Results 1 to 6 of 6
Thread: Soft coding for 2005 Allroad
    Dec 2019
    Hello everyone,
    Ive converted my 2005 Allroad air suspension to coils after being left stranded due to air suspension issues too many times. Blau has instructions on their coil conversion to change the soft code from xxxx5 to xxxx2 to get rid of the CEL after disconnecting the j197 module, but when i try this, the soft code does not change. Any pointers?
    Im still fairly new to vagcom, so if there is any information about the vehicle that may help, let me know and ill try to get it.
    Thanks!
    Quote Originally Posted by 808allroad View Post
    That would be a full unedited VCDS Auto-Scan - see my signature for a How-To.
  3. Likes 808allroad liked this post
    Hi and welcome.
    Soft coding in what module?
    Please post a complete Auto-Scan for context. My recollection is there's no way to get a C5 Allroad free of faults after removing the air suspension without swapping out some other modules as well, because those modules were specific to the Allroad and will forever be unhappy without data from the suspension module.
  5. Likes PetrolDave, 808allroad liked this post
  6. #4
    Dec 2019
    engine module, i'm following the instructions provided by Blau and their coil conversion kit.
    To recode the Audi Allroad ECU proceed as follows:
    Tools Needed - Ross Tech Diagnostic Software
    Plug Ross Tech PC into Audi Allroad OBD com-port.
    Cycle the ignition key to the accessory position.
    Access Ross Tech software from PC desktop.
    Select control module.
    (01-Engine) control module (Allow several seconds to pass and allow the Ross Tech to communicate with the engine control module).
    (07-Coding) engine recode module
    (Software Coding) change the last digit from 5 to 2 and save the software coding by clicking (DO IT!) (Allow several seconds to pass and allow the Ross Tech to communicate with the engine control module).
    Cycle the ignition key to the off position.
    If necessary remove all stored codes from control modules. Cycle the ignition key to the accessory position, re-access the vehicles control modules and remove all stored codes from the control modules. Cycle the ignition key to the off position when done.
    Unplug OBD com-port from vehicle.
    After all stored codes have been removed from the control modules start the vehicle to confirm there is no check engine light and leveling light.
    I'll post the auto-scan when i get home. And thank you btw for the quick replies!
    Dec 2019
              75 76 77
    VIN: WA1YD64B75N008073
    Address 01: Engine        Labels: 078-907-551-AZA.lbl
       Part No: 4Z7 907 551 T
       Component: 2.7L V6/5VT     G   0010
       Coding: 07755
       Shop #: WSC 02334
       VCID: 54F17CB7B7E50CD73DF-5160
       WA1YD64B75N008073     AUZ7Z0D2635649
    18005 - Powertrain Databus
                P1597 - 35-00 - Missing Message from Level Control System (J197)
    Readiness: 0000 1001
    Address 02: Auto Trans        Labels: 01V-927-156.lbl
       Part No: 4Z7 927 156 T
       Component: AG5 01V 2.7l5VT USA 0404
       Coding: 0001002
       Shop #: WSC 02334 785 00200
       VCID: 57EB8BBBA31327CFD8D-5160
    Address 03: ABS Brakes        Labels: 8D0-907-389.lbl
       Part No: 4Z7 907 389 A
       Component: ABS/ESP allrad      D66
       Coding: 06497
       Shop #: WSC 02334
       VCID: 4ACD62CF65A14A27573-5160
    01310 - Level Control System Control Module (J197)
                49-00 - No Communications
    Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
       Part No: 4B0 820 043 AQ
       Component: A6-Klimavollautomat 0208
       Coding: 00010
       Shop #: WSC 02335
       VCID: 698FBD430057A13F7E9-2586
    Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
       Part No: 4Z7 959 655 N
       Component: Airbag 8.4EP        1000
       Coding: 0000607
       VCID: 5AED928FD0013AA7E73-5184
    00532 - Supply Voltage B+
    Address 16: Steering wheel        Labels: 4B0-907-487.lbl
       Part No: 4B0 907 487 F
       Component: Lenkradelektronik   D01
       Coding: 01002
       Shop #: WSC 02334
       VCID: 2F3B135BFE330F0F60D-5184
    00926 - Terminal 30
    Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
       Part No: 4B0 920 983 F
       Component: KOMBI+WEGFAHRS. VDO D16
       Coding: 20264
       Shop #: WSC 08986
       VCID: 2B03074BCA1B732F4C5-5160
    Address 35: Centr. Locks        Labels:. 4B0-962-258.clb
       Part No: 4B0 962 258 M
       Component: Central Lock/Alarm  D38
       Coding: 15885
       Shop #: WSC 02334
       VCID: 33331F2B121B2BEF045-4EEA
    01561 - Rear left door
                59-00 - Can't Unlock
    01562 - Rear right door
    01573 - Alarm triggered by Door Contact Switch; Rear Left
                35-00 - -
       Part No: 4B0 959 760 B
       Component: Sitzmemory R1 F     0204
       Coding: 00001
       VCID: 2C010457CF25741745F-4B1E
       Part No: 4Z7 907 357
       Coding: 00030
       Shop #: WSC 02334
       VCID: 04518CF707355C57EDF-4B00
       Part No: 4B0 035 195 N
       Component: symphony II PM6    0410
       Coding: 02005
       Shop #: WSC 21248
       VCID: 2B03074BCA2B732F4C5-5066
    End----------(Elapsed Time: 05:03, VBatt start/end: 12.2V/12.2V)-----------
    Just trying to make my c5 allroad stop acting like a c5 allroad.
  8. Likes Uwe liked this post
  9. #6
    I'll note that the last digit of your ECU's coding isn't '5' to begin with.
    But I'll also note that your ECU, your TCU, your ABS, your Airbag module, and your headlight range controller all have part numbers that start with '4Z'. This indicates that they have Allroad-specific software in them and quite likely won't accept coding values that would be used on a regular A6 (with steel suspension) of the same vintage.
    You may want to talk to a tuner to see if they can install regular A6 software in some of these modules.
