Results 21 to 30 of 35
Thread: Project retrofit from MK100 5Q0 ABS to newer MK100 3Q0 ABS
  1. #21
    Dec 2019
    de
    Can you please post an autoscan from the current situation. New ABS etc. I’ll check the codings then to see if there’s an issue.
    Monday,30,December,2019,19:09:07:27865
    VIN:   License Plate: MY
    Mileage:    Repair Order:
    Chassis Type: 8V-AU37 (5Q0)
    Scan: 01 02 03 08 09 13 15 16 17 19 3C 42 44 52 55 5F 6C A5 BB BC
              CF
    VIN:
       Revision: 00000000    Serial number: 63565000002775
       Coding: 12F162A224260A74037C060441CC2948462450C0608294F71841507886C8
       VCID: 7AAC036E1C599447873-802E
    No fault code End----(Elapsed Time: 01:37, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
    VW
  2. #22
    May 2017
    Change ABS coding to :
    12F162A224260A74037C060441CC2948462450C0608294F71841507886E8
    byte 29 bit 5 is AWV.
    Have you modified the ABS code yourself? You have byte29 bit 6 enabled which I've not seen enabled in any of the codings so far. Maybe an error?
  3. Likes Sebstar liked this post
  4. #23
    What is "AWV"? Seems to be a candidate for our acronym decoder.
  5. #24
    May 2017
    From your own acronym section : AWV Stopping Distance Shortening / Anhaltewegverkürzung
    http://wiki.ross-tech.com/wiki/index...ommon_Acronyms
  6. Likes Uwe liked this post
  7. #25
    Dec 2019
    de
    Coding is done. No Fault. looks good.
    Tomorrow i test it and give an info.
    AnhalteWegVerkürzung in german it make sence for me
  8. Likes downtime liked this post
  9. #26
    Dec 2019
    de
    The change in ABS was done during remote session of Activated the ACC
  10. #27
    Haha! I had forgotten about that page. Meanwhile, I've added it to the forum's decoder.
  11. Likes downtime liked this post
  12. #28
    Dec 2019
    de
    Today i tested the shock/spot brake function if no reaction in Lane Assist mode. That works great.
    But about ABS prefill during AWV PreSense for to close distance, i don't can tell something. I had only one situation with PreSense warning but there was no prefill in ABS, Brake Pedal had normal force.
    Maybee there are now different steps of warning an prefill?
    Because with the old acc sensor and PreSense warning, i had on every warning an prefill.
    Happy new Year
  13. #29
    May 2017
    The AWV is a last mean security function and it is not very easy to test it safely. The audible warning is quite easy to trigger.
    I’ve had one situation where the the warning came on and the brakes were clearly pre filled as the braking was really efficient.
  14. Likes Sebstar liked this post
  15. #30
    Dec 2019
    de
    Ok and you have also Facelift acc Sensor and the Same abs like mine?
    Than it changed to the FL.
