Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: 2014 Tiguan Aftermarket NAV and Genuine RNS510 questions/problems
    Jan 2015
    Canada
    Hi all.
    I bought a 2014 Tiguan, Trendline with convenience package (Canada) and the dealer said they would install a NAV unit in place of the stock radio.
    The aftermarket NAV had some issues where it would not shut off with key and only go into "sleep" mode, thus putting strain on the battery.
    We had the unit replaced and had the same problem.
    I then had the dealer put a genuine RNS510 unit in the Tiguan and I Think I am having the same problem.
    I do not get the "Welcome to Volkswagen" screen when I turn the key forward... the RNS510 just powers up to the radio right away.
    I found this post about some older versions of the Gateways not being compatible and caused the Databus to stay active even with the Ignition turned OFF which resulted in excessive Battery Draw and failure. (makes reference to "older" units, any idea what year this problem stopped?)
    http://wiki.ross-tech.com/wiki/index...9_Retrofitting
    I am wondering if there is a way to hook up my vag com to the car without turning the ignition on and see if the RNS or gateway is in fact still active. I will let the car sit for 2 hours after parked to be sure?
    Here is some more background information....
    the RNS is currently not coded correctly, dealer said they will fix this.
    my scan of module 19 (I know the installer did not code the unit correctly, dealer is going to fix this)
    Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 AK HW: 7N0 907 530 AK
    Component: J533 Gateway H57 1642
    Revision: H57 Serial number: 250314F1001343
    Coding: 356002
    VCID: 79F9FDE5F06BFDE9285-802C
    here is a auto scan....
    Chassis Type: AX (7N0)
    Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 4C 52 53 56 62 72
    77
    VIN: WVGKV3AX9EW613189 Mileage: 12420km-7717miles
    37-Navigation -- Status: Not registered 0011
    Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
    Part No SW: 06J 997 027 N HW: 06J 907 309 A
    Component: MED17.5.2 TFSI 2 06 0397
    Revision: P3H07--- Serial number:
    Coding: 0423010A18070160
    Shop #: WSC 42378 001 1048576
    VCID: 408F500113316C212FB-8015
    P0300 - 000 - - Intermittent
    Mileage: 11748 km
    Date: 2015.01.04
    Time: 09:45:45
    RPM: 1080 /min
    Load: 34.1 %
    Temperature: -6.0°C
    Temperature: -3.0°C
    Absolute Pres.: 990.0 mbar
    Voltage: 14.351 V
    000770 - Cylinder 2
    P0302 - 000 - Misfire Detected - Intermittent
    Mileage: 11748 km
    Date: 2015.01.04
    Time: 09:45:46
    RPM: 1080 /min
    Load: 34.1 %
    Temperature: -6.0°C
    Temperature: -3.0°C
    Voltage: 14.351 V
    Address 03: ABS Brakes Labels: 5N0-614-109-C6.clb
    Part No SW: 5N0 614 109 BK HW: 5N0 614 109 BK
    Component: J104 C6 450M VD5C 0014
    Revision: --H07--- Serial number: 00000007882544
    Coding: 0005173
    VCID: 75E1F1D51C7399894CD-8020
    Address 08: Auto HVAC (J301) Labels: None
    Part No SW: 561 907 426 E HW: 561 907 426 E
    Component: AC Manuell H02 0303
    Revision: 00001K02
    Coding: 0010001002
    ASAM Dataset: EV_ACManuaElectGen2BHTC 001002
    ROD: EV_ACManuaElectGen2BHTC.rod
    VCID: 1D31C9750C0361C964D-8048
    Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
    Part No SW: 5K0 937 086 R HW: 5K0 937 086 R
    Component: BCM PQ35 M 122 0173
    Revision: BJ122001
    Coding: EF180A1B80232EC4008800C11000854448010086524D8D6064 8040000040
    VCID: 43855F0DC2277739329-8016
    Subsystem 1 - Part No: 5N1 955 119 A Labels: 1KX-955-119.CLB
    Component: WWS 200214 03 32 0010
    Coding: 009795
    Part No SW: 5N0 959 655 AD HW: 5N0 959 655 AD
    Component: J234__207 VW10 HI 2418
    Revision: 28019000 Serial number: 003N4PQ1GL6$
    Coding: 0012343
    VCID: 7F0D13FD2E4FD3D9161-802A
    Subsystem 1 - Part No: 5N0 959 339 B
    Subsystem 2 - Serial number: 0000000000HX2A
    Subsystem 3 - Serial number: 0020.01.140000300000660013˙†63
    Subsystem 4 - Serial number: 660013˙†6332MTS613530804.˙†63
    Subsystem 5 - Serial number: 30804.˙†6342MTS6147307845˙†63
    Subsystem 6 - Serial number: 307845˙†6351HTS64CCLPCKJ5˙†63
    Subsystem 7 - Serial number: LPCKJ5˙†6361HTS6L4JSQCKJU˙†63
    Subsystem 8 - Serial number: SQCKJU˙†63727TS6MIMINCKRZ˙†63
    Subsystem 9 - Serial number: INCKRZ˙†63827TS6KMFGPCKJN˙
    Subsystem 10 - Serial number: GPCKJN˙
    Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
    Part No SW: 5K0 953 501 DJ HW: 5K0 953 569 AP
    Component: LENKS.MODUL 016 0140
    Revision: FF010042 Serial number: 20140408101111
    Coding: 118A140000
    VCID: 75E1F1D5D47399894CD-8020
    Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
    Component: E221__MFL-TAS H31 0037
    Coding: 820000
    Part No SW: 5N0 920 873 B HW: 5N0 920 873 B
    Component: KOMBI H04 0811
    Coding: 311F01
    ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
    VCID: 326B0AC9659DCEB1A9F-8067
    Coding: 311F01
    Coding: 356002
    Component: IMMO H04 0811
    VCID: 6ADBD2A98DCD4671D1F-803F
    Address 2E: Media Player 3
    Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
    Part No SW: 3C0 035 684 K HW: 3C0 035 684 K
    Component: RNS-MID H12 4366
    Revision: AB001001 Serial number: VWZ6Z7M9302148
    Coding: 00000400000000000000
    VCID: 2B5517AD4AB79F79EA9-807E
    Subsystem 1 - Part No: 7L6 919 859
    Component: NAR V8 8112
    Reset counter: 92
    Mileage: 12424 km
    02633 - Antenna for Satellite Tuner
    Reset counter: 92
    Mileage: 12424 km
    Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
    Part No SW: 5N0 959 701 F HW: 3C0 959 793 B
    Component: TUER-SG FT 002 0503
    Revision: 13110009 Serial number: 0008338232
    Coding: 0004B4
    ROD: EV_TSGFPQ35BRFVW46X.rod
    VCID: 387F38E183E124E197B-806D
    Slave Driver:
    Subsystem 1 - Part No SW: 5N0 959 703 G HW: 3C0 959 794 D
    Component: J388__TSG-HL 009 1504
    Serial number: 00000008647415
    Coding: 000490
    Part No SW: 5N1 909 144 R HW: 5N1 909 148 J
    Component: J500__APA-BS KL.285 1401
    Revision: 1BH04841 Serial number: 00140910152601
    Coding: 0000258
    VCID: 41895505183B6529205-8014
    Address 4C: Tire Pressure II
    Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
    Part No SW: 5N0 959 702 F HW: 3C0 959 792 B
    Component: TUER-SG BT 002 0503
    Revision: 15110009 Serial number: 0008330864
    Coding: 0004B4
    ROD: EV_TSGBPQ35BRFVW46X.rod
    VCID: 39793DE5B8EB3DE9685-806C
    Slave Passenger:
    Subsystem 1 - Part No SW: 5N0 959 704 G HW: 3C0 959 795 D
    Component: J389__TSG-HR 009 1504
    Serial number: 00000008685026
    Coding: 000490
    Part No SW: 3AA 907 801 H HW: 3AA 907 801 H
    Component: J540 EPB4 VW-86594 0010
    Revision: H19 Serial number: 00000002120078
    Coding: 0026156
    VCID: 366336D941F5D291857-8063
    Address 56: Radio (J0506) Labels: 1T0-035-680.clb
    Reset counter: 92
    Mileage: 12424 km
    Reset counter: 92
    Mileage: 12424 km
    Address 77: Telephone (J412) Labels: None
    Part No SW: 5N0 035 729 A HW: 5N0 035 729 A
    Component: TELEFON H05 0592
    Revision: 1B001001 Serial number: 00007666047602
    Coding: 0A10030080010110
    ROD: EV_UHVUMI.rod
    VCID: 2E531EB971A5EA51CD7-807B
    9457664 - Function limitation due to excessive temperature
    B1050 00 [009] - -
    Reset counter: 92
    Mileage: 12427 km
    Date: 2015.01.17
    Time: 12:33:51
    I hope someone here can point me in the right direction to either fix this problem (via correct coding or enabling things in the control units) OR help me find a way to confirm the RNS510 is not turning off and staying in "sleep/standby" mode
    Interesting that your CAN Gateway shows "Status: Malfunction 0010" in the Installation List, but doesn't show fault codes (or even "No fault code found.") in the full scan. I'm reasonably confident it should show at least one fault code like "Incorrectly Coded". Let's fix that first:
    [Select]
    [19-CAN Gateway]
    [Installation List]
    Scroll down to 37-Navigation, put a check-mark in that box, then
    [Save Coding]
    [Fault Codes]
    [Clear Codes]
    As for the coding of the RNS510 itself, someone who's more familiar with them than I am will hopefully chime in here.
  3. Likes luxus panzer liked this post
    United States
    You cannot use VCDS to see if a CAN controller is directly causing a battery draw, you'd need to measure Amp draw -or- use the newer VW TSB which has you measure voltage across fuses with a DVOM, but you should correct that 19-CAN GW issue as Uwe suggested first.
    Next, I noticed this:
    That is on the infotainment bus but I didn't run the VIN to see if it was factory installed or a retrofit. Either way, if it isn't communicating I would look into that.
    You can use the LCH to code the new 37/56 unit but starting with all zeros can be tricky. Try pasting this into the new coding section with non zero WSC/Importer/Equipment numbers: 0400040204000084000C
    Lastly, anything Golf based that's newer than 2010 in the NAR market should have a factory installed CAN GW that wouldn't suffer from the draw issue. You have one of the latest 7N0 series units already and that is what someone with an older 2005-2008ish car would be upgrading to.
  5. Likes Uwe, luxus panzer liked this post
  6. #4
    Jan 2015
    Canada
    Could this be the factory installed "convenience package" (Canada)? The Kit inside the Armrest.
    Nothing non factory installed in this Tiguan other than the current RNS510
    Jan 2015
    Canada
    [Select]
    [19-CAN Gateway]
    [Installation List]
    [Save Coding]
    [Fault Codes]
    [Clear Codes]
    WilCo as soon as my wife gets home from work tomorrow evening and let you know soonest.
    thanks all
    United States
    Quote Originally Posted by luxus panzer View Post
    Could this be the factory installed "convenience package" (Canada) The Kit inside the Armrest.
    Yeah, My 2012 Tiggy Media In device is in the center console. See if that still works both with the Aux IN and an iDevice (or USB with music on a flash drive if your car came with cable that instead).
    Aug 2014
    I've done this on a 2013 NAR Tiguan (my mom's) and another. I didn't recall any issues after ticking the 37 nav box for the gateway.
  10. #8
    Jan 2015
    Canada
    Did this
    [Select]
    [19-CAN Gateway]
    [Installation List]
    [Save Coding]
    [Fault Codes]
    [Clear Codes]
    Here is a new scan....
    Thursday,22,January,2015,14:27:40:45743
    VCDS Version: 14.10.0.0
    Data version: 20141022
    VIN: WVGKV3AX9EW613189   License Plate:
    Mileage: 12720km-7903mi   Repair Order: jess tiguan post rns AND i checked off NAV in controler 19
              77
    VIN: WVGKV3AX9EW613189   Mileage: 12720km-7903miles
                        Mileage: 11748 km
                        Date: 2015.01.04
                        Time: 09:45:45
                        RPM: 1080 /min
                        Load: 34.1 %
                        Temperature: -6.0°C
                        Temperature: -3.0°C
                        Voltage: 14.351 V
    000770 - Cylinder 2
                        Mileage: 11748 km
                        Date: 2015.01.04
                        Time: 09:45:46
                        RPM: 1080 /min
                        Load: 34.1 %
                        Temperature: -6.0°C
                        Temperature: -3.0°C
                        Voltage: 14.351 V
    053285 - Please Check Fault Codes in Control Module for HVAC (J301)
                   U1025 - 000 -  - Intermittent
                        Mileage: 12427 km
                        Date: 2015.01.18
                        Time: 10:16:39
                        RPM: 1528 /min
                        Load: 28.2 %
                        Speed: 20.0 km/h
                        Temperature: 9.0°C
                        Temperature: -6.0°C
                        Voltage: 14.478 V
       Component: J104   C6 450M VD64 0014
       Coding: 0005173
       Revision: 00001K02
       Coding: 0010001002
       Revision: BJ122001
       Coding: EF180A1B80232EC4008800C11000854448010086524D8D60648040000040
       Coding: 009795
       Coding: 0012343
       Coding: 118A140000
       Coding: 820000
       Coding: 311F01
       Coding: 356002
                        Fault Frequency: 16
                        Reset counter: 100
                        Mileage: 12424 km
                        Fault Frequency: 38
                        Reset counter: 100
                        Mileage: 12424 km
       Coding: 0004B4
       Slave Driver:
       Coding: 000490
       Coding: 0000258
       Coding: 0004B4
       Slave Passenger:
       Coding: 000490
       Coding: 0026156
                        Fault Frequency: 16
                        Reset counter: 100
                        Mileage: 12424 km
                        Fault Frequency: 38
                        Reset counter: 100
                        Mileage: 12424 km
       ROD: EV_UHVUMI.rod
              B1050 00 [008] -  -
                        Reset counter: 138
                        Mileage: 12503 km
                        Date: 2015.01.20
                        Time: 06:12:20
    End-------------------------(Elapsed Time: 02:59)--------------------------
    Question... how long does the car have to sit off with doors locked before all modules will power down? This way I can check if the RNS510 is powered down (not sleeping) and boots up from scratch giving me the "welcome to VW screen" My wife was home for approx 30 min when I went out to do this work and the unit came right on with key (no "welcome to VW screen" )
    Thanks all
  11. #9
    Jan 2015
    Canada
    2 mornings in a row now I got the correct "welcome to VW" screen.
    This is after I checked off "NAV" in the gateway instillation list and ALSO gave the RNS510 a restart by holding the brightness left and right buttons at the top of the unit.
    I will give it a few days than report back again.
    NEW QUESTION....
    The dealer told me over the phone what their plan is to fix the 01042 - Control Module; Not Coded fault is...
    They plan on looking at the coding on a 2015 Tiguan that came with RNS510 NAV and then duplicating this coding on my unit.
    Does this sound like a valid course of action?
    Thanks all
  12. #10
    Have you tried Dana's suggestion?
