2012 Audi A3 TDI abs module replacement and coding issues
   #41
Bozwhizzle
C?ID=389205
So I have gotten through a few sections and now I am stuck on one.
Hydronic Unit Intake Valve
I’ve gotten through the first part - (116-123) press the pedal and hold then I get the (46-53) range and it keeps repeating without ever calibrating correct. Or at least just continues....
Engine is running, it about 70degrees in the shop I am working in. Engine bay too hot?
Not sure what’s keeping it from progressing to the next step?
   #42
MartinsX
Riga, Latvia
C?ID=268515
Autoscan from current state?
   #43
Bozwhizzle
C?ID=389205
Here is my latest scan. It looks like I do nbot have the 00003 code and do not need to perform basic settings for hydraulic unit? Just move on to the next?
Thursday,30,January,2020,13:06:14:19969
VIN: WAUKJAFM5CA067047   License Plate:
Mileage: 127440km-79187mi   Repair Order: 1.30.20 c
Chassis Type: FM-AU35 (7N0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 47 4C 52 55 56 62
          72 77
VIN: WAUKJAFM5CA067047   Mileage: 127440km-79187miles
4C-Tire Pressure II -- Status: Cannot be reached 1100
Address 01: Engine (CBE)       Labels: 03L-906-022-CBE.clb
   Part No SW: 03L 997 030 A    HW: 03L 906 019 EJ
   Component: R4 2.0l TDI G000AG  9983
   Revision: 12H14---    Serial number: AUX7Z0K8FNT0IN
   Coding: 0050078
   Shop #: WSC 03377 002 1048576
   VCID: 2C010314DA0FD77745F-8078
               U1017 - 000 -  - Intermittent
                    Fault Frequency: 255
                    Mileage: 113554 km
                    Date: 2019.06.29
                    Time: 15:15:21
                    RPM: 1196 /min
                    Speed: 15.0 km/h
                    Load: 29.0 %
                    Voltage: 13.15 V
                    Torque: 96.0 Nm
                    Hex Value: 0xFF02
                    Bin. Bits: 00101100
009298 - Diesel Particle Filter; Differential Pressure Sensor
               P2452 - 000 - Elect. Malfunction - Intermittent
                    Mileage: 127443 km
                    Mileage: 450 km
                    Pressure: 0 mbar
                    Pressure: 0 mbar
                    (no units): 0.0
                    Temperature: 18.0°C
049441 - No Communication with ABS Brake Control Module
               U0121 - 002 -  - Intermittent
                    Mileage: 127443 km
                    Temperature: 18.0°C
                    Voltage: 9.88 V
                    Bin. Bits: 00000000
                    Torque: 219.0 Nm
                    Temperature: 17.1°C
001674 - ECM Power Relay Load Circuit
               P068A - 000 - Opens Too Early - Intermittent
                    Voltage: 0.00 V
                    Hex Value: 0xFF00
                    Bin. Bits: 00000000
                    Temperature: -90.0°C
008449 - Throttle Valve Actuator Control System
               P2101 - 000 - Malfunction - Intermittent
                    Voltage: 13.98 V
                    Lambda: 99.4 %
                    Bin. Bits: 00000000
   Part No SW: 02E 300 057 A    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 9334
   Revision: 05351113    Serial number: 00001109200366
   Shop #: WSC 06314 000 00000
   VCID: 176BCCF8738944AF18D-8042
   Revision: 00H31001
   VCID: 7BA3F04863E180CF9C5-802E
                    Fault Status: 01100101
                    Reset counter: 89
                    Mileage: 127444 km
                    Date: 2020.01.13
                    Time: 02:56:40
                    Count: 2
                    Count: 12
                    Count: 20480
                    Count: 212
                    Count: 54272
                    Count: 256
                    Reset counter: 89
                    Mileage: 127444 km
                    Date: 2020.01.13
                    Time: 02:56:40
                    Count: 2
                    Count: 12
                    Count: 20480
                    Count: 279
                    Count: 54272
                    Count: 256
                    Reset counter: 89
                    Mileage: 127444 km
                    Date: 2020.01.13
                    Time: 02:56:40
                    Count: 2
                    Count: 12
                    Count: 20480
                    Count: 295
                    Count: 54272
                    Count: 256
                    Reset counter: 89
                    Mileage: 127444 km
                    Date: 2020.01.13
                    Time: 02:56:40
                    Count: 2
                    Count: 12
                    Count: 20480
                    Count: 270
                    Count: 54272
                    Count: 256
   Part No SW: 8P0 820 043 BM    HW: 8P0 820 043 BM
   Component: KlimavollautomatH09 0180
   Revision: 000046      Serial number: 8P0820043BM
   VCID: 78A9EF445ED7ABD7F17-802C
00532 - Supply Voltage B+
                    Fault Status: 00100001
                    Reset counter: 129
                    Mileage: 127444 km
                    Voltage: 17.40 V
01301 - Control Module for Voice Recognition (J507)
                    Reset counter: 129
                    Mileage: 127444 km
                    Date: 2020.01.13
                    Time: 01:11:05
                    Reset counter: 129
                    Mileage: 127444 km
                    Date: 2020.01.13
                    Time: 00:47:20
                    Voltage: 15.50 V
                    Reset counter: 89
                    Mileage: 127444 km
                    Date: 2020.01.13
                    Time: 02:42:54
Address 09: Cent. Elect. (J519)       Labels:. 8P0-907-063.clb
   Part No SW: 8P0 907 063 Q    HW: 8P0 907 063 Q
   Component: BCM PQ35  M   110 0719
   Revision: 00110 AF
   Coding: 6E000A0FA01336E4287241E000100D4D401E62AA104DD128E40008840040
   Shop #: WSC 09550 758 180955
   VCID: 42DD4DAC448B31079F3-8016
   Subsystem 1 - Part No SW: 8P1 955 119 F    HW: 8P1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350  H11 0050
   Coding: 00DD13
01134 - Alarm Horn (H12)
                    Reset counter: 89
                    Mileage: 127444 km
                    Date: 2020.01.13
                    Time: 02:57:54
                    Voltage: 13.35 V
                        Term 50 Off
   Part No SW: 8E0 035 593 P    HW: 8E0 035 593 P
   Component: SDAR SIRIUS     H07 0160
   Revision: 00000000    Serial number: AUZ4Z7L0603354
   Coding: 0000100
   VCID: 3635217C14439DA723B-8062
Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 Q    HW: 8P0 959 655 Q
   Component: Airbag AU1042 H09 0250
   Revision: --------    Serial number: 003FC001JVA5
   Coding: 303142393041303030374A55304C38503053
   ROD: EV_Airba10AURB4.rod
   VCID: 50F977E49A67D397197-8004
   Subsystem 1 - Part No SW: 8P0 959 339 D    HW: 8P0 959 339 D
   Component: BF-Gewichtss.  H03 0040
   Serial number: 5850000R1190600QZV
   Serial number: 3572DRB40000E005315E
   Serial number: 3582DRB40000E0087A4U
   Serial number: 35128RB400006601E0DF
   Serial number: 35228RB40000660A93CM
   Serial number: 35547RB4000066D588B.
   Serial number: 35647RB4000066D5877X
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Coding: 0014142
   VCID: 46D551BC64A30D27B3B-8012
   Component: E0221           H02 0100
Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
   Part No SW: 8P0 920 983 D    HW: 8P0 920 983 D
   Component: KOMBIINSTR. VDO H02 0150
   Revision: D0H02002    Serial number: 2248K002001786
   Coding: 0272288
   Shop #: WSC 12345 067 57207
   VCID: 3B2330482F6140CFDC5-806E
   Revision:   H42       Serial number: 210911F2002401
   Coding: 352102
   VCID: 35372670054596BF2A1-8060
03109 - Tire Pressure Monitoring Control Module 2 (J793)
                    Reset counter: 89
                    Mileage: 127444 km
                    Date: 2020.01.13
                    Time: 02:56:45
   Revision: D0H02002    Serial number: AUX7Z0K8FNT0IN
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
   Part No SW: 8P0 959 801 Q    HW: 8P0 959 801 Q
   Component: Tuer-SG         H04 0101
   Coding: 0001181
   VCID: 49CF5A8075BDE25F5E9-801C
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 233    3201
   Revision: 00H20000
   VCID: 34311B74023F8FB71DF-8060
            000 - - - MIL ON
                    Fault Status: 11100000
                    Mileage: 127444 km
                    Date: 2020.01.13
                    Time: 02:56:38
                    Battery Volts: 13.8 V
                        DD
                    Temperature: 23.0°C
                    Count: 2
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
   Part No SW: 8P4 035 382 E    HW: 8P4 035 382 E
   Component: AB2 SUBWOOFERBOXH07 0180
   Revision: 00006       Serial number: 92158124266503
   Part No SW: 8P0 959 802 Q    HW: 8P0 959 802 Q
   Coding: 0001181
   VCID: 4ACD658C70BBE947573-801E
   Part No: 8P3 907 357 B
   Coding: 0000013
   VCID: 3C2133542A6F47F7D5F-8068
   Part No SW: 8P0 035 186 AC    HW: 8P0 035 186 AC
   Component: R Concert2+     H05 0293
   Revision: 00H05000    Serial number: AUZ1Z3L2599809
   Coding: 0750112
   VCID: 73B3D86847B1C88FC45-8026
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
   Component: Tuer-SG         H04 0050
   Coding: 0001176
   Shop #: WSC 06314 000 1012544
   VCID: 42DD4DAC488B31079F3-8016
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
   Coding: 0001176
   VCID: 43D348A85791380F945-8016
   Part No SW: 8P1 862 336 A    HW: 8P1 862 336
   Component: FSE_256x BT     H44 0660
   Revision: 00000000    Serial number: 00000005158070
   Coding: 0001277
                    Reset counter: 89
                    Mileage: 127444 km
                    Date: 2020.01.13
                    Time: 02:53:31
End----------(Elapsed Time: 01:35, VBatt start/end: 13.8V/15.6V)-----------
Bozwhizzle
C?ID=389205
Just ran a new scan and now 00003 appears?
Friday,31,January,2020,16:37:54:19969
Mileage: 127440km-79187mi   Repair Order: 1.31.20 a
          72 77
   Coding: 0050078
                    Mileage: 113554 km
                    Date: 2019.06.29
                    Time: 15:15:21
                    RPM: 1196 /min
                    Speed: 15.0 km/h
                    Load: 29.0 %
                    Voltage: 13.15 V
                    Torque: 96.0 Nm
                    Hex Value: 0xFF02
                    Bin. Bits: 00101100
                    Mileage: 127443 km
                    Mileage: 450 km
                    Pressure: 0 mbar
                    Pressure: 0 mbar
                    (no units): 0.0
                    Temperature: 18.0°C
                    Mileage: 127443 km
                    Temperature: 18.0°C
                    Voltage: 9.88 V
                    Bin. Bits: 00000000
                    Torque: 219.0 Nm
                    Temperature: 17.1°C
                    Voltage: 0.00 V
                    Hex Value: 0xFF00
                    Bin. Bits: 00000000
                    Voltage: 13.98 V
                    Lambda: 99.4 %
                    Bin. Bits: 00000000
18255 - Please check DTC Memory of ABS Controller
            P1847 - 000 -  - Intermittent
                    Reset counter: 1
                    Mileage: 127444 km
                    Date: 2020.01.14
                    Time: 06:15:51
   Revision: 00H31001
                    Fault Status: 00101100
                    Reset counter: 90
                    Mileage: 127444 km
                    Date: 2020.01.14
                    Time: 06:23:13
                    Count: 3
                    Count: 12
                    Count: 20480
                    Count: 88
                    Count: 45824
                    Count: 65280
00003 - Control Module
                    Reset counter: 90
                    Date: 2020.01.13
                    Time: 08:43:41
                    Count: 7
                    Count: 12
                    Count: 4096
                    Count: 143
                    Count: 46848
                    Reset counter: 90
                    Date: 2020.01.13
                    Time: 08:43:41
                    Count: 7
                    Count: 12
                    Count: 4096
                    Count: 195
                    Count: 46848
                    Reset counter: 90
                    Mileage: 127444 km
                    Date: 2020.01.14
                    Time: 06:15:51
                    Count: 16387
                    Count: 4
                    Count: 12800
                    Count: 64
                    Count: 50688
                    Count: 65280
                    Count: 256
                    Count: 1280
                    Reset counter: 129
                    Mileage: 127444 km
                    Voltage: 17.40 V
                    Reset counter: 129
                    Mileage: 127444 km
                    Date: 2020.01.13
                    Time: 01:11:05
                    Reset counter: 129
                    Mileage: 127444 km
                    Date: 2020.01.13
                    Time: 00:47:20
                    Voltage: 15.50 V
   Revision: 00110 AF
   Coding: 00DD13
   Subsystem 2 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  9005
                    Reset counter: 90
                    Mileage: 127444 km
                    Date: 2020.01.13
                    Time: 08:43:54
                        Term 15 Off
                    Voltage: 12.95 V
                        Term 50 Off
                    Fault Status: 01100010
                    Reset counter: 90
                    Mileage: 127444 km
                    Date: 2020.01.13
                    Time: 08:43:56
                        Term 15 Off
                    Voltage: 12.95 V
                        Term 50 Off
   Coding: 0000100
   Coding: 0014142
   Coding: 0272288
   Coding: 352102
                    Reset counter: 90
                    Mileage: 127444 km
                    Date: 2020.01.13
                    Time: 08:43:46
   Coding: 0001181
   Revision: 00H20000
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 90
                    Mileage: 127444 km
                    Date: 2020.01.14
                    Time: 06:25:28
                    Voltage: 12.50 V
                        DD
                    Temperature: 20.0°C
   Coding: 0001181
   Coding: 0000013
                    Fault Status: 00101101
                    Reset counter: 130
                    Mileage: 127448 km
                    Date: 2020.01.14
                    Time: 06:15:55
   Coding: 0750112
   Coding: 0001176
   Coding: 0001176
   Coding: 0001277
End----------(Elapsed Time: 01:28, VBatt start/end: 12.5V/12.5V)-----------
MartinsX
Riga, Latvia
C?ID=268515
Try to do coding and basic settings at one diagnostic session.
Check wiring to rear left wheel speed sensor. Replace sensor if wiring is ok.
Bozwhizzle
C?ID=389205
May I will try what you suggest. My problem seems to be the engine bay getting too hot and only being able to get part way through the brake test, hydraulic unit valve section.
   #47
Bozwhizzle
C?ID=389205
Any ideas on why it would keep getting stuck on that particular brake pressure test?
   #48
Bozwhizzle
C?ID=389205
SO I have cleared all the dtc's in each individual group, then performed the basic settings needed from coding abs module on up to the basic settings for intake unite valve and keep getting stuck. Anything direction based on the auto scan?
Recent auto scan...
Tuesday,04,February,2020,16:18:44:19969
Mileage: 127440km-79187mi   Repair Order: 2.4.20
          72 77
   Coding: 0050078
   Revision: 00H31001
   Coding: 1150400F49280001880B02E892200042BF0C00
                    Reset counter: 94
                    Mileage: 127444 km
                    Date: 2020.01.18
                    Time: 05:56:20
                    Count: 3
                    Count: 12
                    Count: 4096
                    Count: 143
                    Count: 46336
                    Count: 251
                    Reset counter: 94
                    Mileage: 127444 km
                    Date: 2020.01.18
                    Time: 05:56:20
                    Count: 3
                    Count: 12
                    Count: 4096
                    Count: 16390
                    Count: 46336
                    Count: 251
   Revision: 00110 AF
   Coding: 00DD13
   Component: LIN BACKUP HO  H11 9005
                    Reset counter: 94
                    Mileage: 127444 km
                    Date: 2020.01.18
                    Time: 05:56:33
                    Voltage: 12.75 V
                        Term 50 Off
   Coding: 0000100
   Coding: 0014142
   Coding: 0272288
   Coding: 352102
   Coding: 0001181
   Revision: 00H20000
   Coding: 0001181
   Coding: 0000013
   Coding: 0750112
   Coding: 0001176
   Coding: 0001176
   Coding: 0001277
End----------(Elapsed Time: 01:23, VBatt start/end: 12.8V/12.8V)-----------
   #49
MartinsX
Riga, Latvia
C?ID=268515
What if You run output tests for hydraulic valves? Does those tests store more fault codes in ABS module? Does the pump motor can be heard when switched on via output test?
Bozwhizzle
C?ID=389205
So when I did the brake bleed through vcds the abs pump runs. I have not tried the output test yet. I will try that and see if it stores any other codes.
Thanks for the reply!
   #51
Bozwhizzle
C?ID=389205
Can you guys please take a look at my latest scan. I replaced the rear left abs speed sensor.
Still getting hung up on pressure pedal test(046-053) and will not make any progress. Please let me know what you see or suggest?
Friday,14,February,2020,17:34:31:19969
Mileage: 127440km-79187mi   Repair Order: 2.14.20
          72 77
   Coding: 0050078
   Revision: 00H31001
                    Reset counter: 96
                    Mileage: 127447 km
                    Date: 2020.01.28
                    Time: 07:03:34
                    Count: 3
                    Count: 12
                    Count: 12800
                    Count: 16390
                    Count: 51456
                    Count: 251
                    Reset counter: 96
                    Mileage: 127447 km
                    Date: 2020.01.28
                    Time: 07:03:34
                    Count: 3
                    Count: 12
                    Count: 12800
                    Count: 143
                    Count: 51456
                    Count: 251
   Revision: 00110 AF
   Coding: 00DD13
                    Reset counter: 96
                    Mileage: 127447 km
                    Date: 2020.01.28
                    Time: 06:33:36
                    Voltage: 12.40 V
                        Term 50 Off
                    Reset counter: 136
                    Mileage: 127447 km
                    Date: 2020.01.28
                    Time: 07:24:23
                    Voltage: 12.70 V
                        Term 50 Off
   Coding: 0000100
   Coding: 0014142
   Coding: 0272288
                    Mileage: 127447 km
                    Date: 2020.01.28
                    Time: 06:33:36
   Coding: 352102
   Coding: 0001181
   Revision: 00H20000
   Coding: 0001181
   Coding: 0000013
   Coding: 0750112
   Coding: 0001176
   Coding: 0001176
   Coding: 0001277
End----------(Elapsed Time: 01:24, VBatt start/end: 12.9V/12.6V)-----------
   #52
Bozwhizzle
C?ID=389205
Hi there, so now I have replaced both rear left and rear right abs wheel speed sensors and all four corners are reading measurements properly. I am still getting stuck on the brake test (046-053) and will not proceed to the next test. I noticed I have a TPMS code on the list too. Can someone please take a look at the latest auto scan and let me know if you see anything that would be holding up the abs for completing the adaptation?
Thanks!!!
Recent scan...
Saturday,22,February,2020,17:28:22:19969
Mileage: 127440km-79187mi   Repair Order: 2.22.20 b
          72 77
   Coding: 0050078
               U1017 - 000 -
                    Mileage: 127448 km
                    Date: 2020.02.05
                    Time: 07:15:02
                    RPM: 1104 /min
                    Speed: 15.0 km/h
                    Load: 31.0 %
                    Voltage: 13.91 V
                    Torque: 111.0 Nm
                    Hex Value: 0xFF00
                    Bin. Bits: 00101000
   Revision: 00H31001
                    Reset counter: 97
                    Mileage: 127448 km
                    Date: 2020.02.05
                    Time: 06:32:35
                    Count: 3
                    Count: 12
                    Count: 20480
                    Count: 16390
                    Count: 43008
                    Count: 250
                    Reset counter: 97
                    Mileage: 127448 km
                    Date: 2020.02.05
                    Time: 06:32:35
                    Count: 3
                    Count: 12
                    Count: 20480
                    Count: 143
                    Count: 43008
                    Count: 250
   Revision: 00110 AF
   Coding: 00DD13
                    Reset counter: 137
                    Mileage: 127448 km
                    Date: 2020.02.05
                    Time: 06:32:47
                    Voltage: 11.80 V
                        Term 50 Off
                    Reset counter: 137
                    Mileage: 127448 km
                    Date: 2020.02.05
                    Time: 06:34:26
                    Voltage: 13.80 V
                        Term 50 Off
                    Reset counter: 98
                    Mileage: 127448 km
                    Date: 2020.02.05
                    Time: 06:34:26
                    Voltage: 13.75 V
                        Term 50 Off
   Coding: 0000100
   Coding: 0014142
   Coding: 0272288
                    Mileage: 127448 km
                    Date: 2020.02.05
                    Time: 06:33:01
   Coding: 352102
   Coding: 0001181
   Revision: 00H20000
   Coding: 0001181
   Coding: 0000013
   Coding: 0750112
   Coding: 0001176
   Coding: 0001176
   Coding: 0001277
End----------(Elapsed Time: 01:26, VBatt start/end: 14.0V/13.9V)-----------
   #55
NEtech
C?ID=56995
Are you 100% sure you have connected the brake pipes, the exact place as it is original?
Bozwhizzle
C?ID=389205
I believe so...
The top lines ave two different size threads. They seem to be intuitive where they went back to. I will double check for sure. Thanks!!!
   #57
Bozwhizzle
C?ID=389205
Just want to update.
I had a local shop diagnose my Audi...they scanned and told me the abs module needs replaced. I purchased an new abs module from ecs tuning, great people! However, they sent me the wrong module. They took it back! I purchased a Ross-tech cable and began learning how to do this myself along with the help of you guys on this forum!!!! Then purchased a used abs pump and module and installed.
Come to find out, abs module was never the issue. Both rear abs wheel speed sensors were bad... Then to make things worse, all the abs pump and module removal and installation x3 equaled me getting 2 hardlines flipped into the wrong connections in the abs pump and was keeping it from progressing in the pressure test.
Found a picture of the proper hard line layout then connected properly, re-bled the brakes for the 4th time, including working the abs pump through vcds. Once I had the lines in the proper place it went through the test quickly and now I have no dash lights on and the car runs like it’s supposed to.
Lesson....people at Ross-tech are great folks!
And...mark your hard lines before you remove.
Thanks again guys!
