Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 44
Thread: Me thinks the ECM is toast!
    Hey Tubes
    Who knows grounds and FOD?
    NostraJackASS knows grounds, however, does not know everything or new possible lurking FOD!
  2. #12
    Feb 2015
    Excellent!
    Why did fuse blow and did you know firmware is needed?
    Are ECT values and after run fan switch in failure or stuck static?
    What are status of each consumer with amperage draw monitored?
    Please reset faults and post a new scan and is FOD modified tuning present masking a stack entry?
    Since the CAT is in sporadic error, what are OXS oxygen sensors/heaters status?
    Didn't know firmware was needed. I assume I go to VW dealer and they do it? probably charge me one hour rate.
    Been a while since I ran coolant values. Will take car for a trip around the block tomorrow with my son afterwork and ensuring we get to operating temps. I did simulate the replacement of the new afterun switch without pulling the old switch out to see if this would change anything, however there was no difference in how the vehicle reacted when I hooked up new switch to the existing plug (simply pulled plug from sensor in the vehicle and plugged it in to a new sensor leaving it hanging not touching anything). Did not turn vehicle on, but as soon as I put key in engine off position the fan came right on as usual.
    New scan posted below. We have never modified the ECM ourselves, but as stated, I wonder if there is a FOD modified tuning. I assume this might be undone and it might be worth sending this to you. He has access to my vehicles for work so I am convincing him to pull ECM and send to you.
    Since I reset, readiness is not set. I will check Ox sensor and heaters tomorrow as well.
    Thanks for the guidance and suggestions.
    Sunday,29,December,2019,20:19:29:46074
    VCDS Version: 19.6.2.0 (x64)
    Mileage: 295210km-183434mi   Repair Order: Liam
    Chassis Type: 1J - VW Golf/Bora IV (1998 > 2006)
              76
       Mileage: 295210km-183434miles
    Address 01: Engine        Labels: 021-906-018-AFP.lbl
       Part No: 021 906 018 R
       Component:  MOTRONIC ME7.1 G   0003
       Coding: 00031
       Shop #: WSC 24576
       VCID: 1D31F90D970234A7AC-515E
    Readiness: 0110 1101
    Address 03: ABS Brakes        Labels: 1C0-907-37x-ASR.lbl
       Part No: 1C0 907 379 D
       Component: ASR FRONT MK60      0103
       Coding: 0021505
       Shop #: WSC 00001 785 00200
       VCID: 2B5527D589B6CA1722-5140
    Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
       Part No: 3B1 907 044 C
       Component: CLIMATRONIC     C 0.7.0
       Coding: 01000
       Shop #: WSC 00001
       VCID: 2149C5FDAB7A104788-524C
    00792 - A/C Pressure Switch (F129)
                35-00 - -
    00603 - Footwell/defroster Flap Positioning Motor (V85)
                37-10 - Faulty - Intermittent
       Part No: 6Q0 909 605 F
       Component: 07 AIRBAG VW6  0202 0004
       Coding: 12343
       Shop #: WSC 00001
       VCID: 3A7B129126EC639FA9-515E
    00532 - Supply Voltage B+
    Address 16: Steering wheel        Labels: 1J0-907-487-A.lbl
       Part No: 1J0 907 487 B
       Component: Lenkradelektronik   0001
       Coding: 00008
       Shop #: WSC 00001
       VCID: 306F30B9F090A9CF17-51D4
       Part No: 1J0 920 925 D
       Component: A4-KOMBIINSTR. VDO V09
       Coding: 07232
       Shop #: WSC 00001
       VCID: 2A5B22D1D64CD31FD9-5140
       Subsystem 1 - Part No: IMMO
       Component: IDENTNR: VWZ7Z0Y2950297
       IMMO-IDENTNR: VWZ7Z0Y2950297
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 00001
       VCID: 70EFF0B93010E9CF57-5140
    Address 46: Central Conv.        Labels: 1J0-959-799.lbl
       Part No: 1J0 959 799 AJ
       Component: 62 Zentral-SG Komf. 0001
       Coding: 00256
       Shop #: WSC 00001
       VCID: 0603B6612294D77F9D-4AE8
       Subsystem 1 - Part No: 1J1959801C
       Component: 62 Tõrsteuerger. FS0002r
       Subsystem 2 - Part No: 1J1959802D
       Component: 62 Tõrsteuerger. BF0002r
    00953 - Interior Light Time limit
                25-10 - Unknown Switch Condition - Intermittent
    End-------------------------(Elapsed Time: 05:09)--------------------------
  3. #13
    Tubes
    10-4 send it in and as aforementioned whatever you want sir.
    Did you check WD for fan circuits yet to familiarize or know that fan is controlled by its own controller and maybe it is receiving a call from cluster, climate control or ECU?
    Did you check that PSI switches for AC or high temp switch on coolant flange and not just radiator?
  4. #14
    Feb 2015
    Tubes
    It is funny how JPPSG mentions cause and effect. I have ignored the AC as this is a comfort item (no refrigeration and never worked), yet it seems to be having the effect on fans staying on. New FCM, radiator fan control switch, new large fan and radiator.
    Funny thing is I bet there is an issue with 30 B+. Got this next quote from your Ebay store as I was browsing your products and work
    "In many instances terminal 30 B+ ( voltage all the time ) burns down in a flood condition car. This damages the harness connectors spring retention, causing sporadic conditions and even may blow a fuse due to poor connectivity."
    Although we don't know the past history, but assume since the title is not salvage, it has not been in a flood.
    I had it in my garage for a while when he shipped it from Cali when he moved out here earlier this year. That's when we replaced radiator, front wheel bearings and a few other items... Should have looked into the ECU harness and 30 B+. I did not know that kind of effect it could have.
    Tubes
    PS when I first came in back in 1990, there were a few RT 505's hanging around our shop with tubes in the A1 transmit module.
  5. Likes Jack@European_Parts liked this post
  6. #15
    There is a reason that fuse blew and my money is on OXS oxygen sensors due to heaters but anything on the bus could do it or water corrosion bridge too, right?
    Don't you just love when a corrosion bridge from terminal 15 allows for a car to be started then back feeds the 15 and won't shut down when cycling key off?
    "Give before it hurts" or FOD rules!
  7. #16
    Let me know Tubes I saw your PM.
    Offer still stands indeed.
  8. #17
    Subsystem redundancy check.............reboot started.
    System coming up
    System started & Tubes are glowing!
    FOD CHECK HAS COMMENCED!
    Vehicle Identification No. 9BWPG61J614045108
    Model Golf VR6
    GOB
    Date of production 29.01.2001
    Model year 2001
    Sales type 9B16U4
    Engine Code AFP
    Transmission Code EHC
    pecial editions E0A Without special action equipment
    Lockable wheel bolts 1PC Wheel bolts with anti-theft protection (unlockable)
    Vehicle class differentiation units/platform components 0DW Vehicle class differentiation -1JE-
    Emission standard 0GM Emission standard LEV 1
    Trailer hitch 1D0 Without trailer hitch
    airbag 4UB Airbag for NAR
    Automatic transmission indicator light 9FA Without automatic transmission indicator light
    Aktivkohlebehälter / Ottopartikelfilter 1E4 Activated carbon canister (ORVR) and siphoning device for fueling
    Aerials 8L3 Roof antenna
    Exterior mirror setting 6XN Exterior mirrors, power-adjustable/ separately heated
    Left exterior mirror 5SH Left exterior mirror, flat (US)
    Right exterior mirror 5RR Right exterior mirror, convex (US)
    Drive type 1X0 Front-wheel drive
    Outside temperature display 9Y0 Without outdoor temperature gage
    Equipment levels A8H Top sports equipment
    Brake type in rear 1KV Disc brakes in rear (Geomet D)
    batteries J1L Battery 280 A (60 Ah)
    Brake type, front 1ZD Disc brakes in front (Geomet D)
    Components with special surface 6FF Exterior mirror housing and various attachments colour coded to vehicle
    Controls (steering wheel/steering column) 4LF Controls for radio and cruise control system
    Beverage holders 4M6 Beverage holders
    Special color trim 0UA Without special color trim
    Component part sets with country-specific design requirements B0W Component parts set, complying with vehicle type for California, various parts
    floor covering 3MF Dilours floor covering with scuff guard
    vehicle tools and jack 1S7 Tool kit and aluminum jack
    brake pressure regulator 1H0 without brake pressure regulator
    Brake systems 1AJ Anti-slip regulation (ABS/ASR/EDL) with electronic differential lock (EDL)
    Brake pad wear indicator 9U1 Brake pad wear indicator
    Heated washer nozzles 9T1 Heated washer nozzles in front
    CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
    CD changer/CD player 7A1 CD changer preparation
    Chrome package QJ0 Without aluminum/chrome work package
    General operating permit, alterations C00 Operating permit, initial registration
    Cd enhancing underbody panel 2D1 Complete cd enhancing underbody panel
    Roof rails/roof load rack 3S0 Without roof rails/roof load rack
    Roof insert/convertible top 3FE Tilting and sliding glass sunroof with sunbshade
    Suspension system in rear UA9 Rear shock absorption, sports version
    Suspension system in front G76 Shock absorption in front
    Insert for the filling up of unleaded fuel/fuel type 2G7 Filler neck module 1 with insert
    Installation differentiation for components 0EJ Installation differentiation for transmission MQ 250 -- vehicle components --
    Theft protection system 7AG Electronic immobilizer with anti-theft alarm system (for USA)
    Inserts 5MW Decorative inserts, dark myrtle wood
    Park distance control 7X0 Without park distance control
    Manufacturing sequence differentiation 0FA Standard manufacturing sequence
    Vehicle type AZ0 Vehicle with production equipment
    window regulator 4R4 Power windows with comfort operation and circuit breaker
    fire extinguisher 6A0 without fire extinguisher
    Headlight activation 8K4 Separate daytime running light -- NAR --
    Fresh air intake for passenger compartment (with particulate filter) 2V5 Fresh air intake system with combination filter
    Antifreeze 1C2 Antifreeze up to -35 degree Celsius tolerance up to -40 degree C
    throttle control 0L2 Electronic throttle control
    Alternators 8GL Alternator 120 A
    Transmission types/gearshift mechanisms 0G4 Cable gearshift
    Weight category rear axle 0YZ Without determination of weight category for rear axle
    Weight category front axle L21 Suspension range 21 installation control only, no requirement forecast
    Base engine T2R 6-cylinder SI engine 2.8 l unit 021.H
    Luggage netting/pocket on backrest(s) 4U5 Luggage pockets on backrest
    Luggage compartment cover 3U1 Folding trunk cover
    cruise control system 8T2 Electronic cruise control system (CCS)
    Exterior noise suppression measures 2B8 additional noise dampener
    Garage door opener VC0 without Garage door opener
    Luggage compartment trim 5A7 Comfort luggage compartment lining with service flap
    Transmission specifications G0C 5-speed manual transmission
    Brackets 3P7 Bracket for warning triangle
    handle for hand brake lever 6PC Hand brake lever handle in leather
    Rear window wiper and washer system 8M1 Rear window wiper washer system with intermittent wipe
    Grab handles at roof frame 5N6 Folding grab handles on roof frame soft fold-away
    Rear axle 0N1 Standard rear axle
    Rear seats 3NC Rear seat bench/backrest, split folding
    Heating and air-conditioning system 9AK Climatronic with impact pressure control, CFC-free
    Headlamps 8JT Twin headlight for driving on the right with clear lens (US design)
    Instrument clusters U0F Instrument cluster with tachometer, clock and mph speedometer
    Breakaway interior rearview mirror 4L6 Breakaway interior rearview mirror, auto-dimming
    Sticker (customized or special edition) 0KA Without decals and emblems
    Body style K8G Hatchback
    Luggage compartment floor covering 6SC Luggage compartment floor covering in needle-punched nonwoven
    Cassette and CD storage unit 4W0 without cassette / CD tray
    Electronic map cooling system QS0 Without electronic map cooling system
    Child seats QA0 without child seat
    Rear head restraints 3Q6 Three rear head restraints
    Head restraints 5ZH Head restraints for front seats, tilt- and height-adjustable with integrated adjustment mechanism
    Fuel tank treatment 2LC Fuel tank with special material treatment (coextrusion)
    Fuel quantity for initial filling 1Z2 Increase in initial standard fuel filling
    Fuel systems 0F2 Fuel system for fuel-injected SI engine
    Body measures 5C1 Body measures for increased safety requirements
    Radiator grille 6KG Radiator grille
    Rear license plate carrier 6P2 Rear license plate carrier (NAR)
    Front license plate carrier 6W3 Front license plate carrier (small, NAR)
    Paint preservative/transit coating 5K5 Transportation protective film (instead of paint preservation)
    Paint coating FB0 standard paint coating
    Rear cargo area 3GA Without luggage compartment floor
    Steering system arrangement L0L Left-hand drive
    Reading lamp 8S2 One reading light in front, two reading lights in rear
    steering 1N9 Power steering (limited steering lift mechanism)
    Backrest release 3H9 Backrest release for front seats with Easy Entry feature
    Air duct, front area VK0 Air duct, standard
    Load edge protection 2P0 Without loading edge protection
    Lumbar support 7P4 Manually adjustable lumbar support in front seats
    steering wheels 2ZB Leather-wrapped multi-function steering wheel
    Speaker installation 9VG "Monsoon sound system" (NAR)
    Steering column systems 2C5 Axial and vertical adjustable steering column
    Headlight range control 8Q0 without beam length regulator
    Center armrest 6E3 Center armrest in front
    Multi-function display/trip computer 9Q1 Multi-function display/trip computer
    Engine cooling 8Z7 Engine cooling, version 3
    Engine specifications M6A 6-cylinder SI engine 2.8 l/130 kW (VR6) with MPI base engine is T2R
    Engine compartment lighting 9L0 without engine compartment lighting
    Left vanity mirror 4SQ Left vanity mirror illuminated with cover and special mirror imprint (NAR)
    Right vanity mirror 4TQ Vanity mirror, right, illuminated, with cover and special mirror imprint (NAR)
    Navigation device 7Q0 without navigation system
    rear fog lamp 8TA witout rear fog lamp
    Front fog lamp/additional headlamp 8WD Integrated front fog lamps
    Rear of platform module base 4P0 Rear floor panel module, type 1
    Platform group class 7PA Platform group class 1
    Hubcaps 1NL Trims for alloy wheels
    Wheels C3K Cast alloy wheels 6.5J x 16 BBS, one-piece, offset 42
    Radios 8YT Radio "Premium"
    Smoker's/non-smoker's package 9JA Non smoker version
    tire H4B All-season tires 205/55 R16 H (NAR)
    Tire suppliers V0A Tires without specification of tire brand
    Spare wheel/breakdown kit 1G2 Steel spare wheel with original equipment tire
    Restraint systems, front 4QQ 3-point seat belts in front with pretensioner and height adjustment, US label
    PMC California Emissions Package
    Side airbag 4X3 Side airbag in front, with curtain airbag
    Gearshift knob/handle 6Q3 Gearshift knob/handle in wood
    Special labels/plates 0SC Labels in English
    Tail lamp assemblies 8SB Rear combination lamp with darkened lens
    Locking mechanism for boot lid/cover rear 4E2 Tailgate/trunk lid release from inside (electrically)
    Nameplate for sales name QD0 Without nameplate for sales name
    Seat belt check 9P7 Visual and acoustic seat belt reminder, electric contact in buckle
    Outer rear seat belts 3ZM 3-point seat belts, outer rear
    Center rear seat belts 3C8 3-point seat belt, center rear with US label
    Gearshift boot/cover 6R2 Gearshift boot in leather
    seat covers N7D Seat trim covers in part leather
    Seat adjustment 3L3 Manual height adjustment for front seats
    seat heater 4A3 seat heating for front seats separat controlable
    Side lights 7R4 Side marker lamps and turn signal repeaters (turn signals with white lens)
    Horns 8Y1 Two-tone horn
    Control number (no PR family) S50 Control of logistics 1
    Control number (no PR family) S51 Control of logistics 2
    Side and rear windows 4KC Side and rear windows in heat-insulating glass
    Protective side molding 4B2 Body-colored protective side molding
    Sunroof roller blind for rear/side windows 3Y0 without roller blind
    Supertone system and tone sequence control 9J0 Without supertone system and tone sequence control
    power outlet 7B2 12 volt socket in luggage compartment
    Bumper 2JC Comfort bumpers
    Rear stabilizer bar 0BB Rear stabilizer bar
    Front stabilizer bar 0AE Front stabilizer bar
    Heavy-duty/sports version 2UA Without bad road/sports version
    Headlamp washer system 8X0 Without headlamp washer system
    Windshield wiper intermittent control/ light/rain sensor 8N3 intermittent windscreen wiper with rain sensor
    Special approval measures 3M0 Without special measures
    Nameplate set 1RV Nameplate set "GTI VR6" (without model designation)
    Special alarm systems 9A0 Without taxi alarm system
    Door storage compartments in front 3YR Door pockets with insert mats
    Fuel filler cap/door, locking option 2W2 Fuel filler cap, attached (NAR)
    Mass damper for steering wheels 1Q0 steering wheel without balance weight
    Door and lid locking system 4K0 Central locking w/ radio remote control and interior controls
    Type approval countries/countries with special requirements B38 Legal requirements for California
    Carrier frequency for remote control 5D2 Carrier frequency 315 MHz
    Partition 3CA without partition
    Door and side trim panels 3LJ Door and side trim panel in foam film, insert in leatherette
    doors 0A1 2 doors
    TV reception/digital radio reception QV0 Without TV reception/digital radio reception
    Speedometer cable and seal 8CC Speedometer sensor without seal (electronic speedometer sensor)
    Identification plates 1EB without identification plate
    First aid kit / warning triangle 1T0 Without first aid kit and warning triangle
    Two-way radio installation preparation 9D0 without prepared for two way radio system
    Front seats Q4H Sports comfort seats in front
    Rear seat catch 6QA Rear seat catch
    Preparation for rotating beacon/siren combination 9F0 Without preparation for rotating beacon/siren combination
    Telephone / telematics 9W0 Without car phone preparation/ installation
    Additional warning lights 9TB Additional warning lights (door area)
    LongLife Service Regime QG0 without service interval extension
    Heat accumulator system/auxiliary heater 7E2 Heated crankcase ventilation system
    Windshield Glass 4GC Windshield in heat-insulating glass with sunshield
    Washer fluid level indicator 8W1 Washer fluid level indicator
    Additional tires (snow tires) 2WA without spare tyre
    floor mats 0TD Front and rear floor mats
    Additional body panels, side 6EJ Additional body cover on sill without wheel arch
    Additional child seat anchors 3B1 Child seat anchors acc. to Canadian requirements
    Zündanlaß/Schloß-Sperrsystem/ Elektrische Lenksäulenverriegelung 0RB Ignition/starter switch locking system
    Additional tunnel cover 4J1 Floor tray, extension center console
    Additional dust seals 6U0 Without additional seals outside
    Auxiliary heating system 9M0 Without auxiliary heater/parking heater
  9. Likes Eric liked this post
  10. #18
    WURTH THE GOOD STUFF FROM 25 YEARS AGO COCKPIT CLEANER POLISHED THE OPTICS!
    WHERE IS MY GERMAN CHOCOLATE WTF!? BRAND NEW ECU......HMMMM NEED ANOTHER OXS! MAF CHECK!
    THIS KEY CASE IS BEAT ILL SEE IF I CAN MAKE SOMETHING HAPPEN NOT EVEN GENERATION CORRECT.
    STAND BY! STILL COMPILING BLITZ PACKAGE!
    2 ROUGE KEYS!
    FORENSICS IN BELOW!
    Control Module Part Number: 021 906 018 R
      Component and/or Version:  MOTRONIC ME7.1 G   0003 <<<<<<<<<<<< INDEED FOD FUCKAROO
               Software Coding: 00031
                Work Shop Code: WSC 24576
    7 Faults Found:
    16804 - Catalyst System; Bank 1: Efficiency Below Threshold
            P0420 - 35-10 -  -  - Intermittent
    16507 - Throttle Position Sensor (G69): Signal too High
            P0123 - 35-00 -  -
    16606 - Angle Sensor 2 for Throttle (G188): Signal Too Low
            P0222 - 35-00 -  -
    16497 - Intake Air Temp. Sensor (G42): Signal too High
            P0113 - 35-00 -  -
    16502 - Engine Coolant Temp. Sensor (G62): Signal too High
            P0118 - 35-00 -  -
    18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
            P1650 - 35-10 -  -  - Intermittent
    18044 - Powertrain Data Bus: Missing Message from Airbag Controller
            P1636 - 35-00 -  -
    Readiness Status: 0000 0000
    Exhaust Gas Recirculation: Passed
    Oxygen Sensor Heating: Passed
    Oxygen Sensor(s): Passed
    Air Conditioning: Passed
    Seconday Air Injection: Passed
    Evaporative Emissions: Passed
    Catalyst Heating: Passed
    Catalytic Converter(s): Passed
                    Address 01: Engine  (021 906 018 R)
    16:58:15 Group 060: Electronic Throttle (Throttle Body Adaptation)
      99.6 %  Throttle Valve Sensor 1 (G187)
      0.0 %  Throttle Valve Sensor 2 (G188)
      1  Throttle Adaptation Steps Counter
      ERROR   Result Throttle Valve Adp.
    16:58:47 Group 125
      ABS 1
      Instruments 1
                Bin. Bits
    Adaptation Channel 091:
    Stored value 4
    Control Module Part Number: 1J0 920 925 D
      Component and/or Version: A4-KOMBIINSTR. VDO V09
               Software Coding: 07232
                Work Shop Code: WSC 00001
               Additional Info: IMMO-IDENTNR: VWZ7Z0Y2950297
    6 Faults Found:
    00771 - Fuel Level Sensor (G)
            30-00 - Open or Short to Plus
    01312 - Powertrain Data Bus
            49-00 - No Communications
    17:02:02
       1   Engine Start permitted
       0   Engine (ECU) responds <<<<<<<<<<<<<<<<<<<< FOD FUCKAROO!
       1   Key Status
       3   Number of adapted Keys
       1   Variable Code authorized
       0   Key Status (Transponder)
       1   Fixed Code authorized
      N/A   Immobilizer Status
      N/A   Lock-Time Instrument Cluster
  11. Likes Uwe liked this post
  12. #19
    Feb 2015
    You are so awesome. Let me know what cost is for another key and ill cover it for my son. I'll send check out right away. Let me know what additional cost you have incurred and I'll cover it.
    Break,break..
    I assume the one we sent was toast?
    Over....
  13. #20
    Feb 2015
    Video reminds me of time in Okinawa, Japan. Although it was too small of an island to go that fast. It would take the length of the video to get from north to south supposing you had minimal traffic.
    We will replace OSB and I'll look at MAF.
    Over....
