2015 MK7 GTI MIB1 --> MIB2 Retrofit w/out hacked 5F
RMP750
C?ID=281672
My son and I installed a new MIBII brain unit (3Q0035876A) into his 2015 GTI S that came originally with MIBI (5G0035844) head unit and base audio. I also upgraded the screen to the 8" glass screen. When I first plugged the units in, there was component protection on the 5F which I had removed by a VW dealer. While the unit had CP everything worked (CarPlay, radio, Bluetooth, etc.) but with no sound. After CP was removed, I now have sound but the unit seems to be stuck in Fender "boot" screen. The tech at the dealer tried to set the coding back to my base coding but nothing seems to resolve this "stuck" screen. I've attempted to change the 5F coding to '16 Golf R w/ MIBII and the color of the unit change to blue but it is still stuck at the boot screen. If anyone could provide a solution or some guidance to hopefully get the unit out of the boot screen and fully functioning I'd greatly appreciate it!
Autoscan from before installing MIBII
Saturday,22,July,2017,21:27:01:23899
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
VCDS Version: 17.1.3.0  HEX-NET CB: 0.4341.4
VIN: 3VW4T7AU6FM063979   License Plate: DEVIN 07/22/17
Mileage: 37158km-23088mi   Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F 75 A9
VIN: 3VW4T7AU6FM063979   Mileage: 37158km-23088miles
A9-Struct. Borne Sound -- Status: Malfunction 0010
Address 01: Engine (J623-CXCA)       Labels: 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 A    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0006
   Revision: --H13---
   Coding: 091D00124424002F0000
   Shop #: WSC 00066 790 00218
   ASAM Dataset: EV_ECM20TFS0205G0906259A 001008
   ROD: EV_ECM20TFS0205G0906259A.rod
   VCID: 2C14CC8547566C2165-8078
17178 - Databus
14833 - Internal Control Module
          P0606 00 [032] - Processor Fault
                    Mileage: 37140 km
                    Date: 2017.07.22
                    Time: 11:06:38
                    Coolant temperature: 83 °C
                    Intake air temperature: 70 °C
                    Voltage terminal 30: 12.285 V
                    Engine: operating status: ES
                    STATE_LS_SAE[1]: INI
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 89 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                    FAC_TPS_1_SAE: 15.625000 %
                    FUP_H_SAE: 7090.0 kPa
15122 - Manifold / Barometric Pressure Sensor (G71) / (F96)
          P0106 00 [168] - Implausible Signal
                    Mileage: 36352 km
                    Date: 2017.07.01
                    Time: 12:39:44
                    Coolant temperature: 108 °C
                    Intake air temperature: 59 °C
                    Voltage terminal 30: 12.714 V
                    STATE_LS_SAE[1]: OL_INTR
                    T_AST_SAE: 205 s
                    MAP_MES_SAE: 86 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.943 V
                    FUP_H_SAE: 4160.0 kPa
   Part No SW: 0D9 300 041 T    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4511
   Revision: 03253104    Serial number: TFK01410212182
   ROD: EV_TCMDQ250021.rod
   VCID: 291A359148A479099E-807C
          P1734 00 [002] - -
   Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
   Component: ESC           H32 0385
   Revision: 00000000    Serial number: 53194000000637
   Coding: 01FA6BA13426096F0080020781CC2980D62C9000408194B400430050C009
   Shop #: WSC 01383 790 50316
   VCID: 47DE9329FEF0AF7968-8012
16401 - Tire Pressure Warning
          C102D 00 [008] -  -
                    Reset counter: 212
                    Mileage: 33393 km
                    Date: 2017.05.27
                    Time: 13:44:26
Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
   Part No SW: 5GM 907 426 A    HW: 5GM 907 426 A
   Component: AC Manuell    H02 1001
   Revision: 00001K01
   Coding: 00020004200100000000000000000000
   ROD: EV_ACManueBHBVW37X_SK48.rod
   VCID: 46C09E2DF9FAB67193-8012
   Part No SW: 5Q0 937 087 R    HW: 5Q0 937 087 R
   Component: BCM PQ37BOSCH 028 0145
   Revision: --------    Serial number: 86582511140186
   Coding: 000018464041804969E44000001407201000000000000000000000000000
   Shop #: WSC 00066 790 00226
   ROD: EV_BCMBOSCH_014.rod
   VCID: 4AD8AA1DEDE2521177-801E
   Component: WWS    141129  043 0581
   Serial number:         150106194713
                    Fault Frequency: 35
                    Reset counter: 45
                    Mileage: 28765 km
                    Date: 2016.12.06
                    Time: 09:58:04
   Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
   Serial number: 003MHM01HKCS
   VCID: 51EABD7100B461C936-8004
   Occupant Detection:
   Component: BF-Gewichtss.  H10 0021
   Serial number: IBH0000J1400021L5Y04
   Coding: 30305A
   Subsystem 2 - Part No SW: -----------    HW: 480 001 811 14
   Serial number: 35700000000539AC811L
   Subsystem 3 - Part No SW: -----------    HW: 480 001 911 14
   Serial number: 35800000000D0D6D221N
   Subsystem 4 - Part No SW: -----------    HW: 480 402 310 14
   Serial number: 3510002AB1811BA1338-
   Subsystem 5 - Part No SW: -----------    HW: 480 402 310 14
   Serial number: 3520002AB1811BA4A2E9
   Subsystem 6 - Part No SW: -----------    HW: 480 402 909 14
   Serial number: 3550002A9175A922B195
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 909 14
   Serial number: 3560002A3175A923228Z
   Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20141118500238
   Coding: 0410
   Shop #: WSC 66564 385 16448
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3FCE8BC9A620E7B9D0-806A
   Part No SW: 5G1 920 856     HW: 5G1 920 856
   Component: KOMBI         342 4270
   Coding: 0BBD090A2180CF0502086A001000000000000000
   VCID: 6B960F9982D8AB192C-803E
   Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2203
   Revision: --------    Serial number: 20111410000231
   Coding: 0101000820085900EF0000281C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 07026
   ROD: EV_GatewConti_011.rod
   VCID: 71AA1DF1A0F441C916-8024
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0101
   Serial number: 29140002591740084484
   Coding: 29FFFF
65793 - Powertrain Databus (VAG Wingle-Wire Mode) (SAE  L Shorted H)
          U0009 00 [008] - -
                    Reset counter: 44
                    Mileage: 36832 km
                    Date: 2017.07.02
                    Time: 21:15:49
                    Supply voltage: Terminal 30: 13.7 V
                    Terminal 15: On
   Serial number: 111214060506T2
   Coding: 001F03205000040000000000
   VCID: 40CC8835DBDE9841A9-8014
   Serial number: 00000000000000331545
   Coding: 011000
   Coding: 8102
   ROD: EV_SteerAssisMQB_VW31.rod
   VCID: 373EE3E98E10DFF918-8062
   Serial number: 111214060505IR
   Serial number: 00000000000000362502
   Coding: 091000
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD1.clb
   Part No SW: 5G0 035 844     HW: 5G0 035 844
   Component: MU-S-S-US     014 0645
   Serial number: V7B02711140054
   Coding: 02730000FF00000021220001001800001F0203040100010002
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 648464A56F06E4616D-8030
   Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
   Component: ABT_Std_Plus  H60 0030
   Serial number: VWZ8Z9PS500ZD6
          B11CF 53 [009] - Deactivated
                    Reset counter: 21
                    Mileage: 28503 km
                    Date: 2016.11.30
                    Time: 15:16:32
                    Voltage terminal 30: 14.1 V
Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
   Component: OCULowMQBUS   007 0564
   Shop #: WSC 00066 790 07177
   ROD: EV_OCULowMQB.rod
   VCID: 43C68739CAC88359B4-8016
   Serial number: 141011200824
   ROD: EV_SoundActuaGen2AU64X_VW26.rod
0006 - Actuator for Structural Accoustics
          P193A 00 [008] - Open Circuit
                    Fault Frequency: 65
                    Mileage: 28503 km
                    Date: 2016.11.30
                    Time: 15:16:31
End----------(Elapsed Time: 01:23, VBatt start/end: 12.4V/12.4V)-----------
Autoscan from after MIBII was installed
Tuesday,31,December,2019,10:40:34:23899
VIN: 3VW4T7AU6FM063979   License Plate: DEVINSGTI
Mileage: 59528km-36988mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
VIN: 3VW4T7AU6FM063979   Mileage: 59528km-36988miles
Address 01: Engine (J623-CXCA)       Labels:. 06K-907-425-V1.clb
   Revision: --H13---
   VCID: 2C14CC8547566C2F2B-8078
17169 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [175] - -
                    Fault Frequency: 12
                    Mileage: 59506 km
                    Date: 2019.12.30
                    Time: 10:33:03
                    Engine speed: 696.75 /min
                    Normed load value: 8.2 %
                    Coolant temperature: 77 °C
                    Intake air temperature: 41 °C
                    Voltage terminal 30: 14.277 V
                    ACC variants (coding): CCS
                    CCS Switch: CCS operating unit
                    Cruise control switch actuation-Main switch hardware: not activated
                    Cruise control switch actuation-Main switch CAN: not activated
                    ACC variants: ACC
                    Engine: operating status: IS
Readiness: 1010 0001
   Component: DQ250-6F MQB  H54 4511
   Revision: 06454104    Serial number: TFK01806210302
   Shop #: WSC 04742 780 00200
   VCID: 291A359148A47907D0-807C
   VCID: 47DE9329FEF0AF7726-8012
   Revision: 00001K01
   VCID: 46C09E2DF9FAB67FDD-8012
   VCID: 4AD8AA1DEDE2521F39-801E
17674 - Bulb for Front Left Side Marker Lamp
          B12BA 15 [009] - Open or Short to Plus
                    Reset counter: 94
                    Mileage: 59508 km
                    Date: 2019.12.30
                    Time: 11:52:22
17930 - Bulb for Front Right Side Marker Lamp
          B12BB 15 [009] - Open or Short to Plus
                    Reset counter: 94
                    Mileage: 59508 km
                    Date: 2019.12.30
                    Time: 11:52:22
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 51EABD7100B461C778-8004
   Occupant Detection:
   Coding: 30305A
   Coding: 0410
   VCID: 3FCE8BC9A620E7B79E-806A
   VCID: 6B960F9982D8AB1762-803E
16777022 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
          [BAP_NAV SD_0x32 keine Kommunikation]
                    Reset counter: 94
                    Mileage: 59506 km
                    Date: 2019.12.30
                    Time: 10:33:06
   VCID: 71AA1DF1A0F441C758-8024
   Coding: 29FFFF
   VCID: 40CC8835DBDE984FE7-8014
   Coding: 011000
   Coding: 8102
   VCID: 373EE3E98E10DFF756-8062
   Coding: 091000
   Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
   Component: MU-S-NS-US    851 0867
   Shop #: WSC 05139 004 104857
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 3326D7F99A6833D76A-8066
   Subsystem 1 - Part No SW: 5G6 919 605 C    HW: 5G6 919 605 C
   Component: ABT_Std-2  H50 8130
   Serial number: VWZ6ZJV0041227
6 Faults Found:
1598 - Data Set Implausible
          B2012 00 [008] - -
          [Control module (data record download) - implausible data record for visible MMI system languages]
                    Reset counter: 134
                    Mileage: 59506 km
                    Date: 2019.12.30
                    Time: 11:18:57
                    Voltage terminal 30: 14.2 V
1543 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 94
                    Mileage: 59506 km
                    Date: 2019.12.30
                    Time: 10:33:03
                    Voltage terminal 30: 14.3 V
                    Byte_Coding_Condition-byte_0_condition: OK
                    Byte_Coding_Condition-byte_1_condition: OK
                    Byte_Coding_Condition-byte_10_condition: ERROR
                    Byte_Coding_Condition-byte_11_condition: ERROR
                    Byte_Coding_Condition-byte_12_condition: ERROR
                    Byte_Coding_Condition-byte_13_condition: ERROR
                    Byte_Coding_Condition-byte_14_condition: ERROR
                    Byte_Coding_Condition-byte_15_condition: ERROR
                    Byte_Coding_Condition-byte_16_condition: ERROR
                    Byte_Coding_Condition-byte_17_condition: ERROR
                    Byte_Coding_Condition-byte_18_condition: ERROR
                    Byte_Coding_Condition-byte_19_condition: ERROR
                    Byte_Coding_Condition-byte_2_condition: OK
                    Byte_Coding_Condition-byte_20_condition: ERROR
                    Byte_Coding_Condition-byte_21_condition: ERROR
                    Byte_Coding_Condition-byte_22_condition: ERROR
                    Byte_Coding_Condition-byte_23_condition: ERROR
                    Byte_Coding_Condition-byte_24_condition: ERROR
                    Byte_Coding_Condition-byte_25_condition: ERROR
                    Byte_Coding_Condition-byte_26_condition: ERROR
                    Byte_Coding_Condition-byte_27_condition: ERROR
                    Byte_Coding_Condition-byte_3_condition: OK
                    Byte_Coding_Condition-byte_4_condition: OK
                    Byte_Coding_Condition-byte_5_condition: OK
                    Byte_Coding_Condition-byte_6_condition: OK
                    Byte_Coding_Condition-byte_7_condition: OK
                    Byte_Coding_Condition-byte_8_condition: ERROR
                    Byte_Coding_Condition-byte_9_condition: OK
6698 - Optical data bus
          U1049 00 [009] - Open circuit
          [Optical data bus: open circuit: wakeup]
                    Reset counter: 94
                    Mileage: 59528 km
                    Date: 2019.12.31
                    Time: 10:11:47
                    Voltage terminal 30: 11.9 V
7178 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Park assist OPS (0x0A) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 94
                    Mileage: 59506 km
                    Date: 2019.12.30
                    Time: 10:33:06
                    BAP-BAP_Function_ID: 02
7191 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Driving mode selection (0x17) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 94
                    Mileage: 59506 km
                    Date: 2019.12.30
                    Time: 10:33:06
                    BAP-BAP_Function_ID: 10
7195 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 94
                    Mileage: 59506 km
                    Date: 2019.12.30
                    Time: 10:33:06
   VCID: 43C68739CAC88357FA-8016
End----(Elapsed Time: 01:16, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
kamold
Australia
C?ID=241363
You'll need more than the correct coding to get it working.
There are licenses (Feature Enable Codes) that control the availability of features like navigation, App connect (Carplay, Android Auto) etc that are tied to the VIN of the vehicle that the MIB unit came from.
You cannot restore a license to a car that didn't have that feature from factory.
So for example your MIB1 did not have App connect, so you need to either purchase this as a FEC activation code (and then have the dealer apply it) or use some other more 'creative' methods to address it.
Did your dealer also remove CP from your amp, gateway, radar, cluster, BCM etc? Did they restore available FEC to the newly installed MIB, gateway, radar etc?
These sort of things a bit of a grey area. There are folks on here who can point you in the right direction if you ask politely, but that's not what this forum is for.
m87a
Bosnia and Herzegovina
C?ID=156900
for boot screen change
adaptation -> (8)-Startup_Screen_Sticker_HMI-Fender
set deactived
RMP750
C?ID=281672
The MIBII unit was brand new, does it still need FEC's? Initially after install, App Connect and other features worked just with no sound but now I cant seem to get into the radio at all. Shouldn't basic features such as radio, Bluetooth, etc. still work if they were available on the MIBI? I am open to paying for FEC's for features like App Connect, but want to make sure I will be able to use the head unit before making that purchase. The VW tech told me that all CP was removed. Trying to do this retrofit as legitimately as possible.
RMP750
C?ID=281672
m87a will this adaptation allow me to get past the Fender boot screen or just remove the Fender insignia from the start up screen?
kamold
Australia
C?ID=241363
After CP is removed, only the radio will work. FEC need to be restored for other features including bluetooth.
nirvananils
C?ID=289109
But You can't restore FEC from MIB1 tot MIB2, you'll need a Patches Unit weich hast deactivated CP and activated all FEC
downtime
C?ID=280813
^ you can some. For example bluetooth is possible as same FeC is for both MIB1 and MIB2. But other features like app connect not possible.
And app connect you cannot activate even you would buy the official license. Reason is that your car did not have a suitable MIB unit from factory which in turn causes that when you try to enable the FeC for it, the factory will deny it.
And given the fact that the license is one use only, you will lose it and the money you paid for it.
Only option is APG Poland or Vag navisystem like companies.
nirvananils
C?ID=289109
But in Europa Appconnect in MIB2 Jeans also Mirrorlink an AA AC, so you'll need it if you want to use These features
downtime
C?ID=280813
Yes exactly. BT itself will work without Appconnect license, it just needs the FeC restored through online connection. BUT Appconnect is not possible by any official means to retrofitted MIB units if the original unit did not have it.
m87a
C?ID=156900
This will just remove fender insignia, i was under impression that's was your problem, when you say stuck you mean device won't boot?
