2014 Tiguan Aftermarket NAV and Genuine RNS510 questions/problems
luxus panzer
Canada
hc824066
Hi all.
I bought a 2014 Tiguan, Trendline with convenience package (Canada) and the dealer said they would install a NAV unit in place of the stock radio.
The aftermarket NAV had some issues where it would not shut off with key and only go into "sleep" mode, thus putting strain on the battery.
We had the unit replaced and had the same problem.
I then had the dealer put a genuine RNS510 unit in the Tiguan and I Think I am having the same problem.
I do not get the "Welcome to Volkswagen" screen when I turn the key forward... the RNS510 just powers up to the radio right away.
I found this post about some older versions of the Gateways not being compatible and caused the Databus to stay active even with the Ignition turned OFF which resulted in excessive Battery Draw and failure. (makes reference to "older" units, any idea what year this problem stopped?)
http://wiki.ross-tech.com/wiki/index.php/Navigation_System_(RNS510)_Retrofitting
I am wondering if there is a way to hook up my vag com to the car without turning the ignition on and see if the RNS or gateway is in fact still active. I will let the car sit for 2 hours after parked to be sure?
Here is some more background information....
the RNS is currently not coded correctly, dealer said they will fix this.
my scan of module 19 (I know the installer did not code the unit correctly, dealer is going to fix this)
Part No SW: 7N0 907 530 AK HW: 7N0 907 530 AK
Component: J533 Gateway H57 1642
Revision: H57 Serial number: 250314F1001343
Coding: 356002
VCID: 79F9FDE5F06BFDE9285-802C
here is a auto scan....
Chassis Type: AX (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 4C 52 53 56 62 72
77
VIN: WVGKV3AX9EW613189 Mileage: 12420km-7717miles
37-Navigation -- Status: Not registered 0011
Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
Part No SW: 06J 997 027 N HW: 06J 907 309 A
Component: MED17.5.2 TFSI 2 06 0397
Revision: P3H07--- Serial number:
Coding: 0423010A18070160
Shop #: WSC 42378 001 1048576
VCID: 408F500113316C212FB-8015
P0300 - 000 - - Intermittent
Mileage: 11748 km
Date: 2015.01.04
Time: 09:45:45
RPM: 1080 /min
Load: 34.1 %
Temperature: -6.0°C
Temperature: -3.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.351 V
000770 - Cylinder 2
P0302 - 000 - Misfire Detected - Intermittent
Mileage: 11748 km
Date: 2015.01.04
Time: 09:45:46
RPM: 1080 /min
Load: 34.1 %
Temperature: -6.0°C
Temperature: -3.0°C
Voltage: 14.351 V
Address 03: ABS Brakes Labels: 5N0-614-109-C6.clb
Part No SW: 5N0 614 109 BK HW: 5N0 614 109 BK
Component: J104 C6 450M VD5C 0014
Revision: --H07--- Serial number: 00000007882544
Coding: 0005173
VCID: 75E1F1D51C7399894CD-8020
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 561 907 426 E HW: 561 907 426 E
Component: AC Manuell H02 0303
Revision: 00001K02
Coding: 0010001002
ASAM Dataset: EV_ACManuaElectGen2BHTC 001002
ROD: EV_ACManuaElectGen2BHTC.rod
VCID: 1D31C9750C0361C964D-8048
Part No SW: 5K0 937 086 R HW: 5K0 937 086 R
Component: BCM PQ35 M 122 0173
Revision: BJ122001
Coding: EF180A1B80232EC4008800C11000854448010086524D8D6064 8040000040
VCID: 43855F0DC2277739329-8016
Subsystem 1 - Part No: 5N1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS 200214 03 32 0010
Coding: 009795
Part No SW: 5N0 959 655 AD HW: 5N0 959 655 AD
Component: J234__207 VW10 HI 2418
Revision: 28019000 Serial number: 003N4PQ1GL6$
Coding: 0012343
VCID: 7F0D13FD2E4FD3D9161-802A
Subsystem 1 - Part No: 5N0 959 339 B
Component: BF-Gewichtsens. 003 0001
Subsystem 2 - Serial number: 0000000000HX2A
Subsystem 3 - Serial number: 0020.01.140000300000660013ÿ†63
Subsystem 4 - Serial number: 660013ÿ†6332MTS613530804.ÿ†63
Subsystem 5 - Serial number: 30804.ÿ†6342MTS6147307845ÿ†63
Subsystem 6 - Serial number: 307845ÿ†6351HTS64CCLPCKJ5ÿ†63
Subsystem 7 - Serial number: LPCKJ5ÿ†6361HTS6L4JSQCKJUÿ†63
Subsystem 8 - Serial number: SQCKJUÿ†63727TS6MIMINCKRZÿ†63
Subsystem 9 - Serial number: INCKRZÿ†63827TS6KMFGPCKJNÿ
Subsystem 10 - Serial number: GPCKJNÿ
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 501 DJ HW: 5K0 953 569 AP
Revision: FF010042 Serial number: 20140408101111
Coding: 118A140000
VCID: 75E1F1D5D47399894CD-8020
Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0037
Coding: 820000
Part No SW: 5N0 920 873 B HW: 5N0 920 873 B
Component: KOMBI H04 0811
Coding: 311F01
ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
VCID: 326B0AC9659DCEB1A9F-8067
Coding: 311F01
Coding: 356002
Component: IMMO H04 0811
VCID: 6ADBD2A98DCD4671D1F-803F
Address 2E: Media Player 3
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3C0 035 684 K HW: 3C0 035 684 K
Component: RNS-MID H12 4366
Revision: AB001001 Serial number: VWZ6Z7M9302148
Coding: 00000400000000000000
VCID: 2B5517AD4AB79F79EA9-807E
Component: NAR V8 8112
Reset counter: 92
Mileage: 12424 km
02633 - Antenna for Satellite Tuner
Fault Status: 01101011
Reset counter: 92
Mileage: 12424 km
Part No SW: 5N0 959 701 F HW: 3C0 959 793 B
Component: TUER-SG FT 002 0503
Revision: 13110009 Serial number: 0008338232
Coding: 0004B4
ROD: EV_TSGFPQ35BRFVW46X.rod
VCID: 387F38E183E124E197B-806D
Slave Driver:
Subsystem 1 - Part No SW: 5N0 959 703 G HW: 3C0 959 794 D
Component: J388__TSG-HL 009 1504
Serial number: 00000008647415
Coding: 000490
Part No SW: 5N1 909 144 R HW: 5N1 909 148 J
Component: J500__APA-BS KL.285 1401
Revision: 1BH04841 Serial number: 00140910152601
Coding: 0000258
VCID: 41895505183B6529205-8014
Address 4C: Tire Pressure II
Part No SW: 5N0 959 702 F HW: 3C0 959 792 B
Component: TUER-SG BT 002 0503
Revision: 15110009 Serial number: 0008330864
Coding: 0004B4
ROD: EV_TSGBPQ35BRFVW46X.rod
VCID: 39793DE5B8EB3DE9685-806C
Slave Passenger:
Subsystem 1 - Part No SW: 5N0 959 704 G HW: 3C0 959 795 D
Component: J389__TSG-HR 009 1504
Serial number: 00000008685026
Coding: 000490
Revision: H19 Serial number: 00000002120078
Coding: 0026156
VCID: 366336D941F5D291857-8063
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Reset counter: 92
Mileage: 12424 km
Reset counter: 92
Mileage: 12424 km
Address 77: Telephone (J412) Labels: None
Part No SW: 5N0 035 729 A HW: 5N0 035 729 A
Component: TELEFON H05 0592
Revision: 1B001001 Serial number: 00007666047602
Coding: 0A10030080010110
ROD: EV_UHVUMI.rod
VCID: 2E531EB971A5EA51CD7-807B
9457664 - Function limitation due to excessive temperature
B1050 00 [009] - -
Reset counter: 92
Mileage: 12427 km
Date: 2015.01.17
Time: 12:33:51
I hope someone here can point me in the right direction to either fix this problem (via correct coding or enabling things in the control units) OR help me find a way to confirm the RNS510 is not turning off and staying in "sleep/standby" mode
Interesting that your CAN Gateway shows "Status: Malfunction 0010" in the Installation List, but doesn't show fault codes (or even "No fault code found.") in the full scan. I'm reasonably confident it should show at least one fault code like "Incorrectly Coded". Let's fix that first:
[Select]
[19-CAN Gateway]
[Installation List]
Scroll down to 37-Navigation, put a check-mark in that box, then
[Save Coding]
[Fault Codes]
[Clear Codes]
As for the coding of the RNS510 itself, someone who's more familiar with them than I am will hopefully chime in here.
Dana
Western PA, USA
You cannot use VCDS to see if a CAN controller is directly causing a battery draw, you'd need to measure Amp draw -or- use the newer VW TSB which has you measure voltage across fuses with a DVOM, but you should correct that 19-CAN GW issue as Uwe suggested first.
Next, I noticed this:
That is on the infotainment bus but I didn't run the VIN to see if it was factory installed or a retrofit. Either way, if it isn't communicating I would look into that.
You can use the LCH to code the new 37/56 unit but starting with all zeros can be tricky. Try pasting this into the new coding section with non zero WSC/Importer/Equipment numbers: 0400040204000084000C
Lastly, anything Golf based that's newer than 2010 in the NAR market should have a factory installed CAN GW that wouldn't suffer from the draw issue. You have one of the latest 7N0 series units already and that is what someone with an older 2005-2008ish car would be upgrading to.
luxus panzer
Canada
hc824066
Could this be the factory installed "convenience package" (Canada)? The Kit inside the Armrest.
Nothing non factory installed in this Tiguan other than the current RNS510
luxus panzer
Canada
hc824066
[Select]
[19-CAN Gateway]
[Installation List]
[Save Coding]
[Fault Codes]
[Clear Codes]
WilCo as soon as my wife gets home from work tomorrow evening and let you know soonest.
thanks all
Dana
Western PA, USA
Could this be the factory installed "convenience package" (Canada) The Kit inside the Armrest.
Yeah, My 2012 Tiggy Media In device is in the center console. See if that still works both with the Aux IN and an iDevice (or USB with music on a flash drive if your car came with cable that instead).
fibrizo
C?ID=156569
I've done this on a 2013 NAR Tiguan (my mom's) and another. I didn't recall any issues after ticking the 37 nav box for the gateway.
luxus panzer
Canada
hc824066
Did this
[Select]
[19-CAN Gateway]
[Installation List]
[Save Coding]
[Fault Codes]
[Clear Codes]
Here is a new scan....
Thursday,22,January,2015,14:27:40:45743
VCDS Version: 14.10.0.0
Data version: 20141022
VIN: WVGKV3AX9EW613189   License Plate:
Mileage: 12720km-7903mi   Repair Order: jess tiguan post rns AND i checked off NAV in controler 19
          77
VIN: WVGKV3AX9EW613189   Mileage: 12720km-7903miles
                    Mileage: 11748 km
                    Date: 2015.01.04
                    Time: 09:45:45
                    RPM: 1080 /min
                    Load: 34.1 %
                    Temperature: -6.0°C
                    Temperature: -3.0°C
                    Voltage: 14.351 V
000770 - Cylinder 2
                    Mileage: 11748 km
                    Date: 2015.01.04
                    Time: 09:45:46
                    RPM: 1080 /min
                    Load: 34.1 %
                    Temperature: -6.0°C
                    Temperature: -3.0°C
                    Voltage: 14.351 V
053285 - Please Check Fault Codes in Control Module for HVAC (J301)
               U1025 - 000 -  - Intermittent
                    Mileage: 12427 km
                    Date: 2015.01.18
                    Time: 10:16:39
                    RPM: 1528 /min
                    Load: 28.2 %
                    Speed: 20.0 km/h
                    Temperature: 9.0°C
                    Temperature: -6.0°C
                    Voltage: 14.478 V
   Component: J104   C6 450M VD64 0014
   Coding: 0005173
   Revision: 00001K02
   Coding: 0010001002
   Revision: BJ122001
   Coding: EF180A1B80232EC4008800C11000854448010086524D8D60648040000040
   Coding: 009795
   Coding: 0012343
   Coding: 118A140000
   Coding: 820000
   Coding: 311F01
   Coding: 356002
            000 -  -
                    Fault Frequency: 16
                    Reset counter: 100
                    Mileage: 12424 km
                    Fault Frequency: 38
                    Reset counter: 100
                    Mileage: 12424 km
   Coding: 0004B4
   Slave Driver:
   Coding: 000490
   Coding: 0000258
   Coding: 0004B4
   Slave Passenger:
   Coding: 000490
   Coding: 0026156
            000 -  -
                    Fault Frequency: 16
                    Reset counter: 100
                    Mileage: 12424 km
                    Fault Frequency: 38
                    Reset counter: 100
                    Mileage: 12424 km
   ROD: EV_UHVUMI.rod
          B1050 00 [008] -  -
                    Reset counter: 138
                    Mileage: 12503 km
                    Date: 2015.01.20
                    Time: 06:12:20
End-------------------------(Elapsed Time: 02:59)--------------------------
Question... how long does the car have to sit off with doors locked before all modules will power down? This way I can check if the RNS510 is powered down (not sleeping) and boots up from scratch giving me the "welcome to VW screen" My wife was home for approx 30 min when I went out to do this work and the unit came right on with key (no "welcome to VW screen" )
Thanks all
luxus panzer
Canada
hc824066
2 mornings in a row now I got the correct "welcome to VW" screen.
This is after I checked off "NAV" in the gateway instillation list and ALSO gave the RNS510 a restart by holding the brightness left and right buttons at the top of the unit.
I will give it a few days than report back again.
NEW QUESTION....
The dealer told me over the phone what their plan is to fix the 01042 - Control Module; Not Coded fault is...
They plan on looking at the coding on a 2015 Tiguan that came with RNS510 NAV and then duplicating this coding on my unit.
Does this sound like a valid course of action?
Thanks all
Have you tried Dana's suggestion?
luxus panzer
Canada
hc824066
I have it archived.
I am kinda in a tight situation, I do not want to do the dealers work for them, and I dont want them telling me "I Fd it up" (dont want to give them any excuses)
They also say they have to order a module for the back up camera ($750, they are paying the tab), HOWEVER, I acme across someting in the settings that was a check box for "back up camera without control unit"
Dealers FTL
Dana
Western PA, USA
Thanks all
Well, I already did that with the Long Coding Helper. I took my factory 2012 Tiguan coding, removed/tweaked the Sound System bits for your config, and pasted it above.
Edit: I just noticed the second page of this thread and that RVC retrofit. I would not add/retrofit any additional components to the vehicle until the original battery draw is resolved and that Media In unit is online and communicating when scanned. Adding any additional control modules/components will complicate things IMO.
luxus panzer
Canada
hc824066
Was looking at the 37 Navigation , recode module and saw some bits for "review camera low without control module". Can anyone explain what this is for?
luxus panzer
Canada
hc824066
I need to code my RNS-510 to my Tiguan (2014 Trendline)
Got a 2014 Trendline because it was the only Tiguan offered in manual here in Canada. The Trendline did not come with RNS-510, so I had one put in.
I am now throwing the following faults and need ro recode the RNS-510. Anyone know how?
            000 -  -
                    Reset counter: 92
                    Mileage: 12424 km
                    Reset counter: 92
                    Mileage: 12424 km
            000 -  -
                    Reset counter: 92
                    Mileage: 12424 km
                    Reset counter: 92
                    Mileage: 12424 km
Thank you
Enriquez
C?ID=72075
Post an full autoscan to get answer.
Ah... And the same thread already has a coding suggestion.
I'm merging these threads and moving them where they belong, which is the Retrofits section.
luxus panzer
Canada
hc824066
I must apologize...I completely forgot that I had posted this problem already, sorry all.
Dana... I sorta understand your solution, however, I am wondering if you can help explain to me how I would use my vag-com to figgure out how to do these things myself. I THINK I am asking how to use the long coding helper.
Thank you.
67igor1
C?ID=238444
This control module gives you lines guidance... "connected" with steering wheel...
BTW.
Do what was suggested in this tread... or don't ask for help... :P
Dana
Western PA, USA
It would be significantly easier to take the coding I built for you and paste it into the New Coding: followed by clicking Do it! Providing it is accepted you could reboot the unit to see which, if any, faults return and can fine tune the coding using the Long Coding Helper (LCH).
If you'd prefer to build it from scratch this page explains the VCDS Coding Function.
