Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 44
Thread: Me thinks the ECM is toast!
  1. #21
    I put a key case in box already with old one, German chocolate, front and rear OXS all genuine, MAF, new ECU in genuine box and updated with cluster.
    You figure it out you guys are on honor guard system.
    Will have tracking number activity tomorrow.
  2. Likes Uwe liked this post
  3. #22
    SHIPPED!
    PM sent with tracking...........
    ETA Thursday
  4. Likes Uwe liked this post
  5. #23
    Feb 2015
    SHIPPED!
    ETA Thursday
    PM received. Will update over the weekend when we put it all back together.
    Over and out!
  6. Likes Jack@European_Parts liked this post
  7. #24
    To update the post, we received an awesome package from Jack@European_Parts. New ECM was installed. Although the old ECM needed work, the fuse was not blowing because of the ECM, but for another reason. As suggested, the president and post OXS were replaced. Corrosion was noted when pulling the connectors apart.
    It may have operated but it wasn't in operation properly and why I did what I did.
    Hot spot was indeed found.
    Everything working okay now?
    Final auto-scan Tube's?
  8. #25
    Feb 2015
    Received awesome package from Jack@European_Parts.
    ECM was replaced as we discovered the fuse kept blowing and when we pulled it, the ECM is for a MK4 Jette VR6. Although it worked, it was not the proper one. Thanks Jack.
    To fix the blowing fuse issue, we replaced pre and post OXS. When we pulled the pre, we noticed corrosion present. Connector was dry and no intrusion detected. A bit curious since the connector is sealed and covered. Might consider drilling holes in cover that protects connectors to ensure no water is retained.
    We ohm's the pre OXS and found the following readings. Across pins 3 and 4, we read 3.3 ohms. This was present at same value on both old and new. Only other readings we found were across pins 2 and 6. Old OXS read 112.4 ohms, while new read 122.2 ohms. This is an indication of wear.
    On post OXS found only reading across pins 1 and 2. Found 9 ohms on both old and new. Will start it up and drive it around to set readiness and report issues.
  9. #26
    Feb 2015
    ECM installed.
    She's alive!!!! Reset codes. Taking it out this morning to get readiness set again, and see what other faults still exist.
    Known faults not caused by ECM, after run fan, running way too long (10 minutes). Suspect F129/G65. Already replaced temp sensor in thermostat housing, new fan control module and radiator temp sensor. No refrigerant in HVAC lines. This is next project.
    Will post results. If you have suggestions about what to monitor in adv measure blocks when driving (son is driving,while I monitor) gladly accept for my education.
  10. Likes Uwe liked this post
  11. #27
    Is fan module receiving a signal from radiator fan switch or only the ECT to turn on and is secondary electronic water pump functional?
    Is main water pump functional and not spinning on shaft for impeller being inefficient?
    Maybe thermostat is stuck and causing coolant only to return within block and never opening or enough to permit coolant flow to radiator, hence forcing fans on by ECT in water neck only and using fans to cool engine by air circulation in bay and for extended periods?
  12. #28
    Feb 2015
    Yes. Validated signal and continuity check.
    Don't think so. I think this may be culprit plus saw leak from body.
    Have not checked. If memory serves, can validate flow through coolant overflow.
    Suspect the above first. Recently replaced thermostat housing with new thermostat in last 6 months, but understand failure can come right out of the box.
    I'll put this in General repair section no VCDS.
    Onto latest nd greatest. Stepped though readiness and had a bit of trouble maintaining 1350-1450 rpm at first, but steadied the leg and foot and everything was good except secondary air injection and B1S1, although it passed both OXS tests in readiness.
    Do have a new secondary air pump. Will investigate more. Watched the B1S1 fault go away when we test drove it. Then it came back.
    Still have communication issues with ECM.
    Monday,24,February,2020,18:39:37:46074
    VCDS Version: 19.6.2.0 (x64)
    Mileage: 295560km-183652mi   Repair Order: Liam Post ECM Post Test drive
    Chassis Type: 1J - VW Golf/Bora IV (1998 > 2006)
              76
       Mileage: 295560km-183652miles
    Address 01: Engine        Labels: 021-906-018-AFP.lbl
       Part No: 021 906 018 R
       Component: MOTRONIC ME7.1  G   6762
       Coding: 00031
       Shop #: WSC 03738
       VCID: 1D31F90D970234A7AC-5140
    16518 - Oxygen (Lambda) Sensor B1 S1
                P0134 - 35-10 - No Activity - Intermittent
    Readiness: 0000 1000
    Address 03: ABS Brakes        Labels: 1C0-907-37x-ASR.lbl
       Part No: 1C0 907 379 D
       Component: ASR FRONT MK60      0103
       Coding: 0021505
       Shop #: WSC 00001 785 00200
       VCID: 2B5527D589B6CA1722-515E
    Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
       Part No: 3B1 907 044 C
       Component: CLIMATRONIC     C 0.7.0
       Coding: 01000
       Shop #: WSC 00001
       VCID: 2149C5FDAB7A104788-524C
       Part No: 6Q0 909 605 F
       Component: 07 AIRBAG VW6  0202 0004
       Coding: 12343
       Shop #: WSC 00001
       VCID: 3A7B129126EC639FA9-4B00
    Address 16: Steering wheel        Labels: 1J0-907-487-A.lbl
       Part No: 1J0 907 487 B
       Component: Lenkradelektronik   0001
       Coding: 00008
       Shop #: WSC 00001
       VCID: 306F30B9F090A9CF17-51D4
       Part No: 1J0 920 925 D
       Component: A4-KOMBIINSTR. VDO V09
       Coding: 07232
       Shop #: WSC 03738
       VCID: 2A5B22D1D64CD31FD9-5140
       Subsystem 1 - Part No: IMMO
       Component: IDENTNR: VWZ7Z0Y2950297
       IMMO-IDENTNR: VWZ7Z0Y2950297
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 00001
       VCID: 70EFF0B93010E9CF57-515E
    Address 46: Central Conv.        Labels: 1J0-959-799.lbl
       Part No: 1J0 959 799 AJ
       Component: 62 Zentral-SG Komf. 0001
       Coding: 00256
       Shop #: WSC 00001
       VCID: 0603B6612294D77F9D-4B00
       Subsystem 1 - Part No: 1J1959801C
       Component: 62 Tőrsteuerger. FS0002r
       Subsystem 2 - Part No: 1J1959802D
       Component: 62 Tőrsteuerger. BF0002B
    End-------------------------(Elapsed Time: 05:12)--------------------------
  13. #29
    Feb 2015
    Suspect there might be a contact issue with one pin.
  14. #30
    Did you install new MAF sensor?
    That should be cleaned already, ever etch connection or use Stabilant 22a after cleaning?
