Results 1 to 6 of 6
Thread: Scirocco Cluster Speed Units
    Jun 2014
    Newcastle, England
    My nephew has asked if it is possible to change the digital speed in the centre of the instrument cluster to MPH - rather than km/h. I have had a look at coding from the LCH and it is set for Great Britain. I've also searched through the Adaptations; but can't find anything of relevence.
    The offending value is circled below; but as you'll see, it's a UK cluster, with MPH on the main speedo, the odometer is in miles and the set-speed for the CCS is also in miles. Scratching my head...
    Many Thanks.
    Sunday,27,October,2019,12:10:02:19335
    VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4513.4
    VIN: WVWZZZ13ZFV000000   License Plate:
    Mileage: 30240km-18790mi   Repair Order: George
    Chassis Type: 13-VW36 (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 52 56 61 B9
    VIN: WVWZZZ13ZFV000000   Mileage: 30240km-18790miles
    B9-Aux. Display -- Status: OK 0000
    Address 01: Engine (J623-CZCA)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 027 AF    HW: 04E 907 309 AE
       Component: 1.4l R4 TSI   H21 8079
       Revision: R9H21---
       Coding: 00190032230401080000
       Shop #: WSC 00020 999 00000
       ASAM Dataset: EV_ECM14TFS01104E906027AF 001005
       ROD: EV_ECM14TFS01104E906027AF.rod
       VCID: 689C780793385C0F0F-803C
       Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
       Revision: 00H46001
       Coding: 763B40F5492300FD6E0B02ED921A0090A1000051
       Shop #: WSC 00020 790 00000
       VCID: 04444CB78750986F83-8050
       Part No SW: 1K8 907 044     HW: 1K8 907 044
       Component: Climatronic   H05 0102
       Revision: 00001K02
       Coding: 001000C003
       VCID: 6C94041787C0702F6B-8038
    9481988 - Air Quality Sensor
              B10AF 04 [009] - Internal System Fault
                        Reset counter: 158
                        Mileage: 30021 km
                        Date: 2019.10.21
                        Time: 14:24:53
       Part No SW: 5K0 937 086 Q    HW: 5K0 937 086 Q
       Component: BCM PQ35 M    122 0174
       Revision: BC122001
       Coding: 48180A3C8825E100408800C0340001640BD10008436D0920648087000041
       VCID: 42C88AAFDDC4565FF1-8016
       Subsystem 1 - Part No SW: 1K8 955 119 J    HW: 1K8 955 119 J  Labels: 1KX-955-119.CLB
       Component: WiS364r 16071  24  0654
       Coding: 044D9D
       Component: RLS 141014 05  54  0403
       Coding: 0230ED
       Subsystem 3 - Part No: 5C0 951 171
       Component: Sensor, DWA 0  005 0402
    00897 - Windshield Washer Pump (V5)
                        Fault Status: 00101100
                        Reset counter: 189
                        Mileage: 29807 km
                        Date: 2019.10.21
                        Time: 11:17:51
                        Voltage: 15.00 V
                        Fault Status: 00101011
                        Reset counter: 189
                        Mileage: 29807 km
                        Date: 2019.10.21
                        Time: 11:17:51
                        Voltage: 15.00 V
       Part No SW: 1K8 919 472 A    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0477
       Revision: --------    Serial number: 39331429400300
       Coding: 0001090001
       ASAM Dataset: EV_EPHVA18VW364GP00 001006
       VCID: 3522E173940AF1E744-8060
       Part No SW: 1K0 909 605 AE    HW: 1K0 909 605 AE
       Component: 0H AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 003D1D06MUTV
       Coding: 0012360
       VCID: 6FAE131B7ED68B374E-803A
       Subsystem 1 - Serial number: 6332MSME490B025CE
       Subsystem 2 - Serial number: 6342MSME486E2A38R
       Subsystem 3 - Serial number: 6352QSME48460A54I
       Subsystem 4 - Serial number: 6362QSME12480278A
       Part No SW: 5K0 953 521 DP    HW: 5K0 953 569 AG
       Revision: FF010042    Serial number: 20141020100141
       Coding: 1082040000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 7DB23953ECBAE9A7CC-8028
       Subsystem 1 - Part No SW: 1K8 959 442     HW: 1K8 959 442
       Component: E221__MFL-DC1  H03 0103
       Coding: A4FFFF
       Part No SW: 1K8 920 975 C    HW: 1K8 920 975 C
       Component: KOMBI         H05 0925
       Coding: 470B01
       VCID: 373EEB7B8E0603F756-8062
       Part No SW: 7N0 907 530 AQ    HW: 7N0 907 530 AL
       Component: J533  Gateway H58 1653
       Revision:   H58       Serial number: 251014F1000497
       Coding: 354001
       VCID: 7F4EC35BEEB6FBB7DE-802A
       Component: IMMO          H05 0925
       VCID: 6A98020F8D346E1F19-803E
       Revision: A1001003    Serial number: 7666769647
       Coding: 020100
       VCID: 2B16C70B4A4EB71722-807E
       Part No SW: 1Q0 035 279 K    HW: 1Q0 035 279 K
       Component: RNS315-EU   H85 0501
       Serial number: VWZAZ2P0533616
       Coding: 040004010400040000009002
       ROD: EV_RNS315EUV2UDS.rod
       Component: EUR_W_V7  0066
       Part No SW: 1Q0 959 701 H    HW: 1Q0 959 701 H
       Component: Tuer-SG         009 2162
       Coding: 0152119
       VCID: 393AED4370121587A0-806C
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 68     3501
       Revision: 00H22000
       Part No SW: 1Q0 959 702 H    HW: 1Q0 959 702 H
       Coding: 0152374
       VCID: 3A38F24F75141E9FA9-806E
       Part No SW: 7N0 907 534     HW: 7N0 907 530 AL
       Component: Batt.regelung H58 1653
       Coding: 032F7857
       VCID: 71AA1563A8E29DC758-8024
       Component: J367-BDM  H07 0180
       Serial number: 31290J09191491958571
    Address B9: Aux. Display (J285)       Labels:* 5C5-919-527.clb
       Part No SW: 1K8 919 527     HW: 1K8 919 527
       Component: ZUSATZANZEIGE H08 0003
       Coding: 05
       ASAM Dataset: EV_Auxi_Disp_Unit_UDS_VDD 001010
       ROD: EV_Auxi_Disp_Unit_UDS_VDD.rod
       VCID: 75A22173D48AB1E784-8020
    End----(Elapsed Time: 01:13, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
    Adaptation Map:
    ;SW:1K8-920-975-C   HW:1K8-920-975-C ---  Instruments
    ;Component:KOMBI         H05 0925, Coding:470B01
    ;EV_Kombi_UDS_VDD_RM09,A04727,EV_Kombi_UDS_VDD_RM09_004_VW32.rod
    ;Sunday,27,October,2019,12:14:03:19335
    ;VCDS Version: Release 19.6.2 (x64)  Data version: 20190930 DS308.0
    ;VCID: 373EEB7B8E0603F756-8062
    IDE00301-Distance,30240 km,2
    IDE00342-ESI: Resetting ESI,Reset ,1
    IDE00343-Language version,English ,1
    IDE00344-Seat belt warning,Version 4 ,1
    IDE00492-MAS00900-ESI: Coding of Service Interval Extension (SIE)-Oil level,Oil level evaluation ,1
    IDE00492-MAS02003-ESI: Coding of Service Interval Extension (SIE)-Status ESI or SID,ESI or SID on ,1
    IDE00492-MAS02006-ESI: Coding of Service Interval Extension (SIE)-Selection of ESI or SID,Extended Service Intervals (ESI) ,1
    IDE00492-MAS02010-ESI: Coding of Service Interval Extension (SIE)-Oil pressure,dynamic oil pressure ,1
    IDE00492-MAS02011-ESI: Coding of Service Interval Extension (SIE)-Remote clock receiver,without remote clock receiver ,1
    IDE00492-MAS02012-ESI: Coding of Service Interval Extension (SIE)-Oil quality,poor oil quality ,1
    IDE00492-MAS02013-ESI: Coding of Service Interval Extension (SIE)-TOG,Oil level thermal sensor connected to instrument cluster ,1
    IDE00493-Display correction of fuel gauge,0.0 ,1
    IDE00499-Display correction of consumptions and operating range,100 %,1
    IDE00500-Hour,12 H,1
    IDE00501-Minute,14 min,1
    IDE00505-Speed threshold of dynamic oil pressure warning,kein Offset ,1
    IDE00510-ESI: distance driven from inspection,13500 km,2
    IDE00511-ESI: time from inspection,309 d,2
    IDE00515-ESI: oil quality,poor oil quality ,1
    IDE00517-ESI: soot entry,0 km,2
    IDE00518-ESI: thermal load,19500 km,2
    IDE00714-MAS00888-Additional coding-Tank characteristic curve,1 ,1
    IDE00714-MAS01209-Additional coding-Speed source,via CAN ,1
    IDE00714-MAS01210-Additional coding-Coolant temperature source,via CAN ,1
    IDE00714-MAS01211-Additional coding-Locking bit,locked ,1
    IDE00714-MAS04066-Additional coding-Number of fuel level sensors,1 ,1
    IDE01153-SIA: maximum value of distance to service,15000 km,2
    IDE01154-SIA: maximum value of time to service,372 d,2
    IDE02327-Indicator light for start-stop operation,active ,1
    IDE02489-Display depiction,Not available ,1
    IDE02494-Automatic door locking,Yes ,1
    IDE03346-IDE00301-Units adjusted-Distance,miles ,2
    IDE03346-IDE00316-Units adjusted-Time,24h ,2
    IDE03346-MAS01230-Units adjusted-Date,dd_mm_yy ,2
    IDE03346-MAS01456-Units adjusted-Speed,Miles per hour ,2
    IDE03346-MAS02201-Units adjusted-Temperature,°C ,2
    IDE03346-MAS03032-Units adjusted-Volume,gallons (UK) ,2
    IDE03346-MAS03033-Units adjusted-Consumption,Miles per gallon (UK) ,2
    IDE03346-MAS03034-Units adjusted-Pressure,bar ,2
    IDE03349-FIX: Max. distance until next mileage-related inspection,32200 km,2
    IDE03350-FIX: Maximum time until next time-dependent inspection,365 d,2
    IDE03351-FIX: Distance covered since last mileage-dependent inspection,13600 km,2
    IDE03352-FIX: Time since last time-dependent inspection,309 d,2
    IDE03481-MAS01632-Emergency telephone number-Status,not active ,25
    IDE03481-MAS04225-Emergency telephone number-Preselection,000000000000000000000000 ,25
    IDE03481-MAS04226-Emergency telephone number-Telephone number,000000000000000000000000 ,25
    IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time,10 s,5
    IDE03568-ENG102019-Service-key settings-p_main_switch_basis,On ,5
    IDE03568-ENG102414-Service-key settings-p_main_switch_keyless,On ,5
    IDE03568-ENG102611-Service-key settings-p_write_delay_speed,20 km/h,5
    IDE03568-ENG103545-Service-key settings-p_write_delay_time,40 s,5
    IDE03568-ENG104099-Service-key settings-p_write_distance,20 km,5
    IDE04848-Volume to be replenished,No ,1
    IDE05583-Pause recommendation,Yes ,1
    IDE05930-Service notification in days,30 d,1
    IDE05931-FIX: Reset value for next mileage-dependent inspection,32200 km,2
    IDE05932-FIX: Reset value for next time-dependent inspections,365 d,2
    IDE10059-MAS00844-Component protection mode-Radio,not requested ,1
    IDE10059-MAS01799-Component protection mode-Navigation,not requested ,1
    IDE10059-MAS05506-Component protection mode-Stopping distance reduction,not requested ,1
    IDE10059-ENG114193-Component protection mode-Vorhalt,not requested ,1
    IDE11086-Service notification,30 d,1
    ENG112420-MAS03095-additional_adaption-Function status,No ,3
    ENG112420-MAS03118-additional_adaption-Logic address,0 ,3
    ENG112417-indicator_celebration,active ,1
    ENG108924-Service_Key_Clear_All_Counters,Yes ,1
    ENG109658-Twindrive,not active ,1
    ENG112416-IDE01766-velocity_detection-Distance impulses,4 ,1
    ENG112416-MAS01209-velocity_detection-Speed source,Distance impulses ,1
    Elapsed Time: 00:25
    Tartu, Estonia
    I believe You need to code it to row or was it europe. Then the digital speedo comes bigger and shows native speed.
    There is something with GB coding that doesn't allow big digital speedo. And alternative speed needs to be disabled also.
    The world is my oyster...
  3. Likes Zenerdiode liked this post
    Jun 2014
    Newcastle, England
    Oh, okay. I'll try that the next time I see him - within the next few days. Thanks Magnus.
    Feb 2018
    @golfi_vend Your solution won't work. European Cars also shows mp/h as second value. Our Passat B7 (German car) is showing mp/h but its factory coded. You can edit eeprom to change this
    Jun 2019
    Leicester, UK
    Are all of the units metric (i.e. l/100km)?
    I know I change the display on my C6 through the MMI to display metric or imperial (miles/gallons) to give me the Km/h display in the instruments when I go abroad. I realise the Scirocco is a totally different system but i would be surprised if it wasn't available in a similar way.
    Tartu, Estonia
    Quote Originally Posted by nirvananils View Post
    Yes, it shows mph as small screen when You select Alternative Speed option. Normal view is still kmh in big screen.
    UK cars don't have that big screen.
