Results 1 to 6 of 6
Thread: HELP! Recalibrate Ride Height sensors in 2017 SQ5 (FY) / 2017 S5 (B9)
    Jun 2019
    Australia
    Hi Guys,
    I have the above 2 cars, both of which had suspension repairs done after accidents (by previous owners!).
    Both give errors for the ride height sensors being out of the allowable tolerance.
    It is only a small amount like 15mm, but enough to make the car beep after a few minutes of driving each time.
    I have searched and searched on the forums and internet in general and cannot find anything much on re-calibration of these.
    My cars DO NOT have air suspension, but using the guides for air suspension as a base, I still can't make progress after fiddling for hours.
    I think the problem may be I need a securing code for module 74: Chassis control before it will allow me to delete calibration and start the process. Try as I might to find the security code online I cannot find it either.
    I have tried a bunch of different security codes without success.
    Can anyone shed any light on this?
    I think the calibration procedure will be similar to the below -
    https://forums.ross-tech.com/showthr...fault-position
    I also have access to ODIS, but this wasn't any more useful than the VCDS for what I was trying to do.
    Thanks in advance.
    Without an Auto-Scan of both vehicles it will be difficult to offer suggestions
  3. Likes Uwe liked this post
    Jun 2019
    Australia
    Autoscan for the SQ5
    Here is the autoscan for the SQ5. Let me know if you can help further.
    Chassis Type: FY-AU49 (4M2)
    Scan: 01 02 03 08 09 13 15 16 17 19 29 36 39 3C 42 44 46 47 52 5F
              6C 6D 74 81 82 8B A5 A9 BB BC CA CF D6 D7
    VIN: WAUZZZFY8H2031590   Mileage: 23266km-14456miles
    74-Chassis Control -- Status: Malfunction 0010
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-CWGD)       Labels: Redir Fail!
       Part No SW: 80A 907 559 B    HW: 06M 907 309 D
       Component: 3.0l V6 TFSI  H21 0003
       Revision: B2H21000
       Coding: 2A2A00322566050B34380000000000000000000000000000
       ASAM Dataset: EV_ECM30TFS01180A907559B 001003
       ROD: EV_ECM30TFS01180A907559B.rod
       VCID: 2E050ECBA0907D176BB-807A
    Address 02: Auto Trans (J217)       Labels:* None
       Part No SW: 80A 927 158     HW: 0D5 927 156 H
       Component: 0D5  30TSIRdW H05 1002
       Revision: --H05---
       Coding: 100000
       ASAM Dataset: EV_TCMALX52011 002010
       ROD: EV_TCMALX52011.rod
       VCID: 698FBDD759FEDA2F7E9-803C
    Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PRE-V1.clb
       Part No SW: 80A 907 379 F    HW: 80A 907 379 A
       Component: ESP9 Premium  H09 0657
       Coding: 1CAA14BE30A50A9791A3589A087D52A2E6A5DA38280C50891A104A4567A55B
       ASAM Dataset: EV_ESP9BOSCHAU426K 011013
       ROD: EV_ESP9BOSCHAU426K.rod
       VCID: 323D1ABBB4A859F70F3-8066
       Part No SW: 80A 820 043 G    HW: 80A 820 043 G
       Component: Klima Zone 3  H32 0090
       Coding: 6608098C5544050D10000100080000000000000000000000000000000000
       ROD: EV_AirCondiBHTCAU491.rod
       VCID: 211FE5F7E14ED26FE69-8074
       Subsystem 1 - Part No SW: 4M1 820 021 A    HW: 4M1 820 021 A
       Component: J216 FLuftV  H08 0003
       Serial number: 00000000000001288422
       Serial number: 47898A8880PAG0MUFU02
       Subsystem 3 - Part No SW: 80A 919 158     HW: 80A 919 158
       Component: E265 Kli Fond  H40 0080
       Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
       Component: BCM1 MLBevo   H13 0267
       Coding: 07501143C13900CD050D51199F2F0CF9130B31090000000000000000600016810A4502AA22B70A
       VCID: 025D8A7B44882977DF3-8056
       Subsystem 1 - Part No SW: 80C 955 119     HW: 80C 955 119
       Component: 426 RL 170202  040 0570
       Serial number: 00000001701312105735
       Coding: 5FC7F7
       Serial number: 20247025X81A955555A0
       Coding: 02006E
       Light switch:
       Subsystem 3 - Part No SW: 4M0 941 531 AB    HW: 4M0 941 531 AB
       Component: E1 - LDS  H06 0008
       Serial number: 07 04 2017  70970038
       Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
       Serial number: GX1CE120031723611804
       Coding: 230000
       Interior Light Module:
       Subsystem 5 - Part No SW: 80A 947 135 AB    HW: 80A 947 135
       Component: Dachmodul Q5  H31 0310
       Serial number: Q00000940
       Coding: 010101
       Electrically Adjustable Steering Column:
       Subsystem 6 - Part No SW: 80A 907 705     HW: 80A 907 705
       Component: J866-EVLS-SG  H03 0080
       Serial number: WA125812000027109744
       Coding: 0A0700
       Subsystem 7 - Part No SW: 8W0 925 301 BG    HW: 8W0 925 301 BG
       Component: SL-B9/Q5NF  H17 0010
       Serial number: 2617000058352002
    262165 - Lamp 1 for Contour Lighting of Dashboard
              U117E 00 [009] - No Communications
              [Instrument panel contour illumination lamp 1: No communication]
                        Reset counter: 162
                        Mileage: 23147 km
                        Date: 2019.12.27
                        Time: 14:58:43
                        average_Voltage_terminals: 11.90 V
                        Outside air temperature sensor-Resistance: 0.00 kOhm
                        Outside air temperature sensor-Outside air temperature on CAN: 26.50 °C
                        interior_temperature: 27.50 °C
                        Vehicle speed: 0.00 km/h
    262167 - Lamp 2 for Contour Lighting of Dashboard
              U1180 00 [009] - No Communications
              [Instrument panel contour illumination lamp 2: No communication]
                        Reset counter: 162
                        Mileage: 23147 km
                        Date: 2019.12.27
                        Time: 14:58:43
    262169 - Lamp 3 for Contour Lighting of Dashboard
              U1182 00 [009] - No Communications
                        Reset counter: 162
                        Mileage: 23147 km
                        Date: 2019.12.27
                        Time: 14:58:43
       Part No SW: 80A 907 561     HW: 8W0 907 561
       Component: LRR4          H10 0220
       Coding: 3464E75358FFEC06747860A4
       ASAM Dataset: EV_ACCBOSCHAU49X 002018
       ROD: EV_ACCBOSCHAU49X_002.rod
       VCID: 6597B1E7B5E6FE4F5A1-8030
    Address 15: Airbags (J234)       Labels:| 80A-959-655.clb
       Part No SW: 80A 959 655 N    HW: 80A 959 655 N
       Component: AirbagVW30    031 0513
       Serial number: 003WBM00ZFA%
       Coding: AAFCF0C00C8000009854003FF08C40000065
       ASAM Dataset: EV_AirbaVW31SMEAU65x 001006
       ROD: EV_AirbaVW31SMEAU65x_AU49.rod
       VCID: 3E253E8B70F08D97FBB-806A
       Belt Pretensioner left:
       Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
       Component: BeltPretRevFL  205 2033
       Serial number: 80A857705A0111R01502
       Coding: 88001B
       Belt Pretensioner right:
       Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
       Component: BeltPretRevFR  205 2033
       Serial number: 80A857706A0111R00813
       Coding: 88001B
       Subsystem 3 - Part No SW: -----------    HW: 480 000 802 17
       Serial number: 357000000007B5F4212J
       Subsystem 4 - Part No SW: -----------    HW: 480 000 802 17
       Serial number: 3580000000003D8DF02R
       Subsystem 5 - Part No SW: -----------    HW: 480 030 501 17
       Component: SideSensor_Dr  002 0149
       Serial number: 351000C1C8BAF9A148D.
       Subsystem 6 - Part No SW: -----------    HW: 480 030 602 17
       Component: SideSensor_Pr  002 0149
       Serial number: 352000C1CBCD79710FD.
       Subsystem 7 - Part No SW: -----------    HW: 480 030 602 17
       Component: FrontSensor_D  002 0149
       Serial number: 355000C1CBC97850F9A
       Front Sensor Passenger:
       Subsystem 8 - Part No SW: -----------    HW: 480 030 602 17
       Component: FrontSensor_P  002 0149
       Serial number: 356000C1CBC9B2808A1P
       Pedestrian Protection Center:
       Subsystem 9 - Part No SW: -----------    HW: 480 030 403 17
       Component: PedP_Sensor_C  002 0149
       Serial number: 230000C206A2DAE0DDAO
       Subsystem 10 - Part No SW: -----------    HW: 480 000 302 17
       Serial number: I0M0000000094D0DAF9R
       Subsystem 11 - Part No SW: -----------    HW: 480 000 302 17
       Serial number: I0N00000000A4569EE9Q
       Central Sensor XY:
       Subsystem 12 - Part No SW: -----------    HW: 480 020 802 17
       Component: CentrSensorXY  000 0108
       Serial number: I0O0001C12465B54669S
    9634901 - Control Module for Front Left Belt Tensioner
              B1304 55 [009] - Not configured
                        Mileage: 23147 km
                        Time: 00:00:00
    9635157 - Control Module for Front Right Belt Tensioner
              B1305 55 [009] - Not configured
                        Mileage: 23147 km
                        Time: 00:00:00
       Part No SW: 80A 907 129 AD    HW: 80A 907 129 AD
       Component: Lenks.Modul   H02 0003
       ROD: EV_SMLSKLOAU736_007_AU49.rod
       VCID: 6A8DC2DB5CF8D137773-803E
    Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
       Part No SW: 8W5 920 790 C    HW: 8W5 920 790 C
       Component: FBenRDW       H17 0309
       Coding: 248D96C43C98000801A3E9601000000000000000
       ASAM Dataset: EV_DashBoardAU736 001022
       VCID: 42DD4A7B0408E9779F3-8016
       Part No SW: 4M2 907 468 D    HW: 4M2 907 468 A
       Component: Gateway       H16 0107
       Revision: 4W010003    Serial number: 03G4W006817104
       Coding: 03010001000086405407000000590032FC920007100000000100000000000000
       ASAM Dataset: EV_GatewCONTIAU736 002040
       ROD: EV_GatewCONTIAU736_002_AU49.rod
       VCID: 392F2D9769DEAAAFCE9-806C
       Subsystem 1 - Part No SW: 4M0 951 523     HW: 4M0 951 523
       Component: J453 MFL  H06 0002
       Serial number: 20170328125738 00395
       Serial number: 7675565000
    Address 29: Left Light (J1018)       Labels: None
       Part No SW: 80A 907 397 D    HW: 80A 907 397 D
       Component: LCM_MLBevo    H06 0017
       ASAM Dataset: EV_LCMLeftCONTIAU426 001009
       ROD: EV_LCMLeftCONTIAU426_VW41.rod
       VCID: 303910B3BAA46BE7797-8064
       Part No SW: 4M1 959 760     HW: 4M1 959 760
       Component: MEM-FS        008 0031
       Serial number: 512A1470771133
       Coding: 00781B000000B0010000010101010000000000000000000000000000000000
       VCID: 76B5E6AB184005D7E3B-8022
    Address 39: Right Light (J1023)       Labels: None
       Component: LCM_MLBevo    H06 0016
       ASAM Dataset: EV_LCMRightCONTIAU426 001008
    Address 3C: Lane Change (J769)       Labels:* None
       Part No SW: 4M0 907 566 D    HW: 4M0 907 566
       Component: MRR1Rear      H18 0410
       Revision: --------
       Coding: 4E8002
       ASAM Dataset: EV_RearRadarS1BoschAU736 001022
       ROD: EV_RearRadarS1BoschAU736.rod
       VCID: 363526AB58C045D723B-8062
       Part No SW: 4M1 959 793 B    HW: 4M1 959 793 B
       Component: TSG FS006 0737
       Serial number: CLSM1QBO008AV
       Coding: 005D1B015E010480000110B0
       Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
       Component: EPS_MLBEVO1BS H20 0005
       Serial number: 0000665218
       Coding: B0112001000100
       ASAM Dataset: EV_EPSVWBSAU736 009023
       ROD: EV_EPSVWBSAU736_009.rod
       VCID: 34311CA34EBC57C71DF-8060
       Part No SW: 8W0 907 064 CP    HW: 8W0 907 064 P
       Component: BCM2 MLBevo   018 0344
       Coding: 01350000000000C0630980006E00980033004010004F02502F0000000504803F001F0001000000
       ASAM Dataset: EV_BCM2HellaAU736 012013
       ROD: EV_BCM2HellaAU736_012_AU49.rod
       VCID: 0C41A44376CC6F07A5F-8058
       Subsystem 1 - Part No SW: 3G0 962 243 B    HW: 3G0 962 243 B
       Component: GEB.F.Heckoef  H17 0904
       Serial number: 58036241
       Part No SW: 80A 035 223 A    HW: 80A 035 223
       Component: MIB2_amp_P_Q5 H03 0420
       Revision: 00000001    Serial number: AUZ8ZAGTK00C1E5
       Coding: 0194010800AFAAAFAA0000010000
       ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
       ROD: EV_AMPMst16C2Gen2ALPI.rod
       VCID: 196FCD17C91E8AAF2E9-804C
       Part No SW: 4M1 959 792 B    HW: 4M1 959 792 B
       Component: TSG BFS006 0737
       Serial number: CLSM1QD7003HU
       VCID: 3D2739877DF6968FE21-8068
    Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
       Part No SW: 8W5 035 041     HW: 8W5 035 041
       Component: MU-P-LND-RW   033 0917
       Serial number: A802D0H9180570
       Coding: 012456080000000013511102000A00102F001AE601700104DE
       VCID: 71BFD5B7712E22EF369-8024
       Subsystem 1 - Part No SW: V03 959 801 FQ    HW: -----------
       Component: ROW 2017  --- 0062
       Subsystem 2 - Part No SW: 80A 919 605     HW: 80A 919 605
       Component: AU426_DU_HIGH  H42 0008
       Serial number: AUZ8Z9HBL00VCM
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 80A 919 615     HW: 80A 919 615
       Component: ControlUnit_P  H15 0209
       Serial number: 07021700000000000194
       Component: Gracenote2  --- 4011
       Part No SW: 4M0 907 428 E    HW: 4M0 907 428
       Component: Areaview 2    H12 0315
       Serial number: C854607JG002314
       Coding: 02240601BE0FA10008404080
       ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
       ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
       Part No SW: 8W8 959 107 B    HW: 8W8 959 107
       Component: HDSG-Modul    H13 0161
       Revision: --------    Serial number: ˙˙˙˙˙˙˙˙˙˙˙˙˙˙
       Coding: 0730
       Shop #: WSC 50620 822 00000
       VCID: 48C958532234C327417-801C
    Address 74: Chassis Control (J775)       Labels:* None
       Part No SW: 80A 907 777 N    HW: 80A 907 777 D
       Component: Fahrwerk-SG   H35 1214
       Serial number: 2102170031
       Coding: 1050182A78
       ASAM Dataset: EV_ChassContrContiAU426 001003
       ROD: EV_ChassContrContiAU426.rod
       VCID: 3C21348366EC9F87D5F-8068
    32776 - Sensor for Ride-Height
              C1048 07 [008] - Mechanical Failure
                        Reset counter: 207
                        Mileage: 23151 km
                        Date: 2019.12.27
                        Time: 17:01:13
    Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
       Part No SW: 80C 713 041 K    HW: 80C 713 041 K
       Component: GSM-LL        H09 0073
       Revision: 0L0D5012    Serial number: 20170309000333
       ROD: EV_GSMWaehlZFAU736.rod
       VCID: 2615F6EB8860355793B-8072
       Part No SW: 80A 919 617 A    HW: 80A 919 617 A
       Component: HeadUpDisplay H11 1603
       Coding: 4A01C0
       ASAM Dataset: EV_HudNSEIKAU736 001015
       ROD: EV_HudNSEIKAU736.rod
       VCID: 2B0307DF9382083F4C5-807E
    Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
       Part No SW: 80A 907 541     HW: 8W0 907 541
       ASAM Dataset: EV_ACC2BOSCHAU49X 002018
       ROD: EV_ACC2BOSCHAU736_002_AU73.rod
       VCID: 6393AFFFBBD2807FB45-8036
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
       Part No SW: 80A 907 217     HW: 80A 907 217
       Component: BVS           H14 0042
       Coding: 0404020600000404024023A6CD0000FE00F0C020C280
       ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
    Address A9: Struct. Borne Sound (J869)       Labels: None
       Part No SW: 80A 907 159     HW: 4H0 907 159 A
       Serial number: 170124201106
       VCID: 6889B8D342F4E327617-803C
       Part No SW: 4M1 959 795 B    HW: 4M1 959 795 B
       Component: TSG HFS006 0737
       Serial number: CLSM1QD500BAH
       Coding: 000D190000010480000010A0
       VCID: 40D940730A04FB67897-8014
       Component: TSG HBFS006 0737
       Serial number: CLSM1QD50091B
       Component: SAD_STG_1     013 0005
       Coding: 728000042602
    Address CF: Lane Chge Asst 2 (J770)       Labels: None
       Part No SW: 4M0 907 590 D    HW: 4M0 907 590
       Revision: --------
       Coding: 4E8002
       ASAM Dataset: EV_RearRadarS2BoschAU736 001022
       ROD: EV_RearRadarS2BoschAU736.rod
       VCID: 33331FBF4BB250FF045-8066
    Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-592.clb
       Part No SW: 7PP 941 592 CB    HW: 7PP 941 592 C
       Component: LED1L         H10 2003
       VCID: 1A6DD21BCC1881B7273-804E
    Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-592.clb
       Component: LED1R         H10 2003
    I do not think that a "Mechanical Failure" type fault code can be fixed via a re-calibration of any kind.
  6. Likes PetrolDave liked this post
    Jun 2019
    Australia
    Thanks for the reply.
    I can see that the ride height does work as normal looking at the vcds measurements. I can see that the "calibrated" height is around 15mm away from the actual height.
    Therefore I think if I can re-calibrate to the actual height it will stop giving me the message.
    If I pull off the plastic that connects the sensor to the lower control arm it is easy to move it up and down and change the ride height (on the live data through VCDS) so everything electrically should be working.
    Can you offer any further assistance for security access to module 74? and do you think the bulk of the air suspension adjustment link I linked in my first post will do the job?
    Jun 2019
    Australia
    Anyone know the security code for module 74??
