VW Golf 7 Module A5 for Front Camera
Kor
Belgium
C?ID=273921
I'm trying to activate the traffic sign assist and lane assist but I can't find module A5. The car is equipped with a front camera for the high beam assistant (not the dynamic version) and this works fine. Isn't this the same camera that should direct the traffic sign assist? As you can see in the auto-scan, there is no address A5. Does this mean the high beam assistant depends on a different module and traffic sign assist can't be activated?
Thanks in advance.
Saturday,28,December,2019,13:46:14:07904
VIN: WVWZZZAUZKP581957   License Plate:
Mileage: 6801km-4225mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 20 2B 3C 42 44 52 5F 69 80
VIN: WVWZZZAUZKP581957   Mileage: 6801km-4225miles
80-Batt. reg. aux. accum. -- Status: OK 0000
Address 01: Engine (J623-DACA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 05E 906 018 AK    HW: 05E 907 309
   Component: R4 1.5l TFS   H22 6323
   Revision: 81H22000
   Coding: 0125003224741D0870000200000000000000000000000000
   Shop #: WSC 00028 028 00073
   ASAM Dataset: EV_ECM15TFS01105E906018AK 003003
   ROD: EV_ECM15TFS01105E906018AK.rod
   VCID: 6E85CEF42016EB772BB-803A
   Radiator shutter:
   Subsystem 1 - Part No SW: 95B 965 501 S    HW: 95B 965 501 S
   Component: V544KJS1  H12 0109
   Serial number: 20190210020104056891
33708 - Coolant Pump 2
          P2B63 00 [032] - Stuck
   Part No SW: 0CW 300 043 C    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1602
   Revision: 00005008    Serial number: CU501905068878
   Shop #: WSC 00028 028 00069
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 372B2B901FCC6ABF38D-8062
   Part No SW: 5Q0 614 517 EF    HW: 5Q0 614 517 BP
   Component: ESC           H35 0107
   Revision: 00000000    Serial number: 61369000001071
   Coding: 04FA6AA12028216D4780060560CA2920560484E26006947338225078D2824B0B0000000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 79AFEDA86958BCCF8E9-802C
8400 - Databus
          [FCAN: AB_Gurt_FA signal is invalid]
                    Reset counter: 98
                    Mileage: 2486 km
                    Date: 2019.08.05
                    Time: 16:47:14
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0515928193
   Coding: 132C0C0723
   VCID: 43D34F405B14361F945-8016
   Part No SW: 5G0 907 044 CE    HW: 5G0 907 044 CE
   Revision: 00001K08
   Coding: 02020024200110011005000000101022
   VCID: 6C81C4FC160A196705F-8038
   Part No SW: 5Q0 937 086 BP    HW: 5Q0 937 086 BP
   Component: BCM PQ37BOSCH 036 0265
   Revision: --------    Serial number: 8658050519015P
   ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 094F9D6839B8AC4F9E9-805C
   Component: WWS    190419  043 0551
   Serial number:         190425194206
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  051 0205
   Serial number: S5Y19M05D17H14M09S28
   Coding: 0008DD
   Sun Roof:
   Subsystem 3 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS22.409  H04 0005
   Serial number: 0000FST002BTKA000000
   Coding: 191800
   Roof Blind:
   Subsystem 4 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS22.409  H04 0005
   Serial number: 0000FST002BTJYN00000
   Coding: 191800
   Steering Column Switch:
   Subsystem 6 - Part No SW: 5Q1 953 521 M    HW: 5Q1 953 569
   Component: Lenks.Modul  H03 0170
   Serial number: 0100150520190C203114
203016 - Unlock Switch in Rear Lid Handle
          B140B 29 [008] - Signal Implausible
                    Reset counter: 106
                    Mileage: 4890 km
                    Date: 2019.10.15
                    Time: 14:35:53
   Serial number: 000308418019120
   Coding: 0471155911
   VCID: 4CC1647C764AF96765F-8018
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0682
   Coding: 3300670951FFC728949C834580400600000000000000000004
   ASAM Dataset: EV_ACCBOSCHVW416 002008
   VCID: 44D14C5C5E1A3127ADF-8010
0836 - Databus
          [FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
                    Fault Frequency: 145
                    Reset counter: 104
                    Mileage: 4725 km
                    Date: 2019.09.20
                    Time: 07:01:34
                    Control Module temperature: 23 °C
                    Voltage terminal 15: 11.5 V
                    Status_ACC_System: ACC_Init
   Part No SW: 5Q0 959 655 BS    HW: 5Q0 959 655 BS
   Component: AirbagVW21    007 0403
   Serial number: 003FMR5ABNL8
   Coding: 98CCC000000000005C0000CF000800000065
   Shop #: WSC 00028 028 00062
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 127DBA0454EE6F976F3-8046
   Subsystem 1 - Part No SW: -----------    HW: 480 001 405 19
   Serial number: 35700000000FF2403C3Q
   Subsystem 2 - Part No SW: -----------    HW: 480 001 405 19
   Serial number: 3580000000051A613C3E
   Subsystem 3 - Part No SW: -----------    HW: 480 401 705 19
   Component: SideSensor_Dr  005 6149
   Serial number: 3510001C2F001354945R
   Subsystem 4 - Part No SW: -----------    HW: 480 401 705 19
   Component: SideSensor_Pr  005 6149
   Serial number: 3520001BCEFE7863F9A6
   Subsystem 5 - Part No SW: -----------    HW: 480 401 105 19
   Component: FrontSensor_D  005 6149
   Serial number: 3550001B6F029AA7E74N
   Part No SW: 5G1 920 740 D    HW: 5G1 920 740 D
   Component: KOMBI         211 2700
   Coding: 05A521182788000801887E095401000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009068
   VCID: 270BFBD0CF6CFA3FA8D-8072
   Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5366
   Serial number: 09051910520245
   Coding: 030100347F085702FB0802481C0F00000001070000000000000000000000
   ROD: EV_GatewNF.rod
   Component: 1-00-02-00-04
   Subsystem 2 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H18 0052
   Serial number: 39190000994060039155
   Coding: 2CFFFF
   Serial number: 6198501305
Address 20: High Beam Assist. (J844)       Labels:| 8S0-857-511.clb
   Part No SW: 3G0 857 511 BE    HW: 3G0 857 511 BE
   Component: FLA           H01 0010
   Revision: AA001001
   Coding: 0101000000000000000000
   ASAM Dataset: EV_HighBeamAssisAU33X 001019
   ROD: EV_HighBeamAssisAU33X_VW37.rod
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000136569001
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 313F1588F1A8B48F769-8064
   Component: HRE_Master    H12 0081
   Serial number: 0514888812
   Coding: 02012103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D2739B83DF040EFE21-8068
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0081
   Serial number: 0515707090
   Coding: 020121
   Part No SW: 5Q4 959 593 F    HW: 5Q4 959 593 F
   Component: TSG FS        006 0246
   Serial number: 0000375546764
   Coding: 00351320D000040000001000
   VCID: 48C9586C62321547417-801C
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000012270742
Address 44: Steering Assist (J500)       Labels:| 5Q0-910-143.clb
   Part No SW: 5Q0 910 143 C    HW: 5Q0 910 143
   Component: MQB_VWBS_GEN2 212 2211
   Serial number: 953009 00
   Coding: 0100001000400010
   ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
   ROD: EV_SteerAssisVWBSMQBGen2_VW37.rod
   VCID: 2B0307E0D384DE5F4C5-807E
   Part No SW: 5Q4 959 592 F    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0246
   Serial number: 0000376200098
   Coding: 00351120DE00040000001000
   VCID: 47CB5B506F2C1A3F48D-8012
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000012273803
   Coding: 090000
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    853 0891
   Coding: 02731201FF0000004111010100880A001F0004D401200100CE
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 323D1A84F4AE8F970F3-8066
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZHW1373550
   Subsystem 2 - Part No SW: 5NA 919 866     HW: -----------
   Component: ECE1 2018/19  --- 1030
6720 - Rear View Camera
          B1102 31 [008] - No Signal
                    Reset counter: 124
                    Mileage: 2553 km
                    Date: 2019.08.08
                    Time: 10:21:25
                    Voltage terminal 30: 14.4 V
   Part No SW: 5Q0 907 383 M    HW: 5Q0 907 383 M
   Component: Anhaenger     H27 0260
   Revision: 8B001004    Serial number: 0516329077
   Coding: 0100000202000000
   VCID: 41DF45484108240F869-8014
Address 80: Batt. reg. aux. accum. (A8)       Labels: None
   Part No SW: 5Q0 915 089     HW: 5Q0 915 089
   Component: FMA H46 1074
   Serial number: 770252-00021
   Coding: 2F968A00
   ASAM Dataset: EV_FMACATLVW37X 003010
   ROD: EV_FMACATLVW37X_003.rod
   VCID: 76B5E6945846D3B7E3B-8022
End----(Elapsed Time: 01:49, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
siLc
Tallinn, Estonia
C?ID=330192
With module 20 HBA, you can't activate these features. Its logical you can't find module A5 as your vehicle does not have it.
If you want these features, you'll have to buy the A5 module 3Q0980654 with appropriate suffix and have the appropriate windscreen installed for mounting for the A5 camera. That's just the start...
Kor
Belgium
C?ID=273921
Thank you for the quick response. So the camera that is installed in the car, isn't the A5 camera? Or is it the correct camera but the A5 module just has to be installed?
HBA at address 20 is not a "Camera" per se.
MasterTommy
Amsterdam
C?ID=295586
The one you currently have is a sensor in your rear view mirror that points forward (driving direction). Module A5 is a full sized camera that is mounted against the windshield, and is clearly visible from outside.
What you have right now:
What you need for everything else and dont have right now (The camera is in the triangle shaped opening in the top-center of the windscreen):
