Hi everyone,
I had problems with ABS esp lights flashing and beeping with my car a few months ago and when I took it to a indy repair shop they told me It was my ABS module and It had to be replaced.
I found one, used, with the same part number as the old one. "Apparently" they have coded the module correctly when they installed the new one (I wasn't the one who took the car when they replaced it) but I am still getting the ABS and Esp lights since.
I tried to do an ABS module adaptation but I am stuck on the "Basic Setting for Hydraulic Unit Intake Valves"
Here's a copy of my autoscan, unfortunately they didn't give me the autoscan from when the old module was installed and I just got mine recently.
This must have been discussed elsewhere but since it is my first post.
Greetings from Madagascar
Thursday,19,December,2019,14:22:54:49789
VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4508.4
VIN: WVWZZZ1KZ9W150029 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ9W150029 Mileage: 186690km-116003miles
Address 01: Engine Labels: 03G-906-021-BMM.clb
Part No SW: 03G 906 021 PR HW: 03G 906 021 AB
Component: R4 2,0L EDC G000AG 2116
Revision: --H09--- Serial number: VWXBZ0H0823967
Coding: 0000078
Shop #: WSC 66565 257 00032
VCID: 7EB0EE3E293508BFD5-802A
Part No SW: 02E 300 052 HW: 02E 927 770 AJ
Component: GSG DSG AG6 440 1976
Revision: 04844002 Serial number: 00000810111462
VCID: 51EA6582C82B47C778-8004
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 113B400D092700FA880B02E690220042B100
Shop #: WSC 80093 222 69422
VCID: 75A2F112DC034BE784-8020
01487 - System Function Test
Fault Frequency: 11
Reset counter: 171
Mileage: 186570 km
Count: 3
Count: 14
Count: 12800
Count: 321
Count: 49920
Count: 511
00003 - Control Module
Fault Status: 01100101
Reset counter: 168
Mileage: 186570 km
Count: 3
Count: 14
Count: 12288
Count: 143
Count: 43520
Count: 511
Reset counter: 168
Mileage: 186570 km
Count: 3
Count: 14
Count: 12288
Count: 320
Count: 43520
Count: 511
Part No SW: 1K0 820 047 HM HW: 1K0 820 047 HM
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
VCID: 76A0F61E010540FF8D-8022
Revision: 00H54000 Serial number: 00000009004161
Coding: E5890F2700041500471400001400000000097F075C000100000000000000
VCID: 33260F0A52F715D76A-8066
Component: Wischer 211008 021 0501
Coding: 00038805
Shop #: WSC 01357
Component: RLS 161008 054 0402
Coding: 00209069
Shop #: WSC 01357
Fault Status: 00101100
Reset counter: 210
Mileage: 186659 km
Voltage: 12.40 V
01117 - Generator Terminal DF Load Signal
Reset counter: 210
Mileage: 186611 km
Voltage: 12.80 V
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 3B AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD28ZNXL
Coding: 0013122
VCID: 3D32293264B3D3A78C-8068
Subsystem 1 - Serial number: 6332MSME42526F08D
Subsystem 2 - Serial number: 6342MSME43030219.
Subsystem 3 - Serial number: 6352QSME7C0E4516Q
Subsystem 4 - Serial number: 6362QSME6F0D352CY
Part No SW: 1K0 953 549 BF HW: 1K0 953 549 BF
Component: J0527 757 0101
Coding: 0010042
VCID: 77BEFB1A060F39F796-8022
Part No SW: 1K0 920 864 B HW: 1K0 920 864 B
Component: KOMBIINSTRUMENT VN4 4005
Revision: V0010000 Serial number: VWXBZ0H0823967
Coding: 0003103
Shop #: WSC 24829 001 1048576
VCID: 2B16176A8AC74D1722-807E
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K08A1101C4
Coding: ED807F060002020002
VCID: 352231125C830BE744-8060
Reset counter: 171
Mileage: 180802 km
Time: 16:21:37
01304 - Radio
Reset counter: 232
Mileage: 180802 km
Time: 16:21:42
Component: IMMO VN4 4005
Part No SW: 1K0 959 701 N HW: 1K0 959 701 N
Component: Tuer-SG 006 1219
Coding: 0000182
VCID: 393A3D22709BEF87A0-806C
00109 - Left Mirror Turn Signal Lamp (L131)
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.070 H08 1901
Shop #: WSC 00000 028 00001
Part No SW: 1K0 959 433 CA HW: 1K0 959 433 CA
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 989002005103087F2D0484056008CF03E0FCA0
Shop #: WSC 13204 875 77680
VCID: 71AAC502686B67C758-8024
Part No SW: 1K0 959 702 N HW: 1K0 959 702 N
Coding: 0000438
VCID: 3A38222E759DE49FA9-806E
Address 56: Radio
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 006 1302
Coding: 0000144
Shop #: WSC 01357 011 1012552
VCID: 383C38264B91F68F5F-806C
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Coding: 0000144
End----------(Elapsed Time: 01:05, VBatt start/end: 12.3V/12.3V)-----------
