Results 1 to 10 of 11
Thread: 2015 MK7 GTI MIB1 --> MIB2 Retrofit w/out hacked 5F
    Jun 2016
    My son and I installed a new MIBII brain unit (3Q0035876A) into his 2015 GTI S that came originally with MIBI (5G0035844) head unit and base audio. I also upgraded the screen to the 8" glass screen. When I first plugged the units in, there was component protection on the 5F which I had removed by a VW dealer. While the unit had CP everything worked (CarPlay, radio, Bluetooth, etc.) but with no sound. After CP was removed, I now have sound but the unit seems to be stuck in Fender "boot" screen. The tech at the dealer tried to set the coding back to my base coding but nothing seems to resolve this "stuck" screen. I've attempted to change the 5F coding to '16 Golf R w/ MIBII and the color of the unit change to blue but it is still stuck at the boot screen. If anyone could provide a solution or some guidance to hopefully get the unit out of the boot screen and fully functioning I'd greatly appreciate it!
    Autoscan from before installing MIBII
    Saturday,22,July,2017,21:27:01:23899
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
    VCDS Version: 17.1.3.0  HEX-NET CB: 0.4341.4
    VIN: 3VW4T7AU6FM063979   License Plate: DEVIN 07/22/17
    Mileage: 37158km-23088mi   Repair Order:
    Chassis Type: AU (5Q0)
    Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F 75 A9
    VIN: 3VW4T7AU6FM063979   Mileage: 37158km-23088miles
    A9-Struct. Borne Sound -- Status: Malfunction 0010
    Address 01: Engine (J623-CXCA)       Labels: 06K-907-425-V1.clb
       Component: 2.0l R4 TFSI  H13 0006
       Revision: --H13---
       Coding: 091D00124424002F0000
       Shop #: WSC 00066 790 00218
       ASAM Dataset: EV_ECM20TFS0205G0906259A 001008
       ROD: EV_ECM20TFS0205G0906259A.rod
       VCID: 2C14CC8547566C2165-8078
    17178 - Databus
    14833 - Internal Control Module
              P0606 00 [032] - Processor Fault
                        Mileage: 37140 km
                        Date: 2017.07.22
                        Time: 11:06:38
                        Coolant temperature: 83 °C
                        Intake air temperature: 70 °C
                        Voltage terminal 30: 12.285 V
                        Engine: operating status: ES
                        STATE_LS_SAE[1]: INI
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 89 kPa
                        Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                        FAC_TPS_1_SAE: 15.625000 %
                        FUP_H_SAE: 7090.0 kPa
    15122 - Manifold / Barometric Pressure Sensor (G71) / (F96)
              P0106 00 [168] - Implausible Signal
                        Mileage: 36352 km
                        Date: 2017.07.01
                        Time: 12:39:44
                        Coolant temperature: 108 °C
                        Intake air temperature: 59 °C
                        Voltage terminal 30: 12.714 V
                        STATE_LS_SAE[1]: OL_INTR
                        T_AST_SAE: 205 s
                        MAP_MES_SAE: 86 kPa
                        Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.943 V
                        FUP_H_SAE: 4160.0 kPa
       Part No SW: 0D9 300 041 T    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H53 4511
       Revision: 03253104    Serial number: TFK01410212182
       ROD: EV_TCMDQ250021.rod
       VCID: 291A359148A479099E-807C
              P1734 00 [002] - -
       Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
       Component: ESC           H32 0385
       Revision: 00000000    Serial number: 53194000000637
       Coding: 01FA6BA13426096F0080020781CC2980D62C9000408194B400430050C009
       Shop #: WSC 01383 790 50316
       VCID: 47DE9329FEF0AF7968-8012
    16401 - Tire Pressure Warning
              C102D 00 [008] -  -
                        Reset counter: 212
                        Mileage: 33393 km
                        Date: 2017.05.27
                        Time: 13:44:26
    Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
       Part No SW: 5GM 907 426 A    HW: 5GM 907 426 A
       Revision: 00001K01
       Coding: 00020004200100000000000000000000
       ROD: EV_ACManueBHBVW37X_SK48.rod
       VCID: 46C09E2DF9FAB67193-8012
       Part No SW: 5Q0 937 087 R    HW: 5Q0 937 087 R
       Component: BCM PQ37BOSCH 028 0145
       Revision: --------    Serial number: 86582511140186
       Coding: 000018464041804969E44000001407201000000000000000000000000000
       Shop #: WSC 00066 790 00226
       ROD: EV_BCMBOSCH_014.rod
       VCID: 4AD8AA1DEDE2521177-801E
       Component: WWS    141129  043 0581
       Serial number:         150106194713
    329480 - Heated Passenger Seat
              B1806 F0 [008] - Safety Shut-Off due to Occupant Detection
                        Fault Frequency: 35
                        Reset counter: 45
                        Mileage: 28765 km
                        Date: 2016.12.06
                        Time: 09:58:04
       Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
       Serial number: 003MHM01HKCS
       VCID: 51EABD7100B461C936-8004
       Occupant Detection:
       Component: BF-Gewichtss.  H10 0021
       Serial number: IBH0000J1400021L5Y04
       Coding: 30305A
       Subsystem 2 - Part No SW: -----------    HW: 480 001 811 14
       Serial number: 35700000000539AC811L
       Subsystem 3 - Part No SW: -----------    HW: 480 001 911 14
       Serial number: 35800000000D0D6D221N
       Subsystem 4 - Part No SW: -----------    HW: 480 402 310 14
       Serial number: 3510002AB1811BA1338-
       Subsystem 5 - Part No SW: -----------    HW: 480 402 310 14
       Serial number: 3520002AB1811BA4A2E9
       Subsystem 6 - Part No SW: -----------    HW: 480 402 909 14
       Serial number: 3550002A9175A922B195
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 402 909 14
       Serial number: 3560002A3175A923228Z
    Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
       Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
       Revision: FF032032    Serial number: 20141118500238
       Coding: 0410
       Shop #: WSC 66564 385 16448
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 3FCE8BC9A620E7B9D0-806A
       Part No SW: 5G1 920 856     HW: 5G1 920 856
       Component: KOMBI         342 4270
       Coding: 0BBD090A2180CF0502086A001000000000000000
       VCID: 6B960F9982D8AB192C-803E
       Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 L
       Component: GW MQB Mid    211 2203
       Revision: --------    Serial number: 20111410000231
       Coding: 0101000820085900EF0000281C0F00000001050000000000000000000000
       Shop #: WSC 00066 790 07026
       ROD: EV_GatewConti_011.rod
       VCID: 71AA1DF1A0F441C916-8024
       Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H10 0101
       Serial number: 29140002591740084484
       Coding: 29FFFF
    65793 - Powertrain Databus (VAG Wingle-Wire Mode) (SAE  L Shorted H)
              U0009 00 [008] - -
                        Reset counter: 44
                        Mileage: 36832 km
                        Date: 2017.07.02
                        Time: 21:15:49
                        Supply voltage: Terminal 30: 13.7 V
                        Terminal 15: On
       Serial number: 111214060506T2
       Coding: 001F03205000040000000000
       VCID: 40CC8835DBDE9841A9-8014
       Serial number: 00000000000000331545
       Coding: 011000
       Coding: 8102
       ROD: EV_SteerAssisMQB_VW31.rod
       VCID: 373EE3E98E10DFF918-8062
       Serial number: 111214060505IR
       Serial number: 00000000000000362502
       Coding: 091000
    Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD1.clb
       Part No SW: 5G0 035 844     HW: 5G0 035 844
       Component: MU-S-S-US     014 0645
       Serial number: V7B02711140054
       Coding: 02730000FF00000021220001001800001F0203040100010002
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 648464A56F06E4616D-8030
       Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
       Component: ABT_Std_Plus  H60 0030
       Serial number: VWZ8Z9PS500ZD6
              B11CF 53 [009] - Deactivated
                        Reset counter: 21
                        Mileage: 28503 km
                        Date: 2016.11.30
                        Time: 15:16:32
                        Voltage terminal 30: 14.1 V
                        Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                        Satellite radio tuner status-Channel selection for satellite radio: 0
                        Satellite radio tuner status-Audio Signal: Not available
                        Satellite radio tuner status-Antenna current: 0 mA
                        Satellite radio tuner status-Reception quality: Not available
                        Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
    Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
       Component: OCULowMQBUS   007 0564
       Coding: 02730002C2821A017F1E06000000
       Shop #: WSC 00066 790 07177
       ROD: EV_OCULowMQB.rod
       VCID: 43C68739CAC88359B4-8016
       Part No SW: 5G0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0014
       Serial number: 141011200824
    0006 - Actuator for Structural Accoustics
              P193A 00 [008] - Open Circuit
                        Fault Frequency: 65
                        Mileage: 28503 km
                        Date: 2016.11.30
                        Time: 15:16:31
    End----------(Elapsed Time: 01:23, VBatt start/end: 12.4V/12.4V)-----------
    Autoscan from after MIBII was installed
    Tuesday,31,December,2019,10:40:34:23899
    VIN: 3VW4T7AU6FM063979   License Plate: DEVINSGTI
    Mileage: 59528km-36988mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    VIN: 3VW4T7AU6FM063979   Mileage: 59528km-36988miles
    Address 01: Engine (J623-CXCA)       Labels:. 06K-907-425-V1.clb
       Revision: --H13---
       VCID: 2C14CC8547566C2F2B-8078
    17169 - Check Coding of ECUs on Powertrain Data Bus
              P1647 00 [175] - -
                        Fault Frequency: 12
                        Mileage: 59506 km
                        Date: 2019.12.30
                        Time: 10:33:03
                        Engine speed: 696.75 /min
                        Normed load value: 8.2 %
                        Coolant temperature: 77 °C
                        Intake air temperature: 41 °C
                        Voltage terminal 30: 14.277 V
                        ACC variants (coding): CCS
                        CCS Switch: CCS operating unit
                        Cruise control switch actuation-Main switch: not activated
                        Cruise control switch actuation-Setting: not activated
                        Cruise control switch actuation-Activation: not activated
                        Cruise control switch actuation-Status: OK
                        Cruise control switch actuation-Accelerate: not activated
                        Cruise control switch actuation-Decelerate: not activated
                        Cruise control switch actuation-Cancel: not activated
                        Cruise control switch actuation-Main switch hardware: not activated
                        Cruise control switch actuation-Coding: plausible
                        Cruise control switch actuation-Limit function: not selected
                        Cruise control switch actuation-Limit button: not activated
                        Cruise control switch actuation-Main switch CAN: not activated
                        Cruise control switch actuation-Large increment: not activated
                        Cruise control switch actuation-Control component verified: Yes
                        ACC variants: ACC
                        Engine: operating status: IS
    Readiness: 1010 0001
       Component: DQ250-6F MQB  H54 4511
       Revision: 06454104    Serial number: TFK01806210302
       Shop #: WSC 04742 780 00200
       VCID: 291A359148A47907D0-807C
       VCID: 47DE9329FEF0AF7726-8012
       Revision: 00001K01
       ROD: EV_ACManueBHBVW37X_003.rod
       VCID: 46C09E2DF9FAB67FDD-8012
       VCID: 4AD8AA1DEDE2521F39-801E
    17674 - Bulb for Front Left Side Marker Lamp
              B12BA 15 [009] - Open or Short to Plus
                        Reset counter: 94
                        Mileage: 59508 km
                        Date: 2019.12.30
                        Time: 11:52:22
    17930 - Bulb for Front Right Side Marker Lamp
              B12BB 15 [009] - Open or Short to Plus
                        Reset counter: 94
                        Mileage: 59508 km
                        Date: 2019.12.30
                        Time: 11:52:22
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 51EABD7100B461C778-8004
       Occupant Detection:
       Coding: 30305A
       Coding: 0410
       VCID: 3FCE8BC9A620E7B79E-806A
       VCID: 6B960F9982D8AB1762-803E
    16777022 - Function Restricted due to Interrupted Communications
              U1110 00 [009] - -
              [BAP_NAV SD_0x32 keine Kommunikation]
                        Reset counter: 94
                        Mileage: 59506 km
                        Date: 2019.12.30
                        Time: 10:33:06
       VCID: 71AA1DF1A0F441C758-8024
       Coding: 29FFFF
       VCID: 40CC8835DBDE984FE7-8014
       Coding: 011000
       Coding: 8102
       VCID: 373EE3E98E10DFF756-8062
       Coding: 091000
       Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
       Component: MU-S-NS-US    851 0867
       Shop #: WSC 05139 004 104857
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 3326D7F99A6833D76A-8066
       Subsystem 1 - Part No SW: 5G6 919 605 C    HW: 5G6 919 605 C
       Component: ABT_Std-2  H50 8130
       Serial number: VWZ6ZJV0041227
    1598 - Data Set Implausible
              B2012 00 [008] - -
              [Control module (data record download) - implausible data record for visible MMI system languages]
                        Reset counter: 134
                        Mileage: 59506 km
                        Date: 2019.12.30
                        Time: 11:18:57
                        Voltage terminal 30: 14.2 V
    1543 - Control Module Incorrectly Coded
              U1014 00 [009] - -
                        Reset counter: 94
                        Mileage: 59506 km
                        Date: 2019.12.30
                        Time: 10:33:03
                        Voltage terminal 30: 14.3 V
                        Byte_Coding_Condition-byte_0_condition: OK
                        Byte_Coding_Condition-byte_1_condition: OK
                        Byte_Coding_Condition-byte_10_condition: ERROR
                        Byte_Coding_Condition-byte_11_condition: ERROR
                        Byte_Coding_Condition-byte_12_condition: ERROR
                        Byte_Coding_Condition-byte_13_condition: ERROR
                        Byte_Coding_Condition-byte_14_condition: ERROR
                        Byte_Coding_Condition-byte_15_condition: ERROR
                        Byte_Coding_Condition-byte_16_condition: ERROR
                        Byte_Coding_Condition-byte_17_condition: ERROR
                        Byte_Coding_Condition-byte_18_condition: ERROR
                        Byte_Coding_Condition-byte_19_condition: ERROR
                        Byte_Coding_Condition-byte_2_condition: OK
                        Byte_Coding_Condition-byte_20_condition: ERROR
                        Byte_Coding_Condition-byte_21_condition: ERROR
                        Byte_Coding_Condition-byte_22_condition: ERROR
                        Byte_Coding_Condition-byte_23_condition: ERROR
                        Byte_Coding_Condition-byte_24_condition: ERROR
                        Byte_Coding_Condition-byte_25_condition: ERROR
                        Byte_Coding_Condition-byte_26_condition: ERROR
                        Byte_Coding_Condition-byte_27_condition: ERROR
                        Byte_Coding_Condition-byte_3_condition: OK
                        Byte_Coding_Condition-byte_4_condition: OK
                        Byte_Coding_Condition-byte_5_condition: OK
                        Byte_Coding_Condition-byte_6_condition: OK
                        Byte_Coding_Condition-byte_7_condition: OK
                        Byte_Coding_Condition-byte_8_condition: ERROR
                        Byte_Coding_Condition-byte_9_condition: OK
    6698 - Optical data bus
              U1049 00 [009] - Open circuit
              [Optical data bus: open circuit: wakeup]
                        Reset counter: 94
                        Mileage: 59528 km
                        Date: 2019.12.31
                        Time: 10:11:47
                        Voltage terminal 30: 11.9 V
    7178 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Park assist OPS (0x0A) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 94
                        Mileage: 59506 km
                        Date: 2019.12.30
                        Time: 10:33:06
                        BAP-BAP_Function_ID: 02
    7191 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Driving mode selection (0x17) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 94
                        Mileage: 59506 km
                        Date: 2019.12.30
                        Time: 10:33:06
                        BAP-BAP_Function_ID: 10
    7195 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 94
                        Mileage: 59506 km
                        Date: 2019.12.30
                        Time: 10:33:06
       VCID: 43C68739CAC88357FA-8016
    End----(Elapsed Time: 01:16, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
    Mar 2015
    Australia
    You'll need more than the correct coding to get it working.
    There are licenses (Feature Enable Codes) that control the availability of features like navigation, App connect (Carplay, Android Auto) etc that are tied to the VIN of the vehicle that the MIB unit came from.
    You cannot restore a license to a car that didn't have that feature from factory.
    So for example your MIB1 did not have App connect, so you need to either purchase this as a FEC activation code (and then have the dealer apply it) or use some other more 'creative' methods to address it.
    Did your dealer also remove CP from your amp, gateway, radar, cluster, BCM etc? Did they restore available FEC to the newly installed MIB, gateway, radar etc?
    These sort of things a bit of a grey area. There are folks on here who can point you in the right direction if you ask politely, but that's not what this forum is for.
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|Full colour MFD|Quad LED tail rings| Climatronics upgrade| Dynaudio retrofit | B7 RLine Flat Steering Wheel|3AA CCM|B7 Adaptive Cruise with Front Assist|TPMS Direct|Discover Media retrofit|PLA 2.0|Lane Assist|BCM Retrofit|HBA/FLA
  3. Likes downtime, Uwe liked this post
    Jan 2015
    Bosnia and Herzegovina
    for boot screen change
    adaptation -> (8)-Startup_Screen_Sticker_HMI-Fender
    set deactived
    There are 3 kind of services
    GOOD CHEAP FAST
    But you can only choose 2:
    GOOD and CHEAP won't be FAST
    FAST and GOOD won't be CHEAP
    CHEAP and FAST won't be GOOD
    Jun 2016
    Quote Originally Posted by kamold View Post
    The MIBII unit was brand new, does it still need FEC's? Initially after install, App Connect and other features worked just with no sound but now I cant seem to get into the radio at all. Shouldn't basic features such as radio, Bluetooth, etc. still work if they were available on the MIBI? I am open to paying for FEC's for features like App Connect, but want to make sure I will be able to use the head unit before making that purchase. The VW tech told me that all CP was removed. Trying to do this retrofit as legitimately as possible.
    Jun 2016
    m87a will this adaptation allow me to get past the Fender boot screen or just remove the Fender insignia from the start up screen?
    Mar 2015
    Australia
    After CP is removed, only the radio will work. FEC need to be restored for other features including bluetooth.
    Feb 2018
    But You can't restore FEC from MIB1 tot MIB2, you'll need a Patches Unit weich hast deactivated CP and activated all FEC
  9. Likes downtime, PetrolDave liked this post
  10. #8
    May 2017
    ^ you can some. For example bluetooth is possible as same FeC is for both MIB1 and MIB2. But other features like app connect not possible.
    And app connect you cannot activate even you would buy the official license. Reason is that your car did not have a suitable MIB unit from factory which in turn causes that when you try to enable the FeC for it, the factory will deny it.
    And given the fact that the license is one use only, you will lose it and the money you paid for it.
    Only option is APG Poland or Vag navisystem like companies.
  11. #9
    Feb 2018
    But in Europa Appconnect in MIB2 Jeans also Mirrorlink an AA AC, so you'll need it if you want to use These features
    VW: VCDS HEX-NET | VCP Inkl. VIM Addon | VAGTacho | RNS Manager | Setconfig
    Porsche: Durametric
    Ford: UCDS | F-Com (ex Fo-Com)
    Opel: AutoScannerCAN Opel Pro | OP-COM
    Fiat: MultiECUScan
    Renault/Dacia: DDT4all
    BMW Motorrad: MotoScan
    Launch X431 Pro3
  12. Likes downtime liked this post
  13. #10
    May 2017
    Quote Originally Posted by nirvananils View Post
    Yes exactly. BT itself will work without Appconnect license, it just needs the FeC restored through online connection. BUT Appconnect is not possible by any official means to retrofitted MIB units if the original unit did not have it.
