Me thinks the ECM is toast!
bruceleroy
C?ID=224520
Backstory---
VW GTI 2.8L AFP. Multiple owners, son has owned for almost five years. Has had head gasket replacement twice now. Once when we bought it (known issue), and again when he had electrical issues (ignition coil) when in California (wish I was close enough to help). Sent to reputable VW shop while he was deployed. They had hard time finding the issue and suspected ECM. Problem seemed to disappear.
Present problem---
Engine cut off on him after coming off highway. Will not restart. I suspect the ECM is finally done. I will check compression. Cranks just fine.
Sunday,29,December,2019,13:21:39:46074
VCDS Version: 19.6.2.0 (x64)
VIN:    License Plate: UNF-5559
Mileage: 295210km-183434mi   Repair Order: Liam
Chassis Type: 1J - VW Golf/Bora IV (1998 > 2006)
          76
   Mileage: 295210km-183434miles
Address 03: ABS Brakes        Labels: 1C0-907-37x-ASR.lbl
   Part No: 1C0 907 379 D
   Component: ASR FRONT MK60      0103
   Coding: 0021505
   Shop #: WSC 00001 785 00200
   VCID: 2B5527D589B6CA1722-5140
Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
   Part No: 3B1 907 044 C
   Component: CLIMATRONIC     C 0.7.0
   Coding: 01000
   Shop #: WSC 00001
   VCID: 2149C5FDAB7A104788-524C
00792 - A/C Pressure Switch (F129)
            35-00 - -
00603 - Footwell/defroster Flap Positioning Motor (V85)
            37-10 - Faulty - Intermittent
   Part No: 6Q0 909 605 F
   Component: 07 AIRBAG VW6  0202 0004
   Coding: 12343
   Shop #: WSC 00001
   VCID: 3A7B129126EC639FA9-5140
00532 - Supply Voltage B+
Address 16: Steering wheel        Labels: 1J0-907-487-A.lbl
   Part No: 1J0 907 487 B
   Component: Lenkradelektronik   0001
   Coding: 00008
   Shop #: WSC 00001
   VCID: 306F30B9F090A9CF17-51D4
   Part No: 1J0 920 925 D
   Component: A4-KOMBIINSTR. VDO V09
   Coding: 07232
   Shop #: WSC 00001
   VCID: 2A5B22D1D64CD31FD9-5140
   Subsystem 1 - Part No: IMMO
   Component: IDENTNR: VWZ7Z0Y2950297
   IMMO-IDENTNR: VWZ7Z0Y2950297
            49-00 - No Communications
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 00001
   VCID: 70EFF0B93010E9CF57-5140
Address 46: Central Conv.        Labels: 1J0-959-799.lbl
   Part No: 1J0 959 799 AJ
   Component: 62 Zentral-SG Komf. 0001
   Coding: 00256
   Shop #: WSC 00001
   VCID: 0603B6612294D77F9D-4B00
   Subsystem 1 - Part No: 1J1959801C
   Component: 62 Tõrsteuerger. FS0002r
   Subsystem 2 - Part No: 1J1959802D
   Component: 62 Tõrsteuerger. BF0002r
00953 - Interior Light Time limit
            25-10 - Unknown Switch Condition - Intermittent
End-------------------------(Elapsed Time: 06:05)--------------------------
Deployed still active?
Send it to me after you confirm it is dead okay?
Did you verify power and grounds at ECU and why it failed?
JPPSG yet?
What is your sons MOS?
VIN #?
Pictures of ECU disassembled for visual inspection of damage please?
The ECU is clearly off-line. Check engine light doesn't light up with key on the on position, right?
But I agree with Jack; check powers and grounds to ECU first before condemning it.
bruceleroy
C?ID=224520
JPPSG yet?
VIN #?
VIN 9BWPG61J614045108
JPPSG Now Posted before to start conversation.
Testing power and grounds at ECU as we speak.
Sons MOS 0621 Radio Man or now Communications Transmissions Operator
My MOS 2891 Ground Electronics Maintenance Chief
We are both still active! (for a few more months til I retire)
I order you "Hand cranker's" to send me the ECU via contact form in my signature & for observation, repair or data transfer and you pay freight and donation of what you think is fair.
Send PM for authentication & triangulation.
OUT!
Vehicle Identification No. 9BWPG61J614045108
Model Golf VR6
GOB
Date of production 29.01.2001
Model year 2001
Sales type 9B16U4
Engine Code AFP
Transmission Code EHC
bruceleroy
C?ID=224520
Update.
No aftermarket, except radio and running 225 45 ZR17 on Corsca wheels.
Found 15 amp fuse broken in fuse 29 on side fuse panel on drivers side.
Replaced. Vehicles starts and runs.
Took another scan and am curious why ECM is intermittent, and focus on repairing problems such as radiator fans on constantly from moment key is turned to 10 minutes after shut off.
Sunday,29,December,2019,17:05:20:46074
          76
Address 01: Engine        Labels: 021-906-018-AFP.lbl
   Part No: 021 906 018 R
   Component:  MOTRONIC ME7.1 G   0003
   Coding: 00031
   Shop #: WSC 24576
   VCID: 1D31F90D970234A7AC-515E
16804 - Catalyst System; Bank 1
            P0420 - 35-10 - Efficiency Below Threshold - Intermittent
   Coding: 0021505
   Coding: 01000
   Shop #: WSC 00001
            35-00 - -
   Coding: 12343
   Shop #: WSC 00001
   Coding: 00008
   Shop #: WSC 00001
   Coding: 07232
   Shop #: WSC 00001
   Coding: 00006
   Shop #: WSC 00001
   Coding: 00256
   Shop #: WSC 00001
End-------------------------(Elapsed Time: 05:13)--------------------------
Excellent!
Why did fuse blow and did you know firmware is needed?
Are ECT values and after run fan switch in failure or stuck static?
What are status of each consumer with amperage draw monitored?
Please reset faults and post a new scan and is FOD modified tuning present masking a stack entry?
Since the CAT is in sporadic error, what are OXS oxygen sensors/heaters status?
bruceleroy
C?ID=224520
Jack,
You gonna make my agent orange act up. When I was in the fleet I used to hammer the communicators in my unit and subordinate units who failed to properly ground their equipment and complained their equipment wasn't working. Let alone my own maintenance community for failing to ensure proper bonding when repairing and returning equipment to a ready for use state. The value of a good grounding plane is underestimated. We have a much older TM in the Marine Corps, but the information is identical.
Hey Tubes
Who knows grounds and FOD?
NostraJackASS knows grounds, however, does not know everything or new possible lurking FOD!
:rolleyes:
bruceleroy
C?ID=224520
Excellent!
Didn't know firmware was needed. I assume I go to VW dealer and they do it? probably charge me one hour rate.
Been a while since I ran coolant values. Will take car for a trip around the block tomorrow with my son afterwork and ensuring we get to operating temps. I did simulate the replacement of the new afterun switch without pulling the old switch out to see if this would change anything, however there was no difference in how the vehicle reacted when I hooked up new switch to the existing plug (simply pulled plug from sensor in the vehicle and plugged it in to a new sensor leaving it hanging not touching anything). Did not turn vehicle on, but as soon as I put key in engine off position the fan came right on as usual.
New scan posted below. We have never modified the ECM ourselves, but as stated, I wonder if there is a FOD modified tuning. I assume this might be undone and it might be worth sending this to you. He has access to my vehicles for work so I am convincing him to pull ECM and send to you.
Since I reset, readiness is not set. I will check Ox sensor and heaters tomorrow as well.
Thanks for the guidance and suggestions.
Sunday,29,December,2019,20:19:29:46074
          76
   Coding: 00031
   Shop #: WSC 24576
Readiness: 0110 1101
   Coding: 0021505
   Coding: 01000
   Shop #: WSC 00001
            35-00 - -
   Coding: 12343
   Shop #: WSC 00001
   VCID: 3A7B129126EC639FA9-515E
   Coding: 00008
   Shop #: WSC 00001
   Coding: 07232
   Shop #: WSC 00001
   Coding: 00006
   Shop #: WSC 00001
   Coding: 00256
   Shop #: WSC 00001
   VCID: 0603B6612294D77F9D-4AE8
End-------------------------(Elapsed Time: 05:09)--------------------------
Tubes
10-4 send it in and as aforementioned whatever you want sir.
Did you check WD for fan circuits yet to familiarize or know that fan is controlled by its own controller and maybe it is receiving a call from cluster, climate control or ECU?
Did you check that PSI switches for AC or high temp switch on coolant flange and not just radiator?
bruceleroy
C?ID=224520
Tubes
It is funny how JPPSG mentions cause and effect. I have ignored the AC as this is a comfort item (no refrigeration and never worked), yet it seems to be having the effect on fans staying on. New FCM, radiator fan control switch, new large fan and radiator.
Funny thing is I bet there is an issue with 30 B+. Got this next quote from your Ebay store as I was browsing your products and work
"In many instances terminal 30 B+ ( voltage all the time ) burns down in a flood condition car. This damages the harness connectors spring retention, causing sporadic conditions and even may blow a fuse due to poor connectivity."
Although we don't know the past history, but assume since the title is not salvage, it has not been in a flood.
I had it in my garage for a while when he shipped it from Cali when he moved out here earlier this year. That's when we replaced radiator, front wheel bearings and a few other items... Should have looked into the ECU harness and 30 B+. I did not know that kind of effect it could have.
Tubes
PS when I first came in back in 1990, there were a few RT 505's hanging around our shop with tubes in the A1 transmit module.
There is a reason that fuse blew and my money is on OXS oxygen sensors due to heaters but anything on the bus could do it or water corrosion bridge too, right?
Don't you just love when a corrosion bridge from terminal 15 allows for a car to be started then back feeds the 15 and won't shut down when cycling key off?
"Give before it hurts" or FOD rules!
Let me know Tubes I saw your PM.
Offer still stands indeed.
Subsystem redundancy check.............reboot started.
System coming up
System started & Tubes are glowing!
Mb_r5Jxoqf4ki8c_6Xn2RC7avJt77tVlNldYZkNgLhJw5BUH_ALvaJZPK6GVFAw2Rv-zdmLrd5SmEap74ZWhYD_zJS52G5gYJDw8zQ
FOD CHECK HAS COMMENCED!
Vehicle Identification No.9BWPG61J614045108
ModelGolf VR6
GOB
Date of production29.01.2001
Model year2001
Sales type9B16U4
Engine CodeAFP
Transmission CodeEHC
pecial editionsE0AWithout special action equipment
Lockable wheel bolts1PCWheel bolts with anti-theft protection (unlockable)
Vehicle class differentiation units/platform components0DWVehicle class differentiation -1JE-
Emission standard0GMEmission standard LEV 1
Trailer hitch1D0Without trailer hitch
airbag4UBAirbag for NAR
Automatic transmission indicator light9FAWithout automatic transmission indicator light
Aktivkohlebehälter / Ottopartikelfilter1E4Activated carbon canister (ORVR) and siphoning device for fueling
Aerials8L3Roof antenna
Exterior mirror setting6XNExterior mirrors, power-adjustable/ separately heated
Left exterior mirror5SHLeft exterior mirror, flat (US)
Right exterior mirror5RRRight exterior mirror, convex (US)
Drive type1X0Front-wheel drive
Outside temperature display9Y0Without outdoor temperature gage
Equipment levelsA8HTop sports equipment
Brake type in rear1KVDisc brakes in rear (Geomet D)
batteriesJ1LBattery 280 A (60 Ah)
Brake type, front1ZDDisc brakes in front (Geomet D)
Components with special surface6FFExterior mirror housing and various attachments colour coded to vehicle
Controls (steering wheel/steering column)4LFControls for radio and cruise control system
Beverage holders4M6Beverage holders
Special color trim0UAWithout special color trim
Component part sets with country-specific design requirementsB0WComponent parts set, complying with vehicle type for California, various parts
floor covering3MFDilours floor covering with scuff guard
vehicle tools and jack1S7Tool kit and aluminum jack
brake pressure regulator1H0without brake pressure regulator
Brake systems1AJAnti-slip regulation (ABS/ASR/EDL) with electronic differential lock (EDL)
Brake pad wear indicator9U1Brake pad wear indicator
Heated washer nozzles9T1Heated washer nozzles in front
CD ROM/DVD/SD card7QAWithout CD/DVD for navigation
CD changer/CD player7A1CD changer preparation
Chrome packageQJ0Without aluminum/chrome work package
General operating permit, alterationsC00Operating permit, initial registration
Cd enhancing underbody panel2D1Complete cd enhancing underbody panel
Roof rails/roof load rack3S0Without roof rails/roof load rack
Roof insert/convertible top3FETilting and sliding glass sunroof with sunbshade
Suspension system in rearUA9Rear shock absorption, sports version
Suspension system in frontG76Shock absorption in front
Insert for the filling up of unleaded fuel/fuel type2G7Filler neck module 1 with insert
Installation differentiation for components0EJInstallation differentiation for transmission MQ 250 -- vehicle components --
Theft protection system7AGElectronic immobilizer with anti-theft alarm system (for USA)
Inserts5MWDecorative inserts, dark myrtle wood
Park distance control7X0Without park distance control
Manufacturing sequence differentiation0FAStandard manufacturing sequence
Vehicle typeAZ0Vehicle with production equipment
window regulator4R4Power windows with comfort operation and circuit breaker
fire extinguisher6A0without fire extinguisher
Headlight activation8K4Separate daytime running light -- NAR --
Fresh air intake for passenger compartment (with particulate filter)2V5Fresh air intake system with combination filter
Antifreeze1C2Antifreeze up to -35 degree Celsius tolerance up to -40 degree C
Vehicle specificationsF0ANo special purpose vehicle, standard equipment
throttle control0L2Electronic throttle control
Alternators8GLAlternator 120 A
Transmission types/gearshift mechanisms0G4Cable gearshift
Weight category rear axle0YZWithout determination of weight category for rear axle
Weight category front axleL21Suspension range 21 installation control only, no requirement forecast
Base engineT2R6-cylinder SI engine 2.8 l unit 021.H
Luggage netting/pocket on backrest(s)4U5Luggage pockets on backrest
Luggage compartment cover3U1Folding trunk cover
cruise control system8T2Electronic cruise control system (CCS)
Exterior noise suppression measures2B8additional noise dampener
Garage door openerVC0without Garage door opener
Luggage compartment trim5A7Comfort luggage compartment lining with service flap
Transmission specificationsG0C5-speed manual transmission
Brackets3P7Bracket for warning triangle
handle for hand brake lever6PCHand brake lever handle in leather
Rear window wiper and washer system8M1Rear window wiper washer system with intermittent wipe
Grab handles at roof frame5N6Folding grab handles on roof frame soft fold-away
Rear axle0N1Standard rear axle
Rear seats3NCRear seat bench/backrest, split folding
Heating and air-conditioning system9AKClimatronic with impact pressure control, CFC-free
Headlamps8JTTwin headlight for driving on the right with clear lens (US design)
Instrument clustersU0FInstrument cluster with tachometer, clock and mph speedometer
Breakaway interior rearview mirror4L6Breakaway interior rearview mirror, auto-dimming
Sticker (customized or special edition)0KAWithout decals and emblems
Body styleK8GHatchback
Luggage compartment floor covering6SCLuggage compartment floor covering in needle-punched nonwoven
Cassette and CD storage unit4W0without cassette / CD tray
Electronic map cooling systemQS0Without electronic map cooling system
Child seatsQA0without child seat
Rear head restraints3Q6Three rear head restraints
Head restraints5ZHHead restraints for front seats, tilt- and height-adjustable with integrated adjustment mechanism
Fuel tank treatment2LCFuel tank with special material treatment (coextrusion)
Fuel quantity for initial filling1Z2Increase in initial standard fuel filling
Fuel systems0F2Fuel system for fuel-injected SI engine
Body measures5C1Body measures for increased safety requirements
Radiator grille6KGRadiator grille
Rear license plate carrier6P2Rear license plate carrier (NAR)
Front license plate carrier6W3Front license plate carrier (small, NAR)
Paint preservative/transit coating5K5Transportation protective film (instead of paint preservation)
Paint coatingFB0standard paint coating
Rear cargo area3GAWithout luggage compartment floor
Steering system arrangementL0LLeft-hand drive
Reading lamp8S2One reading light in front, two reading lights in rear
steering1N9Power steering (limited steering lift mechanism)
Backrest release3H9Backrest release for front seats with Easy Entry feature
Air duct, front areaVK0Air duct, standard
Load edge protection2P0Without loading edge protection
Lumbar support7P4Manually adjustable lumbar support in front seats
steering wheels2ZBLeather-wrapped multi-function steering wheel
Speaker installation9VG"Monsoon sound system" (NAR)
Steering column systems2C5Axial and vertical adjustable steering column
Headlight range control8Q0without beam length regulator
Center armrest6E3Center armrest in front
Multi-function display/trip computer9Q1Multi-function display/trip computer
Engine cooling8Z7Engine cooling, version 3
Engine specificationsM6A6-cylinder SI engine 2.8 l/130 kW (VR6) with MPI base engine is T2R
Engine compartment lighting9L0without engine compartment lighting
Left vanity mirror4SQLeft vanity mirror illuminated with cover and special mirror imprint (NAR)
Right vanity mirror4TQVanity mirror, right, illuminated, with cover and special mirror imprint (NAR)
Navigation device7Q0without navigation system
rear fog lamp8TAwitout rear fog lamp
Front fog lamp/additional headlamp8WDIntegrated front fog lamps
Rear of platform module base4P0Rear floor panel module, type 1
Platform group class7PAPlatform group class 1
Hubcaps1NLTrims for alloy wheels
WheelsC3KCast alloy wheels 6.5J x 16 BBS, one-piece, offset 42
Radios8YTRadio "Premium"
Smoker's/non-smoker's package9JANon smoker version
tireH4BAll-season tires 205/55 R16 H (NAR)
Tire suppliersV0ATires without specification of tire brand
Spare wheel/breakdown kit1G2Steel spare wheel with original equipment tire
Restraint systems, front4QQ3-point seat belts in front with pretensioner and height adjustment, US label
PMCCalifornia Emissions Package
Side airbag4X3Side airbag in front, with curtain airbag
Gearshift knob/handle6Q3Gearshift knob/handle in wood
Special labels/plates0SCLabels in English
Tail lamp assemblies8SBRear combination lamp with darkened lens
Locking mechanism for boot lid/cover rear4E2Tailgate/trunk lid release from inside (electrically)
Nameplate for sales nameQD0Without nameplate for sales name
Seat belt check9P7Visual and acoustic seat belt reminder, electric contact in buckle
Outer rear seat belts3ZM3-point seat belts, outer rear
Center rear seat belts3C83-point seat belt, center rear with US label
Gearshift boot/cover6R2Gearshift boot in leather
seat coversN7DSeat trim covers in part leather
Seat adjustment3L3Manual height adjustment for front seats
seat heater4A3seat heating for front seats separat controlable
Side lights7R4Side marker lamps and turn signal repeaters (turn signals with white lens)
Horns8Y1Two-tone horn
Control number (no PR family)S50Control of logistics 1
Control number (no PR family)S51Control of logistics 2
Side and rear windows4KCSide and rear windows in heat-insulating glass
Protective side molding4B2Body-colored protective side molding
Sunroof roller blind for rear/side windows3Y0without roller blind
Supertone system and tone sequence control9J0Without supertone system and tone sequence control
power outlet7B212 volt socket in luggage compartment
Bumper2JCComfort bumpers
Rear stabilizer bar0BBRear stabilizer bar
Front stabilizer bar0AEFront stabilizer bar
Heavy-duty/sports version2UAWithout bad road/sports version
Headlamp washer system8X0Without headlamp washer system
Windshield wiper intermittent control/ light/rain sensor8N3intermittent windscreen wiper with rain sensor
Special approval measures3M0Without special measures
Nameplate set1RVNameplate set "GTI VR6" (without model designation)
Special alarm systems9A0Without taxi alarm system
Door storage compartments in front3YRDoor pockets with insert mats
Fuel filler cap/door, locking option2W2Fuel filler cap, attached (NAR)
Mass damper for steering wheels1Q0steering wheel without balance weight
Door and lid locking system4K0Central locking w/ radio remote control and interior controls
Type approval countries/countries with special requirementsB38Legal requirements for California
Carrier frequency for remote control5D2Carrier frequency 315 MHz
Partition3CAwithout partition
Door and side trim panels3LJDoor and side trim panel in foam film, insert in leatherette
doors0A12 doors
TV reception/digital radio receptionQV0Without TV reception/digital radio reception
Speedometer cable and seal8CCSpeedometer sensor without seal (electronic speedometer sensor)
Front underbody guard1SAWithout additional front underbody guard
Identification plates1EBwithout identification plate
First aid kit / warning triangle1T0Without first aid kit and warning triangle
Two-way radio installation preparation9D0without prepared for two way radio system
Front seatsQ4HSports comfort seats in front
Rear seat catch6QARear seat catch
Preparation for rotating beacon/siren combination9F0Without preparation for rotating beacon/siren combination
Telephone / telematics9W0Without car phone preparation/ installation
Additional warning lights9TBAdditional warning lights (door area)
LongLife Service RegimeQG0without service interval extension
Heat accumulator system/auxiliary heater7E2Heated crankcase ventilation system
Windshield Glass4GCWindshield in heat-insulating glass with sunshield
Washer fluid level indicator8W1Washer fluid level indicator
Additional tires (snow tires)2WAwithout spare tyre
floor mats0TDFront and rear floor mats
Additional body panels, side6EJAdditional body cover on sill without wheel arch
Additional child seat anchors3B1Child seat anchors acc. to Canadian requirements
Zündanlaß/Schloß-Sperrsystem/ Elektrische Lenksäulenverriegelung0RBIgnition/starter switch locking system
Additional tunnel cover4J1Floor tray, extension center console
Additional dust seals6U0Without additional seals outside
Auxiliary heating system9M0Without auxiliary heater/parking heater
WURTH THE GOOD STUFF FROM 25 YEARS AGO COCKPIT CLEANER POLISHED THE OPTICS!
WHERE IS MY GERMAN CHOCOLATE WTF!? BRAND NEW ECU......HMMMM NEED ANOTHER OXS! MAF CHECK!
THIS KEY CASE IS BEAT ILL SEE IF I CAN MAKE SOMETHING HAPPEN NOT EVEN GENERATION CORRECT.
STAND BY! STILL COMPILING BLITZ PACKAGE!
2 ROUGE KEYS!
FORENSICS IN BELOW!
Control Module Part Number: 021 906 018 R
  Component and/or Version:  MOTRONIC ME7.1 G   0003 <<<<<<<<<<<< INDEED FOD FUCKAROO
           Software Coding: 00031
            Work Shop Code: WSC 24576
7 Faults Found:
16804 - Catalyst System; Bank 1: Efficiency Below Threshold
        P0420 - 35-10 -  -  - Intermittent
16507 - Throttle Position Sensor (G69): Signal too High
        P0123 - 35-00 -  -
16606 - Angle Sensor 2 for Throttle (G188): Signal Too Low
        P0222 - 35-00 -  -
16497 - Intake Air Temp. Sensor (G42): Signal too High
        P0113 - 35-00 -  -
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
        P0118 - 35-00 -  -
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
        P1650 - 35-10 -  -  - Intermittent
18044 - Powertrain Data Bus: Missing Message from Airbag Controller
        P1636 - 35-00 -  -
Readiness Status: 0000 0000
Exhaust Gas Recirculation: Passed
Oxygen Sensor Heating: Passed
Oxygen Sensor(s): Passed
Air Conditioning: Passed
Seconday Air Injection: Passed
Evaporative Emissions: Passed
Catalyst Heating: Passed
Catalytic Converter(s): Passed
                Address 01: Engine  (021 906 018 R)
16:58:15 Group 060: Electronic Throttle (Throttle Body Adaptation)
  99.6 %  Throttle Valve Sensor 1 (G187)
  0.0 %  Throttle Valve Sensor 2 (G188)
  1  Throttle Adaptation Steps Counter
  ERROR   Result Throttle Valve Adp.
16:58:47 Group 125
  ABS 1
  Instruments 1
            Bin. Bits
Adaptation Channel 091:
Stored value 4
Control Module Part Number: 1J0 920 925 D
  Component and/or Version: A4-KOMBIINSTR. VDO V09
           Software Coding: 07232
            Work Shop Code: WSC 00001
           Additional Info: IMMO-IDENTNR: VWZ7Z0Y2950297
6 Faults Found:
00771 - Fuel Level Sensor (G)
        30-00 - Open or Short to Plus
01312 - Powertrain Data Bus
17:02:02
   1   Engine Start permitted
   0   Engine (ECU) responds <<<<<<<<<<<<<<<<<<<< FOD FUCKAROO!
   1   Key Status
   3   Number of adapted Keys
   1   Variable Code authorized
   0   Key Status (Transponder)
   1   Fixed Code authorized
  N/A   Immobilizer Status
  N/A   Lock-Time Instrument Cluster
bruceleroy
C?ID=224520
You are so awesome. Let me know what cost is for another key and ill cover it for my son. I'll send check out right away. Let me know what additional cost you have incurred and I'll cover it.
Break,break..
I assume the one we sent was toast?
Over....
bruceleroy
C?ID=224520
Video reminds me of time in Okinawa, Japan. Although it was too small of an island to go that fast. It would take the length of the video to get from north to south supposing you had minimal traffic.
We will replace OSB and I'll look at MAF.
Over....
