- Joined
- Dec 30, 2019
- Messages
- 10
- Reaction score
- 1
- Location
- Welwyn Garden City, UK
- VCDS Serial number
- C?ID=385516
Hello all! New VCDS user here battling with some electrical gremlins on my Audi.
I have a recurring issue with the car in that most of the time when I start it, the dials and MMI illumination turn off for a few seconds, then come back on as normal but with the time and date on the dash cluster reset to 0:00 and Feb 2003.
This usually coincides with at least one other fault occurring - most commonly a fault for implausible signal from the MAP sensor which puts the car into limp mode, but sometimes one of the following:
- ESP not functioning
- indicators not functioning
- ABS not functioning
All of the above are clearable with VCDS after starting the car (even the MAP sensor) and afterwards the car drives normally, but the next time I start it, I have to repeat the process and clear codes to avoid the car going into limp mode.
The car has a new battery which has been coded in, and was having problems before and after the new battery was fitted/coded - I thought this might solve the problem but it didn't. I've also replaced the battery management module in an effort to cure these issues but it has made no difference. Likewise disconnecting the battery for an hour or more clears some of the codes but the dash cluster fault codes remain and refuse to be cleared.
Here's the VCDS log:
I'm hoping that the cluster itself is not dead as I understand that these clusters have component protection on them and are therefore challenging to swap with a replacement part from a breaker. If anyone can offer any suggestions as to what might be causing my issues it would be very much appreciated!
Many thanks
Justin
Thursday,26,December,2019,21:53:33:04536
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WAUZZZ4E24N007142 License Plate:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 18 19 1E 25 34 36 37
38 42 46 47 4F 52 53 55 56 57 61 62 72 76
VIN: WAUZZZ4E24N007142 Mileage: 157280km-97729miles
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
Part No SW: 4E0 910 409 C HW: 4E0 907 409 B
Component: 4.0L 4V/TDI G000AGMª0020
Revision: <> Serial number: AUX3Z0C6120358
Coding: 0010773
Shop #: WSC 02313 785 00200
VCID: 2313E8E3E7D4E39FF45-8076
18058 - Powertrain Data Bus
P1650 - 002 - Missing Message from Instrument Cluster - Intermittent
RPM: 630 /min
Torque: 128.7 Nm
Voltage: 13.53 V
Temperature: 38.7°C
Bin. Bits: 00000000
Readiness: 0 0 X X X
Part No SW: 4E0 910 156 J HW: 09E 927 156 A
Component: AG6 09E 4,0LTDI RdW 0040
Revision: 00000001 Serial number: 0017213
Shop #: WSC 00183 210 58462
VCID: 290FFACB85F839CFBE9-807C
Part No SW: 4E0 910 517 A HW: 4E0 614 517 A
Component: ESP 5.7 allrad H29 0420
Coding: 0008557
Shop #: WSC 02313 000 00000
VCID: 211FE2EBFDC8F18FE69-8074
02257 - Remote Control Receiver
014 - Defective
Fault Status: 01101110
Reset counter: 203
Mileage: 157282 km
Date: 2003.02.27
Time: 01:42:37
Reset counter: 243
Mileage: 157282 km
Date: 2003.02.27
Time: 00:00:35
Bin. Bits: 01
Part No SW: 4E0 910 043 HW: 4E0 820 043
Component: KLIMAAUTOMAT 015 0240
Revision: 00000018 Serial number: 00000000020954
Coding: 1071105
Shop #: WSC 02311 785 00200
VCID: 5AED9507901E6257E73-800E
Address 09: Cent. Elect. Labels: 4E0-910-279.clb
Part No SW: 4E0 910 279 E HW: 4E0 907 279 E
Component: ILM Fahrer H11 0100
Coding: 0010001
VCID: 2A0D05C780FE32D7B73-807E
Subsystem 1 - Part No: 4E2 910 113
Component: Wischer WWS D3 H30 0320
Coding: 00000030
Shop #: WSC 02311
Address 11: Engine II Labels: Redir Fail!
Component: 4.0L 4V/TDI G000AGSª0020
Coding: 0010773
RPM: 630 /min
Torque: 128.7 Nm
Voltage: 13.53 V
Temperature: 38.7°C
Bin. Bits: 00000000
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655
Component: Airbag 8.4E+ H09 0940
Coding: 0431707
VCID: 6393A8E3A754A39FB45-8036
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H09 0030
Coding: 0112041
VCID: 6597B6FBA960DDAF5A1-8030
Component: Lenkradmodul H02 0050
02441 - Yellow Malfunction Lamp in Instrument Cluster
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 203
Date: 2003.02.27
Time: 01:42:59
Voltage: 10.56 V
Reset counter: 243
Mileage: 157288 km
Date: 2003.02.27
Time: 01:42:59
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 HW: 4E0 919 283 A
Component: Parkhilfe 8-Kan H07 0030
Coding: 0001008
VCID: 6099A7EFB642B887A97-8034
End----------(Elapsed Time: 01:59, VBatt start/end: 14.1V/14.3V)-----------
Many thanks
Justin
