Exhaust temperature bank 1,S1/S2/S3/S4:  / 128/114/118/116 °C,
    IDE04092,Diesel particle filter bank 1,0.44/---/---, kPa
    IDE04095,Engine running time,Total:64H573s,
    IDE04098,NOX Sensor,NOx11:65535 ppm / NOx21:65535 ppm,
    IDE04099,Reduction agent dosing,ReAg Rate/Demand:0/0 L/h / Reag Tnk Lvl:65 %,
    IDE04110,Additional inputs and outputs,,
    IDE04272,Counter for regeneration time of diesel particle filter,0.0, s
    IDE04468,Air mass at air mass meter 1,24.3, kg/h
    IDE04623,Kick-down threshold,4125.2, mV
    IDE04651,Torque request: A/C compressor,5.0, Nm
    IDE04652,Exhaust gas jet volume in particle filter,37.9, m³/h
    IDE04653,Simulated particle filter surface temperature,120.7, °C
    IDE04670,Crankshaft signal evaluation: status,GAPFOUND,
    IDE04670-ENG127292,Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE,8,
    IDE04682-ENG57549,Allowed number of injections-Bits 0-7,3,
    IDE04683-ENG57549,Injection release status-Bits 0-7,56,
    IDE04684-ENG57549,Desired injection characteristic-Bits 0-7,56,
    IDE04685,Setpoint generation interior torque,25.8, Nm
    IDE04686,Calculated clutch limit torque,-41.1, Nm
    IDE04687,SCR catalytic converter average temperature,119.7, °C
    IDE04688-ENG57549,Engine control module reset status-Bits 0-7,0,
    IDE04688-ENG57549,Engine control module reset status-Bits 0-7,14,
    IDE04690-ENG57549,Transmission torque intervention status-Bits 0-7,0,
    IDE04693,Increasing desired torque intervention of ESP,-45514.7, Nm
    IDE04694-ENG57549,Engine diagnostic status 2 in curr driving cycle (end-of-line)-Bits 0-7,206,
    IDE04694-ENG57549,Engine diagnostic status 2 in curr driving cycle (end-of-line)-Bits 0-7,240,
    IDE04694-ENG57549,Engine diagnostic status 2 in curr driving cycle (end-of-line)-Bits 0-7,110,
    IDE04694-ENG57549,Engine diagnostic status 2 in curr driving cycle (end-of-line)-Bits 0-7,255,
    IDE04695-ENG06680,Immobilizer snapshot A-Sia Error Snap,00 00 00,
    IDE04696-ENG06680,Immobilizer snapshot B-Sia Error Snap,00 00 00,
    IDE04868-ENG57549,Glow cycles above temperature threshold-Bits 0-7,1,
    IDE04868-ENG57549,Glow cycles above temperature threshold-Bits 0-7,0,
    IDE04869-ENG57549,Glow cycles below temperature threshold-Bits 0-7,1,
    IDE04869-ENG57549,Glow cycles below temperature threshold-Bits 0-7,0,
    IDE04870-ENG57549,Glow cycles upon reaching temperature threshold-Bits 0-7,0,
    IDE04870-ENG57549,Glow cycles upon reaching temperature threshold-Bits 0-7,1,
    IDE04887,Powertrain target torque,-216.0, Nm
    IDE05132-ENG57549,Charge pressure control activity-Bits 0-7,0,
    IDE05136-ENG57549,Current operating mode_2-Bits 0-7,17,
    IDE05136-ENG57549,Current operating mode_2-Bits 0-7,1,
    IDE05136-ENG57549,Current operating mode_2-Bits 0-7,0,
    IDE05137-ENG57549,Shut-off timer: instrum panel counter: open circuit in term 30-Bits 0-7,0,
    IDE05138,Shut-off timer: last engine shut-off time,967, s
    IDE05139,Shut-off timer: last ECM after-run time,169, s
    IDE05260-ENG57549,Gear position sensor: current value-Bits 0-7,0,
    IDE05348,NOx sensor 2: O2 concentration,0.20950,
    IDE05352-ENG57549,Status of trailing throttle detec in trailing throttle coord-Bits 0-7,0,
    IDE05356,Calculated NOx concentration behind turbocharger,60.38, ppm
    IDE05386,Exhaust model temperature 0,183.1, °C
    IDE05387,Exhaust model temperature 1,108.9, °C
    IDE05388,Exhaust model temperature 2,106.8, °C
    IDE05389,Exhaust model temperature 3,108.8, °C
    IDE05440,ESI: Soot equiv 2 calculated from soot index,0.00000014,
    IDE05441,ESI: Wear equivalent 2 calculated from wear index,0.00000028,
    IDE05625,Speed regulation requested torque,-218.0, Nm
    IDE05626,Calculated temperature at reduction agent injection valve,65.9, °C
    IDE05781,Engine temperature management actuator: specified value,0.00, %
    IDE05855,DPF statistics: current regeneration time slice not possible,0.000, H
    IDE05861-ENG57549,DPF statistics: number of interrupted regenerations-Bits 0-7,0,
    IDE05877,DPF statistics: regen time slice not poss in charge cycle,0.000,
    IDE05883,DPF statistics: regeneration time,0, s
    IDE05901,DPF statistics: route in charge cycle,192, km
    IDE05903,DPF statistics: avg driv cycle time during charge cycle,0, s
    IDE05908-ENG57549,DPF statistics: regeneration request-Bits 0-7,0,
    IDE05910,DPF statistics: exhaust temperature regulation average value,0.44,
    IDE05918-ENG57549,DPF statistics: regeneration blocked status-Bits 0-7,0,
    IDE05922-ENG57549,DPF statistics: error status-Bits 0-7,0,
    IDE06013,Engine start: start synchronization 2,EPM_FULL_SYNC,
    IDE06013-ENG127375,Engine start: start synchronization 2-Test_Program_Epm st Sync State t UBYTE,30,
    IDE06041-ENG57549,PDTC drive cycle conditions status-Bits 0-7,36,
    IDE06058-ENG57549,Engine control module reset status info-Bits 0-7,0,
    IDE06059,Particulate filter: oil ash mass,0.8131825, g
    IDE06060,Particulate filter ash load limit,80.000, g
    IDE06216,DPF Statistics: average val.: exhaust temp. ctrl before DPF,2.0,
    IDE06255,Vehicle lateral acceleration,0.02, g
    IDE06256,Vehicle lateral acceleration: raw value,0.02, g
    IDE06257,Vehicle inclination acceleration angle: raw value,0.000, m/s²
    IDE06298-ENG57549,Status of engine during start-Bits 0-7,0,
    IDE06307-MAS00106,Stop prevention history data-Year,2020,
    IDE06307-MAS00107,Stop prevention history data-Month,1,
    IDE06307-MAS00108,Stop prevention history data-Day,30,
    IDE06307-MAS00109,Stop prevention history data-Hours,9,
    IDE06307-MAS00110,Stop prevention history data-Minutes,47,
    IDE06307-MAS00111,Stop prevention history data-Seconds,18,
    IDE06307,Stop prevention history data,not active,
    IDE06307,Stop prevention history data,Steering,
    IDE06308-MAS00106,Start request history data-Year,2020,
    IDE06308-MAS00107,Start request history data-Month,1,
    IDE06308-MAS00108,Start request history data-Day,29,
    IDE06308-MAS00109,Start request history data-Hours,18,
    IDE06308-MAS00110,Start request history data-Minutes,38,
    IDE06308-MAS00111,Start request history data-Seconds,23,
    IDE06308,Start request history data,not active,
    IDE06308,Start request history data,Steering,
    IDE06405,Engine oil temperature_SAE,48, °C
    IDE06433,Standardized airflow ratio: filtered,1.9415,
    IDE06435,A/C compressor: refrigerant pressure,0, hPa
    IDE06445,Longitudinal acceleration: raw value,0.750, m/s²
    IDE06446-ENG57549,Status: incline angle-Bits 0-7,0,
    IDE06552,Time since terminal 15 ON,220060, ms
    IDE06567,Start-stop function deactivation frequency counter,9,
    IDE06568,Stop prevention by driver frequency counter,779,
    IDE06569,Vehicle stopped frequency counter,1254,
    IDE06607,Distance at last active oil overfill warning,0.0, km
    IDE06608,Total distance with active oil overfill warnings,0.0, km
    IDE06610,Vehicle standstill with stop frequency counter,308,
    IDE06703-ENG57549,Drivetrain coordinator: ACC fault status-Bits 0-7,0,
    IDE06705-ENG57549,Drivetrain coordinator: brake function status-Bits 0-7,0,
    IDE06706-ENG57549,ACC variants-Bits 0-7,0,
    IDE06707-ENG57549,CCS Switch-Bits 0-7,2,
    IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,0,
    IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,32,
    IDE06709-ENG57549,ACC variants (coding)-Bits 0-7,2,
    IDE06710-ENG57549,Cruise control system: permanent deactivation-Bits 0-7,0,
    IDE06711-ENG57549,Cruise control system: temporary deactivation-Bits 0-7,0,
    IDE06866-ENG57549,Range limit cancellation due to red. agent metering sys. fault-Bits 0-7,0,
    IDE06946-ENG57549,Brake actuated status-Bits 0-7,0,
    IDE06983-MAS05386,Diesel emissions re-treatment: status-Status of regeneration,not active,
    IDE06983-MAS05386,Diesel emissions re-treatment: status-Status of regeneration,Available,
    IDE06983-MAS05387,Diesel emissions re-treatment: status-Type of regeneration,Passive Regeneration,
    IDE06983-MAS05387,Diesel emissions re-treatment: status-Type of regeneration,Available,
    IDE06983-MAS05388,Diesel emissions re-treatment: status-Status of DeNOx catalytic converter,Not available,
    IDE06983-MAS05388,Diesel emissions re-treatment: status-Status of DeNOx catalytic converter,Adsorption,
    IDE06983-MAS05389,Diesel emissions re-treatment: status-Desulfurization of DeNOx catalytic converter,not active,
    IDE06983-MAS05389,Diesel emissions re-treatment: status-Desulfurization of DeNOx catalytic converter,Not available,
    IDE06983-MAS05390,Diesel emissions re-treatment: status-Regeneration criteria fulfilled,Available,
    IDE06983-MAS05390,Diesel emissions re-treatment: status-Regeneration criteria fulfilled,43.9, %
    IDE06983-MAS05391,Diesel emissions re-treatment: status-Average time between DPF regenerations,0, min
    IDE06983-MAS05391,Diesel emissions re-treatment: status-Average time between DPF regenerations,Not available,
    IDE06983-MAS05392,Diesel emissions re-treatment: status-Average distance between DPF regenerations,Available,
    IDE06983-MAS05392,Diesel emissions re-treatment: status-Average distance between DPF regenerations,0, km
    IDE07001,Piston-cooling jets: activation,0,
    IDE07051-ENG57549,Engaged gear: raw signal-Bits 0-7,0,
    IDE07084,Differential pressure ratio: low-pressure EGR,0.009,
    IDE07086,Exhaust mass flow of low-pressure EGR: calculated,9.9, kg/h
    IDE07088,NOx-Sensor 1: oxygen concentration,0.20894,
    IDE07090-ENG57549,Speed control: status of external torque request-Bits 0-7,4,
    IDE07090-ENG57549,Speed control: status of external torque request-Bits 0-7,0,
    IDE07375,Charge pressure before throttle valve: calculated actual value,1040.3, hPa
    IDE07377,Exhaust recirculation valve 1 bank 1: mass flow - nominal value,11.3, kg/h
    IDE07378,Exhaust recircul. valve 1 bank 1: intake pressur.- nomin. value,1000.5, hPa
    IDE07379,Cylinder charge: spec. value,449.6, mg/stroke
    IDE07380,NOx catalyst accumulator: sulfur charge: act. value calculated,0.000, g
    IDE07381,Cylinder charge: act. value calculated,447.2, mg/stroke
    IDE07382,Exhaust recirculation valve 2 bank 1: mass flow - nominal value,9.7, kg/h
    IDE07383,NOx catalyst accumulator: aging factor: act. value calculated,0, s
    IDE07384,Throttle valv.adapter 1 bank 1: output pressure - nominal value,917.8, hPa
    IDE07385,Exhaust recircul.valve 1 bank 1: intake pressur.- actual value,1000.5, hPa
    IDE07386,Total HFM air mass flow: calculated,23.1, kg/h
    IDE07528-ENG122685,Coordinator releases for DPF regeneration-SwSVW st Ctl Cdn Eng,11111111 11111111 11111111 11111111 ,
    IDE07528-ENG122684,Coordinator releases for DPF regeneration-SwSVW st Ctl Cdn Veh,11111111 11111111 11111111 11110111 ,
    IDE07529-ENG122685,Coordinator releases: standard-SwSVW st Ctl Cdn Eng,00000000 00000000 00000000 00000000 ,
    IDE07529-ENG122684,Coordinator releases: standard-SwSVW st Ctl Cdn Veh,00000000 00000000 00000000 00000000 ,
    IDE07530-ENG122685,Coordinator releases for NOx reduction-SwSVW st Ctl Cdn Eng,00000000 00000000 00000000 00000000 ,
    IDE07530-ENG122684,Coordinator releases for NOx reduction-SwSVW st Ctl Cdn Veh,00000000 00000000 00000000 00000000 ,
    IDE07531-ENG122685,Coordinator releases: sulfur removal-SwSVW st Ctl Cdn Eng,00000000 00000000 00000000 00000000 ,
    IDE07531-ENG122684,Coordinator releases: sulfur removal-SwSVW st Ctl Cdn Veh,00000000 00000000 00000000 00000000 ,
    IDE07532-ENG122685,Coordinator releases for short trip-SwSVW st Ctl Cdn Eng,00000000 00000000 00000000 00000000 ,
    IDE07532-ENG122684,Coordinator releases for short trip-SwSVW st Ctl Cdn Veh,00000000 00000000 00000000 00000000 ,
    IDE07534-ENG57549,Target operating mode for engine-Bits 0-7,17,
    IDE07534-ENG57549,Target operating mode for engine-Bits 0-7,0,
    IDE07534-ENG57549,Target operating mode for engine-Bits 0-7,16,
    IDE07534-ENG57549,Target operating mode for engine-Bits 0-7,1,
    IDE07535-ENG57549,Current operating mode of engine-Bits 0-7,1,
    IDE07535-ENG57549,Current operating mode of engine-Bits 0-7,0,
    IDE07535-ENG57549,Current operating mode of engine-Bits 0-7,16,
    IDE07535-ENG57549,Current operating mode of engine-Bits 0-7,17,
    IDE07536-ENG57549,Next requested operating mode for engine-Bits 0-7,1,
    IDE07536-ENG57549,Next requested operating mode for engine-Bits 0-7,17,
    IDE07536-ENG57549,Next requested operating mode for engine-Bits 0-7,16,
    IDE07536-ENG57549,Next requested operating mode for engine-Bits 0-7,0,
    IDE07548,Engine temp. mangmt. actuator: specified value of angle,38.79, %
    IDE07549,Engine temp. mangmt. actuator: actual value of angle,0.00, %
    IDE07550,Engine temp. management actuator: raw value,0.0, mV
    IDE07551,Engine temp. management actuator: duty cycle activation,0.00, %
    IDE07706,Extern.temp.sens.1 bank 1: raw value,13.0, °C
    IDE07707,Mass airflow sensor 1 bank 1 temperature: raw value,19.2, °C
    IDE07708,Turbocharg. 1 compressor outlet:temp.sensor 1 bank 1: raw value,36.6, °C
    IDE07709,Turboc.1 compres.outlet: temp.sensor 1 bank 1: uncnd.voltage,4054.8, mV
    IDE07710,Charge air cool.output temp.sens.1 bank 1: raw value,43.4, °C
    IDE07711,Charge air cooler output temp.sens.1 bank 1: uncnd. voltage,3848.4, mV
    IDE07712,Turbocharger 1 turbine inlet: temp. sensor 1 bank 1: raw value,126.9, °C
    IDE07713,Turbocharg.1 turbin.inlet: temp.sensor 1 bank 1:uncnd voltage,1140.2, mV
    IDE07714,Turbocharger 1 turbine outlet: temp. sensor 1 bank 1: raw value,114.1, °C
    IDE07715,Turbochar.1 turbin.outlet: temp.sensor 1 bank 1: uncnd voltage,1110.8, mV
    IDE07716,Particle filt.inlet temp.sens.1 bank 1: raw value,118.0, °C
    IDE07717,Particle filt.inlet temp.sens.1 bank 1: uncnd. voltage,1119.4, mV
    IDE07718,Particle filter outlet temp.sens.1 bank 1: raw value,116.9, °C
    IDE07719,Particulate filter output: temp. sensor 1: bank 1: raw voltage,1117.0, mV
    IDE07722,Coolant temp. sens.1 bank 1 before charge air cooler: raw value,33.5, °C
    IDE07723,Coolant temp.sens.1 bank 1 before ch.air cool.:uncnd.voltage,2963.2, mV
    IDE07725,Coolant temp.sens.1 bank 1 at cylinder head: raw value,53.1, °C
    IDE07726,Coolant temp.sens.1 bank 1 at cylinder head: uncnd. voltage,2140.2, mV
    IDE07731,Exh. gas recirc.temp. sens. 2 bank 1: raw value,51.5, °C
    IDE07732,Exhaust recirculation temp. sensor 2 bank 1: uncnd. voltage,4031.6, mV
    IDE07733,Ambient air pressure sensor 1 bank 1: raw value,997, hPa
    IDE07738,Charge air cooler inlet: pressure sensor 1 bank 1: raw value,950.6, hPa
    IDE07742,Cylinder head: pressure sensor 3 bank 1: raw value,40.555, bar
    IDE07744,Particle filter: air pressure sensor 1 bank 1: raw value,5, hPa
    IDE07745,Particl.filt.: different.press.sensor 1 bank 1: adaptat. value,4, hPa
    IDE07747,Par.fil: diff.pr.sens.1 bank 1: offset,0, hPa
    IDE07748,Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset,0, hPa
    IDE07754,Exhaust recirculation valve 1 bank 1: activation,-15.61, %
    IDE07755,Exhaust recirc.valve 1 bank 1: posit.feedback - Uncnd vlt,1957.2, mV
    IDE07756,Exhaust recirc.valve 1 bank 1: posit.feedback - Spec.value,39.25, %
    IDE07757,Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value,39.14, %
    IDE07758,Exhaust recirc.valve 1 bank 1: posit.feedback -Offset closed.,-0.88, %
    IDE07759-ENG57549,Exh.recircul.valve 1 bank 1:posit.feedback - mech. stops-Bits 0-7,65,
    IDE07759-ENG57549,Exh.recircul.valve 1 bank 1:posit.feedback - mech. stops-Bits 0-7,0,
    IDE07759-ENG57549,Exh.recircul.valve 1 bank 1:posit.feedback - mech. stops-Bits 0-7,54,
    IDE07760-ENG57549,Exh.recircul.valve 1 bank 1:posit.feedback - Breakaway attempts-Bits 0-7,0,
    IDE07761,Exhaust recirculation valve 2 bank 1: activation,-11.14, %
    IDE07762,Exhaust recirc.valve 2 bank 1: posit.feedback - Uncnd vlt,1218.0, mV
    IDE07763,Exhaust recirc.valve 2 bank 1: posit.feedback - Spec.value,14.64, %
    IDE07764,Exhaust recirc.valve 2 bank 1: posit.feedback - Act.value,14.64, %
    IDE07765,Exhaust recirc.valve 2 bank 1: posit.feedback -Offset closed.,-0.22, %
    IDE07766-ENG57549,Exh.recircul.valve 2 bank 1:posit.feedback - mech. stops-Bits 0-7,25,
    IDE07766-ENG57549,Exh.recircul.valve 2 bank 1:posit.feedback - mech. stops-Bits 0-7,0,
    IDE07766-ENG57549,Exh.recircul.valve 2 bank 1:posit.feedback - mech. stops-Bits 0-7,11,
    IDE07767-ENG57549,Exh.recircul.valve 2 bank 1:posit.feedback - Breakaway attempts-Bits 0-7,0,
    IDE07768,Throttle valve adapter 1 bank 1: activation,11.47, %
    IDE07769,Throttl.valve adapt. 1 bank 1: posit feedback - Uncnd vlt,1142.6, mV
    IDE07770,Throttl.valve adapt. 1 bank 1: posit feedback - Spec.value,87.45, %
    IDE07771,Throttl.valve adapt. 1 bank 1: posit feedback - Act.value,87.37, %
    IDE07772,Throttl.valve adapt. 1 bank 1: posit feedback - Offset closed,-0.09, %
    IDE07773-ENG57549,Throttl.valve adapt. 1 bank 1: posit feedback - mech. stops-Bits 0-7,0,
    IDE07773-ENG57549,Throttl.valve adapt. 1 bank 1: posit feedback - mech. stops-Bits 0-7,169,
    IDE07773-ENG57549,Throttl.valve adapt. 1 bank 1: posit feedback - mech. stops-Bits 0-7,2,
    IDE07774-ENG57549,Throttl.valve adapt.1 bank 1:pos.feedback - Breakaway attempts-Bits 0-7,0,
    IDE07775,Exhaust recirculation valve 1 bank 1: activation,13.19, %
    IDE07776,Exh.recircul.valve 1 bank 1: pos.feedback - Uncnd vlt,1096.8, mV
    IDE07777,Exh.recircul.valve 1 bank 1: pos.feedback - Spec.value,87.61, %
    IDE07778,Exh.recircul.valve 1 bank 1: pos.feedback - Act.value,87.73, %
    IDE07779,Exh.recircul.valve 1 bank 1: pos.feedback -Offset closed.,0.71, %
    IDE07780-ENG57549,Exh.recircul.valve 1 bank 1: pos.feedback - mech. stops-Bits 0-7,1,
    IDE07780-ENG57549,Exh.recircul.valve 1 bank 1: pos.feedback - mech. stops-Bits 0-7,0,
    IDE07780-ENG57549,Exh.recircul.valve 1 bank 1: pos.feedback - mech. stops-Bits 0-7,248,
    IDE07781-ENG57549,Exh.recircul.valve 1 bank 1: pos.feedback - Breakaway attempts-Bits 0-7,0,
    IDE07783,Turbine actuator 1 bank 1: posit.feedback - Uncnd vlt,1982.8, mV
    IDE07784,Turbine actuator 1 bank 1: posit.feedback - Spec.value,70.61, %
    IDE07785,Turbine actuator 1 bank 1: posit.feedback - Act.value,70.50, %
    IDE07786,Turbine actuator 1 bank 1: posit.feedback - Offset closed,20.63, %
    IDE07787-ENG57549,Turbine actuator 1 bank 1: posit.feedback - mech. stops-Bits 0-7,5,
    IDE07787-ENG57549,Turbine actuator 1 bank 1: posit.feedback - mech. stops-Bits 0-7,0,
    IDE07787-ENG57549,Turbine actuator 1 bank 1: posit.feedback - mech. stops-Bits 0-7,98,
    IDE07788-ENG57549,Turbine actuator 1 bank 1: posit.feedback - Breakaway attempts-Bits 0-7,0,
    IDE07789,Turbine actuator 1 bank 1: activation,4.20, %
    IDE07797,Injector 1 bank 1 for reducing agent before SCR cat: activation,0.00, %
    IDE07798,Heater support pump 1 bank 1 second.circuit: activat.,68.51, %
    IDE07799,Heater support pump 1 bank 1 primary circuit: activation,35.00, %
    IDE07800,Heater supp.pump 1 bank 1 charg.air cool.circuit: activat.,10.00, %
    IDE07801,Mass airflow sensor 1 bank 1 airflow: raw value,239.9, mg/stroke
    IDE07807,Fuel temp. sensor 1 bank 1: raw value,19.0, °C
    IDE07808,Fuel temp. sensor 1 bank 1 before CR pump: uncnd. voltage,4139.0, mV
    IDE07812,Transmission neutral position sensor 1: raw value,42.04, %
    IDE07815-ENG57549,Transmission neutral position sensor: adaptation status-Bits 0-7,62,
    IDE07818,Fuel high pressure sensor: actual value,251600, hPa
    IDE07819,Fuel high pressure sensor: unconditioned voltage,864.4, mV
    IDE07820,Fuel high pressure sensor: nominal value,250500, hPa
    IDE07821,Fuel metering valve: activation,76.40, %
    IDE07822,Fuel pressure regulator valve: activation,20.61, %
    IDE07823-ENG57549,Tank-internal presupply pump 1 bank 1: status-Bits 0-7,0,
    IDE07824,Tank-internal presupply pump 1 bank 1: activation,30.00, %
    IDE07825,Tank-internal presupply pump 1 bank 1: nominal value,67.1, l/h
    IDE07826,Accelerator pedal travel: raw value,0.00, %
    IDE07827,Accelerator pedal: sensor voltage 1,722.8, mV
    IDE07828,Accelerator pedal: sensor voltage 2,361.2, mV
    IDE07832,Coolant fan 1: activation,17.58, %
    IDE07834-ENG57549,Status of starter activation relay-Bits 0-7,0,
    IDE07841,Precontrol value of map,0.000, µs
    IDE07842-ENG57549,Precontrol map value index-Bits 0-7,14,
    IDE07904-ENG57549,Brake test switch status-Bits 0-7,0,
    IDE07905-ENG57549,Brake light switch status-Bits 0-7,0,
    IDE07906-ENG57549,Upper clutch switch: status-Bits 0-7,0,
    IDE07928,Oxygen sensor bank 1 before oxi cat: exhaust temper. calculated,112.8, °C
    IDE07935,Oxyg.sensor bank 1 before oxi cat: curr.pump curr.adaptation,1.0142,
    IDE07936,Oxyg.sens.bank 1 before oxi cat:act.-integr.pump curr.adapt.,0.00, g
    IDE07987,Particle sensor: exhaust temperature,56.7, °C
    IDE07988,Particle sensor: exhust speed,1.98, m/s
    IDE07989,Particle sensor: heat voltage,2.39, V
    IDE07990,Particle sensor: surface temperature,198.85, °C
    IDE08065,Mass airflow sensor 1 bank 1 temperature sensor: raw value,289.8, mV
    IDE08069-ENG57549,Fuel filter: water level sensor 1-Bits 0-7,0,
    IDE08076,Fuel filter: water level sensor 1 raw voltage,0.0, mV
    IDE08132-ENG122793,SCR error notification reset status-SCR Inducement Group,0,
    IDE08132-ENG122794,SCR error notification reset status-SCR Inducement State DFCC,0,
    IDE08132-ENG45524,SCR error notification reset status-SCR Inducement Tester DFCC Five,0,
    IDE08132-ENG45523,SCR error notification reset status-SCR Inducement Tester DFCC Four,0,
    IDE08132-ENG45520,SCR error notification reset status-SCR Inducement Tester DFCC One,0,
    IDE08132-ENG45522,SCR error notification reset status-SCR Inducement Tester DFCC Three,0,
    IDE08132-ENG45521,SCR error notification reset status-SCR Inducement Tester DFCC Two,0,
    IDE08213,Standardised airflow ratio plausibility,0,
    IDE09163,Exhaust recircul.2: different.press.sens.1 bank 1: dyn. offset,0.0, hPa
    IDE09164,Efficiency of the SCR catalytic converter,0.06711,
    IDE09165,Low-pres.exhaust gas recirc.filt.diagn.:release condit.,44049,
    IDE09327,Cylinder 1 bank 1 internal moment,28.2, Nm
    IDE09328,Cylinder 2 bank 1 internal moment,23.9, Nm
    IDE09330,Cylinder 4 bank 1 internal moment,26.9, Nm
    IDE09339,Charge limit for service regeneration while driving,40.00, g
    IDE09490,Exh. gas recirc. 2: diff. press. sensor 1 bank 1: dyn. value,6.0, hPa
    IDE09673-ENG57549,Cyl. head: pos. controller main combust. 3 bank 1: limit stat.-Bits 0-7,0,
    IDE09677,Cyl. head: press. sens 3 bank 1: press. correct. intern. moment,25.1, Nm
    IDE09681-ENG57549,Cyl. head: press. sen 3 bank 1: error stat. combust. rm. press.-Bits 0-7,0,
    IDE09685-ENG57549,Cylinder head: controller internal moment 3 bank 1: limit stat.-Bits 0-7,0,
    IDE09842-ENG57549,Delete engine diagnostic stat. since error memory (end-of-line)-Bits 0-7,255,
    IDE09842-ENG57549,Delete engine diagnostic stat. since error memory (end-of-line)-Bits 0-7,254,
    IDE09843-ENG57549,Delete engine diagn. stat. 2 since error memory (end-of-line)-Bits 0-7,255,
    IDE09880,O2 sens. 1 bank 1 upstrm oxi cat: raw value,3.9119,
    IDE09884,O2 sensor bank 1 upstrm oxi cat: pump current adapt. successful,Correct result,
    IDE09884-ENG127289,O2 sensor bank 1 upstrm oxi cat: pump current adapt. successful-Test_Program_B TRUE UBYTE,1,
    IDE09885,O2 sensor bank 1 upstrm oxi cat: status of signal quality,0,
    IDE09886,Exhaust gas recirc. valve 2 bank 1: mass flow - calculated,9.7, kg/h
    IDE09962,Cyl. head: press. sensor 3 bank 1 primary combustion position,8.37, °
    IDE09966,Cyl. head: press. sensor 3 bank 1: primary comb. Std. deviat.,0.00, °
    IDE09970,Cyl. head: press. sens. 3 bank 1: max press. in decelerat.mode,0.00, °
    IDE09974-ENG57549,Cylinder head: press. sensor 3 bank 1: grp. run time-Bits 0-7,251,
    IDE09974-ENG57549,Cylinder head: press. sensor 3 bank 1: grp. run time-Bits 0-7,255,
    IDE09977,Control module temp.: max. value,42.3, °C
    IDE10032,Reducing agent quality sensor: urea concentration,32.5, %
    IDE10063-MAS00666,Engine oil level: current value-Warning,0,
    IDE10063-MAS00900,Engine oil level: current value-Oil level,999.0, %
    IDE10063-MAS09802,Engine oil level: current value-Odometer reading at entry,3430, km
    IDE10063-MAS09803,Engine oil level: current value-Odometer reading when determining oil level,3430, km
    IDE10063-MAS09807,Engine oil level: current value-Qualification,0,
    IDE10063-ENG06679,Engine oil level: current value-OilLvlDisp_stTstPrcd_VW,2,
    IDE10064-MAS00666,Engine oil level: history 1-Warning,0,
    IDE10064-MAS00900,Engine oil level: history 1-Oil level,999.0, %
    IDE10064-MAS09802,Engine oil level: history 1-Odometer reading at entry,3383, km
    IDE10064-MAS09803,Engine oil level: history 1-Odometer reading when determining oil level,3383, km
    IDE10064-MAS09807,Engine oil level: history 1-Qualification,0,
    IDE10064-ENG06679,Engine oil level: history 1-OilLvlDisp_stTstPrcd_VW,2,
    IDE10065-MAS00666,Engine oil level: history 2-Warning,0,
    IDE10065-MAS00900,Engine oil level: history 2-Oil level,999.0, %
    IDE10065-MAS09802,Engine oil level: history 2-Odometer reading at entry,3318, km
    IDE10065-MAS09803,Engine oil level: history 2-Odometer reading when determining oil level,3316, km
    IDE10065-MAS09807,Engine oil level: history 2-Qualification,0,
    IDE10065-ENG06679,Engine oil level: history 2-OilLvlDisp_stTstPrcd_VW,2,
    IDE10066-MAS00666,Engine oil level: history 3-Warning,0,
    IDE10066-MAS00900,Engine oil level: history 3-Oil level,102.9, %
    IDE10066-MAS09802,Engine oil level: history 3-Odometer reading at entry,3002, km
    IDE10066-MAS09803,Engine oil level: history 3-Odometer reading when determining oil level,2989, km
    IDE10066-MAS09807,Engine oil level: history 3-Qualification,7,
    IDE10066-ENG06679,Engine oil level: history 3-OilLvlDisp_stTstPrcd_VW,2,
    IDE10067-MAS00666,Engine oil level: history 4-Warning,0,
    IDE10067-MAS00900,Engine oil level: history 4-Oil level,999.0, %
    IDE10067-MAS09802,Engine oil level: history 4-Odometer reading at entry,2604, km
    IDE10067-MAS09803,Engine oil level: history 4-Odometer reading when determining oil level,2604, km
    IDE10067-MAS09807,Engine oil level: history 4-Qualification,0,
    IDE10067-ENG06679,Engine oil level: history 4-OilLvlDisp_stTstPrcd_VW,2,
    IDE10068-MAS00666,Engine oil level: history 5-Warning,0,
    IDE10068-MAS00900,Engine oil level: history 5-Oil level,999.0, %
    IDE10068-MAS09802,Engine oil level: history 5-Odometer reading at entry,2467, km
    IDE10068-MAS09803,Engine oil level: history 5-Odometer reading when determining oil level,2456, km
    IDE10068-MAS09807,Engine oil level: history 5-Qualification,0,
    IDE10068-ENG06679,Engine oil level: history 5-OilLvlDisp_stTstPrcd_VW,2,
    IDE10069-MAS00666,Engine oil level: history 6-Warning,0,
    IDE10069-MAS00900,Engine oil level: history 6-Oil level,999.0, %
    IDE10069-MAS09802,Engine oil level: history 6-Odometer reading at entry,2300, km
    IDE10069-MAS09803,Engine oil level: history 6-Odometer reading when determining oil level,2287, km
    IDE10069-MAS09807,Engine oil level: history 6-Qualification,0,
    IDE10069-ENG06679,Engine oil level: history 6-OilLvlDisp_stTstPrcd_VW,2,
    IDE10070-MAS00666,Engine oil level: history 7-Warning,0,
    IDE10070-MAS00900,Engine oil level: history 7-Oil level,999.0, %
    IDE10070-MAS09802,Engine oil level: history 7-Odometer reading at entry,1920, km
    IDE10070-MAS09803,Engine oil level: history 7-Odometer reading when determining oil level,1920, km
    IDE10070-MAS09807,Engine oil level: history 7-Qualification,0,
    IDE10070-ENG06679,Engine oil level: history 7-OilLvlDisp_stTstPrcd_VW,2,
    IDE10071-MAS00666,Engine oil level: history 8-Warning,0,
    IDE10071-MAS00900,Engine oil level: history 8-Oil level,999.0, %
    IDE10071-MAS09802,Engine oil level: history 8-Odometer reading at entry,1880, km
    IDE10071-MAS09803,Engine oil level: history 8-Odometer reading when determining oil level,1880, km
    IDE10071-MAS09807,Engine oil level: history 8-Qualification,0,
    IDE10071-ENG06679,Engine oil level: history 8-OilLvlDisp_stTstPrcd_VW,2,
    IDE10072-MAS00666,Engine oil level: history 9-Warning,0,
    IDE10072-MAS00900,Engine oil level: history 9-Oil level,999.0, %
    IDE10072-MAS09802,Engine oil level: history 9-Odometer reading at entry,1821, km
    IDE10072-MAS09803,Engine oil level: history 9-Odometer reading when determining oil level,1808, km
    IDE10072-MAS09807,Engine oil level: history 9-Qualification,0,
    IDE10072-ENG06679,Engine oil level: history 9-OilLvlDisp_stTstPrcd_VW,2,
    IDE10241,Reducing agent pump module relative press.: calculated,6283, hPa
    IDE10246,Reducing agent tank volume: act. value filtered,13.1934, kg
    IDE10247,Reducing agent tank volume: act. value calculated,11.59, l
    IDE10248,Reducing agent supply pump: offset factor calculated,1.002,
    IDE10249,Reducing agent fill level sensor: act. value,124.5, mm
    IDE10251,Reducing agent supply pump: measured resistance,4228, mOhm
    IDE10253,Exh. gas recirc. valve 1 bank 1: pos. contr. spec. value,37.15, %
    IDE10254,Turbine actuator 1 bank 1: pos. contr. spec. value,71.72, %
    IDE10255,Throttle valve adapter 1 bank 1: pos. contr. spec. value,89.61, %
    IDE10560-ENG57549,Adaption of radiator shutters: status-Bits 0-7,0,
    IDE10569-ENG57549,Turbo charger 1 Turbine inp.: Temp. sensor 1 Bank 1: raw data-Bits 0-7,0,
    IDE10570,Turbo charger.1 turbine inp.: temp.sensor 1 bank 1: comp. temp.,-273.1, °C
    IDE10571,Turbo charger.1 turbine inp.: temp.sens. 1 bank 1: ins.resist.,0, kOhm
    IDE10576-ENG57549,Reducing agent system and actuator: condition-Bits 0-7,0,
    IDE10576-ENG57549,Reducing agent system and actuator: condition-Bits 0-7,4,
    IDE10578-ENG57549,Reducing agent system release: cancel conditions quick start-Bits 0-7,0,
    IDE10579-ENG57549,Reducing agent system pressurization release conditions-Bits 0-7,255,
    IDE10579-ENG57549,Reducing agent system pressurization release conditions-Bits 0-7,2,
    IDE10580,Engine oil level: test method 1,102.4, %
    IDE10581,Engine oil level: test method 2,99.7, %
    IDE10582,Engine oil level: test method 3,0.0, %
    IDE10633,Clutch protection function: reduced torque,3276.0, Nm
    IDE10634,Clutch protection function: slip speed of the clutch,820.5, 1/min/s
    IDE10710-ENG125936,Exhaust warning light: triggering contr. module-Blinking_MIL_due_to_misfire_is_causing_catalyst_damage,No,
    IDE10710-ENG130107,Exhaust warning light: triggering contr. module-MIL Request from Transmission Control Module,No,
    IDE10710-ENG125937,Exhaust warning light: triggering contr. module-MIL_request_register_ident,0,
    IDE10710-ENG130099,Exhaust warning light: triggering contr. module-MIL-Request from All Wheel Drive Control Module,No,
    IDE10710-ENG130102,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module,No,
    IDE10710-ENG06494,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module 48V,No,
    IDE10710-ENG130110,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module,No,
    IDE10710-ENG130100,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module 2,No,
    IDE10710-ENG130103,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module,No,
    IDE10710-ENG130109,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 2,No,
    IDE10710-ENG06495,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 48V,No,
    IDE10710-ENG130105,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module,No,
    IDE10710-ENG130106,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module 2,No,
    IDE10710-ENG130111,Exhaust warning light: triggering contr. module-MIL-Request from HVAC Control Module,No,
    IDE10710-ENG130108,Exhaust warning light: triggering contr. module-MIL-Request from Transmission Control Module 2,No,
    IDE10732,Engine oil level: factor volume,55, ml/mm
    IDE10811-ENG57549,Release requirement for DPF regeneration-Bits 0-7,0,
    IDE10812-ENG57549,Diesel particulate filter regeneration: status-Bits 0-7,0,
    IDE10813,Temp. dwnstrm. of oxi-cat without fuel combustion: calculated,106.6, °C
    IDE10814,Exhaust recirculation cooler 2 Bank 1: efficiency calculated,0.0000,
    IDE10815,Post injection 2: quantity spec. value,0.00, mg/stroke
    IDE10816-ENG57549,Diesel particulate filter regen. level: current-Bits 0-7,0,
    IDE10817,Lambda value at inlet of particulate filter,4.087,
    IDE10818,Temp. spec. value for exhaust gas temp.con.dwnstrm. of oxi-cat,-0.0, °C
    IDE10819,Exh. gas temp.control dwnstrm. of oxi-cat: filtered model error,-0.0, °C
    IDE10820,Exh. gas temp. ctrl. upstrm. of turbine: spec. value,420.0, °C
    IDE10826,Exh. gas temp. controller upstrm. of turbine: I-part,0.000,
    IDE10827,Exh.gas temp.contr. dwnstrm.of oxi-cat:post inject.qty.spec.val,0.00, mg/stroke
    IDE10828,Exh. gas temp.contr. upstrm. of turbine: post inject.qty.corr.,0.00, mg/injection
    IDE10829,Post injection 1: quantity spec. value,0.00, mg/stroke
    IDE10830,Post injection 3: quantity spec. value,0.00, mg/stroke
    IDE10917,Reducing agent delivery pump: coil temperature,10.6, °C
    IDE10920,Temp. upstrm. of reducing agent cat.: calculated,116.9, °C
    IDE10921-ENG57549,Reducing agent delivery pump: number of strokes-Bits 0-7,93,
    IDE10921-ENG57549,Reducing agent delivery pump: number of strokes-Bits 0-7,1,
    IDE10968,Activation radiator shutter result,0.00, %
    IDE10970-MAS11563,Number of prevented stop processes-Engine hood open,0,
    IDE10970-MAS11835,Number of prevented stop processes-Function locked due to excessive stalling,0,
    IDE10970-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,1,
    IDE10989-MAS00106,Immobilizer: historic data-Year,2019,
    IDE10989-MAS00107,Immobilizer: historic data-Month,11,
    IDE10989-MAS00108,Immobilizer: historic data-Day,16,
    IDE10989-MAS00109,Immobilizer: historic data-Hours,9,
    IDE10989-MAS00110,Immobilizer: historic data-Minutes,2,
    IDE10989-MAS00111,Immobilizer: historic data-Seconds,29,
    IDE10989,Immobilizer: historic data,not active,
    IDE10989,Immobilizer: historic data,Brake pedal information: plausibility,
    IDE10994,Poor start counter at start-stop,0,
    IDE11074,Fuel pres.sen. 1 bank 1 upstream from HD pump: press. dev.,0.0, kPa
    IDE11112,Fuel pres.sens.1 bank 1 upstr from HD pump: act.val. filtered,499.9, kPa
    IDE11113,Fuel pres.sen. 1 bank 1 upstream from HD pump: raw volt.,2.284, V
    IDE11114,Fuel press. sensor 1 bank 1 upstr. from HD pump: adapt. value,0.0, kPa
    IDE11115,Start/stop driver request: counter restart by starter,58,
    IDE11116,Start/stop driver request: counter internal-motor restart,47,
    IDE11117,Charge press. ctrl deviation after throttle valve bank 1,913.0, hPa
    IDE11118,Pressure after throttle valve: calculated,-74.0, hPa
    IDE11119,Pressure corr. value after low pressure EGR valve: calculated,-33.8, hPa
    IDE11203,Oil pressure setpoint,259.6, kPa
    IDE11219,Reducing agent inj. quantity: spec. value,0.0, mg/s
    IDE11220,Reducing agent system: current status,COSCR_PRESSURECTL,
    IDE11220-ENG127431,Reducing agent system: current status-Test_Program_SCR Con State 01 UBYTE,4,
    IDE11221,Reducing agent system: last status,COSCR_NOPRESSURECTL,
    IDE11221-ENG127431,Reducing agent system: last status-Test_Program_SCR Con State 01 UBYTE,2,
    IDE11222,Reducing agent system: current substatus,COSCR_METERINGCONTROL,
    IDE11222-ENG127432,Reducing agent system: current substatus-Test_Program_SCR Con State 02 UBYTE,15,
    IDE11223,Reducing agent system: last substatus,COSCR_PRESSUREBUILDUP,
    IDE11223-ENG127432,Reducing agent system: last substatus-Test_Program_SCR Con State 02 UBYTE,13,
    IDE11224,Charge air cool. wat. mix.valve:pos.feedb. - Spec.value,100.00, %
    IDE11225-ENG57549,Charge air cool. wat. mix.valve:pos.feedb. - mech. stops-Bits 0-7,0,
    IDE11226-ENG57549,Charge air cool. wat. mix.valve:pos.feedb. - Breakaway attempts-Bits 0-7,0,
    IDE11228,Charge air cool. wat. mix.valve:pos.feedb. - Raw voltage,0.0, mV
    IDE11229,Charge air cooler water mix. valve: activation,0.00, %
    IDE11230,Charge air cool. wat. mix.valve:pos.feedb. - Act.value,0.00, %
    IDE11233,Charge air cooler water mix. valve: pos. control setpoint,0.00, %
    IDE11250,Reducing agent quality sensor: raw temperature value,11.7, °C
    IDE11267,Oil level: max. value: relative,137.4, %
    IDE11268,Oil level: min. value: relative,70.3, %
    IDE11302-ENG57549,Engine oil level: test method 1:qualification-Bits 0-7,7,
    IDE11303-ENG57549,Engine oil level: test method 3:qualification-Bits 0-7,0,
    IDE11321-ENG57549,Rail press. regulation: operating condition-Bits 0-7,1,
    IDE11329-ENG57549,Oil press. sensor: raw value-Bits 0-7,3,
    IDE11329-ENG57549,Oil press. sensor: raw value-Bits 0-7,9,
    IDE11330,Oil press. control valve: activation pulse duty factor,52.73, %
    IDE11331-MAS03057,Torque reduction: clutch protection history 1-Kilometers,0, km
    IDE11331-MAS10499,Torque reduction: clutch protection history 1-Torque,0, Nm
    IDE11332-MAS03057,Torque reduction: clutch protection history 2-Kilometers,0, km
    IDE11332-MAS10499,Torque reduction: clutch protection history 2-Torque,0, Nm
    IDE11333-MAS03057,Torque reduction: clutch protection history 3-Kilometers,0, km
    IDE11333-MAS10499,Torque reduction: clutch protection history 3-Torque,0, Nm
    IDE11334-MAS03057,Torque reduction: clutch protection history 4-Kilometers,0, km
    IDE11334-MAS10499,Torque reduction: clutch protection history 4-Torque,0, Nm
    IDE11335-MAS03057,Torque reduction: clutch protection history 5-Kilometers,0, km
    IDE11335-MAS10499,Torque reduction: clutch protection history 5-Torque,0, Nm
    IDE11336-MAS03057,Torque reduction: clutch protection history 6-Kilometers,0, km
    IDE11336-MAS10499,Torque reduction: clutch protection history 6-Torque,0, Nm
    IDE11337-MAS03057,Torque reduction: clutch protection history 7-Kilometers,0, km
    IDE11337-MAS10499,Torque reduction: clutch protection history 7-Torque,0, Nm
    IDE11338-MAS03057,Torque reduction: clutch protection history 8-Kilometers,0, km
    IDE11338-MAS10499,Torque reduction: clutch protection history 8-Torque,0, Nm
    IDE11339-MAS03057,Torque reduction: clutch protection history 9-Kilometers,0, km
    IDE11339-MAS10499,Torque reduction: clutch protection history 9-Torque,0, Nm
    IDE11340-MAS03057,Torque reduction: clutch protection history 10-Kilometers,0, km
    IDE11340-MAS10499,Torque reduction: clutch protection history 10-Torque,0, Nm
    IDE11448,Reducing agent over-pressure: diagnosis progress,0.2, %
    IDE11449,Reducing agent under-pressure: diagnosis progress,0.7, %
    IDE11574,Status max. oil level dynamically exceeded,0,
    IDE11575,Status max. oil level permanently exceeded,0,
    IDE11576,Oil level: last valid dynamic value overfilling,0.000, mm
    IDE11577-MAS04415,Stop process prevented 2-Ambient air pressure,not active,
    IDE11577-MAS04416,Stop process prevented 2-Sporadic function restriction,active,
    IDE11577-MAS04417,Stop process prevented 2-Poor start detection,not active,
    IDE11577-MAS04589,Stop process prevented 2-Diagnosis of exhaust system,not active,
    IDE11577-MAS04590,Stop process prevented 2-Mixture adaptation,not active,
    IDE11577-MAS04591,Stop process prevented 2-Diagnosis of air system,not active,
    IDE11577-MAS04870,Stop process prevented 2-Test of thermostat not complete,not active,
    IDE11577-MAS06602,Stop process prevented 2-Engine temperature,not active,
    IDE11577-MAS06604,Stop process prevented 2-Start-stop sensor system,active,
    IDE11577-MAS06605,Stop process prevented 2-Regeneration operation,not active,
    IDE11577-MAS06606,Stop process prevented 2-Brake under pressure too low,not active,
    IDE11577-MAS08032,Stop process prevented 2-Event memory entry in engine control module,not active,
    IDE11577-MAS09416,Stop process prevented 2-Adaptation active,not active,
    IDE11577-MAS13644,Stop process prevented 2-Motor protection active,not active,
    IDE11577-MAS13645,Stop process prevented 2-Fuel salinization protection active,not active,
    IDE11577-MAS13661,Stop process prevented 2-Exhaust emission control diagnosis,not active,
    IDE11577-MAS16918,Stop process prevented 2-Restriction in the start system,not active,
    IDE11895-ENG57549,Particle filter: differential press. sens.1 bank 1: raw data 1-Bits 0-7,161,
    IDE11895-ENG57549,Particle filter: differential press. sens.1 bank 1: raw data 1-Bits 0-7,2,
    IDE11896,Particle filter: differential press. sens.1 bank 1: raw value 1,5, hPa
    IDE11897,Particle filter: differential press. sens.1 bank 1: raw value 2,5, hPa
    IDE11898-ENG57549,Particle filter: differential press. sens.1 bank 1: raw data 2-Bits 0-7,150,
    IDE11898-ENG57549,Particle filter: differential press. sens.1 bank 1: raw data 2-Bits 0-7,2,
    IDE11899,Par.fil: diff.pr.sens.1 bank 1: sensor temperature,33.05, °C
    IDE11900,Par.fil: diff.pr.sens.1 bank 1: data quality,100.00, %
    IDE11901-ENG57549,Par.fil: diff.pr.sens.1 bank 1: sensor configuration-Bits 0-7,0,
    IDE11902-ENG57549,Par.fil: diff.pr.sens.1 bank 1: manufacturer ID-Bits 0-7,0,
    IDE11903-ENG57549,Par.fil: diff.pr.sens.1 bank 1: internal error code-Bits 0-7,0,
    IDE11904-ENG57549,Par.fil: diff.pr.sens.1 bank 1: sensor type-Bits 0-7,0,
    IDE11905-ENG57549,Exhaust recirculation valve 2 bank 1: adaptation status-Bits 0-7,0,
    IDE11905-ENG57549,Exhaust recirculation valve 2 bank 1: adaptation status-Bits 0-7,14,
    IDE11906-ENG57549,Exhaust recirculation valve 1 bank 1: adaptation status-Bits 0-7,0,
    IDE11906-ENG57549,Exhaust recirculation valve 1 bank 1: adaptation status-Bits 0-7,14,
    IDE11907-ENG57549,Exhaust recirculation valve 1 bank 1: adaptation status-Bits 0-7,0,
    IDE11907-ENG57549,Exhaust recirculation valve 1 bank 1: adaptation status-Bits 0-7,15,
    IDE11908-ENG57549,Throttle position actuator 1 bank 1: adaptation status-Bits 0-7,0,
    IDE11908-ENG57549,Throttle position actuator 1 bank 1: adaptation status-Bits 0-7,15,
    IDE11910-ENG57549,Turbine actuator 1 bank 1: adaptation status-Bits 0-7,0,
    IDE11910-ENG57549,Turbine actuator 1 bank 1: adaptation status-Bits 0-7,15,
    IDE11981,Turbocharg. 1 turb: input temp.sensor 1 bank 1: data quality,0.00, %
    IDE12044-ENG57549,Crankshaft Position adapt.: write attempt counter-Bits 0-7,1,
    IDE12074-ENG57549,Position adapt. of intake camshaft bank 1: counter-Bits 0-7,1,
    IDE12078-ENG57549,Position adapt. of camshafts cyl: individual bank 1: counter-Bits 0-7,0,
    IDE12105,Temperature sensor for cylinder block: uncond. voltage value,2241.6, mV
    IDE12106,Temperature sensor for cylinder block,50.6, °C
    IDE12458,Turbocharger 1 bypass valve 1 bank 1: position feedback - first learning,995.8, mV
    IDE12468-ENG57549,Login counter of the simulation interface-Bits 0-7,0,
    IDE13301,Drivetrain coordinator: brake fault status,0,
    IDE13336,Drive train coordinator reversible switch off conditions,2164260866,
    IDE13337,Drive train coordinator irreversible switch off conditions,0,
    IDE13597,NOx sensor 3: NOx concentration,0, ppm
    IDE14135,Cylinder pressure sensor 3: angle correction value,-0.59, °
    IDE14152,Oil level: maximum value: compensated,18.736, mm
    IDE14153,Oil level: minimum value: compensated,45.740, mm
    IDE14207,Fuel pressure sensor for high-pressure pump: regulation status,Correct result,
    IDE14207-ENG127289,Fuel pressure sensor for high-pressure pump: regulation status-Test_Program_B TRUE UBYTE,1,
    IDE14242,Oil pressure valve for piston cooling nozzles: control switch button ratio,0.00, %
    IDE14502-ENG57549,Fuel system output test status-Bits 0-7,0,
    IDE14503-ENG57549,High-pressure fuel system: leak test status-Bits 0-7,0,
    IDE14505-ENG57549,High Pressure test: status-Bits 0-7,0,
    IDE14507,Fuel high-pressure system: residual current pressure regulation valve,0, mA
    IDE14508,Fuel high-pressure system: pressure regulation valve control limit,0, mm³/s
    IDE14509,Fuel high pressure system: lowest fuel low-pressure value,0, hPa
    IDE14510,High-pressure fuel system: metering unit first throttle effect,0, mm³/s
    IDE14511,Fuel high-pressure system: leak test maximum value,0, hPa
    IDE14512,High-pressure fuel system: leak test final result,0, hPa
    IDE14513,High pressure system: leak test starter deactivated,0, hPa
    IDE14518,High Pressure test: standard deviation phase 4,0, hPa
    IDE14519,High Pressure test: standard deviation phase 3,0, hPa
    IDE14520,High Pressure test: standard deviation phase 2,0, hPa
    IDE14521,High Pressure test: standard deviation phase 1,0, hPa
    IDE14522,High Pressure test: pressure build-up time phase 4,0, ms
    IDE14523,High Pressure test: pressure build-up time phase 3,0, ms
    IDE14524,High Pressure test: pressure build-up time phase 2,0, ms
    IDE14525,High Pressure test: pressure build-up time phase 1,0, ms
    IDE14526,High Pressure test: pressure reduction time phase 4,0, ms
    IDE14527,High Pressure test: pressure reduction time phase 3,0, ms
    IDE14528,High Pressure test: pressure reduction time phase 2,0, ms
    IDE14529,High Pressure test: pressure reduction time phase 1,0, ms
    IDE14536,High Pressure test: high pressure average value phase 1,0, hPa
    IDE14537,High Pressure test: high pressure average value phase 2,0, hPa
    IDE14538,High Pressure test: high pressure average value phase 3,0, hPa
    IDE14539,High Pressure test: high pressure average value phase 4,0, hPa
    IDE14540,High Pressure test: pressure build-up time: final value 1,0, ms
    IDE14541,High Pressure test: pressure build-up time: final value 2,0, ms
    IDE14542,High Pressure test: pressure build-up time: final value 3,0, ms
    IDE14607-ENG57549,Coolant distributor module: position feedback - Break away attempts-Bits 0-7,0,
    IDE14608-ENG57549,Coolant distributor module: position feedback - mechanical stops-Bits 0-7,0,
    IDE14610,Charge air cooler water bypass valve: position feedback target value,100.00, %
    IDE14611,Charge air cooler water bypass valve: position control target value,0.00, %
    IDE14612,Charge air cooler water bypass valve: activation,0.00, %
    IDE14903,Fuel Injector 2 for reducing agent before SCR cat: activation,0.00, %
    IDE14904,Crankcase ventilation heater 1: control,100.00, %
    IDE14965,AGR total ground current: deviation from specified value,-0.6, kg/h
    IDE14966,High Pressure AGR ground current: threshold value deviation from specified value,0.0, kg/h
    IDE14967,Low pressure AGR ground current threshold value discrepancy from specified value,-0.6, kg/h
    IDE14968,High Pressure AGR ground current: deviation from specified value,-0.2, kg/h
    IDE14969,Low pressure AGR ground current: deviation from specified value,-0.4, kg/h
    IDE14971,AGR overall ground current: threshold value deviation from specified value,500.0, kg/h
    IDE14985,Reducing agent system: AdBlue distribution dosing,0,
    IDE15033,Oxidation catalytic converter diagnostic: distance since last intervention,3829434, m
    IDE15034,Oxidation catalytic converter diagnostic: frequency counter mode,0,
    IDE15184,Duration of overtemperature at the reduction agent fuel injector 2,0, s
    IDE15186,NOx sensor 3: offset for correction factor,0, ppm
    IDE15187,NOx-Sensor 3: O2-Concentration,0.20950,
    IDE15317,Reducing agent injector 2: current holding phase,429, mA
    IDE15318,Calculated temperature at reduction agent injection valve 2,27.2, °C
    IDE15319,Reducing agent injector 2: current saturation phase,957, mA
    IDE15320,Reducing agent injector 2: resistance,12143, mOhm
    IDE15321,Efficiency of SCR catalytic converter 2,0.12042,
    IDE15322,Temperature of SCR catalytic converter 2 calculated,84.3, °C
    IDE15330-ENG57549,Initial fuel filling with toggle activation: status-Bits 0-7,0,
    IDE15565,High-pressure fuel system: low-pressure pump duty cycle,0.00, %
    IDE15592-ENG57549,Fuel high-pressure system: flow rate test operating point-Bits 0-7,0,
    IDE15593,Fuel high-pressure system: fuel temperature during test,-273.1, °C
    IDE15707,Reducing agent: dosing quantity test: actual quantity,0.000, g
    IDE15712-ENG57549,NOx sensor 1: release status-Bits 0-7,0,
    IDE15713-ENG57549,NOx sensor 2: release status-Bits 0-7,0,
    IDE15714-ENG57549,NOx sensor 3: release status-Bits 0-7,0,
    IDE15715,NOx efficiency SCR diagnostic: progress,0.000,
    IDE15716,NOx efficiency SCR 2 diagnostic: progress,0.000,
    IDE15717,NOx efficiency SCR diagnostic: release status,17589283,
    IDE15718,NOx efficiency SCR 2 diagnostic: release status,4218923,
    IDE15719,NOx efficiency SCR diagnostic: quick-start release status,16801792,
    IDE15720,NOx efficiency SCR 2 diagnostic: quick-start release status,4218880,
    MAS12413-ENG57549,Charge air cooler water mix. valve: monitoring status-Bits 0-7,0,
    MAS16534-ENG57549,A/C compressor info: switch-off status-Bits 0-7,0,
    MAS16535,Exhaust gas recirculation 2: filter pressure loss at bank 1: modeled,4.8, hPa
    MAS16536,Exhaust gas recirculation 2: filter pressure loss at bank 1: simulated,0.3, hPa
    MAS16542,NOx catalytic converter of Bank 1: NH3 reducing agent fill level,0.2891, g/l
    MAS17031,Radiator shutter 1: actual position,399.99, %
    MAS17359-ENG57549,Mass airflow sensor: temperatures: raw data-Bits 0-7,34,
    MAS17359-ENG57549,Mass airflow sensor: temperatures: raw data-Bits 0-7,1,
    MAS17360-ENG57549,Mass airflow sensor including temperature sensor: sensor type-Bits 0-7,0,
    MAS17360-ENG57549,Mass airflow sensor including temperature sensor: sensor type-Bits 0-7,26,
    MAS17361-ENG57549,Mass airflow sensor including temperature sensor: sensor design-Bits 0-7,0,
    MAS17362-ENG57549,Mass airflow sensor including temperature sensor: internal fault code-Bits 0-7,0,
    MAS17363-ENG57549,Mass airflow sensor: airflow: raw data-Bits 0-7,14,
    MAS17363-ENG57549,Mass airflow sensor: airflow: raw data-Bits 0-7,22,
    MAS17364-ENG57549,Mass airflow sensor including temperature sensor: manufacturer ID-Bits 0-7,0,
    MAS17364-ENG57549,Mass airflow sensor including temperature sensor: manufacturer ID-Bits 0-7,3,
    MAS17365,Mass airflow sensor including temperature sensor: data quality,100.00, %
    MAS17366-ENG57549,Charge air cooler inlet: pressure sender: sensor design-Bits 0-7,0,
    MAS17366-ENG57549,Charge air cooler inlet: pressure sender: sensor design-Bits 0-7,1,
    MAS17367-ENG57549,Charge air cooler inlet: pressure sender: raw data-Bits 0-7,3,
    MAS17367-ENG57549,Charge air cooler inlet: pressure sender: raw data-Bits 0-7,214,
    MAS17368,Charge air cooler inlet: pressure sender: data quality,100.00, %
    MAS17369-ENG57549,Charge air cooler inlet: pressure sender: internal error code-Bits 0-7,0,
    MAS17370-ENG57549,Charge air cooler inlet: pressure sender: manufacturer ID-Bits 0-7,86,
    MAS17370-ENG57549,Charge air cooler inlet: pressure sender: manufacturer ID-Bits 0-7,0,
    MAS17371-ENG57549,Charge air cooler inlet: pressure sender: sensor type-Bits 0-7,0,
    MAS17371-ENG57549,Charge air cooler inlet: pressure sender: sensor type-Bits 0-7,4,
    MAS20408,NOx catalytic converter 2: NH3 reducing agent loading,0.0469, g/l
    ENG119898,Actual_section_of_standard_test,0,
    ENG122655,Air_flow_adaption_engine_revolutions_datapoint,3000.0, /min
    ENG122656,Air_flow_adaption_map_number_datapoint,1,
    ENG122654,Air_flow_adaption_mass_flow_value,-16, mg/stroke
    ENG122657,Air_flow_adaption_moment_datapoint,60.0, Nm
    ENG101413,Calibration Identification,05L022BJ9737BEAD,
    ENG99697,Calibration Verification Number,4F A4 F7 2E,
    ENG105735,Cylinder_pressure_offset_cylinder_3,1.016, bar
    ENG123540-ENG124463,Diesel Exhaust Fluid Dosing-Commanded DEF Dosing,0.0, %
    ENG123540-ENG124464,Diesel Exhaust Fluid Dosing-Commanded DEF Dosing Supported,Available,
    ENG123540-ENG124511,Diesel Exhaust Fluid Dosing-DEF Usage for the Current Driving Cycle,0.0000, l
    ENG123540-ENG124512,Diesel Exhaust Fluid Dosing-DEF Usage for the Current Driving Cycle Supported,Available,
    ENG100152-ENG104003,ECUNAME-ECU,ECM,
    ENG100152,ECUNAME,EngineControl,
    ENG115973,Engine Exhaust Flow Rate,33.4, kg/h
    ENG20102,Engine Friction - Percent Torque,7.0, %
    ENG26441-ENG30186,External_stimu_lation_interface_history_data-BasSvrAppl_StTExtSti_tiDay_Stop,28,
    ENG26441-ENG30187,External_stimu_lation_interface_history_data-BasSvrAppl_StTExtSti_tiDay_Strt,0,
    ENG26441-ENG30188,External_stimu_lation_interface_history_data-BasSvrAppl_StTExtSti_tiDurExtSti,0, s
    ENG26441-ENG30189,External_stimu_lation_interface_history_data-BasSvrAppl_StTExtSti_tiHour_Stop,15,
    ENG26441-ENG30190,External_stimu_lation_interface_history_data-BasSvrAppl_StTExtSti_tiHour_Strt,0,
    ENG26441-ENG30191,External_stimu_lation_interface_history_data-BasSvrAppl_StTExtSti_tiMinute_Stop,31,
    ENG26441-ENG30192,External_stimu_lation_interface_history_data-BasSvrAppl_StTExtSti_tiMinute_Strt,0,
    ENG26441-ENG30193,External_stimu_lation_interface_history_data-BasSvrAppl_StTExtSti_tiMonth_Stop,1,
    ENG26441-ENG30194,External_stimu_lation_interface_history_data-BasSvrAppl_StTExtSti_tiMonth_Strt,0,
    ENG26441-ENG30195,External_stimu_lation_interface_history_data-BasSvrAppl_StTExtSti_tiScnd_Stop,30,
    ENG26441-ENG30196,External_stimu_lation_interface_history_data-BasSvrAppl_StTExtSti_tiScnd_Strt,0,
    ENG26441-ENG30197,External_stimu_lation_interface_history_data-BasSvrAppl_StTExtSti_tiYear_Stop,2020,
    ENG26441-ENG30198,External_stimu_lation_interface_history_data-BasSvrAppl_StTExtSti_tiYear_Strt,2000,
    ENG103875-ENG99452,In-use perform. track.: 16 counters-Boost Pressure Monitor Completion Condition Counts,138, counts
    ENG103875-ENG103994,In-use perform. track.: 16 counters-Boost Pressure Monitor Conditions Encountered Counts,30, counts
    ENG103875-ENG100817,In-use perform. track.: 16 counters-EGR and/or VVT Monitor Completion Condition Counts,96, counts
    ENG103875-ENG101113,In-use perform. track.: 16 counters-EGR and/or VVT Monitor Conditions Encountered Counts,30, counts
    ENG103875-ENG104133,In-use perform. track.: 16 counters-Exhaust Gas Sensor Monitor Completion Condition Counts,22, counts
    ENG103875-ENG104165,In-use perform. track.: 16 counters-Exhaust Gas Sensor Monitor Conditions Encountered Counts,30, counts
    ENG103875-ENG28750,In-use perform. track.: 16 counters-Fuel Monitor Completion Condition Counts,100, counts
    ENG103875-ENG28751,In-use perform. track.: 16 counters-Fuel Monitor Conditions Encountered Counts,30, counts
    ENG103875-ENG102823,In-use perform. track.: 16 counters-Ignition Cycle Counter,254, counts
    ENG103875-ENG99234,In-use perform. track.: 16 counters-NMHC Catalyst Monitor Completion Condition Counts,13, counts
    ENG103875-ENG99167,In-use perform. track.: 16 counters-NMHC Catalyst Monitor Conditions Encountered Counts,4, counts
    ENG103875-ENG101363,In-use perform. track.: 16 counters-NOx Adsorber Monitor Completion Condition Counts,0, counts
    ENG103875-ENG103522,In-use perform. track.: 16 counters-NOx Adsorber Monitor Conditions Encountered Counts,0, counts
    ENG103875-ENG125933,In-use perform. track.: 16 counters-NOx/SCR Catalyst Monitor Completion Condition Counts,23, counts
    ENG103875-ENG125934,In-use perform. track.: 16 counters-NOx/SCR Catalyst Monitor Conditions Encountered Counts,30, counts
    ENG103875-ENG99988,In-use perform. track.: 16 counters-OBD Monitoring Conditions Encountered Counts,30, counts
    ENG103875-ENG100240,In-use perform. track.: 16 counters-PM Filter Monitor Completion Condition Counts,10, counts
    ENG103875-ENG103730,In-use perform. track.: 16 counters-PM Filter Monitor Conditions Encountered Counts,4, counts
    ENG127734-MAS00106,Life_cycle_data_start_requirement_development-Year,2020,
    ENG127734-MAS00107,Life_cycle_data_start_requirement_development-Month,1,
    ENG127734-MAS00108,Life_cycle_data_start_requirement_development-Day,29,
    ENG127734-MAS00109,Life_cycle_data_start_requirement_development-Hours,18,
    ENG127734-MAS00110,Life_cycle_data_start_requirement_development-Minutes,38,
    ENG127734-MAS00111,Life_cycle_data_start_requirement_development-Seconds,22,
    ENG127734,Life_cycle_data_start_requirement_development,not active,
    ENG127734,Life_cycle_data_start_requirement_development,Steering,
    ENG127735-MAS00106,Life_cycle_data_stop_prohibition_development-Year,2020,
    ENG127735-MAS00107,Life_cycle_data_stop_prohibition_development-Month,1,
    ENG127735-MAS00108,Life_cycle_data_stop_prohibition_development-Day,29,
    ENG127735-MAS00109,Life_cycle_data_stop_prohibition_development-Hours,8,
    ENG127735-MAS00110,Life_cycle_data_stop_prohibition_development-Minutes,36,
    ENG127735-MAS00111,Life_cycle_data_stop_prohibition_development-Seconds,14,
    ENG127735,Life_cycle_data_stop_prohibition_development,not active,
    ENG127735,Life_cycle_data_stop_prohibition_development,12 V electrical system,
    ENG127733-MAS00106,Life_cycle_data_system_failure-Year,2019,
    ENG127733-MAS00107,Life_cycle_data_system_failure-Month,11,
    ENG127733-MAS00108,Life_cycle_data_system_failure-Day,15,
    ENG127733-MAS00109,Life_cycle_data_system_failure-Hours,18,
    ENG127733-MAS00110,Life_cycle_data_system_failure-Minutes,45,
    ENG127733-MAS00111,Life_cycle_data_system_failure-Seconds,45,
    ENG127733,Life_cycle_data_system_failure,not active,
    ENG127733,Life_cycle_data_system_failure,Engine,
    ENG37798,Oxicat_diagnose_active_status,23742,
    ENG127252-ENG20785,Particulate Matter (PM) Sensor Output-PM Sensor active status Bank 1 Sensor 1,not active,
    ENG127252-ENG20787,Particulate Matter (PM) Sensor Output-PM Sensor active status Bank 2 Sensor 1,not active,
    ENG127252-ENG20783,Particulate Matter (PM) Sensor Output-PM Sensor normalized output value Bank 1 Sensor 1,0.00, %
    ENG127252-ENG20784,Particulate Matter (PM) Sensor Output-PM Sensor normalized output value Bank 2 Sensor 1,0.00, %
    ENG127252-ENG20789,Particulate Matter (PM) Sensor Output-PM Sensor operating status Bank 1 Sensor 1 supported,Available,
    ENG127252-ENG20791,Particulate Matter (PM) Sensor Output-PM Sensor operating status Bank 2 Sensor 1 supported,Not available,
    ENG127252-ENG20786,Particulate Matter (PM) Sensor Output-PM Sensor regen status Bank 1 Sensor 1,not active,
    ENG127252-ENG20788,Particulate Matter (PM) Sensor Output-PM Sensor regen status Bank 2 Sensor 1,not active,
    ENG127252-ENG20790,Particulate Matter (PM) Sensor Output-PM Sensor signal Bank 1 Sensor 1 supported,Available,
    ENG127252-ENG20792,Particulate Matter (PM) Sensor Output-PM Sensor signal Bank 2 Sensor 1 supported,Not available,
    ENG110382-ENG20519,SCR inducem system status-deviation of reagent consumption,Unknown (0),
    ENG110382-ENG20512,SCR inducem system status-Distance traveled in current 10K block,3771, km
    ENG110382-ENG20513,SCR inducem system status-Distance traveled while inducement system active in 20K block,0, km
    ENG110382-ENG20514,SCR inducem system status-Distance traveled while inducement system active in 30K block,0, km
    ENG110382-ENG20515,SCR inducem system status-Distance traveled while inducement system active in 40K block,0, km
    ENG110382-ENG20511,SCR inducem system status-Distance traveled while inducement system active in current 10K block,0, km
    ENG110382-ENG20518,SCR inducem system status-incorrect reagent,Unknown (0),
    ENG110382-ENG20516,SCR inducem system status-inducement system active,not_active,
    ENG110382-ENG20520,SCR inducem system status-NOx emissions too high,Unknown (0),
    ENG110382-ENG20517,SCR inducem system status-reagent level too low,Unknown (0),
    ENG121093-ENG57549,State_of_cruise_control_or_speedlimiter-Bits 0-7,0,
    ENG109106-ENG57549,Status_of_adaption_of_toothed_speed-Bits 0-7,1,
    ENG115975-ENG116124,Transmission Actual Gear-Transmission Actual Gear Ratio,0.000,
    ENG115975-ENG116108,Transmission Actual Gear-Transmission Actual Gear Ratio Supported,Not available,
    ENG115975-ENG116105,Transmission Actual Gear-Transmission Actual Gear Status,NEUT,
    ENG115975-ENG116116,Transmission Actual Gear-Transmission Actual Gear Status Supported,Available,
    Elapsed Time: 00:59
  7. Likes Dana liked this post
