Results 11 to 20 of 35
Thread: Project retrofit from MK100 5Q0 ABS to newer MK100 3Q0 ABS
    Dec 2019
    de
    yes, the tire speed standard stuff.
    not the preassure system.
    I wondering that these ist two times there and "display". it looks like that the ABS search the rest of preassure measure system. hmm I hope tomorrow have some DIY shops open that I can change it finally and change the fluid.
    Oh, you know how to do the change of fluid. I know that I have to start in the front. And for the first time, both sides oben in the front after that both sides in the rear. Also is an option in the Vcds software to change fluid. I should do this or is that not needed per software
  2. #12
    May 2017
    I did it both ways. First started with VCDS to fill the pump. After doing it few times, I finished with the normal brake pedal pumping method
    If I remember it correctly the bleeding sequence was passenger front, driver rear, driver front and passenger rear.
  3. Likes Sebstar liked this post
  4. #13
    Dec 2019
    de
    ok, i let you know. but good to know that you start first with Vcds.
  5. #14
    Dec 2019
    de
    Hii,
    Job done. The new ABS is installed. Everything works perfect. Coding is 1to1 the same.
    Fluid change was really easy and with no trouble. I started in the Front with both sides parallel then to the rear and also both parallel.
    Than go back to the Front and again both parallel und to the rear and both parallel.
    Thanks for support.
    And the Main reason to do this is that now Stop & Go work with the FL ACC Sensor.
    Next step is to get run all the PreSense or AWV (I don't know it in English) features.
    Anybody an idea?
  6. Likes downtime liked this post
  7. #15
    May 2017
    Quote Originally Posted by Sebstar View Post
    Anybody an idea?
    What do you mean by this? You have front camera yes?
  8. #16
    Dec 2019
    de
    it ist called front assist.
    the acc sensor detect an car much slower the you. then you got an message in the cluster attention. the abs profile the brake for much harder brake than normal and short bevor it crashes the brake come in automaticly.
    Or. if you have an active lane assist and don't react on the steering wheel, you get the warning in cluster with an beep, than an short brake shock and than an emergency brake. the emergency brake work but the short brake shock not,
  9. #17
    May 2017
    Yes, I know what AWV is
    My question was do you have the windscreen front assist camera? That is required for AWV full functions. Without it you only get the warning.
    And is your ACC factory or retrofitted?
  10. Likes Sebstar liked this post
  11. #18
    Dec 2019
    de
    both retrofitted
  12. #19
    May 2017
    Can you please post an autoscan from the current situation. New ABS etc. I’ll check the codings then to see if there’s an issue.
  13. #20
    Dec 2019
    de
    ok 5 minutes
