Hi, This is my first post to the forum and am a new user of vcds.
I have a 2006 Skoda Roomster 1.9tdi Pd which I bought a couple of months ago, unfortunately the seller was less than honest about issues the car had. So far I've had to have the ECU reflashed with a virgin instal, and now am battling through a list of things to get her back to tip top condition before her MOT.
My main problem is that whenever I try to log in to adapt the three keys I have (one original and two replacement) to the immobiliser it refuses. I get "FAIL" on the instrument cluster and a message saying "Login lost due to dropped session".
Now before anyone says it..... I have a genuine Ross Tech Hex-V2 cable purchased from Ilexa in the UK.
I had a locksmith come out who tried to code keys for me but couldn't,(faulty remote boards) but he did code the immob transponders. He gave me the four digit code for the cluster at the same time ( I also had the code verified by the tech guy who sorted out my ECU when he came to refit it).
I have no idea what is going on with the system as everytime I input the code with 0 in front it refuses to access.
The two replacement keys will open and start the car but the immob light will flash all the time if they are used. It may be unrelated but my fuel gauge has also gone into reverse as well fluctuating ohm reading of 293 - 294 ohms (And for some reason all my windows dont work and VCDS says they are not installed but that's another fault for later )
If anyone has any ideas I'd be grateful to hear them.
Many thanks
Ben
Many thanks
Ben
Tuesday,24,December,2019,14:54:30:11265
VIN: TMBMG65J075019517 License Plate: KO56DFF
Chassis Type: 5J (5J - Skoda Roomster (2006 > 2010))
Scan: 01 02 03 08 09 15 16 17 19 25 37 44 46 55 56 76 77
VIN: TMBMG65J075019517 Mileage: 178930km-111181miles
Address 01: Engine Labels: 038-906-019-AXR.lbl
Part No: 038 906 019 NR
Component: 1,9l R4 EDC G000SG 9134
Coding: 00102
Shop #: WSC 00046
VCID: 74B0273647A9EFB7DDF-4B3C
Address 03: ABS Brakes Labels:
VCID: 55F67AB2AC0396BFCA1-FFFE
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 5J0 820 045
Component: Klimaanlage X0840
VCID: 629C516EED5D7107BF3-50F4
Address 09: Cent. Elect. Labels:. 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 25738
Shop #: WSC 25071
VCID: 3C20CF162F7967F7D5F-50F4
00903 - Fuse for Heated Outside Mirrors (S196)
37-10 - Faulty - Intermittent
Part No: 1C0 909 605 F
Component: Q5 AIRBAG VW61 Q1Q2 0003
Coding: 20789
Shop #: WSC 73430
VCID: 270A007AC6FFD42FA8D-50F4
Address 17: Instruments Labels: 5J0-920-xxx-17.clb
Part No: 5J0 920 910 C
Component: KOMBIINSTR. V2721446
Coding: 17402
Shop #: WSC 73430
Part No: 6N0 909 901
Component: 003H GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 13765
VCID: 70B82B2633B1D397397-50F4
Address 25: Immobilizer Labels: 5J0-920-xxx-25.clb
Component: IMMOBILIZER V2721446
Coding: 17402
Shop #: WSC 73430
TMBMG65J075019517 SKZ7Z0F3801562
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10110
Shop #: WSC 73430
VCID: 6FBA285A2E8FCC6F20D-50F4
Address 46: Central Conv. Labels:. 6Q0-959-433.clb
Part No: 5J0 959 433 A
Component: 01 Komfortgerát 0001
Coding: 00018
Shop #: WSC 24066
VCID: 313EEE22F83B9A9F769-4B3C
Part No SW: 5J0 035 161 HW: 5J0 035 161
Component: Radio FO3 010 0020
Coding: 0000400
Shop #: WSC 73430 790 00000
VCID: 5F9A589ADB2F5CEF90D-50F4
00856 - Radio Antenna
End----(Elapsed Time: 04:13, VBatt start/end: 14.5V/14.5V. VIgn 0.0V)------
