Project retrofit from MK100 5Q0 ABS to newer MK100 3Q0 ABS
   #21
Sebstar
C?ID=314247
Can you please post an autoscan from the current situation. New ABS etc. I’ll check the codings then to see if there’s an issue.
Monday,30,December,2019,19:09:07:27865
VIN:   License Plate: MY
Mileage:    Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 13 15 16 17 19 3C 42 44 52 55 5F 6C A5 BB BC
          CF
VIN:
   Revision: 00000000    Serial number: 63565000002775
   Coding: 12F162A224260A74037C060441CC2948462450C0608294F71841507886C8
   ROD: EV_Brake1UDSContiMK100IPB_034_AU37.rod
   VCID: 7AAC036E1C599447873-802E
No fault code End----(Elapsed Time: 01:37, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
VW
downtime
C?ID=280813
Change ABS coding to :
12F162A224260A74037C060441CC2948462450C0608294F71841507886E8
byte 29 bit 5 is AWV.
Have you modified the ABS code yourself? You have byte29 bit 6 enabled which I've not seen enabled in any of the codings so far. Maybe an error?
   #23
Sebstar
C?ID=314247
Coding is done. No Fault. looks good.
Tomorrow i test it and give an info.
AnhalteWegVerkürzung in german it make sence for me :p
   #26
Sebstar
C?ID=314247
The change in ABS was done during remote session of Activated the ACC
   #28
Sebstar
C?ID=314247
Today i tested the shock/spot brake function if no reaction in Lane Assist mode. That works great.
But about ABS prefill during AWV PreSense for to close distance, i don't can tell something. I had only one situation with PreSense warning but there was no prefill in ABS, Brake Pedal had normal force.
Maybee there are now different steps of warning an prefill?
Because with the old acc sensor and PreSense warning, i had on every warning an prefill.
Happy new Year
   #29
downtime
C?ID=280813
The AWV is a last mean security function and it is not very easy to test it safely. The audible warning is quite easy to trigger.
I’ve had one situation where the the warning came on and the brakes were clearly pre filled as the braking was really efficient.
   #30
Sebstar
C?ID=314247
Ok and you have also Facelift acc Sensor and the Same abs like mine?
Than it changed to the FL.
   #31
downtime
C?ID=280813
I have the same ABS but the old round faced radar.
   #32
Sebstar
C?ID=314247
Ok if you have That Same ABS and coding. Than i am sure That awv work in Situation.
   #33
downtime
C?ID=280813
Only difference in coding is the byte 29 bit 6 is enabled in your coding and disabled in mine. It’s labeled in the unofficial label file as ESP36. I have no idea what it means.
   #34
Sebstar
C?ID=314247
I turnt Bit 6 now off.
I try the next time with A8 in Byte 29. For now it work.
Is These Label file for Vcds? Can i use These dicekt during coding? And how to get it?
downtime
C?ID=280813
Google for : ABS_3Q0-907-379-AB--IPB-beta_v1.1.lbl
And reminder, this is unofficial label file. It will help you on few of the last bytes but everything else is more or less useless.
